[GRASS-SVN] r29878 - grass/trunk/display/d.grid
svn_grass at osgeo.org
Mon Jan 28 07:53:01 EST 2008
Author: hamish
Date: 2008-01-28 07:53:01 -0500 (Mon, 28 Jan 2008)
New Revision: 29878
Added:
grass/trunk/display/d.grid/fiducial.c
grass/trunk/display/d.grid/Makefile
grass/trunk/display/d.grid/local_proto.h
grass/trunk/display/d.grid/main.c
first pass at adding support for cross marks instead of grid lines
Modified: grass/trunk/display/d.grid/Makefile
--- grass/trunk/display/d.grid/Makefile 2008-01-28 12:40:32 UTC (rev 29877)
+++ grass/trunk/display/d.grid/Makefile 2008-01-28 12:53:01 UTC (rev 29878)
@@ -2,8 +2,8 @@
PGM = d.grid
-LIBES = $(DISPLAYLIB) $(RASTERLIB) $(GPROJLIB) $(GISLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(GPROJDEP) $(GISDEP)
+LIBES = $(SYMBLIB) $(DISPLAYLIB) $(RASTERLIB) $(GPROJLIB) $(GISLIB)
+DEPENDENCIES= $(SYMBDEP) $(DISPLAYDEP) $(RASTERDEP) $(GPROJDEP) $(GISDEP)
EXTRA_INC = $(PROJINC)
include $(MODULE_TOPDIR)/include/Make/Module.make
Added: grass/trunk/display/d.grid/fiducial.c
--- grass/trunk/display/d.grid/fiducial.c (rev 0)
+++ grass/trunk/display/d.grid/fiducial.c 2008-01-28 12:53:01 UTC (rev 29878)
@@ -0,0 +1,54 @@
+#include <grass/gis.h>
+#include <grass/display.h>
+#include <grass/symbol.h>
+#include <grass/colors.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+void plot_cross(double easting, double northing, int color, double rotation)
+ plot_symbol(easting, northing, color, rotation, "basic/cross1");
+void plot_fiducial(double easting, double northing, int color, double rotation)
+ plot_symbol(easting, northing, color, rotation + 45.0, "extra/fiducial");
+void plot_symbol(double easting, double northing, int color, double rotation, char *symbol_name)
+ SYMBOL *Symb;
+ RGBA_Color *line_color, *fill_color;
+ int R, G, B;
+ int x0, y0;
+ int size = 16;
+ int tolerance = 0;
+ x0 = (int)(D_u_to_d_col(easting)+0.5);
+ y0 = (int)(D_u_to_d_row(northing)+0.5);
+ line_color = G_malloc(sizeof(RGBA_Color));
+ fill_color = G_malloc(sizeof(RGBA_Color));
+ /* TODO: color->RGB values, for now just use DEFAULT_FG_COLOR */
+ G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
+ line_color->r = (unsigned char) R;
+ line_color->g = (unsigned char) G;
+ line_color->b = (unsigned char) B;
+ line_color->a = RGBA_COLOR_OPAQUE;
+ fill_color->a = RGBA_COLOR_NONE;
+ Symb = S_read( symbol_name );
+ if(!Symb) G_fatal_error(_("Reading symbol"));
+ S_stroke( Symb, size, rotation, tolerance );
+ D_symbol( Symb, x0, y0, line_color, fill_color );
+ G_free(line_color);
+ G_free(fill_color);
Modified: grass/trunk/display/d.grid/local_proto.h
--- grass/trunk/display/d.grid/local_proto.h 2008-01-28 12:40:32 UTC (rev 29877)
+++ grass/trunk/display/d.grid/local_proto.h 2008-01-28 12:53:01 UTC (rev 29878)
@@ -1,3 +1,5 @@
+#include <grass/gprojects.h>
/* plot.c */
int plot_grid(double, double, double, int, int, int, int);
int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int);
@@ -8,3 +10,12 @@
/* plotborder.c */
int plot_border(double, double, double);
+#define MARK_GRID 0
+#define MARK_CROSS 1
+#define MARK_FIDUCIAL 2
+/* fiducial.c */
+void plot_cross(double, double, int, double);
+void plot_fiducial(double, double, int, double);
+void plot_symbol(double, double, int, double, char*);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2008-01-28 12:40:32 UTC (rev 29877)
+++ grass/trunk/display/d.grid/main.c 2008-01-28 12:53:01 UTC (rev 29878)
@@ -40,7 +40,7 @@
int do_text, fontsize;
struct GModule *module;
struct Option *opt1, *opt2, *opt3, *opt4, *fsize, *tcolor;
- struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84;
+ struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84, *cross, *fiducial;
struct pj_info info_in; /* Proj structures */
struct pj_info info_out; /* Proj structures */
@@ -101,6 +101,16 @@
wgs84->description =
_("Draw geographic grid (referenced to WGS84 ellipsoid)");
+#ifdef NOTYET
+ cross = G_define_flag();
+ cross->key = 'c';
+ cross->description = _("Draw '+' marks instead of grid lines");
+ fiducial = G_define_flag();
+ fiducial->key = 'f';
+ fiducial->description = _("Draw fiducial marks instead of grid lines");
+#endif
nogrid = G_define_flag();
nogrid->key = 'n';
nogrid->description = _("Disable grid drawing");
@@ -132,6 +142,18 @@
if(notext->answer) do_text = FALSE;
else do_text = TRUE;
+#ifdef NOTYET
+ int mark_type = MARK_GRID;
+ if (cross->answer && fiducial->answer)
+ G_fatal_error(_("Chose a single mark style"));
+ if (cross->answer)
+ mark_type = MARK_CROSS;
+ if (fiducial->answer)
+ mark_type = MARK_FIDUCIAL;
+ /* then pass mark_type to plot_grid() and plot_geogrid() */
+#endif
fontsize = atoi(fsize->answer);
/* get grid size */
