[GRASS-SVN] r29879 - grass/trunk/vector/v.hull
Mon Jan 28 08:40:03 EST 2008
Author: neteler
Date: 2008-01-28 08:40:03 -0500 (Mon, 28 Jan 2008)
New Revision: 29879
   grass/trunk/vector/v.hull/description.html
   grass/trunk/vector/v.hull/main.c
Benjamin Ducke: <benjamin.ducke ufg.uni-kiel.de> 3D hull support added
Modified: grass/trunk/vector/v.hull/description.html
--- grass/trunk/vector/v.hull/description.html	2008-01-28 12:53:01 UTC (rev 29878)
+++ grass/trunk/vector/v.hull/description.html	2008-01-28 13:40:03 UTC (rev 29879)
@@ -6,6 +6,10 @@
 given objects. This module creates a vector polygon containing all vector
 points of the input map.
 <P>
+In the case of 3D input points, the hull will be a 3D hull as well, unless the
+user specifies the <b>-f</b> flag. The 3D hull will be composed of triangular
+faces.
+<P>
 <BR>
 Example of <em>v.hull</em> output:
@@ -18,16 +22,35 @@
 </table>
 </center>
+<H2>EXAMPLE</H2>
+Example of <em>v.hull</em> 3D output (using two random 3D point clouds):
+<div class="code"><pre>
+g.region rural_1m -p
+r.mapcalc zero=0
+v.random -z out=random3d_a n=10 zmin=0 zmax=200
+v.random -z out=random3d_b n=15 zmin=400 zmax=600
+v.hull random3d_a out=random3d_a_hull
+v.hull random3d_b out=random3d_b_hull
+nviz zero vect=random3d_a_hull,random3d_b_hull
+</pre></div>
 <H2>REFERENCES</H2>
 <EM>M. de Berg, M. van Kreveld, M. Overmars, O. Schwarzkopf,  (2000).
  Computational geometry, chapter 1.1, 2-8.</EM>
+<BR>
+<EM>J. O'Rourke, (1998).
+ Computational Geometry in C (Second Edition), chapter 4.</EM>
 <H2>SEE ALSO</H2>
 <EM>
 <A HREF="v.delaunay.html">v.delaunay</A></EM>
 <H2>AUTHOR</H2>
 Andrea Aime, Modena, Italy<br>
-Markus Neteler, ITC-irst (update to 5.7)
+Markus Neteler, ITC-irst (update to 5.7)<br>
+Benjamin Ducke, CAU Kiel (3D hull support)
 <p><i>Last changed: $Date$</i></p>
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2008-01-28 12:53:01 UTC (rev 29878)
+++ grass/trunk/vector/v.hull/main.c	2008-01-28 13:40:03 UTC (rev 29879)
@@ -4,8 +4,8 @@
 * @Copyright Andrea Aime <aaime at libero.it>
 * 23 Sept. 2001
-* Last updated 19 Dec 2003, Markus Neteler to 5.7
+* Updated 19 Dec 2003, Markus Neteler to 5.7
+* Last updated 16 jan 2007, Benjamin Ducke to support 3D hull creation
 * This file is part of GRASS GIS. It is free software. You can
 * redistribute it and/or modify it under the terms of
@@ -19,6 +19,7 @@
 * GNU General Public License for more details.
 #include <stdlib.h>
 #include <stdio.h>
 #include <assert.h>
@@ -26,9 +27,12 @@
 #include <grass/Vect.h>
 #include <grass/glocale.h>
+#include "chull.h"
 struct Point {
    double x;
    double y;
+   double z;
 int rightTurn(struct Point *P, int i, int j, int k) {
@@ -118,6 +122,36 @@
+void convexHull3d(struct Point* P, const int numPoints, struct Map_info *Map ) {
+	int error;
+	int i;
+	double *px;
+	double *py;
+	double *pz;
+	px = G_malloc ( sizeof (double) * numPoints );
+	py = G_malloc ( sizeof (double) * numPoints );
+	pz = G_malloc ( sizeof (double) * numPoints );
+	for ( i=0; i < numPoints; i++ ) {
+		px[i] = (P)[i].x;
+		py[i] = (P)[i].y;
+		pz[i] = (P)[i].z;
+	/* make 3D hull */
+	error = make3DHull ( px, py, pz, numPoints, Map );
+	if ( error < 0 ) {
+		G_fatal_error ("Simple planar hulls not implemented yet");
+	G_free ( px );
+	G_free ( py );
+	G_free ( pz );
 #define ALLOC_CHUNK 256
 int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
 			struct Cell_head *window)
@@ -155,6 +189,7 @@
             (*points)[pointIdx].x = sites->x[0];
             (*points)[pointIdx].y = sites->y[0];
+	    (*points)[pointIdx].z = sites->z[0];
             pointIdx++;
@@ -216,7 +251,7 @@
 int main(int argc, char **argv) {
     struct GModule *module;
     struct Option *input, *output;
-    struct Flag *all;
+    struct Flag *all, *flat;
     struct Cell_head window;
     char *mapset;
@@ -227,6 +262,9 @@
     int *hull;   /* index of points located on the convex hull */
     int numSitePoints, numHullPoints;
+    int MODE2D;
     G_gisinit (argv[0]);
     module = G_define_module();
@@ -243,6 +281,10 @@
     all->key = 'a';
     all->description = _("Use all vector points (do not limit to current region)");
+    flat = G_define_flag ();
+    flat->key = 'f';
+    flat->description = _("Create a 'flat' 2D hull even if the input is 3D points");
     if (G_parser (argc, argv))
 	exit (EXIT_FAILURE);
@@ -257,7 +299,7 @@
     /* open site file */
     if (Vect_open_old(&Map, sitefile, mapset) < 0)
-        G_fatal_error (_("Unable to open vector map <%s>"), sitefile);
+        G_fatal_error (_("Cannot open vector map <%s>"), sitefile);
     /* load site coordinates */
     G_get_window (&window);
@@ -268,18 +310,46 @@
     if(numSitePoints < 3 )
         G_fatal_error (_("Convex hull calculation requires at least three points"));
+    /* create a 2D or a 3D hull? */
+    MODE2D = 1;
+    if ( Vect_is_3d ( &Map ) ) {
+    	MODE2D = 0;
+    if ( flat->answer ) {
+    	MODE2D = 1;
     /* create vector map */
-    if (0 > Vect_open_new (&Map, output->answer, 0) )
-        G_fatal_error (_("Unable to create vector map <%s>"), output->answer);
+    if ( MODE2D ) {
+    	if (0 > Vect_open_new (&Map, output->answer, 0 ) ) {
+        	G_fatal_error (_("Cannot open vector map <%s>"), output->answer);
+    } else {
+    	if (0 > Vect_open_new (&Map, output->answer, 1 ) ) {
     Vect_hist_command ( &Map );
-    /* compute convex hull */
-    numHullPoints = convexHull(points, numSitePoints, &hull);
+    if ( MODE2D ) {
+       /* compute convex hull */
+       numHullPoints = convexHull(points, numSitePoints, &hull);
+       /* output vector map */
+       outputHull(&Map, points, hull, numHullPoints);
-    /* output vector map */
-    outputHull(&Map, points, hull, numHullPoints);
+    } else {
+	/* this does everything for the 3D hull including vector map creation */
+    	convexHull3d (points, numSitePoints, &Map );
     /* clean up and bye bye */
     Vect_build (&Map, stderr);
     Vect_close (&Map);
