[GRASS-SVN] r29880 - grass/trunk/display/d.grid
svn_grass at osgeo.org
Mon Jan 28 08:44:17 EST 2008
Author: hamish
Date: 2008-01-28 08:44:17 -0500 (Mon, 28 Jan 2008)
New Revision: 29880
grass/trunk/display/d.grid/local_proto.h
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.grid/plot.c
second pass at adding support for cross marks instead of grid lines
Modified: grass/trunk/display/d.grid/local_proto.h
--- grass/trunk/display/d.grid/local_proto.h 2008-01-28 13:40:03 UTC (rev 29879)
+++ grass/trunk/display/d.grid/local_proto.h 2008-01-28 13:44:17 UTC (rev 29880)
@@ -1,8 +1,8 @@
#include <grass/gprojects.h>
/* plot.c */
-int plot_grid(double, double, double, int, int, int, int);
-int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int);
+int plot_grid(double, double, double, int, int, int, int, int);
+int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int, int);
void init_proj(struct pj_info *, struct pj_info *, int);
void get_ll_bounds(double *, double *, double *, double *, struct Cell_head, struct pj_info, struct pj_info);
void check_coords(double, double, double *, double *, int, struct Cell_head, struct pj_info, struct pj_info);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2008-01-28 13:40:03 UTC (rev 29879)
+++ grass/trunk/display/d.grid/main.c 2008-01-28 13:44:17 UTC (rev 29880)
@@ -37,7 +37,7 @@
int colort = 0;
double size=0., gsize=0.; /* initialize to zero */
double east, north;
- int do_text, fontsize;
+ int do_text, fontsize, mark_type;
struct GModule *module;
struct Option *opt1, *opt2, *opt3, *opt4, *fsize, *tcolor;
struct Flag *noborder, *notext, *geogrid, *nogrid, *wgs84, *cross, *fiducial;
@@ -101,7 +101,6 @@
wgs84->description =
_("Draw geographic grid (referenced to WGS84 ellipsoid)");
-#ifdef NOTYET
cross = G_define_flag();
cross->key = 'c';
cross->description = _("Draw '+' marks instead of grid lines");
@@ -109,7 +108,6 @@
fiducial = G_define_flag();
fiducial->key = 'f';
fiducial->description = _("Draw fiducial marks instead of grid lines");
-#endif
nogrid = G_define_flag();
nogrid->key = 'n';
@@ -142,8 +140,9 @@
if(notext->answer) do_text = FALSE;
else do_text = TRUE;
-#ifdef NOTYET
- int mark_type = MARK_GRID;
+ fontsize = atoi(fsize->answer);
+ mark_type = MARK_GRID;
if (cross->answer && fiducial->answer)
G_fatal_error(_("Chose a single mark style"));
if (cross->answer)
@@ -151,11 +150,6 @@
if (fiducial->answer)
mark_type = MARK_FIDUCIAL;
- /* then pass mark_type to plot_grid() and plot_geogrid() */
-#endif
- fontsize = atoi(fsize->answer);
/* get grid size */
if (geogrid->answer)
@@ -204,10 +198,10 @@
/* initialzie proj stuff */
init_proj(&info_in, &info_out, wgs84->answer);
- plot_geogrid(gsize, info_in, info_out, do_text, colorg, colort, fontsize);
+ plot_geogrid(gsize, info_in, info_out, do_text, colorg, colort, fontsize, mark_type);
} else {
/* Do the grid plotting */
- plot_grid(size, east, north, do_text, colorg, colort, fontsize);
+ plot_grid(size, east, north, do_text, colorg, colort, fontsize, mark_type);
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c 2008-01-28 13:40:03 UTC (rev 29879)
+++ grass/trunk/display/d.grid/plot.c 2008-01-28 13:44:17 UTC (rev 29880)
@@ -10,9 +10,10 @@
#include "local_proto.h"
-int plot_grid (double grid_size, double east, double north, int do_text, int gcolor, int tcolor, int fontsize)
+int plot_grid (double grid_size, double east, double north, int do_text,
+ int gcolor, int tcolor, int fontsize, int mark_type)
- double x,y;
+ double x,y,y0;
double e1,e2;
struct Cell_head window ;
double row_dist, colm_dist;
@@ -39,9 +40,12 @@
while (x <= window.east)
- D_raster_use_color(gcolor);
- G_plot_line (x, window.north, x, window.south);
+ if(mark_type == MARK_GRID) {
+ D_raster_use_color(gcolor);
+ G_plot_line (x, window.north, x, window.south);
if(do_text) {
D_raster_use_color(tcolor);
G_format_easting(x, text, G_projection());
@@ -79,10 +83,12 @@
while (y <= window.north)
- G_plot_line (window.east, y, e1, y);
- G_plot_line (e1, y, e2, y);
- G_plot_line (e2, y, window.west, y);
+ G_plot_line (window.east, y, e1, y);
+ G_plot_line (e1, y, e2, y);
+ G_plot_line (e2, y, window.west, y);
if(do_text) {
@@ -102,12 +108,38 @@
y += grid_size;
+ /* draw marks not grid lines */
+ if(mark_type != MARK_GRID) {
+ /* reset x and y */
+ if (window.west > east)
+ x = ceil((window.west - east)/grid_size) * grid_size + east ;
+ else
+ x = east - ceil((east - window.west)/grid_size) * grid_size ;
+ if (window.south > north)
+ y0 = ceil((window.south - north)/grid_size) * grid_size + north ;
+ else
+ y0 = north - ceil((north - window.south)/grid_size) * grid_size ;
+ /* plot marks */
+ while (x <= window.east) {
+ y = y0; /* reset */
+ while (y <= window.north) {
+ if(mark_type == MARK_CROSS)
+ plot_cross(x, y, gcolor, 0.0);
+ if(mark_type == MARK_FIDUCIAL)
+ plot_fiducial(x, y, gcolor, 0.0);
+ y += grid_size;
+ x += grid_size;
return 0;
int plot_geogrid(double size, struct pj_info info_in, struct pj_info info_out,
- int do_text, int gcolor, int tcolor, int fontsize)
+ int do_text, int gcolor, int tcolor, int fontsize, int mark_type)
double g;
double e1, e2, n1, n2;
