[GRASS-SVN] r31984 - grass/trunk/gui/wxpython/gui_modules
Thu Jul 3 11:59:35 EDT 2008
Author: martinl
Date: 2008-07-03 11:59:34 -0400 (Thu, 03 Jul 2008)
New Revision: 31984
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: 'Zoom to selected map (ignore NULLs)' and 'Set computational region from selected map (ignore NULLs)' added to popup menu for raster layers, related to trac #157
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-07-03 15:21:55 UTC (rev 31983)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-07-03 15:59:34 UTC (rev 31984)
@@ -157,7 +157,7 @@
     def OnMouseMotion(self, event):
         pass
-    def ZoomToMap(self, event):
+    def OnZoomToMap(self, event):
         pass
     def GetSelectedLayer(self, nviz=False, index=False):
@@ -2138,8 +2138,21 @@
         return removed
+        Set display extents to match selected raster (including NULLs)
+        or vector map.
+        self.ZoomToMap()
+    def OnZoomToRaster(self, event):
+        Set display extents to match selected raster map (ignore NULLs)
+        self.ZoomToMap(zoom=True)
+    def ZoomToMap(self, zoom=False):
         or vector map.
@@ -2155,7 +2168,10 @@
         # selected layer must be a valid map
         if layer.type in ('raster', 'rgb', 'his', 'shaded', 'arrow'):
-            self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
+            if layer.type == 'raster':
+                self.Map.region = self.Map.GetRegion(rast="%s" % layer.name, zoom=zoom)
+            else:
+                self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
         elif layer.type in ('vector', 'thememap', 'themechart'):
             if self.parent.digit and layer.name == self.parent.digit.map and \
                self.parent.digit.type == 'vdigit':
@@ -3651,7 +3667,7 @@
         # Add items to the menu
         zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map'))
         zoommenu.AppendItem(zoommap)
-        self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToMap, zoommap)
+        self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
         zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
         zoommenu.AppendItem(zoomwind)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-03 15:21:55 UTC (rev 31983)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-03 15:59:34 UTC (rev 31984)
@@ -290,7 +290,7 @@
         self.nvizClass.Reset()
         self.init = False
         or vector map or volume.
@@ -302,7 +302,7 @@
         if layer is None:
             return
-        Debug.msg (3, "GLWindow.ZoomToMap(): layer=%s, type=%s" % \
+        Debug.msg (3, "GLWindow.OnZoomToMap(): layer=%s, type=%s" % \
                        (layer.name, layer.type))
         self.nvizClass.SetViewportDefault()
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-07-03 15:21:55 UTC (rev 31983)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-07-03 15:59:34 UTC (rev 31984)
@@ -474,7 +474,7 @@
             self.height = 480
             return False
-    def GetRegion(self, rast=None, vect=None,
+    def GetRegion(self, rast=None, zoom=False, vect=None,
                   n=None, s=None, e=None, w=None, default=False):
         Get region settings (g.region -upgc)
@@ -483,6 +483,7 @@
         @param rast raster name or None
         @param vect vector name or None
+        @param zoom zoom to raster (ignore NULLs)
         @param n,s,e,w force extent
         @param default force default region settings
@@ -516,10 +517,14 @@
             cmdList.append('w=%s' % w)
         if rast:
-            cmdList.append('rast=%s' % rast)
+            if zoom:
+                cmdList.append('zoom=%s' % rast)
+            else:
+                cmdList.append('rast=%s' % rast)
         if vect:
             cmdList.append('vect=%s' % vect)
         try:
             cmdRegion = gcmd.Command(cmdList)
         except gcmd.CmdError, e:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-03 15:21:55 UTC (rev 31983)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-03 15:59:34 UTC (rev 31984)
@@ -215,7 +215,9 @@
             self.popupID9 = wx.NewId()
             self.popupID10 = wx.NewId()
             self.popupID11 = wx.NewId() # nviz
+            self.popupID12 = wx.NewId()
+            self.popupID13 = wx.NewId()
         self.popupMenu = wx.Menu()
         # general item
         self.popupMenu.Append(self.popupID1, text=_("Remove"))
@@ -239,7 +241,7 @@
             self.popupMenu.Append(self.popupID3, text=_("Properties"))
             self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
             self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map"))
-            self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.ZoomToMap, id=self.popupID9)
+            self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
             self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map"))
             self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
@@ -285,6 +287,10 @@
         # raster layers (specific items)
         elif mltype and mltype == "raster":
+            self.popupMenu.Append(self.popupID12, text=_("Zoom to selected map (ignore NULLs)"))
+            self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToRaster, id=self.popupID12)
+            self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map (ignore NULLs)"))
+            self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID13)
             self.popupMenu.AppendSeparator()
             self.popupMenu.Append(self.popupID4, _("Histogram"))
             self.Bind (wx.EVT_MENU, self.OnHistogram, id=self.popupID4)
@@ -316,8 +322,19 @@
         # print output to command log area
         self.gismgr.goutput.RunCmd(cmd)
+    def OnSetCompRegFromRaster(self, event):
+        """Set computational region from selected raster map (ignore NULLs)"""
+        mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+        cmd = ['g.region',
+               '-p',
+               'zoom=%s' % mapLayer.name]
+        # print output to command log area
+        self.gismgr.goutput.RunCmd(cmd)
     def OnSetCompRegFromMap(self, event):
-        """Set computational region from selected map"""
+        """Set computational region from selected raster/vector map"""
         mltype = self.GetPyData(self.layer_selected)[0]['type']
