[GRASS-SVN] r31985 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Jul 3 12:05:41 EDT 2008
Author: martinl
Date: 2008-07-03 12:05:41 -0400 (Thu, 03 Jul 2008)
New Revision: 31985
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: 'Zoom to selected map (ignore NULLs)' and 'Set computational region from selected map (ignore NULLs)' added to popup menu for raster layers, related to trac #157
(merged from trunk, r31984)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-07-03 15:59:34 UTC (rev 31984)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-07-03 16:05:41 UTC (rev 31985)
@@ -2074,8 +2074,21 @@
return removed
- def ZoomToMap(self, event):
+ def OnZoomToMap(self, event):
+ Set display extents to match selected raster (including NULLs)
+ or vector map.
+ self.ZoomToMap()
+ def OnZoomToRaster(self, event):
+ Set display extents to match selected raster map (ignore NULLs)
+ self.ZoomToMap(zoom=True)
+ def ZoomToMap(self, zoom=False):
or vector map.
@@ -2099,7 +2112,10 @@
# selected layer must be a valid map
if layer.type in ('raster', 'rgb', 'his', 'shaded', 'arrow'):
- self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
+ if layer.type == 'raster':
+ self.Map.region = self.Map.GetRegion(rast="%s" % layer.name, zoom=zoom)
+ else:
+ self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
elif layer.type in ('vector', 'thememap', 'themechart'):
if self.parent.digit and layer.name == self.parent.digit.map and \
self.parent.digit.type == 'vdigit':
@@ -3509,7 +3525,7 @@
# Add items to the menu
zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map'))
zoommenu.AppendItem(zoommap)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToMap, zoommap)
+ self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
zoommenu.AppendItem(zoomwind)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-07-03 15:59:34 UTC (rev 31984)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2008-07-03 16:05:41 UTC (rev 31985)
@@ -474,7 +474,7 @@
self.height = 480
return False
- def GetRegion(self, rast=None, vect=None,
+ def GetRegion(self, rast=None, zoom=False, vect=None,
n=None, s=None, e=None, w=None, default=False):
Get region settings (g.region -upgc)
@@ -483,6 +483,7 @@
@param rast raster name or None
@param vect vector name or None
+ @param zoom zoom to raster (ignore NULLs)
@param n,s,e,w force extent
@param default force default region settings
@@ -516,10 +517,14 @@
cmdList.append('w=%s' % w)
if rast:
- cmdList.append('rast=%s' % rast)
+ if zoom:
+ cmdList.append('zoom=%s' % rast)
+ else:
+ cmdList.append('rast=%s' % rast)
if vect:
cmdList.append('vect=%s' % vect)
try:
cmdRegion = gcmd.Command(cmdList)
except gcmd.CmdError, e:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-03 15:59:34 UTC (rev 31984)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-03 16:05:41 UTC (rev 31985)
@@ -214,7 +214,9 @@
self.popupID8 = wx.NewId()
self.popupID9 = wx.NewId()
self.popupID10 = wx.NewId()
+ self.popupID12 = wx.NewId()
+ self.popupID13 = wx.NewId()
self.popupMenu = wx.Menu()
# general item
self.popupMenu.Append(self.popupID1, text=_("Remove"))
@@ -238,7 +240,7 @@
self.popupMenu.Append(self.popupID3, text=_("Properties"))
self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map"))
- self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.ZoomToMap, id=self.popupID9)
+ self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
@@ -281,6 +283,10 @@
# raster
elif mltype and mltype == "raster":
+ self.popupMenu.Append(self.popupID12, text=_("Zoom to selected map (ignore NULLs)"))
+ self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToRaster, id=self.popupID12)
+ self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map (ignore NULLs)"))
+ self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID13)
self.popupMenu.AppendSeparator()
self.popupMenu.Append(self.popupID4, _("Histogram"))
self.Bind (wx.EVT_MENU, self.OnHistogram, id=self.popupID4)
@@ -309,8 +315,19 @@
# print output to command log area
self.gismgr.goutput.RunCmd(cmd)
+ def OnSetCompRegFromRaster(self, event):
+ """Set computational region from selected raster map (ignore NULLs)"""
+ mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
+ cmd = ['g.region',
+ '-p',
+ 'zoom=%s' % mapLayer.name]
+ # print output to command log area
+ self.gismgr.goutput.RunCmd(cmd)
def OnSetCompRegFromMap(self, event):
- """Set computational region from selected map"""
+ """Set computational region from selected raster/vector map"""
mltype = self.GetPyData(self.layer_selected)[0]['type']
