[GRASS-SVN] r32072 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Thu Jul 10 13:53:06 EDT 2008
Author: martinl
Date: 2008-07-10 13:53:06 -0400 (Thu, 10 Jul 2008)
New Revision: 32072
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/wxgui.py
nviz2/wxGUI: workspace file definition (gxw) extended for Nviz properties (in progress)"
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-10 12:20:08 UTC (rev 32071)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-10 17:53:06 UTC (rev 32072)
@@ -1439,52 +1439,6 @@
file = UserSettings.SaveToFile(fileSettings)
self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
-# # surface attributes
-# data['attribute'] = {}
-# for attrb in ('topo', 'color', 'mask',
-# 'transp', 'shine', 'emit'):
-# use = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
-# if self.win['surface'][attrb]['required']: # map, constant
-# if use == 0: # map
-# map = True
-# elif use == 1: # constant
-# map = False
-# else: # unset, map, constant
-# if use == 0: # unset
-# map = None
-# elif use == 1: # map
-# map = True
-# elif use == 2: # constant
-# map = False
-# if map is None:
-# continue
-# if map:
-# value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
-# else:
-# if attrb == 'color':
-# value = self.FindWindowById(self.win['surface'][attrb]['map']).GetColour()
-# else:
-# value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
-# data['attribute'][attrb] = {}
-# data['attribute'][attrb]['map'] = map
-# data['attribute'][attrb]['value'] = value
-# # draw
-# data['draw'] = {}
-# for control in ('mode', 'shading', 'style'):
-# data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetSelection()
-# for control in ('res-coarse', 'res-fine'):
-# data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetValue()
-# self.mapWindow.SetLayerSettings(data)
def UpdateLayerProperties(self):
"""Update data layer properties"""
mapLayer = self.mapWindow.GetSelectedLayer()
@@ -1510,7 +1464,8 @@
if self.mapWindow.update['surface']['attribute'].has_key(attrb):
- map, value = self.mapWindow.update['surface']['attribute'][attrb]
+ map = self.mapWindow.update['surface']['attribute'][attrb]['map']
+ value = self.mapWindow.update['surface']['attribute'][attrb]['value']
if map is None: # unset
# only optional attributes
if attrb == 'mask':
@@ -1586,8 +1541,9 @@
def UpdateVectorProperties(self, id, data):
"""Apply changes for vector"""
if self.mapWindow.update['vector']['lines'].has_key('mode'):
- width, color, flat = self.mapWindow.update['vector']['lines']['mode']
- self.mapWindow.nvizClass.SetVectorLineMode(id, color, width, flat)
+ attrb = self.mapWindow.update['vector']['lines']['mode']
+ self.mapWindow.nvizClass.SetVectorLineMode(id, attrb['color'],
+ attrb['width'], attrb['flat'][0])
if self.mapWindow.update['vector']['lines'].has_key('height'):
height = self.mapWindow.update['vector']['lines']['height']
@@ -1649,7 +1605,9 @@
self.SetSurfaceUseMap(attrb, useMap)
- self.mapWindow.update['surface']['attribute'][attrb] = (useMap, str(value))
+ self.mapWindow.update['surface']['attribute'][attrb] = { 'map' : useMap,
+ 'value' : str(value),
self.UpdateLayerProperties()
if self.parent.autoRender.IsChecked():
@@ -1706,7 +1664,9 @@
map = False
if self.pageUpdated: # do not update when selection is changed
- self.mapWindow.update['surface']['attribute'][attrb] = (map, str(value))
+ self.mapWindow.update['surface']['attribute'][attrb] = { 'map' : map,
@@ -1857,10 +1817,15 @@
if self.FindWindowById(self.win['vector']['lines']['flat']).GetSelection() == 0:
flat = False
+ map = ''
else:
flat = True
+ map = ''
- self.mapWindow.update['vector']['lines']['mode'] = (width, color, flat)
+ self.mapWindow.update['vector']['lines']['mode'] = { 'width' : width,
+ 'color' : color,
+ 'flat' : (flat, map)
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-07-10 12:20:08 UTC (rev 32071)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-07-10 17:53:06 UTC (rev 32072)
@@ -5,6 +5,7 @@
Classes:
- ProcessWorkspaceFile
+ - WriteWorkspaceFile
- ProcessGrcFile
(C) 2007-2008 by the GRASS Development Team
@@ -47,10 +48,19 @@
self.inDisplay = False
self.inLayerManager = False
+ # Nviz section
+ self.inNviz = False
+ self.inAttribute = False
# layer manager properties
self.layerManager = {}
self.layerManager['pos'] = None # window position
self.layerManager['size'] = None # window size
# list of mapdisplays
self.displays = []
# list of map layers
@@ -153,6 +163,15 @@
else:
pass
+ # Nviz section
+ elif name == 'nviz':
+ self.inNviz = True
+ elif name == 'attribute':
+ self.inAttribute = True
def endElement(self, name):
if name == 'gxw':
self.inGxw = False
@@ -201,6 +220,15 @@
elif name == 'layer_manager':
+ # Nviz section
def characters(self, ch):
self.my_characters(ch)
@@ -208,6 +236,217 @@
if self.inValue:
self.value += ch
+class WriteWorkspaceFile(object):
+ """Generic class for writing workspace file"""
+ def __init__(self, lmgr, file):
+ self.file = file
+ self.lmgr = lmgr
+ self.indent = 0
+ # write header
+ self.file.write('<?xml version="1.0" encoding="UTF-8"?>\n')
+ self.file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
+ self.file.write('%s<gxw>\n' % (' ' * self.indent))
+ self.indent =+ 4
+ # layer manager
+ windowPos = self.lmgr.GetPosition()
+ windowSize = self.lmgr.GetSize()
+ file.write('%s<layer_manager dim="%d,%d,%d,%d">\n' % (' ' * self.indent,
+ windowPos[0],
+ windowPos[1],
+ windowSize[0],
+ windowSize[1]
+ file.write('%s</layer_manager>\n' % (' ' * self.indent))
+ # list of displays
+ for page in range(0, self.lmgr.gm_cb.GetPageCount()):
+ mapTree = self.lmgr.gm_cb.GetPage(page).maptree
+ region = mapTree.Map.region
+ displayPos = mapTree.mapdisplay.GetPosition()
+ displaySize = mapTree.mapdisplay.GetSize()
+ file.write('%s<display render="%d" '
+ 'mode="%d" showCompExtent="%d" '
+ 'dim="%d,%d,%d,%d" '
+ 'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
+ int(mapTree.mapdisplay.autoRender.IsChecked()),
+ mapTree.mapdisplay.toggleStatus.GetSelection(),
+ int(mapTree.mapdisplay.showRegion.IsChecked()),
+ displayPos[0],
+ displayPos[1],
+ displaySize[0],
+ displaySize[1],
+ region['w'],
+ region['s'],
+ region['e'],
+ region['n']
+ # list of layers
+ item = mapTree.GetFirstChild(mapTree.root)[0]
+ self.__writeLayer(mapTree, item)
+ file.write('%s</display>\n' % (' ' * self.indent))
+ self.indent =- 4
+ file.write('%s</gxw>\n' % (' ' * self.indent))
+ def __writeLayer(self, mapTree, item):
+ """Write bunch of layers to GRASS Workspace XML file"""
+ self.indent += 4
+ while item and item.IsOk():
+ type = mapTree.GetPyData(item)[0]['type']
+ if type != 'group':
+ maplayer = mapTree.GetPyData(item)[0]['maplayer']
+ else:
+ maplayer = None
+ checked = int(item.IsChecked())
+ cmd = mapTree.GetPyData(item)[0]['cmd']
+ if type == 'command':
+ self.file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
+ (' ' * self.indent, type, ' '.join(cmd), checked));
+ self.file.write('%s</layer>\n' % (' ' * self.indent));
+ elif type == 'group':
+ name = mapTree.GetItemText(item)
+ self.file.write('%s<group name="%s" checked="%d">\n' % \
+ (' ' * self.indent, name, checked));
+ self.indent += 4
+ subItem = mapTree.GetFirstChild(item)[0]
+ self.WriteLayer(subItem)
+ self.indent -= 4
+ self.file.write('%s</group>\n' % (' ' * self.indent));
+ else:
+ opacity = maplayer.GetOpacity(float=True)
+ self.file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
+ (' ' * self.indent, type, name, checked, opacity));
+ self.indent += 4
+ # selected ?
+ if item == mapTree.layer_selected:
+ self.file.write('%s<selected />\n' % (' ' * self.indent))
+ # layer properties
+ self.file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
+ self.indent += 4
+ for option in cmd[1:]:
+ if option[0] == '-': # flag
+ self.file.write('%s<flag name="%s" />\n' %
+ (' ' * self.indent, option[1]))
+ else: # parameter
+ key, value = option.split('=', 1)
+ self.file.write('%s<parameter name="%s">\n' %
+ (' ' * self.indent, key))
+ self.indent += 4
+ self.file.write('%s<value>%s</value>\n' %
+ (' ' * self.indent, value))
+ self.indent -= 4
+ self.file.write('%s</parameter>\n' % (' ' * self.indent));
+ self.indent -= 4
+ self.file.write('%s</task>\n' % (' ' * self.indent));
+ nviz = mapTree.GetPyData(item)[0]['nviz']
+ if nviz:
+ self.file.write('%s<nviz>\n' % (' ' * self.indent));
+ if maplayer.type == 'raster':
+ self.__writeNvizSurface(nviz)
+ elif maplayer.type == 'vector':
+ self.__writeNvizVector(nviz)
+ self.file.write('%s</nviz>\n' % (' ' * self.indent));
+ self.indent -= 4
+ item = mapTree.GetNextSibling(item)
+ self.indent -= 4
+ def __writeNvizSurface(self, data):
+ """Save Nviz raster layer properties to workspace
+ @param data Nviz layer properties
+ self.indent += 4
+ for attrb in data.iterkeys():
+ if len(data[attrb]) < 1: # skip empty attributes
+ continue
+ for name in data[attrb].iterkeys():
+ # surface attribute
+ if attrb == 'attribute':
+ self.file.write('%s<%s name="%s" map="%d">\n' % \
+ (' ' * self.indent, attrb, name, data[attrb][name]['map']))
+ self.indent += 4
+ self.file.write('%s<value>%s</value>\n' % (' ' * self.indent, data[attrb][name]['value']))
+ self.indent -= 4
+ # draw mode
+ if attrb == 'draw':
+ self.file.write('%s<%s' %(' ' * self.indent, attrb))
+ resTag = None
+ for name in data[attrb]:
+ if name == 'resolution':
+ self.indent += 4
+ resTag = ''
+ for type, value in (('coarse', data[attrb][name][0]),
+ ('fine', data[attrb][name][1])):
+ resTag += '%s<resolution type="%s">\n' % (' ' * self.indent, type)
+ self.indent += 4
+ resTag += '%s<value>%s</value>\n' % (' ' * self.indent, value)
+ self.indent -= 4
+ resTag += '%s</resolution>\n' % (' ' * self.indent)
+ self.indent -= 4
+ else:
+ # note: second argument is 'all' -> skip
+ self.file.write(' %s="%s"' % (name, data[attrb][name][0]))
+ self.file.write('>\n') # <draw ...>
+ if resTag:
+ self.file.write(resTag)
+ # position
+ elif attrb == 'position':
+ self.file.write('%s<%s>\n' %(' ' * self.indent, attrb))
+ i = 0
+ for tag in ('x', 'y', 'z'):
+ self.indent += 4
+ self.file.write('%s<%s>%s<%s>\n' % (' ' * self.indent, tag,
+ data[attrb][name][i], tag))
+ i += 1
+ self.indent -= 4
+ # end tag
+ self.file.write('%s<%s>\n' % (' ' * self.indent, attrb))
+ self.indent -= 4
+ def __writeNvizVector(self, data):
+ """Save Nviz vector layer properties to workspace
+ self.indent += 4
+ continue
+ self.indent += 4
+ self.file.write('%s<%s>' % (' ' * self.indent, name))
+ if type(data[attrb][name]) == type({}):
+ self.file.write('\n')
+ self.indent += 4
+ for subname in data[attrb][name].iterkeys():
+ if subname == 'flat':
+ self.file.write('%s<style flat="%d">%s</style>\n' % (' ' * self.indent,
+ data[attrb][name][subname][0],
+ data[attrb][name][subname][1]))
+ else:
+ self.file.write('%s<%s>%s</%s>\n' % (' ' * self.indent, subname,
+ data[attrb][name][subname], subname))
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, name))
+ else:
+ self.file.write('%s</%s>\n' % (data[attrb][name], name))
+ self.indent -= 4
+ self.file.write('%s</%s>\n' % (' ' * self.indent, attrb))
+ self.indent -= 4
class ProcessGrcFile(object):
def __init__(self, filename):
"""Process GRC file"""
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-07-10 12:20:08 UTC (rev 32071)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-07-10 17:53:06 UTC (rev 32072)
@@ -813,94 +813,6 @@
else:
self.OnWorkspaceSaveAs()
- def WriteLayersToWorkspaceFile(self, file, mapTree, item):
- """Write bunch of layers to GRASS Workspace XML file"""
- self.indent += 4
- while item and item.IsOk():
- type = mapTree.GetPyData(item)[0]['type']
- if type != 'group':
- maplayer = mapTree.GetPyData(item)[0]['maplayer']
- else:
- maplayer = None
- checked = int(item.IsChecked())
- cmd = mapTree.GetPyData(item)[0]['cmd']
- if type == 'command':
- file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
- (' ' * self.indent, type, ' '.join(cmd), checked));
- file.write('%s</layer>\n' % (' ' * self.indent));
- elif type == 'group':
- name = mapTree.GetItemText(item)
- file.write('%s<group name="%s" checked="%d">\n' % \
- (' ' * self.indent, name, checked));
- self.indent += 4
- subItem = mapTree.GetFirstChild(item)[0]
- self.WriteLayersToWorkspaceFile(file, mapTree, subItem)
- self.indent -= 4
- file.write('%s</group>\n' % (' ' * self.indent));
- else:
- opacity = maplayer.GetOpacity(float=True)
- file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
- (' ' * self.indent, type, name, checked, opacity));
- self.indent += 4
- # selected ?
- if item == mapTree.layer_selected:
- file.write('%s<selected />\n' % (' ' * self.indent))
- # layer properties
- file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
- self.indent += 4
- for option in cmd[1:]:
- if option[0] == '-': # flag
- file.write('%s<flag name="%s" />\n' %
- (' ' * self.indent, option[1]))
- else: # parameter
- key, value = option.split('=', 1)
- file.write('%s<parameter name="%s">\n' %
- (' ' * self.indent, key))
- self.indent += 4
- file.write('%s<value>%s</value>\n' %
- (' ' * self.indent, value))
- self.indent -= 4
- file.write('%s</parameter>\n' % (' ' * self.indent));
- self.indent -= 4
- file.write('%s</task>\n' % (' ' * self.indent));
- nviz = mapTree.GetPyData(item)[0]['nviz']
- if nviz:
- file.write('%s<nviz>\n' % (' ' * self.indent));
- self.WriteNvizToWorkspace(file, self.indent, nviz, type=maplayer.type)
- file.write('%s</nviz>\n' % (' ' * self.indent));
- self.indent -= 4
- item = mapTree.GetNextSibling(item)
- self.indent -= 4
- def WriteNvizToWorkspace(self, file, indent, data, type):
- """Save Nviz layer properties to workspace
- @param file file stream
- @param indent indentation value
- @param data Nviz layer properties
- @param type map layer type ('raster' or 'vector')
- indent += 4
- if type == 'raster':
- for attrb in data.iterkeys():
- if len(data[attrb]) < 1: # skip empty attributes
- continue
- for name in data[attrb].iterkeys():
- if attrb == 'attribute': # surface attribute
- map, value = data[attrb][name]
- print '%s<%s name="%s" map="%d">\n' % \
- (' ' * indent, attrb, name, map)
- indent += 4
- print '%s<value>%s</value>\n' % (' ' * indent, value)
- indent -= 4
- print '%s<%s>\n' % (' ' * indent, attrb)
- elif type == 'vector':
- pass
def SaveToWorkspaceFile(self, filename):
"""Save layer tree layout to workspace file
@@ -916,59 +828,7 @@
return False
try:
- self.indent = 0 # number of spaces
- # write header
- file.write('<?xml version="1.0" encoding="UTF-8"?>\n')
- file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
- file.write('%s<gxw>\n' % (' ' * self.indent))
- self.indent =+ 4
- # layer manager
- windowPos = self.GetPosition()
- windowSize = self.GetSize()
- file.write('%s<layer_manager dim="%d,%d,%d,%d">\n' % (' ' * self.indent,
- windowPos[0],
- windowPos[1],
- windowSize[0],
- windowSize[1]
- file.write('%s</layer_manager>\n' % (' ' * self.indent))
- # list of displays
- for page in range(0, self.gm_cb.GetPageCount()):
- mapTree = self.gm_cb.GetPage(page).maptree
- region = mapTree.Map.region
- displayPos = mapTree.mapdisplay.GetPosition()
- displaySize = mapTree.mapdisplay.GetSize()
- file.write('%s<display render="%d" '
- 'mode="%d" showCompExtent="%d" '
- 'dim="%d,%d,%d,%d" '
- 'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
- int(mapTree.mapdisplay.autoRender.IsChecked()),
- mapTree.mapdisplay.toggleStatus.GetSelection(),
- int(mapTree.mapdisplay.showRegion.IsChecked()),
- displayPos[0],
- displayPos[1],
- displaySize[0],
- displaySize[1],
- region['w'],
- region['s'],
- region['e'],
- region['n']
- # list of layers
- item = mapTree.GetFirstChild(mapTree.root)[0]
- self.WriteLayersToWorkspaceFile(file, mapTree, item)
- file.write('%s</display>\n' % (' ' * self.indent))
- self.indent =- 4
- file.write('%s</gxw>\n' % (' ' * self.indent))
- del self.indent
+ workspace.WriteWorkspaceFile(lmgr=self, file=file)
except StandardError, e:
file.close()
wx.MessageBox(parent=self,
