[GRASS-SVN] r32073 - in
grass/branches/develbranch_6/raster/r.terraflow: .
IOStream/include IOStream/lib/src
svn_grass at osgeo.org
Thu Jul 10 16:41:25 EDT 2008
Author: neteler
Date: 2008-07-10 16:41:25 -0400 (Thu, 10 Jul 2008)
New Revision: 32073
grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/ami_stream.h
grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mem_stream.h
grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mm_utils.h
grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/ami_stream.cc
grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/mm_utils.cc
grass/branches/develbranch_6/raster/r.terraflow/direction.cc
grass/branches/develbranch_6/raster/r.terraflow/direction.h
grass/branches/develbranch_6/raster/r.terraflow/fill.cc
grass/branches/develbranch_6/raster/r.terraflow/main.cc
Single flow direction (SFD) patch from Andrew Danner (r32067, merge from trunk)
Modified: grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/ami_stream.h
--- grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/ami_stream.h 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/ami_stream.h 2008-07-10 20:41:25 UTC (rev 32073)
@@ -178,7 +178,7 @@
/* creates a random file name, opens the file for reading and writing
and and returns a file descriptor */
-int ami_single_temp_name(char *base, char* tmp_path);
+int ami_single_temp_name(const std::string& base, char* tmp_path);
Modified: grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mem_stream.h
--- grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mem_stream.h 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mem_stream.h 2008-07-10 20:41:25 UTC (rev 32073)
@@ -84,7 +84,7 @@
template<class T>
AMI_err MEM_STREAM<T>::name(char **stream_name) {
- char *path = "dummy";
+ char const* path = "dummy";
*stream_name = new char [strlen(path) + 1];
strcpy(*stream_name, path);
Modified: grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mm_utils.h
--- grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mm_utils.h 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/IOStream/include/mm_utils.h 2008-07-10 20:41:25 UTC (rev 32073)
@@ -22,12 +22,12 @@
#include "mm.h"
+#include <string>
void LOG_avail_memo();
size_t getAvailableMemory();
-void MEMORY_LOG(char* str);
+void MEMORY_LOG(std::string str);
#endif
Modified: grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/ami_stream.cc
--- grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/ami_stream.cc 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/ami_stream.cc 2008-07-10 20:41:25 UTC (rev 32073)
@@ -32,7 +32,7 @@
int
-ami_single_temp_name(char *base, char* tmp_path) {
+ami_single_temp_name(const std::string& base, char* tmp_path) {
char *base_dir;
int fd;
@@ -41,7 +41,7 @@
base_dir = getenv(STREAM_TMPDIR);
assert(base_dir);
- sprintf(tmp_path, "%s/%s_XXXXXX", base_dir, base);
+ sprintf(tmp_path, "%s/%s_XXXXXX", base_dir, base.c_str());
#ifdef __MINGW32__
fd = mktemp(tmp_path) ? open(tmp_path, O_CREAT|O_EXCL|O_RDWR, 0600) : -1;
#else
Modified: grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/mm_utils.cc
--- grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/mm_utils.cc 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/IOStream/lib/src/mm_utils.cc 2008-07-10 20:41:25 UTC (rev 32073)
@@ -46,8 +46,7 @@
return fmem;
-void
-MEMORY_LOG(char* str) {
- printf("%s", str);
+void MEMORY_LOG(std::string str) {
+ printf("%s", str.c_str());
fflush(stdout);
Modified: grass/branches/develbranch_6/raster/r.terraflow/direction.cc
--- grass/branches/develbranch_6/raster/r.terraflow/direction.cc 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/direction.cc 2008-07-10 20:41:25 UTC (rev 32073)
@@ -19,9 +19,10 @@
#include "direction.h"
#include "nodata.h"
+#include "common.h" /*for global opt->d8 flag*/
-/* returns the direction corresponding to the window */
+#define TF_ROOTTWO 1.4142135623
/* directions:
32 64 128
16 * 1
@@ -33,6 +34,21 @@
dimension_type row,
dimension_type col) {
+ /*check global opt flag and call appropriate model*/
+ if(opt->d8){
+ return encodeDirectionSFD(elevwin, nrows, ncols, row, col);
+ return encodeDirectionMFD(elevwin, nrows, ncols, row, col);
+/* returns the direction corresponding to the window using MFD */
+direction_type
+encodeDirectionMFD(const genericWindow<elevation_type>& elevwin,
+ const dimension_type nrows, const dimension_type ncols,
+ dimension_type row,
+ dimension_type col) {
direction_type dir = DIRECTION_UNDEF;
if(!is_nodata(elevwin.get())) {
@@ -67,7 +83,71 @@
return dir;
+/* returns the direction corresponding to the window using SFD */
+direction_type
+encodeDirectionSFD(const genericWindow<elevation_type>& elevwin,
+ direction_type dir = DIRECTION_UNDEF;
+ float tdrop, max_drop;
+ int max_indx;
+ if(!is_nodata(elevwin.get())) {
+ dir = 0;
+ max_drop = 0;
+ max_indx = -1;
+ for(int i=0; i<9; i++){
+ if(i%2==1){ /*cardinal direction*/
+ tdrop=elevwin.get()-elevwin.get(i);
+ if(tdrop>max_drop){ max_drop=tdrop; max_indx=i; }
+ else if(i!=4){ /*diagonal*/
+ tdrop=(elevwin.get()-elevwin.get(i))/TF_ROOTTWO;
+ switch(max_indx){
+ case 0:
+ case 1:
+ case 2:
+ dir=32<<max_indx; break;
+ case 3:
+ dir=16; break;
+ case 5:
+ dir=1; break;
+ case 6:
+ case 7:
+ case 8:
+ dir=8>>(max_indx-6); break;
+ default:
+ dir=0; break;
+ /* if no direction, check for boundary */
+ if(dir==0 || dir==DIRECTION_UNDEF) {
+ if(row==0) {
+ dir = 64;
+ if(row==nrows-1) {
+ dir = 48;
+ if(col==0) {
+ if(row==0) dir = 32;
+ else if(row==nrows-1) dir = 8;
+ else dir = 16;
+ if(col==ncols-1) {
+ if(row==0) dir = 128;
+ else if(row==nrows-1) dir = 2;
+ else dir = 1;
+ return dir;
direction_type
findDominant(direction_type dir) {
@@ -143,8 +223,25 @@
return 128;
- return dir;
+ /* Otherwise, there is no dominant direction.
+ * SFD must output a single direction 1,2,4,8,16,32,64, or 128
+ * pick the first matching one, with preference to cardinal direction
+ if(dir & 85 ){
+ /* at least one cardinal direction (1+4+16+64=E+S+W+N) matches */
+ if(dir & 1){ return 1;}
+ if(dir & 4){ return 4;}
+ if(dir & 16){ return 16;}
+ if(dir & 64){ return 64;}
+ else{
+ /* 2 8 32 128 = SE SW NW NE*/
+ if(dir & 2){ return 2;}
+ if(dir & 8){ return 8;}
+ if(dir & 32){ return 32;}
+ if(dir & 128){ return 128;}
+ return dir; /* shouldn't get here unless dir <= 0 */
@@ -152,7 +249,7 @@
directionSymbol(direction_type dir) {
char c='?';
int cnt=0;
- char *symbols = ">\\v/<\\^/";
+ char symbols[] = ">\\v/<\\^/";
if(dir == 0) return '.';
@@ -201,3 +298,4 @@
+#undef TF_ROOTTWO
Modified: grass/branches/develbranch_6/raster/r.terraflow/direction.h
--- grass/branches/develbranch_6/raster/r.terraflow/direction.h 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/direction.h 2008-07-10 20:41:25 UTC (rev 32073)
@@ -141,6 +141,16 @@
dimension_type row, dimension_type col);
+direction_type encodeDirectionMFD(const genericWindow<elevation_type>& elevwin,
+ const dimension_type ncols,
+ dimension_type row, dimension_type col);
+direction_type encodeDirectionSFD(const genericWindow<elevation_type>& elevwin,
direction_type findDominant(direction_type dir);
char directionSymbol(direction_type dir);
Modified: grass/branches/develbranch_6/raster/r.terraflow/fill.cc
--- grass/branches/develbranch_6/raster/r.terraflow/fill.cc 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/fill.cc 2008-07-10 20:41:25 UTC (rev 32073)
@@ -20,8 +20,8 @@
#include <ctype.h>
#include <time.h>
+#include <string>
#include "fill.h"
-#include "option.h"
#include "common.h"
#include "water.h"
#include "sortutils.h"
@@ -138,9 +138,9 @@
char *
-verbosedir(char *s) {
+verbosedir(std::string s) {
static char buf[BUFSIZ];
- sprintf(buf, "dump/%s", s);
+ sprintf(buf, "dump/%s", s.c_str());
return buf;
Modified: grass/branches/develbranch_6/raster/r.terraflow/main.cc
--- grass/branches/develbranch_6/raster/r.terraflow/main.cc 2008-07-10 17:53:06 UTC (rev 32072)
+++ grass/branches/develbranch_6/raster/r.terraflow/main.cc 2008-07-10 20:41:25 UTC (rev 32073)
@@ -111,7 +111,7 @@
d8cut->key = "d8cut";
d8cut->type = TYPE_DOUBLE;
d8cut->required = NO;
- d8cut->answer = "infinity"; /* default value */
+ d8cut->answer = G_store("infinity"); /* default value */
d8cut->description =
_("If flow accumulation is larger than this value it is routed using "
"SFD (D8) direction \n \t\t (meaningfull only for MFD flow)");
@@ -122,7 +122,7 @@
mem->key = "memory";
mem->type = TYPE_INTEGER;
mem->required = NO;
- mem->answer = "300"; /* 300MB default value */
+ mem->answer = G_store("300"); /* 300MB default value */
mem->description = _("Maximum runtime memory size (in MB)");
/* temporary STREAM path */
@@ -131,7 +131,7 @@
streamdir->key = "STREAM_DIR";
streamdir->type = TYPE_STRING;
streamdir->required = NO;
- streamdir->answer = "/var/tmp";
+ streamdir->answer = G_store("/var/tmp");
streamdir->description=
_("Directory to hold temporary files (they can be large)");
@@ -150,7 +150,7 @@
stats_opt->type = TYPE_STRING;
stats_opt->required = NO;
stats_opt->description= _("Name of file containing runtime statistics");
- stats_opt->answer = "stats.out";
+ stats_opt->answer = G_store("stats.out");
if (G_parser(argc, argv)) {
