[GRASS-SVN] r32074 - in grass/trunk/gui/wxpython: . gui_modules
Fri Jul 11 06:35:00 EDT 2008
Author: martinl
Date: 2008-07-11 06:34:59 -0400 (Fri, 11 Jul 2008)
New Revision: 32074
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
   grass/trunk/gui/wxpython/wxgui.py
nviz2/wxGUI: reading nviz layer properties from workspace file (initial, surface/attribute)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-10 20:41:25 UTC (rev 32073)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-11 10:34:59 UTC (rev 32074)
@@ -1,5 +1,4 @@
- at package nviz.py
+"""@package nviz.py
 @brief 2.5/3D visialization mode for Map Display Window
@@ -1726,7 +1725,7 @@
         if self.pageUpdated:
             # reset updates
             self.mapWindow.update['surface']['draw'] = {}
-            self.mapWindow.update['surface']['draw']['style'] = (value, all)
+            self.mapWindow.update['surface']['draw']['mode'] = (value, all)
             self.UpdateLayerProperties()
     def OnSurfaceMode(self, event):
@@ -1863,48 +1862,58 @@
             self.notebook.GetPage(self.page['surface']).Enable(True)
             self.notebook.GetPage(self.page['vector']).Enable(False)
-            # use default values
-            if data == {} or data == None:
-                # attributes
-                for attr in ('topo', 'color'): # required
-                    if layer and layer.type == 'raster':
-                        self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
-                    else:
-                        self.FindWindowById(self.win['surface'][attr]['map']).SetValue('')
-                    self.SetSurfaceUseMap(attr, True) # -> map
-                if UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map']) is False:
-                    self.SetSurfaceUseMap('shine', False)
-                    value = UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
-                    self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
+            # set default values
+            # attributes
+            for attr in ('topo', 'color'): # required
+                if layer and layer.type == 'raster':
+                    self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+                else:
+                    self.FindWindowById(self.win['surface'][attr]['map']).SetValue('')
+                self.SetSurfaceUseMap(attr, True) # -> map
+            if UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map']) is False:
+                self.SetSurfaceUseMap('shine', False)
+                value = UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
+                self.FindWindowById(self.win['surface']['shine']['const']).SetValue(value)
-                # draw
-                for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
-                    win = self.FindWindowById(self.win['surface']['draw'][control])
-                    name = win.GetName()
-                    if name == "selection":
-                        win.SetSelection(value)
-                    elif name == "colour":
-                        win.SetColour(value)
-                    else:
-                        win.SetValue(value)
-                # enable/disable res widget + set draw mode
-                self.SetSurfaceMode()
-                color = self.FindWindowById(self.win['surface']['draw']['color'])
-                self.SetSurfaceWireColor(color.GetColour())
-            elif layer.type == 'raster':
+            # draw
+            for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
+                win = self.FindWindowById(self.win['surface']['draw'][control])
+                name = win.GetName()
+                if name == "selection":
+                    win.SetSelection(value)
+                elif name == "colour":
+                    win.SetColour(value)
+                else:
+                    win.SetValue(value)
+            # enable/disable res widget + set draw mode
+            self.SetSurfaceMode()
+            color = self.FindWindowById(self.win['surface']['draw']['color'])
+            self.SetSurfaceWireColor(color.GetColour())
+            if layer.type == 'raster':
+                surfProp = data['surface']
                 # surface attributes
-                for attr in data['attr']:
-                    if attr['map']:
+                for attr in surfProp['attribute'].iterkeys():
+                    print attr
+                    if surfProp['attribute'][attr]['map']:
                         win = self.FindWindowById(self.win['surface'][attr]['map'])
                     else:
                         win = self.FindWindowById(self.win['surface'][attr]['const'])
-                    win.SetValue(data['value'])
+                    if attr == 'color':
+                        color = tuple(map(int, surfProp['attribute'][attr]['value'].split(':')))
+                        # TODO: save as tuple
+                        win.SetColour(color)
+                    else:
+                        win.SetValue(surfProp['attribute'][attr]['value'])
         elif pageId == 'vector':
             # disable surface and enable current
             self.notebook.GetPage(self.page['surface']).Enable(False)
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-07-10 20:41:25 UTC (rev 32073)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-07-11 10:34:59 UTC (rev 32074)
@@ -53,6 +53,7 @@
         self.inNviz = False
         self.inAttribute = False
+        self.refAttribute = None
         # layer manager properties
@@ -125,7 +126,8 @@
             self.layerName     = attrs.get('name', None)
             self.layerChecked  = attrs.get('checked', None)
             self.layerOpacity  = attrs.get('opacity', None)
-            self.layerSelected = False;
+            self.layerSelected = False
+            self.layerNviz     = None
             self.cmd = []
         elif name == 'task':
@@ -168,10 +170,28 @@
         elif name == 'nviz':
             self.inNviz = True
+            # init nviz layer properties
+            self.layerNviz = {}
+            self.layerNviz['view'] = None
+            self.layerNviz['surface'] = {}
+            for sec in ('attribute', 'draw', 'mask', 'position'):
+                self.layerNviz['surface'][sec] = {}
+            self.layerNviz['vector'] = {}
+            for sec in ('lines', ):
+                self.layerNviz['vector'][sec] = {}
         elif name == 'attribute':
             self.inAttribute = True
+            tagName = str(name)
+            attrbName = str(attrs.get('name', ''))
+            self.layerNviz['surface'][tagName][attrbName] = {}
+            if attrs.get('map', '0'):
+                self.layerNviz['surface'][tagName][attrbName]['map'] = False
+            else:
+                self.layerNviz['surface'][tagName][attrbName]['map'] = True
+            self.refAttribute = self.layerNviz['surface'][tagName][attrbName]
     def endElement(self, name):
         if name == 'gxw':
             self.inGxw = False
@@ -193,7 +213,8 @@
                     "cmd"      : None,
                     "group"    : self.inGroup,
                     "display"  : self.displayIndex,
-                    "selected" : self.layerSelected})
+                    "selected" : self.layerSelected,
+                    "nviz"     : self.layerNviz})
             if self.layerOpacity:
                 self.layers[-1]["opacity"] = float(self.layerOpacity)
@@ -225,9 +246,10 @@
             self.inNviz = False
+            self.refAttribute['value'] = str(self.value)
     def characters(self, ch):
         self.my_characters(ch)
@@ -411,7 +433,7 @@
                     i += 1
                     self.indent -= 4
             # end tag
-            self.file.write('%s<%s>\n' % (' ' * self.indent, attrb))
+            self.file.write('%s</%s>\n' % (' ' * self.indent, attrb))
         self.indent -= 4
     def __writeNvizVector(self, data):
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-10 20:41:25 UTC (rev 32073)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-11 10:34:59 UTC (rev 32074)
@@ -485,11 +485,17 @@
         self.EditLabel(self.layer_selected)
     def AddLayer(self, ltype, lname=None, lchecked=None,
-                 lopacity=None, lcmd=None, lgroup=None):
+                 lopacity=None, lcmd=None, lgroup=None, lnviz=None):
         """Add new item to the layer tree, create corresponding MapLayer instance.
         Launch property dialog if needed (raster, vector, etc.)
-        Note: lcmd is given as a list
+        @param ltyle layer type (raster, vector, ...)
+        @param lname layer name
+        @param lchecked if True layer is checked
+        @param lopacity layer opacity level
+        @param lcmd command (given as a list)
+        @param lgroup group name or None
+        @param lnviz layer Nviz properties
         self.first = True
@@ -636,7 +642,7 @@
                                     'type' : ltype,
                                     'ctrl' : ctrlId,
                                     'maplayer' : None,
-                                    'nviz' : None,
+                                    'nviz' : lnviz,
                                     'prowin' : None},
                                    None))
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-07-10 20:41:25 UTC (rev 32073)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-07-11 10:34:59 UTC (rev 32074)
@@ -667,7 +667,8 @@
                                            lchecked=layer['checked'],
                                            lopacity=layer['opacity'],
                                            lcmd=layer['cmd'],
-                                           lgroup=layer['group'])
+                                           lgroup=layer['group'],
+                                           lnviz=layer['nviz'])
                 # tag 'selected' added 2008/04
                 if layer.has_key('selected'):
