[GRASS-SVN] r32118 - in grass/trunk: include lib/nviz visualization/nviz2/cmd
Tue Jul 15 03:57:08 EDT 2008
Author: glynn
Date: 2008-07-15 03:57:07 -0400 (Tue, 15 Jul 2008)
New Revision: 32118
   grass/trunk/include/nviz.h
   grass/trunk/lib/nviz/Makefile
   grass/trunk/lib/nviz/render.c
   grass/trunk/visualization/nviz2/cmd/write_img.c
Clean-up, portability fixes
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2008-07-15 05:53:52 UTC (rev 32117)
+++ grass/trunk/include/nviz.h	2008-07-15 07:57:07 UTC (rev 32118)
@@ -117,12 +117,14 @@
     GLXPixmap windowId;
     Pixmap pixmap;
 #elif defined(OPENGL_AQUA)
-    AGLPixelFmtID displayId;
+    AGLPixelFmtID pixelFmtId;
     AGLContext contextId;
     AGLPixmap windowId;
     GWorldPtr pixmap;
 #elif defined(OPENGL_WINDOWS)
-    /* TODO */
+    HDC displayId;   /* display context */
+    HGLRC contextId; /* rendering context */
+    HBITMAP bitmapId;
 #endif
Modified: grass/trunk/lib/nviz/Makefile
--- grass/trunk/lib/nviz/Makefile	2008-07-15 05:53:52 UTC (rev 32117)
+++ grass/trunk/lib/nviz/Makefile	2008-07-15 07:57:07 UTC (rev 32118)
@@ -7,6 +7,10 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+ifeq ($(OPENGL_WINDOWS),1)
+EXTRA_LIBS += -lgdi32
+endif
 EXTRA_INC = $(VECT_INC) $(OPENGLINC) $(TIFFINCPATH) $(FFMPEGINCPATH)
 EXTRA_CFLAGS = $(VECT_CFLAGS) $(XCFLAGS)
Modified: grass/trunk/lib/nviz/render.c
--- grass/trunk/lib/nviz/render.c	2008-07-15 05:53:52 UTC (rev 32117)
+++ grass/trunk/lib/nviz/render.c	2008-07-15 07:57:07 UTC (rev 32118)
@@ -25,7 +25,7 @@
   \return pointer to render_window struct
   \return NULL on failure
-struct render_window *Nviz_new_render_window()
+struct render_window *Nviz_new_render_window(void)
   struct render_window *rwin;
@@ -42,12 +42,20 @@
 void Nviz_init_render_window(struct render_window *rwin)
+#if defined(OPENGL_X11)
     rwin->displayId = NULL;
     rwin->contextId = NULL;
     rwin->pixmap = 0;
     rwin->windowId = 0;
-    return;
+#elif defined(OPENGL_AQUA)
+    rwin->pixelFmtId = NULL;
+    rwin->contextId = NULL;
+    rwin->pixmap = 0;
+    rwin->windowId = 0;
+#elif defined(OPENGL_WINDOWS)
+    rwin->displayId = NULL;
+#endif
@@ -66,12 +74,12 @@
     aglDestroyAGLPixmap(rwin->windowId);
     /* TODO FreePixMap */
-    /* TODO: wglDeleteContext( HRC hrc ) */
+    wglDeleteContext(rwin->contextId);
+    DeleteDC(rwin->displayId);
+    DeleteObject(rwin->bitmapId);
 #endif
     G_free ((void *) rwin);
-    return;
@@ -88,53 +96,27 @@
 			      int width, int height)
-    XVisualInfo  *v;
-#elif defined(OPENGL_AQUA)
-    AGLPixelFmtID v;
-#elif defined(OPENGL_WINDOWS)
-    int v;
-#endif
     int attributeList[] = { GLX_RGBA, GLX_RED_SIZE, 1,
 			    GLX_GREEN_SIZE, 1, GLX_BLUE_SIZE, 1,
 			    GLX_DEPTH_SIZE, 1, None };
+    XVisualInfo  *v;
-    /* get the default display connection */
-#if defined(OPENGL_X11)
     rwin->displayId = XOpenDisplay((char *) display);
-    /* TODO: open mac display */
-    /* TODO */
-#endif
     if (!rwin->displayId) {
 	G_fatal_error (_("Bad server connection"));
-    /* get visual info and set up pixmap buffer */
     v = glXChooseVisual(rwin->displayId,
 			DefaultScreen(rwin->displayId),
 			attributeList);
     rwin->contextId = glXCreateContext(rwin->displayId,
 				       v, NULL, GL_FALSE);
-    /* TODO: dev = NULL, ndev = 0 ? */
-    rwin->displayId = aglChoosePixelFmt(NULL, 0, attributeList);
-    rwin->contextId = aglCreateContext(rwin->displayId, NULL);
-    /* TODO int ChoosePixelFormat( HDC hdc, PIXELFORMATDESCRIPTOR *pfd ) */
-#endif
     if (!rwin->contextId) {
 	G_fatal_error (_("Unable to create rendering context"));
     /* create win pixmap to render to (same depth as RootWindow) */
     rwin->pixmap = XCreatePixmap(rwin->displayId,
 				RootWindow(rwin->displayId, v->screen),
@@ -145,20 +127,57 @@
     /* create an off-screen GLX rendering area */
     rwin->windowId = glXCreateGLXPixmap(rwin->displayId,
 					v, rwin->pixmap);
+    if (v) {
+	XFree(v);
+    int attributeList[] = { AGL_RGBA, AGL_RED_SIZE, 1,
+			    AGL_GREEN_SIZE, 1, AGL_BLUE_SIZE, 1,
+			    AGL_DEPTH_SIZE, 1, AGL_NONE };
+    /* TODO: open mac display */
+    /* TODO: dev = NULL, ndev = 0 ? */
+    rwin->pixelFmtId = aglChoosePixelFmt(NULL, 0, attributeList);
+    rwin->contextId = aglCreateContext(rwin->pixelFmtId, NULL);
     rwin->pixmap = NULL; /* TODO: create GWorldPtr */
     /* create an off-screen AGL rendering area */
-    rwin->windowId = aglCreateAGLPixmap(rwin->displayId,
+    rwin->windowId = aglCreateAGLPixmap(rwin->pixelFmtId,
 					rwin->pixmap);
+    PIXELFORMATDESCRIPTOR pfd = {
+	    sizeof(PIXELFORMATDESCRIPTOR),  //  size of this pfd
+	    1,                     /* version number           */
+	    PFD_DRAW_TO_WINDOW |   /* support window 	       */
+	    PFD_SUPPORT_OPENGL |   /* support OpenGL 	       */
+	    PFD_DOUBLEBUFFER,      /* double buffered 	       */
+	    PFD_TYPE_RGBA,         /* RGBA type 	       */
+	    24,                    /* 24-bit color depth       */
+	    0, 0, 0, 0, 0, 0,      /* color bits ignored       */
+	    0,                     /* no alpha buffer 	       */
+	    0,                     /* shift bit ignored        */
+	    0,                     /* no accumulation buffer   */
+	    0, 0, 0, 0,            /* accum bits ignored       */
+	    32,                    /* 32-bit z-buffer          */
+	    0,                     /* no stencil buffer        */
+	    0,                     /* no auxiliary buffer      */
+	    PFD_MAIN_PLANE,        /* main layer 	       */
+	    0,                     /* reserved 		       */
+	    0, 0, 0                /* layer masks ignored      */
+    int iPixelFormat;
+    rwin->displayId = CreateCompatibleDC(NULL);
+    iPixelFormat = ChoosePixelFormat(rwin->displayId, &pfd);
+    SetPixelFormat(rwin->displayId, iPixelFormat, &pfd);
+    rwin->bitmapId = CreateCompatibleBitmap(rwin->displayId, width, height);
+    SelectObject(rwin->displayId, rwin->bitmapId);
+    rwin->contextId = wglCreateContext(rwin->displayId);
     /* TODO */
 #endif
-    if (v) {
-	XFree(v);
     return 1;
@@ -172,10 +191,10 @@
 int Nviz_make_current_render_window(const struct render_window *rwin)
     if (!rwin->displayId || !rwin->contextId)
 	return 0;
     if (rwin->contextId == glXGetCurrentContext())
 	return 1;
@@ -188,7 +207,10 @@
     /* TODO: mac_win */
     aglMakeCurrent((AGLDrawable) mac_win, rwin->contextId);
-    /* TODO wglMakeCurrent( HDC hdc, HGLRC hrc ) */
+    if (!rwin->displayId || !rwin->contextId)
+	return 0;
+    wglMakeCurrent(rwin->displayId, rwin->contextId);
 #endif
     return 1;
Modified: grass/trunk/visualization/nviz2/cmd/write_img.c
--- grass/trunk/visualization/nviz2/cmd/write_img.c	2008-07-15 05:53:52 UTC (rev 32117)
+++ grass/trunk/visualization/nviz2/cmd/write_img.c	2008-07-15 07:57:07 UTC (rev 32118)
@@ -16,11 +16,11 @@
   \date 2008
+#include "local_proto.h"
 #include <grass/gsurf.h>
 #include <grass/gstypes.h>
-#include "local_proto.h"
   \brief Save current GL screen to an ppm file.
