[GRASS-SVN] r32119 - grass/trunk
    svn_grass at osgeo.org
    Tue Jul 15 03:58:27 EDT 2008
Author: glynn
Date: 2008-07-15 03:58:27 -0400 (Tue, 15 Jul 2008)
New Revision: 32119
   grass/trunk/configure
   grass/trunk/configure.in
Remove (outdated) comment about --with-opengl=windows being untested
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-07-15 07:57:07 UTC (rev 32118)
+++ grass/trunk/configure	2008-07-15 07:58:27 UTC (rev 32119)
@@ -11672,13 +11672,11 @@
 if test "$OPENGL_WINDOWS" = 1 ; then
-echo "configure: warning: *** --with-opengl=windows is untested." 1>&2
 # With OpenGL includes directory
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11682: checking for location of OpenGL includes" >&5
+echo "configure:11680: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11704,15 +11702,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11708: checking for $ac_hdr" >&5
+echo "configure:11706: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11711 "configure"
+#line 11709 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11714: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11746,7 +11744,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11750: checking for location of OpenGL library" >&5
+echo "configure:11748: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11771,18 +11769,18 @@
 ac_save_ldflags="$LDFLAGS"
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11775: checking for OpenGL library" >&5
+echo "configure:11773: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11779 "configure"
+#line 11777 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11806,18 +11804,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11810: checking for GLU library" >&5
+echo "configure:11808: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11814 "configure"
+#line 11812 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11866,7 +11864,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11870: checking whether to use ODBC" >&5
+echo "configure:11868: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11885,7 +11883,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11889: checking for location of ODBC includes" >&5
+echo "configure:11887: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11911,15 +11909,15 @@
 do
-echo "configure:11915: checking for $ac_hdr" >&5
+echo "configure:11913: checking for $ac_hdr" >&5
-#line 11918 "configure"
+#line 11916 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11921: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11953,7 +11951,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11957: checking for location of ODBC library" >&5
+echo "configure:11955: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11978,13 +11976,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11982: checking for SQLConnect in -lodbc" >&5
+echo "configure:11980: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11988 "configure"
+#line 11986 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -11995,7 +11993,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12020,13 +12018,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12024: checking for SQLConnect in -liodbc" >&5
+echo "configure:12022: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12030 "configure"
+#line 12028 "configure"
@@ -12037,7 +12035,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12062,11 +12060,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12066: checking for ODBC library" >&5
+echo "configure:12064: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12070 "configure"
+#line 12068 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12074,7 +12072,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12123,7 +12121,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12127: checking whether to use FFTW" >&5
+echo "configure:12125: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12142,7 +12140,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12146: checking for location of FFTW includes" >&5
+echo "configure:12144: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12168,15 +12166,15 @@
 do
-echo "configure:12172: checking for $ac_hdr" >&5
+echo "configure:12170: checking for $ac_hdr" >&5
-#line 12175 "configure"
+#line 12173 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12180: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12204,15 +12202,15 @@
 do
-echo "configure:12208: checking for $ac_hdr" >&5
+echo "configure:12206: checking for $ac_hdr" >&5
-#line 12211 "configure"
+#line 12209 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12214: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12240,15 +12238,15 @@
 do
-echo "configure:12244: checking for $ac_hdr" >&5
+echo "configure:12242: checking for $ac_hdr" >&5
-#line 12247 "configure"
+#line 12245 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12294,7 +12292,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12298: checking for location of FFTW library" >&5
+echo "configure:12296: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12319,13 +12317,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12323: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12321: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12329 "configure"
+#line 12327 "configure"
@@ -12336,7 +12334,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12361,13 +12359,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12365: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12363: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12371 "configure"
+#line 12369 "configure"
@@ -12378,7 +12376,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12403,13 +12401,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12407: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12405: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12413 "configure"
+#line 12411 "configure"
@@ -12420,7 +12418,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12477,7 +12475,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12481: checking whether to use BLAS" >&5
+echo "configure:12479: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12498,7 +12496,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12502: checking for location of BLAS includes" >&5
+echo "configure:12500: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12518,7 +12516,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12522: checking for location of BLAS library" >&5
+echo "configure:12520: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12544,15 +12542,15 @@
 do
-echo "configure:12548: checking for $ac_hdr" >&5
+echo "configure:12546: checking for $ac_hdr" >&5
-#line 12551 "configure"
+#line 12549 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12587,13 +12585,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12591: checking for dnrm2_ in -lblas" >&5
+echo "configure:12589: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12597 "configure"
+#line 12595 "configure"
@@ -12604,7 +12602,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12623,13 +12621,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:12627: checking for dnrm2_ in -lblas" >&5
+echo "configure:12625: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12633 "configure"
+#line 12631 "configure"
@@ -12640,7 +12638,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12684,13 +12682,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12688: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12686: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12694 "configure"
+#line 12692 "configure"
@@ -12701,7 +12699,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12716,13 +12714,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12720: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12718: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12726 "configure"
+#line 12724 "configure"
@@ -12733,7 +12731,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12748,13 +12746,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12752: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12750: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12758 "configure"
+#line 12756 "configure"
@@ -12765,7 +12763,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12810,16 +12808,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12814: checking for sgemm in $vlib_flags" >&5
+echo "configure:12812: checking for sgemm in $vlib_flags" >&5
-#line 12816 "configure"
+#line 12814 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12837,13 +12835,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12841: checking for sgemm_ in -lblas" >&5
+echo "configure:12839: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12847 "configure"
+#line 12845 "configure"
@@ -12854,7 +12852,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12869,13 +12867,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12873: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12871: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12879 "configure"
+#line 12877 "configure"
@@ -12886,7 +12884,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12901,13 +12899,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12905: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12903: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12911 "configure"
+#line 12909 "configure"
@@ -12918,7 +12916,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12952,13 +12950,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12956: checking for acosp in -lsunmath" >&5
+echo "configure:12954: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12962 "configure"
+#line 12960 "configure"
@@ -12969,7 +12967,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12984,13 +12982,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12988: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12986: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12994 "configure"
+#line 12992 "configure"
@@ -13001,7 +12999,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13031,13 +13029,13 @@
 # Generic BLAS library
-echo "configure:13035: checking for sgemm_ in -lblas" >&5
+echo "configure:13033: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13041 "configure"
+#line 13039 "configure"
@@ -13048,7 +13046,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13087,7 +13085,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13091: checking whether to use LAPACK" >&5
+echo "configure:13089: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13112,7 +13110,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13116: checking for location of LAPACK includes" >&5
+echo "configure:13114: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13132,7 +13130,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13136: checking for location of LAPACK library" >&5
+echo "configure:13134: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13158,15 +13156,15 @@
 do
-echo "configure:13162: checking for $ac_hdr" >&5
+echo "configure:13160: checking for $ac_hdr" >&5
-#line 13165 "configure"
+#line 13163 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13170: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13198,10 +13196,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13202: checking for dsegv_" >&5
+echo "configure:13200: checking for dsegv_" >&5
-#line 13205 "configure"
+#line 13203 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char dsegv_(); below.  */
@@ -13224,7 +13222,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13251,13 +13249,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13255: checking for desgv_ in -llapack" >&5
+echo "configure:13253: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13261 "configure"
+#line 13259 "configure"
@@ -13268,7 +13266,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13300,13 +13298,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13304: checking for dgesv_ in -llapack" >&5
+echo "configure:13302: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13310 "configure"
+#line 13308 "configure"
@@ -13317,7 +13315,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13336,13 +13334,13 @@
-echo "configure:13340: checking for dgesv_ in -llapack" >&5
+echo "configure:13338: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13346 "configure"
+#line 13344 "configure"
@@ -13353,7 +13351,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13409,7 +13407,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13413: checking whether to use Motif" >&5
+echo "configure:13411: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13428,7 +13426,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13432: checking for location of Motif includes" >&5
+echo "configure:13430: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13454,15 +13452,15 @@
 do
-echo "configure:13458: checking for $ac_hdr" >&5
+echo "configure:13456: checking for $ac_hdr" >&5
-#line 13461 "configure"
+#line 13459 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13466: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13496,7 +13494,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13500: checking for location of Motif library" >&5
+echo "configure:13498: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13521,13 +13519,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13525: checking for XmStringCreate in -lXm" >&5
+echo "configure:13523: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13531 "configure"
+#line 13529 "configure"
@@ -13538,7 +13536,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13579,7 +13577,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13583: checking whether to use Cairo" >&5
+echo "configure:13581: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13605,15 +13603,15 @@
 do
-echo "configure:13609: checking for $ac_hdr" >&5
+echo "configure:13607: checking for $ac_hdr" >&5
-#line 13612 "configure"
+#line 13610 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13650,10 +13648,10 @@
 LDFLAGS="$LDFLAGS $CAIROLIB"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13654: checking for cairo_create" >&5
+echo "configure:13652: checking for cairo_create" >&5
-#line 13657 "configure"
+#line 13655 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13676,7 +13674,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13711,7 +13709,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13715: checking whether to use GLw" >&5
+echo "configure:13713: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13730,7 +13728,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13734: checking for location of GLw includes" >&5
+echo "configure:13732: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13756,15 +13754,15 @@
 do
-echo "configure:13760: checking for $ac_hdr" >&5
+echo "configure:13758: checking for $ac_hdr" >&5
-#line 13763 "configure"
+#line 13761 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13792,15 +13790,15 @@
 do
-echo "configure:13796: checking for $ac_hdr" >&5
+echo "configure:13794: checking for $ac_hdr" >&5
-#line 13799 "configure"
+#line 13797 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13840,7 +13838,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13844: checking for location of GLw library" >&5
+echo "configure:13842: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13865,13 +13863,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13869: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13867: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 13875 "configure"
+#line 13873 "configure"
@@ -13882,7 +13880,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13907,13 +13905,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13911: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13909: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13917 "configure"
+#line 13915 "configure"
@@ -13924,7 +13922,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13949,13 +13947,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13953: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13951: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13959 "configure"
+#line 13957 "configure"
@@ -13966,7 +13964,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:13970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13991,13 +13989,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13995: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13993: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14001 "configure"
+#line 13999 "configure"
@@ -14008,7 +14006,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14033,13 +14031,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14037: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14035: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14043 "configure"
+#line 14041 "configure"
@@ -14050,7 +14048,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14075,13 +14073,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14079: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14077: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14085 "configure"
+#line 14083 "configure"
@@ -14092,7 +14090,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14119,13 +14117,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14123: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14121: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14129 "configure"
+#line 14127 "configure"
@@ -14136,7 +14134,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14155,13 +14153,13 @@
-echo "configure:14159: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14157: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14165 "configure"
+#line 14163 "configure"
@@ -14172,7 +14170,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14199,13 +14197,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14203: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14201: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14209 "configure"
+#line 14207 "configure"
@@ -14216,7 +14214,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14235,13 +14233,13 @@
-echo "configure:14239: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14237: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14245 "configure"
+#line 14243 "configure"
@@ -14252,7 +14250,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14365,7 +14363,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14369: checking whether to use FreeType" >&5
+echo "configure:14367: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14384,7 +14382,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14388: checking for location of FreeType includes" >&5
+echo "configure:14386: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14410,15 +14408,15 @@
 do
-echo "configure:14414: checking for $ac_hdr" >&5
+echo "configure:14412: checking for $ac_hdr" >&5
-#line 14417 "configure"
+#line 14415 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14452,7 +14450,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14456: checking for location of FreeType library" >&5
+echo "configure:14454: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14477,13 +14475,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14481: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14479: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14487 "configure"
+#line 14485 "configure"
@@ -14494,7 +14492,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14535,7 +14533,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14539: checking whether to use NLS" >&5
+echo "configure:14537: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14555,10 +14553,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14559: checking for gettext" >&5
+echo "configure:14557: checking for gettext" >&5
-#line 14562 "configure"
+#line 14560 "configure"
     which can conflict with char gettext(); below.  */
@@ -14581,7 +14579,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14599,13 +14597,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14603: checking for gettext in -lintl" >&5
+echo "configure:14601: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14609 "configure"
+#line 14607 "configure"
@@ -14616,7 +14614,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14651,7 +14649,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14655: checking whether to use C++" >&5
+echo "configure:14653: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14667,7 +14665,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14671: checking for $ac_word" >&5
+echo "configure:14669: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14696,7 +14694,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14700: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14698: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14707,12 +14705,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14711 "configure"
+#line 14709 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14738,19 +14736,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14742: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14740: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14747: checking whether we are using GNU C++" >&5
+echo "configure:14745: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14768,7 +14766,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14772: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14770: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14809,7 +14807,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14813: checking whether to use openDWG" >&5
+echo "configure:14811: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14829,7 +14827,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14833: checking for location of openDGW includes" >&5
+echo "configure:14831: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14855,15 +14853,15 @@
 do
-echo "configure:14859: checking for $ac_hdr" >&5
+echo "configure:14857: checking for $ac_hdr" >&5
-#line 14862 "configure"
+#line 14860 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14897,7 +14895,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14901: checking for location of openDWG library" >&5
+echo "configure:14899: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14944,7 +14942,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14948: checking for special C compiler options needed for large files" >&5
+echo "configure:14946: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14952,7 +14950,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14956 "configure"
+#line 14954 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14968,7 +14966,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14972: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14977,7 +14975,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14981 "configure"
+#line 14979 "configure"
@@ -14993,7 +14991,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14995: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15013,11 +15011,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15017: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15015: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15021 "configure"
+#line 15019 "configure"
@@ -15033,14 +15031,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15044 "configure"
+#line 15042 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15058,7 +15056,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15062: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15077,11 +15075,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15081: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15079: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15085 "configure"
+#line 15083 "configure"
@@ -15097,14 +15095,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15099: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15108 "configure"
+#line 15106 "configure"
 #define _LARGE_FILES 1
@@ -15122,7 +15120,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15141,25 +15139,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15143: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15149 "configure"
+#line 15147 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15163 "configure"
+#line 15161 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15168,7 +15166,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15170: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15189,10 +15187,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15193: checking if system supports Large Files at all" >&5
+echo "configure:15191: checking if system supports Large Files at all" >&5
-#line 15196 "configure"
+#line 15194 "configure"
 #include <stdio.h>
@@ -15224,7 +15222,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15228: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15226: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15253,7 +15251,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15257: checking whether to use Python" >&5
+echo "configure:15255: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15273,7 +15271,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15277: checking for $ac_word" >&5
+echo "configure:15275: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15318,15 +15316,15 @@
 do
-echo "configure:15322: checking for $ac_hdr" >&5
+echo "configure:15320: checking for $ac_hdr" >&5
-#line 15325 "configure"
+#line 15323 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15366,7 +15364,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15370: checking for $ac_word" >&5
+echo "configure:15368: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15412,7 +15410,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15416: checking whether to use wxWidgets" >&5
+echo "configure:15414: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15432,7 +15430,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15436: checking for $ac_word" >&5
+echo "configure:15434: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15480,7 +15478,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15484: checking wxWidgets version" >&5
+echo "configure:15482: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15503,15 +15501,15 @@
 do
-echo "configure:15507: checking for $ac_hdr" >&5
+echo "configure:15505: checking for $ac_hdr" >&5
-#line 15510 "configure"
+#line 15508 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15547,15 +15545,15 @@
 do
-echo "configure:15551: checking for $ac_hdr" >&5
+echo "configure:15549: checking for $ac_hdr" >&5
-#line 15554 "configure"
+#line 15552 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15557: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-07-15 07:57:07 UTC (rev 32118)
+++ grass/trunk/configure.in	2008-07-15 07:58:27 UTC (rev 32119)
@@ -1133,8 +1133,6 @@
-AC_MSG_WARN([*** --with-opengl=windows is untested.])
 LOC_CHECK_INC_PATH(opengl,OpenGL,OPENGLINC)
