[GRASS-SVN] r32152 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Thu Jul 17 10:08:56 EDT 2008
Author: martinl
Date: 2008-07-17 10:08:56 -0400 (Thu, 17 Jul 2008)
New Revision: 32152
grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: workspace module updated (from trunk, except of 'nviz' part)"
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-07-17 14:01:56 UTC (rev 32151)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-07-17 14:08:56 UTC (rev 32152)
@@ -5,6 +5,7 @@
Classes:
- ProcessWorkspaceFile
+ - WriteWorkspaceFile
- ProcessGrcFile
(C) 2007-2008 by the GRASS Development Team
@@ -37,20 +38,19 @@
defined in grass-gxw.dtd.
def __init__(self):
- self.inGxw = False
- self.inLayer = False
- self.inTask = False
- self.inParameter = False
- self.inFlag = False
- self.inValue = False
- self.inGroup = False
- self.inDisplay = False
- self.inLayerManager = False
+ self.inTag = {}
+ for tag in ('gxw', 'layer', 'task', 'parameter',
+ 'flag', 'value', 'group', 'display',
+ 'layer_manager'):
+ self.inTag[tag] = False
# layer manager properties
self.layerManager = {}
self.layerManager['pos'] = None # window position
self.layerManager['size'] = None # window size
# list of mapdisplays
self.displays = []
# list of map layers
@@ -60,11 +60,7 @@
self.displayIndex = -1 # first display has index '0'
def startElement(self, name, attrs):
- if name == 'gxw':
- self.inGxw = True
- elif name == 'display':
- self.inDisplay = True
+ if name == 'display':
self.displayIndex += 1
# window position and size
@@ -105,43 +101,36 @@
"checked" : int(self.groupChecked),
"opacity" : None,
"cmd" : None,
- "group" : self.inGroup,
- "display" : self.displayIndex})
- self.inGroup = True
+ "group" : self.inTag['group'],
+ "display" : self.displayIndex })
elif name == 'layer':
- self.inLayer = True
self.layerType = attrs.get('type', None)
self.layerName = attrs.get('name', None)
self.layerChecked = attrs.get('checked', None)
self.layerOpacity = attrs.get('opacity', None)
- self.layerSelected = False;
+ self.layerSelected = False
self.cmd = []
elif name == 'task':
- self.inTask = True;
name = attrs.get('name', None)
self.cmd.append(name)
elif name == 'parameter':
- self.inParameter = True;
self.parameterName = attrs.get('name', None)
- elif name == 'value':
- self.inValue = True
+ elif name in ('value', 'x', 'y', 'z'):
self.value = ''
elif name == 'flag':
- self.inFlag = True;
self.cmd.append('-' + name)
elif name == 'selected':
- if self.inLayer:
+ if self.inTag['layer']:
self.layerSelected = True;
elif name == 'layer_manager':
- self.inLayerManager = True
posAttr = attrs.get('dim', '')
if posAttr:
posVal = map(int, posAttr.split(','))
@@ -153,28 +142,22 @@
else:
pass
+ self.inTag[name] = True
def endElement(self, name):
- if name == 'gxw':
- elif name == 'group':
+ if name == 'group':
self.groupName = self.groupChecked = None
self.layers.append({
"type" : self.layerType,
"name" : self.layerName,
"checked" : int(self.layerChecked),
"opacity" : None,
"cmd" : None,
"display" : self.displayIndex,
- "selected" : self.layerSelected})
+ "selected" : self.layerSelected })
if self.layerOpacity:
self.layers[-1]["opacity"] = float(self.layerOpacity)
@@ -184,30 +167,137 @@
self.layerType = self.layerName = self.Checked = \
self.Opacity = self.cmd = None
- elif name == 'task':
self.cmd.append('%s=%s' % (self.parameterName, self.value))
self.parameterName = self.value = None
+ self.inTag[name] = False
- elif name == 'flag':
- elif name == 'layer_manager':
def characters(self, ch):
self.my_characters(ch)
def my_characters(self, ch):
- if self.inValue:
+ if self.inTag['value']:
self.value += ch
+class WriteWorkspaceFile(object):
+ """Generic class for writing workspace file"""
+ def __init__(self, lmgr, file):
+ self.file = file
+ self.lmgr = lmgr
+ self.indent = 0
+ # write header
+ self.file.write('<?xml version="1.0" encoding="UTF-8"?>\n')
+ self.file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
+ self.file.write('%s<gxw>\n' % (' ' * self.indent))
+ self.indent =+ 4
+ # layer manager
+ windowPos = self.lmgr.GetPosition()
+ windowSize = self.lmgr.GetSize()
+ file.write('%s<layer_manager dim="%d,%d,%d,%d">\n' % (' ' * self.indent,
+ windowPos[0],
+ windowPos[1],
+ windowSize[0],
+ windowSize[1]
+ file.write('%s</layer_manager>\n' % (' ' * self.indent))
+ # list of displays
+ for page in range(0, self.lmgr.gm_cb.GetPageCount()):
+ mapTree = self.lmgr.gm_cb.GetPage(page).maptree
+ region = mapTree.Map.region
+ displayPos = mapTree.mapdisplay.GetPosition()
+ displaySize = mapTree.mapdisplay.GetSize()
+ file.write('%s<display render="%d" '
+ 'mode="%d" showCompExtent="%d" '
+ 'dim="%d,%d,%d,%d" '
+ 'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
+ int(mapTree.mapdisplay.autoRender.IsChecked()),
+ mapTree.mapdisplay.toggleStatus.GetSelection(),
+ int(mapTree.mapdisplay.showRegion.IsChecked()),
+ displayPos[0],
+ displayPos[1],
+ displaySize[0],
+ displaySize[1],
+ region['w'],
+ region['s'],
+ region['e'],
+ region['n']
+ # list of layers
+ item = mapTree.GetFirstChild(mapTree.root)[0]
+ self.__writeLayer(mapTree, item)
+ file.write('%s</display>\n' % (' ' * self.indent))
+ self.indent =- 4
+ file.write('%s</gxw>\n' % (' ' * self.indent))
+ def __writeLayer(self, mapTree, item):
+ """Write bunch of layers to GRASS Workspace XML file"""
+ self.indent += 4
+ while item and item.IsOk():
+ type = mapTree.GetPyData(item)[0]['type']
+ if type != 'group':
+ maplayer = mapTree.GetPyData(item)[0]['maplayer']
+ else:
+ maplayer = None
+ checked = int(item.IsChecked())
+ cmd = mapTree.GetPyData(item)[0]['cmd']
+ if type == 'command':
+ self.file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
+ (' ' * self.indent, type, ' '.join(cmd), checked));
+ self.file.write('%s</layer>\n' % (' ' * self.indent));
+ elif type == 'group':
+ name = mapTree.GetItemText(item)
+ self.file.write('%s<group name="%s" checked="%d">\n' % \
+ (' ' * self.indent, name, checked));
+ self.indent += 4
+ subItem = mapTree.GetFirstChild(item)[0]
+ self.__writeLayer(mapTree, subItem)
+ self.indent -= 4
+ self.file.write('%s</group>\n' % (' ' * self.indent));
+ else:
+ opacity = maplayer.GetOpacity(float=True)
+ self.file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
+ (' ' * self.indent, type, name, checked, opacity));
+ self.indent += 4
+ # selected ?
+ if item == mapTree.layer_selected:
+ self.file.write('%s<selected />\n' % (' ' * self.indent))
+ # layer properties
+ self.file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
+ self.indent += 4
+ for option in cmd[1:]:
+ if option[0] == '-': # flag
+ self.file.write('%s<flag name="%s" />\n' %
+ (' ' * self.indent, option[1]))
+ else: # parameter
+ key, value = option.split('=', 1)
+ self.file.write('%s<parameter name="%s">\n' %
+ (' ' * self.indent, key))
+ self.indent += 4
+ self.file.write('%s<value>%s</value>\n' %
+ (' ' * self.indent, value))
+ self.indent -= 4
+ self.file.write('%s</parameter>\n' % (' ' * self.indent));
+ self.indent -= 4
+ self.file.write('%s</task>\n' % (' ' * self.indent));
+ self.indent -= 4
+ item = mapTree.GetNextSibling(item)
+ self.indent -= 4
class ProcessGrcFile(object):
def __init__(self, filename):
"""Process GRC file"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-17 14:01:56 UTC (rev 32151)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-17 14:08:56 UTC (rev 32152)
@@ -868,12 +868,19 @@
oldlayer = event.GetOldItem()
layer = event.GetItem()
self.layer_selected = layer
try:
self.RefreshLine(oldlayer)
self.RefreshLine(layer)
except:
pass
+ # update statusbar -> show command string
+ if self.GetPyData(layer) and self.GetPyData(layer)[0]['maplayer']:
+ cmd = self.GetPyData(layer)[0]['maplayer'].GetCmd(string=True)
+ if len(cmd) > 0:
+ self.gismgr.SetStatusText(cmd)
def OnCollapseNode(self, event):
Collapse node
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-07-17 14:01:56 UTC (rev 32151)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-07-17 14:08:56 UTC (rev 32152)
@@ -812,64 +812,6 @@
else:
self.OnWorkspaceSaveAs()
- def WriteLayersToWorkspaceFile(self, file, mapTree, item):
- """Write bunch of layers to GRASS Workspace XML file"""
- self.indent += 4
- while item and item.IsOk():
- type = mapTree.GetPyData(item)[0]['type']
- if type != 'group':
- maplayer = mapTree.GetPyData(item)[0]['maplayer']
- else:
- maplayer = None
- checked = int(item.IsChecked())
- cmd = mapTree.GetPyData(item)[0]['cmd']
- if type == 'command':
- file.write('%s<layer type="%s" name="%s" checked="%d">\n' % \
- (' ' * self.indent, type, ' '.join(cmd), checked));
- file.write('%s</layer>\n' % (' ' * self.indent));
- elif type == 'group':
- name = mapTree.GetItemText(item)
- file.write('%s<group name="%s" checked="%d">\n' % \
- (' ' * self.indent, name, checked));
- self.indent += 4
- subItem = mapTree.GetFirstChild(item)[0]
- self.WriteLayersToWorkspaceFile(file, mapTree, subItem)
- self.indent -= 4
- file.write('%s</group>\n' % (' ' * self.indent));
- else:
- opacity = maplayer.GetOpacity(float=True)
- file.write('%s<layer type="%s" name="%s" checked="%d" opacity="%f">\n' % \
- (' ' * self.indent, type, name, checked, opacity));
- self.indent += 4
- # selected ?
- if item == mapTree.layer_selected:
- file.write('%s<selected />\n' % (' ' * self.indent))
- # layer properties
- file.write('%s<task name="%s">\n' % (' ' * self.indent, cmd[0]))
- self.indent += 4
- for option in cmd[1:]:
- if option[0] == '-': # flag
- file.write('%s<flag name="%s" />\n' %
- (' ' * self.indent, option[1]))
- else: # parameter
- key, value = option.split('=', 1)
- file.write('%s<parameter name="%s">\n' %
- (' ' * self.indent, key))
- self.indent += 4
- file.write('%s<value>%s</value>\n' %
- (' ' * self.indent, value))
- self.indent -= 4
- file.write('%s</parameter>\n' % (' ' * self.indent));
- self.indent -= 4
- file.write('%s</task>\n' % (' ' * self.indent));
- self.indent -= 4
- item = mapTree.GetNextSibling(item)
- self.indent -= 4
def SaveToWorkspaceFile(self, filename):
"""Save layer tree layout to workspace file
@@ -885,59 +827,7 @@
return False
try:
- self.indent = 0 # number of spaces
- # write header
- file.write('<?xml version="1.0" encoding="UTF-8"?>\n')
- file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
- file.write('%s<gxw>\n' % (' ' * self.indent))
- self.indent =+ 4
- # layer manager
- windowPos = self.GetPosition()
- windowSize = self.GetSize()
- file.write('%s<layer_manager dim="%d,%d,%d,%d">\n' % (' ' * self.indent,
- windowPos[0],
- windowPos[1],
- windowSize[0],
- windowSize[1]
- file.write('%s</layer_manager>\n' % (' ' * self.indent))
- # list of displays
- for page in range(0, self.gm_cb.GetPageCount()):
- mapTree = self.gm_cb.GetPage(page).maptree
- region = mapTree.Map.region
- displayPos = mapTree.mapdisplay.GetPosition()
- displaySize = mapTree.mapdisplay.GetSize()
- file.write('%s<display render="%d" '
- 'mode="%d" showCompExtent="%d" '
- 'dim="%d,%d,%d,%d" '
- 'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
- int(mapTree.mapdisplay.autoRender.IsChecked()),
- mapTree.mapdisplay.toggleStatus.GetSelection(),
- int(mapTree.mapdisplay.showRegion.IsChecked()),
- displayPos[0],
- displayPos[1],
- displaySize[0],
- displaySize[1],
- region['w'],
- region['s'],
- region['e'],
- region['n']
- # list of layers
- item = mapTree.GetFirstChild(mapTree.root)[0]
- self.WriteLayersToWorkspaceFile(file, mapTree, item)
- file.write('%s</display>\n' % (' ' * self.indent))
- self.indent =- 4
- file.write('%s</gxw>\n' % (' ' * self.indent))
- del self.indent
+ workspace.WriteWorkspaceFile(lmgr=self, file=file)
except StandardError, e:
file.close()
wx.MessageBox(parent=self,
