[GRASS-SVN] r32153 - grass-addons/gipe/i.eb.h_SEBAL95
svn_grass at osgeo.org
Thu Jul 17 19:00:26 EDT 2008
Author: ychemin
Date: 2008-07-17 19:00:26 -0400 (Thu, 17 Jul 2008)
New Revision: 32153
grass-addons/gipe/i.eb.h_SEBAL95/main.c
cleaning manual pixel setup
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-07-17 14:08:56 UTC (rev 32152)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-07-17 23:00:26 UTC (rev 32153)
@@ -42,6 +42,8 @@
int row, col;
double row_wet, col_wet;
double row_dry, col_dry;
+ double m_row_wet, m_col_wet;
+ double m_row_dry, m_col_dry;
int infd_T,infd_ndvi,infd_u2,infd_dem,infd_Rn,infd_g0,infd_albedo;
int outfd;
@@ -194,21 +196,17 @@
if(input_row_wet->answer&&input_row_dry&&
input_col_wet->answer&&input_col_dry){
+ m_row_wet = atof(input_row_wet->answer);
+ m_col_wet = atof(input_col_wet->answer);
+ m_row_dry = atof(input_row_dry->answer);
+ m_col_dry = atof(input_col_dry->answer);
if(flag3->answer){
- row_wet = atof(input_row_wet->answer);
- col_wet = atof(input_col_wet->answer);
- row_dry = atof(input_row_dry->answer);
- col_dry = atof(input_col_dry->answer);
G_message("Manual wet/dry pixels in image coordinates");
- G_message("Wet Pixel=> x:%f y:%f",col_wet,row_wet);
- G_message("Dry Pixel=> x:%f y:%f",col_dry,row_dry);
+ G_message("Wet Pixel=> x:%f y:%f",m_col_wet,m_row_wet);
+ G_message("Dry Pixel=> x:%f y:%f",m_col_dry,m_row_dry);
} else {
- row_wet = (int) atof(input_row_wet->answer);
- col_wet = (int) atof(input_col_wet->answer);
- row_dry = (int) atof(input_row_dry->answer);
- col_dry = (int) atof(input_col_dry->answer);
- G_message("Wet Pixel=> row:%i col:%i",row_wet,col_wet);
- G_message("Dry Pixel=> row:%i col:%i",row_dry,col_dry);
+ G_message("Wet Pixel=> row:%.0f col:%.0f",m_row_wet,m_col_wet);
+ G_message("Dry Pixel=> row:%.0f col:%.0f",m_row_dry,m_col_dry);
/* find maps in mapset */
@@ -679,17 +677,18 @@
/*MPI_BARRIER*/
/* MANUAL WET/DRY PIXELS */
- if(input_row_wet->answer&&input_row_dry&&
- input_col_wet->answer&&input_col_dry){
+ if(input_row_wet->answer&&input_row_dry->answer&&
+ input_col_wet->answer&&input_col_dry->answer){
/*DRY PIXEL*/
if(flag3->answer){
/*Calculate coordinates of row/col from projected ones*/
- row = ( ymax - row_dry ) / stepy ;
- col = ( col_dry - xmin ) / stepx ;
+ row = (int) (( ymax - m_row_dry ) / (double) stepy) ;
+ col = (int) (( m_col_dry - xmin ) / (double) stepx) ;
G_message("Dry Pixel | row:%i col:%i",row,col);
} else {
- row=row_dry;
- col=col_dry;
+ row = (int) m_row_dry;
+ col = (int) m_col_dry;
+ G_message("Dry Pixel | row:%i col:%i",row,col);
DCELL d_tempk;
DCELL d_dem;
@@ -746,21 +745,23 @@
d_g0 = (double) ((DCELL *) inrast_g0)[col];
break;
- d_t0dem = d_tempk + 0.001649*d_dem;
- d_t0dem_dry=d_t0dem;
- d_tempk_dry=d_tempk;
- d_Rn_dry=d_Rn;
- d_g0_dry=d_g0;
- d_dem_dry=d_dem;
+ d_t0dem = d_tempk + 0.001649 * d_dem;
+ d_t0dem_dry = d_t0dem;
+ d_tempk_dry = d_tempk;
+ d_Rn_dry = d_Rn;
+ d_g0_dry = d_g0;
+ d_dem_dry = d_dem;
/*WET PIXEL*/
if(flag3->answer){
- row = ( ymax - row_wet ) / stepy ;
- col = ( col_wet - xmin ) / stepx ;
+ row = (int) (( ymax - m_row_wet ) / (double) stepy) ;
+ col = (int) (( m_col_wet - xmin ) / (double) stepx) ;
G_message("Wet Pixel | row:%i col:%i",row,col);
} else {
- row=row_wet;
- col=col_wet;
+ row = m_row_wet;
+ col = m_col_wet;
+ G_message("Wet Pixel | row:%i col:%i",row,col);
if(G_get_raster_row(infd_T,inrast_T,row,data_type_T)<0)
G_fatal_error(_("Could not read from <%s>"),T);
@@ -775,7 +776,7 @@
d_tempk = (double) ((DCELL *) inrast_T)[col];
break;
- d_tempk_wet=d_tempk;
+ d_tempk_wet = d_tempk;
/* END OF MANUAL WET/DRY PIXELS */
@@ -882,14 +883,14 @@
break;
- if(G_is_d_null_value(&d_tempk)||
- G_is_d_null_value(&d_u2m)||
- G_is_d_null_value(&d_dem)||
- G_is_d_null_value(&d_ndvi)||
- G_is_d_null_value(&d_Rn)||
- G_is_d_null_value(&d_g0)||
- d_g0<0.0||d_Rn<0.0||
- d_dem<=-100.0||d_dem>9000.0||
+ if(G_is_d_null_value(&d_tempk) ||
+ G_is_d_null_value(&d_u2m) ||
+ G_is_d_null_value(&d_dem) ||
+ G_is_d_null_value(&d_ndvi) ||
+ G_is_d_null_value(&d_Rn) ||
+ G_is_d_null_value(&d_g0) ||
+ d_g0<0.0 || d_Rn<0.0 ||
+ d_dem<=-100.0 || d_dem>9000.0 ||
d_tempk<200.0){
G_set_d_null_value(&outrast[col],1);
} else {
@@ -898,7 +899,7 @@
d_albedo=0.01;
/* Calculate T0dem */
- d_t0dem = (double)d_tempk + 0.001649*(double)d_dem;
+ d_t0dem = (double)d_tempk + 0.001649 * (double) d_dem;
/* G_message("**InLoop d_t0dem=%5.3f",d_t0dem);
G_message(" d_dem=%5.3f",d_dem);
G_message(" d_tempk=%5.3f",d_tempk);
