[GRASS-SVN] r32213 - in grass/trunk/raster: . r.grow.distance
svn_grass at osgeo.org
Tue Jul 22 11:55:13 EDT 2008
Author: glynn
Date: 2008-07-22 11:55:12 -0400 (Tue, 22 Jul 2008)
New Revision: 32213
Added:
grass/trunk/raster/r.grow.distance/
grass/trunk/raster/r.grow.distance/Makefile
grass/trunk/raster/r.grow.distance/description.html
grass/trunk/raster/r.grow.distance/main.c
Add r.grow.distance
Property changes on: grass/trunk/raster/r.grow.distance
___________________________________________________________________
+ *.tmp.html
*OBJ*
Added: grass/trunk/raster/r.grow.distance/Makefile
--- grass/trunk/raster/r.grow.distance/Makefile (rev 0)
+++ grass/trunk/raster/r.grow.distance/Makefile 2008-07-22 15:55:12 UTC (rev 32213)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.grow.distance
+LIBES = $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster/r.grow.distance/description.html
--- grass/trunk/raster/r.grow.distance/description.html (rev 0)
+++ grass/trunk/raster/r.grow.distance/description.html 2008-07-22 15:55:12 UTC (rev 32213)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2>
+<em>r.grow.distance</em> generates a raster map representing the
+distance to the nearest non-null cell in the input map.
+<h2>NOTES</h2>
+The user has the option of specifying four different metrics which
+control the geometry in which grown cells are created, (controlled by
+the <b>metric</b> parameter): <i>Euclidean</i>, <i>Squared</i>,
+<i>Manhattan</i>, and <i>Maximum</i>.
+<p>
+The <i>Euclidean distance</i> or <i>Euclidean metric</i> is the "ordinary" distance
+between two points that one would measure with a ruler, which can be
+proven by repeated application of the Pythagorean theorem.
+The formula is given by:
+<div class="code"><pre>d(dx,dy) = sqrt(dx^2 + dy^2)</pre></div>
+Cells grown using this metric would form isolines of distance that are
+circular from a given point, with the distance given by the <b>radius</b>.
+<p>
+The <i>Squared</i> metric is the <i>Euclidean</i> distance squared,
+i.e. it simply omits the square-root calculation. This may be faster,
+and is sufficient if only relative values are required.
+<p>
+The <i>Manhattan metric</i>, or <i>Taxicab geometry</i>, is a form of geometry in
+which the usual metric of Euclidean geometry is replaced by a new
+metric in which the distance between two points is the sum of the (absolute)
+differences of their coordinates. The name alludes to the grid layout of
+most streets on the island of Manhattan, which causes the shortest path a
+car could take between two points in the city to have length equal to the
+points' distance in taxicab geometry.
+<div class="code"><pre>d(dx,dy) = abs(dx) + abs(dy)</pre></div>
+where cells grown using this metric would form isolines of distance that are
+rhombus-shaped from a given point.
+<p>
+The <i>Maximum metric</i> is given by the formula
+<div class="code"><pre>d(dx,dy) = max(abs(dx),abs(dy))</pre></div>
+where the isolines of distance from a point are squares.
+<h2>SEE ALSO</h2>
+<em><a href="r.grow.html">r.grow</a></em><br>
+<em><a href="r.buffer.html">r.buffer</a></em><br>
+<em><a href="r.patch.html">r.patch</a></em>
+<p>
+<em><a href="http://en.wikipedia.org/wiki/Euclidean_metric">Wikipedia Entry: Euclidean Metric</a><br>
+<em><a href="http://en.wikipedia.org/wiki/Manhattan_metric">Wikipedia Entry: Manhattan Metric</a>
+<h2>AUTHORS</h2>
+Glynn Clements
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/raster/r.grow.distance/description.html
+ Author Date Id
Added: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c (rev 0)
+++ grass/trunk/raster/r.grow.distance/main.c 2008-07-22 15:55:12 UTC (rev 32213)
@@ -0,0 +1,279 @@
+ * MODULE: r.grow2
+ * AUTHOR(S): Marjorie Larson - CERL
+ * Glynn Clements
+ * PURPOSE: Generates a raster map layer with contiguous areas
+ * grown by one cell.
+ * COPYRIGHT: (C) 2006 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <unistd.h>
+#include <fcntl.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+static int nrows, ncols;
+static char *in_row;
+static CELL *old_x_row, *old_y_row;
+static CELL *new_x_row, *new_y_row;
+static DCELL *dist_row;
+static double (*distance)(double dx, double dy);
+static double xres, yres;
+#define MAX(a, b) ((a) > (b) ? (a) : (b))
+static double distance_euclidian_squared(double dx, double dy)
+ return dx * dx + dy * dy;
+static double distance_maximum(double dx, double dy)
+ return MAX(abs(dx), abs(dy));
+static double distance_manhattan(double dx, double dy)
+ return abs(dx) + abs(dy);
+void swap_rows(void)
+ CELL *temp;
+ temp = old_x_row; old_x_row = new_x_row; new_x_row = temp;
+ temp = old_y_row; old_y_row = new_y_row; new_y_row = temp;
+static void check(int col, int dx, int dy)
+ const CELL *xrow = dy ? old_x_row : new_x_row;
+ const CELL *yrow = dy ? old_y_row : new_y_row;
+ int x, y;
+ double d;
+ if (dist_row[col] == 0)
+ return;
+ if (col + dx < 0)
+ return;
+ if (col + dx >= ncols)
+ return;
+ if (G_is_c_null_value(&xrow[col + dx]))
+ return;
+ x = xrow[col + dx] + dx;
+ y = yrow[col + dx] + dy;
+ d = (*distance)(xres * x, yres * y);
+ if (!G_is_d_null_value(&dist_row[col]) && dist_row[col] < d)
+ return;
+ dist_row[col] = d;
+ new_x_row[col] = x;
+ new_y_row[col] = y;
+int main(int argc, char **argv)
+ struct GModule *module;
+ struct {
+ struct Option *in, *out, *met;
+ } opt;
+ char *in_name;
+ char *out_name;
+ char *mapset;
+ int in_fd;
+ int out_fd;
+ char *temp_name;
+ int temp_fd;
+ int row, col;
+ struct Colors colors;
+ struct FPRange range;
+ DCELL min, max;
+ DCELL *out_row;
+ struct Cell_head window;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("raster");
+ module->description =
+ _("Generates a raster map layer of distance to features in input layer.");
+ opt.in = G_define_standard_option(G_OPT_R_INPUT);
+ opt.out = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt.met = G_define_option();
+ opt.met->key = "metric";
+ opt.met->type = TYPE_STRING;
+ opt.met->required = NO;
+ opt.met->description = _("Metric");
+ opt.met->options = "euclidian,squared,maximum,manhattan";
+ opt.met->answer = "euclidian";
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ in_name = opt.in->answer;
+ out_name = opt.out->answer;
+ mapset = G_find_cell(in_name, "");
+ if (!mapset)
+ G_fatal_error(_("Raster map <%s> not found"), in_name);
+ if (strcmp(opt.met->answer, "euclidian") == 0)
+ distance = &distance_euclidian_squared;
+ else if (strcmp(opt.met->answer, "squared") == 0)
+ else if (strcmp(opt.met->answer, "maximum") == 0)
+ distance = &distance_maximum;
+ else if (strcmp(opt.met->answer, "manhattan") == 0)
+ distance = &distance_manhattan;
+ else
+ G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
+ in_fd = G_open_cell_old(in_name, mapset);
+ if (in_fd < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), in_name);
+ out_fd = G_open_raster_new(out_name, DCELL_TYPE);
+ if (out_fd < 0)
+ G_fatal_error(_("Unable to create raster map <%s>"), out_name);
+ temp_name = G_tempfile();
+ temp_fd = open(temp_name, O_RDWR|O_CREAT|O_EXCL, 0700);
+ if (temp_fd < 0)
+ G_fatal_error(_("Unable to create temporary file <%s>"), temp_name);
+ G_get_window(&window);
+ nrows = window.rows;
+ ncols = window.cols;
+ xres = window.ew_res;
+ yres = window.ns_res;
+ in_row = G_allocate_null_buf();
+ old_x_row = G_allocate_c_raster_buf();
+ old_y_row = G_allocate_c_raster_buf();
+ new_x_row = G_allocate_c_raster_buf();
+ new_y_row = G_allocate_c_raster_buf();
+ dist_row = G_allocate_d_raster_buf();
+ out_row = G_allocate_d_raster_buf();
+ else
+ out_row = dist_row;
+ G_set_c_null_value(old_x_row, ncols);
+ G_set_c_null_value(old_y_row, ncols);
+ for (row = 0; row < nrows; row++)
+ int irow = nrows - 1 - row;
+ G_percent(row, nrows, 2);
+ G_set_c_null_value(new_x_row, ncols);
+ G_set_c_null_value(new_y_row, ncols);
+ G_set_d_null_value(dist_row, ncols);
+ G_get_null_value_row(in_fd, in_row, irow);
+ for (col = 0; col < ncols; col++)
+ if (!in_row[col])
+ new_x_row[col] = 0;
+ new_y_row[col] = 0;
+ dist_row[col] = 0;
+ check(col, -1, 0);
+ for (col = ncols - 1; col >= 0; col--)
+ check(col, 1, 0);
+ check(col, -1, 1);
+ check(col, 0, 1);
+ check(col, 1, 1);
+ write(temp_fd, new_x_row, ncols * sizeof(CELL));
+ write(temp_fd, new_y_row, ncols * sizeof(CELL));
+ write(temp_fd, dist_row, ncols * sizeof(DCELL));
+ swap_rows();
+ G_close_cell(in_fd);
+ off_t offset = (off_t) irow * ncols * (2 * sizeof(CELL) + sizeof(DCELL));
+ lseek(temp_fd, offset, SEEK_SET);
+ read(temp_fd, new_x_row, ncols * sizeof(CELL));
+ read(temp_fd, new_y_row, ncols * sizeof(CELL));
+ read(temp_fd, dist_row, ncols * sizeof(DCELL));
+ check(col, -1, -1);
+ check(col, 0, -1);
+ check(col, 1, -1);
+ if (out_row != dist_row)
+ out_row[col] = sqrt(dist_row[col]);
+ G_put_d_raster_row(out_fd, out_row);
+ swap_rows();
+ close(temp_fd);
+ remove(temp_name);
+ G_close_cell(out_fd);
+ G_init_colors(&colors);
+ G_read_fp_range(out_name, G_mapset(), &range);
+ G_get_fp_range_min_max(&range, &min, &max);
+ G_make_fp_colors(&colors, "rainbow", min, max);
+ G_write_colors(out_name, G_mapset(), &colors);
+ return EXIT_SUCCESS;
