[GRASS-SVN] r32226 - in grass/trunk/gui/wxpython: gui_modules nviz
svn_grass at osgeo.org
Wed Jul 23 09:50:24 EDT 2008
Author: martinl
Date: 2008-07-23 09:50:23 -0400 (Wed, 23 Jul 2008)
New Revision: 32226
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/nviz/nviz.h
grass/trunk/gui/wxpython/nviz/nviz_types.i
grass/trunk/gui/wxpython/nviz/vector.cpp
nviz2/wxGUI: improved 2d vector points support
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-07-23 13:50:23 UTC (rev 32226)
@@ -163,12 +163,12 @@
def OnZoomToRaster(self, event):
pass
- def GetSelectedLayer(self, nviz=False, index=False):
+ def GetSelectedLayer(self, type='layer'):
"""Get selected layer from layer tree
- @param nviz get nviz properties instead
+ @param type 'item' / 'layer' / 'nviz'
- @return map layer instance
+ @return layer / map layer properties / nviz properties
@return None on failure
# get currently selected map layer
@@ -179,8 +179,11 @@
if not item.IsChecked():
return None
+ if type == 'item':
+ return item
try:
- if nviz:
+ if type == 'nviz':
layer = self.tree.GetPyData(item)[0]['nviz']
else:
layer = self.tree.GetPyData(item)[0]['maplayer']
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-23 13:50:23 UTC (rev 32226)
@@ -82,7 +82,7 @@
# list of loaded map layers
self.layers = {}
- for type in ('raster', 'vector'):
+ for type in ('raster', 'vlines', 'vpoints'):
self.layers[type] = {}
self.layers[type]['name'] = []
self.layers[type]['id'] = []
@@ -260,7 +260,7 @@
self.parent.onRenderGauge.SetValue(1)
wx.Yield()
self.nvizClass.Draw(False)
- elif render is False:
+ elif self.render is False:
self.nvizClass.Draw(True) # quick
else: # None -> reuse last rendered image
pass # TODO
@@ -291,13 +291,25 @@
self.nvizClass.EraseMap()
self.SwapBuffers()
- def IsLoaded(self, layer):
- """Check if layer (item) is already loaded"""
- data = self.tree.GetPyData(layer)[0]['nviz']
+ def IsLoaded(self, item):
+ """Check if layer (item) is already loaded
- if not data or not data.has_key('object'):
+ @param item layer item
+ layer = self.tree.GetPyData(item)[0]['maplayer']
+ data = self.tree.GetPyData(item)[0]['nviz']
+ if not data:
return 0
+ if layer.type == 'raster':
+ if not data['surface'].has_key('object'):
+ return 0
+ elif layer.type == 'vector':
+ if not data['vlines'].has_key('object') and \
+ not data['points'].has_key('object'):
+ return 0
return 1
def LoadDataLayers(self):
@@ -324,17 +336,13 @@
while(len(listOfItems) > 0):
item = listOfItems.pop()
type = self.tree.GetPyData(item)[0]['type']
- mapLayer = self.tree.GetPyData(item)[0]['maplayer']
if type == 'raster':
- id = self.LoadRaster(mapLayer)
+ self.LoadRaster(item)
elif type == 'vector':
- id = self.LoadVector(mapLayer)
- if type == 'raster' or type == 'vector':
- self.SetLayerData(item, id)
- self.UpdateLayerProperties(item)
+ self.LoadVector(item)
stop = time.time()
Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
@@ -359,7 +367,7 @@
self.SetSurfaceDefaultProp(data['surface'])
data['vector'] = {}
- for sec in ('lines', ):
+ for sec in ('lines', 'points'):
data['vector'][sec] = {}
self.SetVectorDefaultProp(data['vector'])
@@ -369,18 +377,18 @@
for sec in data.keys():
for sec1 in data[sec].keys():
for sec2 in data[sec][sec1].keys():
- self.update.append('%s:%s:%s' % (sec, sec1, sec2))
+ if sec2 != 'object':
+ self.update.append('%s:%s:%s' % (sec, sec1, sec2))
+ return data
- # associate with map object id
- if not data.has_key('object'):
- data['object'] = { 'id' : id,
- 'init' : False }
- if not data.has_key('view'):
- data['view'] = None
+ def LoadRaster(self, item):
+ """Load raster map and set surface attributes
- def LoadRaster(self, layer):
- """Load raster map -> surface"""
+ @param layer item
if layer.type != 'raster':
return
@@ -392,24 +400,46 @@
self.layers['raster']['name'].append(layer.name)
self.layers['raster']['id'].append(id)
+ # set default/workspace layer properties
+ data = self.SetLayerData(item, id)
+ # associate with map object id
+ data['surface']['object'] = { 'id' : id,
+ 'init' : False }
+ # update properties
+ self.UpdateLayerProperties(item)
# update tools window
- if hasattr(self.parent, "nvizToolWin"):
+ if hasattr(self.parent, "nvizToolWin") and \
+ item == self.GetSelectedLayer(type='item'):
toolWin = self.parent.nvizToolWin
win = toolWin.FindWindowById( \
toolWin.win['vector']['lines']['surface'])
win.SetItems(self.layers['raster']['name'])
+ toolWin.UpdatePage('surface')
+ toolWin.SetPage('surface')
return id
- def UnloadRaster(self, id):
- """Unload raster map"""
- idx = self.layers['raster']['id'].index(id)
- layerName = self.layers['raster']['name']
+ def UnloadRaster(self, item):
+ """Unload raster map
+ id = data['surface']['object']['id']
if self.nvizClass.UnloadSurface(id) == 0:
raise gcmd.NvizError(parent=self.parent,
- message=_("Unable to unload raster map <%s>" % layerName))
+ message=_("Unable to unload raster map <%s>" % layer.name))
+ data['surface'].pop('object')
+ idx = self.layers['raster']['id'].index(id)
del self.layers['raster']['name'][idx]
del self.layers['raster']['id'][idx]
@@ -425,7 +455,7 @@
toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
toolWin.page['surface']['id'] = -1
toolWin.page['settings']['id'] = 1
def GetSurfaceMode(self, mode, style, shade, string=False):
"""Determine surface draw mode"""
value = 0
@@ -525,69 +555,117 @@
'desc' : desc,
'all' : False }
- def LoadVector(self, layer, points=False):
- """Load vector map overlay
+ def LoadVector(self, item, vecType=None):
+ """Load vector map overlay (lines / points)
- @param layer map layer instance
- @param points if True load points instead of lines
if layer.type != 'vector':
return
- id = self.nvizClass.LoadVector(str(layer.name), points)
- print id, points
- if id < 0:
- raise gcmd.NvizError(parent=self.parent,
- message=_("Unable to load vector map <%s>" % layer.name))
+ if vecType is None:
+ vecType = []
+ for v in ('lines', 'points'):
+ if UserSettings.Get(group='nviz', key='vector',
+ subkey=[v, 'show']):
+ vecType.append(v)
- self.layers['vector']['name'].append(layer.name)
- self.layers['vector']['id'].append(id)
+ for type in vecType:
+ if type == 'lines':
+ id = self.nvizClass.LoadVector(str(layer.name), False)
+ else:
+ id = self.nvizClass.LoadVector(str(layer.name), True)
+ if id < 0:
+ raise gcmd.NvizError(parent=self.parent,
+ message=_("Unable to load vector map <%s>" % layer.name))
+ self.layers['v' + type]['name'].append(layer.name)
+ self.layers['v' + type]['id'].append(id)
+ data = self.SetLayerData(item, id)['vector']
+ data[type]['object'] = { 'id' : id,
+ 'init' : False }
+ # update tools window
+ if hasattr(self.parent, "nvizToolWin"):
+ toolWin = self.parent.nvizToolWin
+ toolWin.UpdatePage('vector')
+ toolWin.SetPage('vector')
return id
- def UnloadVector(self, id, points=False):
+ def UnloadVector(self, item, vecType=None):
"""Unload vector map overlay
- @param id data layer id
- @param points if True unload points layer instead of lines layer
+ @param vecType vector type (lines, points)
- ret = self.nvizClass.UnloadVector(id, points)
+ data = self.tree.GetPyData(item)[0]['nviz']['vector']
- idx = self.layers['vector']['id'].index(id)
- layerName = self.layers['vector']['name'][idx]
+ vecType = []
+ vecType.append(v)
- if ret == 0:
- message=_("Unable to unload vector map <%s>" % layerName))
+ for vtype in vecType:
+ if not data[vtype].has_key('object'):
+ continue
- del self.layers['vector']['name'][idx]
- del self.layers['vector']['id'][idx]
+ id = data[vtype]['object']['id']
+ if vtype == 'lines':
+ ret = self.nvizClass.UnloadVector(id, False)
+ else:
+ ret = self.nvizClass.UnloadVector(id, True)
+ if ret == 0:
+ message=_("Unable to unload vector map <%s>" % layer.name))
+ data[vtype].pop('object')
+ idx = self.layers['v' + vtype]['id'].index(id)
+ del self.layers['v' + vtype]['name'][idx]
+ del self.layers['v' + vtype]['id'][idx]
+ vecType is None:
+ # remove surface page
+ if toolWin.notebook.GetSelection() == toolWin.page['surface']['id']:
+ toolWin.notebook.RemovePage(toolWin.page['surface']['id'])
+ toolWin.page['surface']['id'] = -1
+ toolWin.page['settings']['id'] = 1
def SetVectorDefaultProp(self, data):
"""Set default vector properties"""
- if UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'show']):
- self.SetVectorLinesDefaultProp(data)
+ self.SetVectorLinesDefaultProp(data['lines'])
+ self.SetVectorPointsDefaultProp(data['points'])
- subkey=['points', 'show']):
- self.SetVectorPointsDefaultProp(data)
def SetVectorLinesDefaultProp(self, data):
"""Set default vector properties -- lines"""
# width
- data['lines']['width'] = \
- UserSettings.Get(group='nviz', key='vector',
- subkey=['lines', 'width'])
- self.update.append('vector:lines:width')
+ data['width'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['lines', 'width'])
# color
value = UserSettings.Get(group='nviz', key='vector',
subkey=['lines', 'color'])
color = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
- data['lines']['color'] = color
- self.update.append('vector:lines:color')
+ data['color'] = color
# mode
@@ -595,32 +673,60 @@
type = 'flat'
map = None
else:
- if len(self.layers['raster']['name']) > 1:
+ if len(self.layers['raster']['name']) > 0:
type = 'surface'
- map = self.layers['raster']['name']
+ map = self.layers['raster']['name'][0]
else:
type = 'flat'
map = None
- data['lines']['mode'] = {}
- data['lines']['mode']['type'] = type
+ data['mode'] = {}
+ data['mode']['type'] = type
if map:
- data['lines']['mode']['surface'] = map
- self.update.append('vector:lines:mode')
+ data['mode']['surface'] = map
# height
- data['lines']['height'] = UserSettings.Get(group='nviz', key='vector',
+ data['height'] = UserSettings.Get(group='nviz', key='vector',
subkey=['lines', 'height'])
- self.update.append('vector:lines:height')
+ if data.has_key('object'):
+ self.update.append('vector:lines:color')
+ self.update.append('vector:lines:width')
+ self.update.append('vector:lines:mode')
+ self.update.append('vector:lines:height')
def SetVectorPointsDefaultProp(self, data):
"""Set default vector properties -- points"""
# size
- # symbol
+ data['size'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'size'])
+ # width
+ subkey=['points', 'width'])
+ # marker
+ data['marker'] = UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker'])
# color
- pass
+ value = UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'color'])
+ color = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
+ # mode
+ data['mode'] = { 'type' : 'surface',
+ 'surface' : '' }
+ data['mode']['surface'] = self.layers['raster']['name'][0]
+ self.update.append('vector:points:size')
+ self.update.append('vector:points:width')
+ self.update.append('vector:points:marker')
+ self.update.append('vector:points:color')
def Reset(self):
"""Reset (unload data)"""
self.nvizClass.Reset()
@@ -667,21 +773,25 @@
if not layer:
mapLayer = self.GetSelectedLayer()
- data = self.GetSelectedLayer(nviz=True)
+ data = self.GetSelectedLayer(type='nviz')
else:
mapLayer = self.tree.GetPyData(layer)[0]['maplayer']
- id = data['object']['id']
if mapLayer.type == 'raster':
self.UpdateRasterProperties(id, data['surface'])
+ # -> initialized
+ data['surface']['object']['init'] = True
elif mapLayer.type == 'vector':
- self.UpdateVectorProperties(id, data['vector'])
+ for type in ('lines', 'points'):
+ if data['vector'][type].has_key('object'):
+ id = data['vector'][type]['object']['id']
+ self.UpdateVectorProperties(id, data['vector'], type)
+ # -> initialized
+ data['vector'][type]['object']['init'] = True
- # -> initialized
- data['object']['init'] = True
def UpdateRasterProperties(self, id, data):
"""Apply changes for surfaces"""
@@ -764,23 +874,31 @@
z = data['position']['z']
self.nvizClass.SetSurfacePosition(id, x, y, z)
self.update.remove('surface:position')
- def UpdateVectorProperties(self, id, data):
- """Apply changes for vector"""
- # lines
+ def UpdateVectorProperties(self, id, data, type):
+ """Update vector layer properties
+ @param id layer id
+ @param data properties
+ @param type lines/points
+ if type == 'points':
+ self.UpdateVectorPointsProperties(id, data[type])
+ else:
+ self.UpdateVectorLinesProperties(id, data[type])
+ def UpdateVectorLinesProperties(self, id, data):
+ """Apply changes for vector line layer"""
# mode
if 'vector:lines:color' in self.update or \
'vector:lines:width' in self.update or \
'vector:lines:mode' in self.update:
- width = data['lines']['width']
- color = data['lines']['color']
- if data['lines']['mode']['type'] == 'flat':
+ width = data['width']
+ color = data['color']
+ if data['mode']['type'] == 'flat':
flat = True
- if data['lines'].has_key('surface'):
- data['lines'].pop('surface')
+ if data.has_key('surface'):
+ data.pop('surface')
else:
flat = False
if not 'vector:lines:surface' in self.update:
@@ -796,18 +914,57 @@
self.update.remove('vector:lines:mode')
# height
if 'vector:lines:height' in self.update:
- self.nvizClass.SetVectorHeight(id,
- data['lines']['height'])
+ self.nvizClass.SetVectorLineHeight(id,
+ data['height'])
self.update.remove('vector:lines:height')
# surface
if 'vector:lines:surface' in self.update:
- idx = self.layers['raster']['name'].index(data['lines']['mode']['surface'])
+ idx = self.layers['raster']['name'].index(data['mode']['surface'])
if idx > -1:
- self.nvizClass.SetVectorSurface(id,
- self.layers['raster']['id'][idx])
+ self.nvizClass.SetVectorLineSurface(id,
+ self.layers['raster']['id'][idx])
self.update.remove('vector:lines:surface')
+ def UpdateVectorPointsProperties(self, id, data):
+ """Apply changes for vector point layer"""
+ if 'vector:points:size' in self.update or \
+ 'vector:points:width' in self.update or \
+ 'vector:points:marker' in self.update or \
+ 'vector:points:color' in self.update:
+ ret = self.nvizClass.SetVectorPointMode(id, data['color'],
+ data['width'], float(data['size']),
+ data['marker'] + 1)
+ error = None
+ if ret == -1:
+ error = _("Vector point layer not found (id=%d)") % id
+ elif ret == -2:
+ error = _("Unable to set data layer properties (id=%d)") % id
+ if error:
+ message=_("Setting data layer properties failed.\n\n%s") % error)
+ for prop in ('size', 'width', 'marker', 'color'):
+ if 'vector:points:%s' % prop in self.update:
+ self.update.remove('vector:points:%s' % prop)
+ # height
+ if 'vector:points:height' in self.update:
+ self.nvizClass.SetVectorPointHeight(id,
+ data['height'])
+ self.update.remove('vector:points:height')
+ # surface
+ if 'vector:points:surface' in self.update:
+ if idx > -1:
+ self.nvizClass.SetVectorPointSurface(id,
+ self.update.remove('vector:points:surface')
class NvizToolWindow(wx.Frame):
"""Experimental window for Nviz tools
@@ -1351,24 +1508,25 @@
gridSizer.Add(item=display, flag=wx.ALIGN_CENTER_VERTICAL,
pos=(0, 7))
+ # hight
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Hight above surface:")),
+ pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL,
+ span=(1, 2))
surface = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(250, -1),
style=wx.CB_SIMPLE | wx.CB_READONLY,
choices=[])
surface.Bind(wx.EVT_COMBOBOX, self.OnVectorSurface)
self.win['vector']['lines']['surface'] = surface.GetId()
gridSizer.Add(item=surface,
- pos=(1, 0), span=(1, 8),
+ pos=(1, 2), span=(1, 6),
flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
- # high
- gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Hight above surface:")),
- pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL,
- span=(1, 2))
self.CreateControl(panel, dict=self.win['vector']['lines'], name='height', size=300,
range=(0, 1000),
- bind=(self.OnVectorHeight, self.OnVectorHeight, self.OnVectorHeight))
+ bind=(self.OnVectorHeight, self.OnVectorHeightFull, self.OnVectorHeightSpin))
gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['slider']),
pos=(2, 2), span=(1, 6))
gridSizer.Add(item=self.FindWindowById(self.win['vector']['lines']['height']['spin']),
@@ -1409,36 +1567,79 @@
pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
isize = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=100,
+ initial=1,
min=1,
max=1e6)
+ isize.SetName('value')
self.win['vector']['points']['size'] = isize.GetId()
+ isize.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
gridSizer.Add(item=isize, pos=(0, 1),
+ # icon width
+ label=_("width:")),
+ pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=1,
+ min=1,
+ max=1e6)
+ iwidth.SetName('value')
+ self.win['vector']['points']['width'] = iwidth.GetId()
+ iwidth.Bind(wx.EVT_SPINCTRL, self.OnVectorPoints)
+ gridSizer.Add(item=iwidth, pos=(0, 3),
+ flag=wx.ALIGN_CENTER_VERTICAL)
# icon symbol
label=_("symbol:")),
- pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
isym = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices = [_("coarse"),
- _("fine"),
- _("both")])
+ choices=UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'marker'], internal=True))
isym.SetName("selection")
- self.win['vector']['points']['symbol'] = isym.GetId()
+ self.win['vector']['points']['marker'] = isym.GetId()
+ isym.Bind(wx.EVT_CHOICE, self.OnVectorPoints)
gridSizer.Add(item=isym, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 3))
+ pos=(0, 5))
- # icon symbol
+ # icon color
label=_("color:")),
- pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+ pos=(0, 6), flag=wx.ALIGN_CENTER_VERTICAL)
icolor = csel.ColourSelect(panel, id=wx.ID_ANY)
icolor.SetName("color")
self.win['vector']['points']['color'] = icolor.GetId()
+ icolor.Bind(csel.EVT_COLOURSELECT, self.OnVectorPoints)
gridSizer.Add(item=icolor, flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 5))
+ pos=(0, 7))
+ # high
+ span=(1, 2))
+ surface = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(250, -1),
+ style=wx.CB_SIMPLE | wx.CB_READONLY,
+ choices=[])
+ surface.Bind(wx.EVT_COMBOBOX, self.OnVectorSurface)
+ self.win['vector']['points']['surface'] = surface.GetId()
+ gridSizer.Add(item=surface,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
+ self.CreateControl(panel, dict=self.win['vector']['points'], name='height', size=300,
+ range=(0, 1000),
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['slider']),
+ pos=(2, 2), span=(1, 6))
+ gridSizer.Add(item=self.FindWindowById(self.win['vector']['points']['height']['spin']),
+ pos=(3, 4),
+ flag=wx.ALIGN_CENTER)
boxSizer.Add(item=gridSizer, proportion=1,
flag=wx.ALL | wx.EXPAND, border=3)
pageSizer.Add(item=boxSizer, proportion=0,
@@ -1710,12 +1911,12 @@
showPoints.SetValue(UserSettings.Get(group='nviz', key='vector',
subkey=['points', 'show']))
self.win['settings']['vector']['points']['show'] = showPoints.GetId()
- gridSizer.Add(item=showPoints, pos=(row, 0))
+ gridSizer.Add(item=showPoints, pos=(row, 0), span=(1, 8))
# icon size
row += 1
- label=_("Icon size:")),
+ label=_("Size:")),
pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
@@ -1728,31 +1929,47 @@
gridSizer.Add(item=isize, pos=(row, 1),
+ # icon width
+ label=_("Witdh:")),
+ pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ initial=2,
+ min=1,
+ max=1e6)
+ self.win['settings']['vector']['points']['width'] = isize.GetId()
+ iwidth.SetValue(UserSettings.Get(group='nviz', key='vector',
+ subkey=['points', 'width']))
+ gridSizer.Add(item=iwidth, pos=(row, 3),
# icon symbol
- label=_("symbol:")),
- pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+ label=_("Marker:")),
+ pos=(row, 4), flag=wx.ALIGN_CENTER_VERTICAL)
- subkey=['points', 'icon'], internal=True))
- self.win['settings']['vector']['points']['symbol'] = isym.GetId()
+ self.win['settings']['vector']['points']['marker'] = isym.GetId()
isym.SetSelection(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'symbol']))
+ subkey=['points', 'marker']))
- pos=(row, 3))
+ pos=(row, 5))
# icon color
- label=_("color:")),
- pos=(row, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+ label=_("Color:")),
+ pos=(row, 6), flag=wx.ALIGN_CENTER_VERTICAL)
self.win['settings']['vector']['points']['color'] = icolor.GetId()
icolor.SetColour(UserSettings.Get(group='nviz', key='vector',
subkey=['points', 'color']))
- pos=(row, 5))
+ pos=(row, 7))
@@ -1973,7 +2190,6 @@
for subgroup, key in settings.iteritems(): # view, surface, vector...
for subkey, value in key.iteritems():
for subvalue in value.keys():
- # print subgroup, subkey, subvalue
try: # TODO
win = self.FindWindowById(self.win['settings'][subgroup][subkey][subvalue])
except:
@@ -2055,7 +2271,7 @@
self.SetSurfaceUseMap(attrb, useMap)
self.mapWindow.update.append('surface:attribute:%s' % attrb)
- data = self.mapWindow.GetSelectedLayer(nviz=True)
+ data = self.mapWindow.GetSelectedLayer(type='nviz')
data['surface']['attribute'][attrb] = { 'map' : useMap,
'value' : str(value),
@@ -2117,7 +2333,7 @@
if not self.pageChanging:
data['surface']['attribute'][attrb] = { 'map' : map,
@@ -2139,7 +2355,7 @@
fine = self.FindWindowById(self.win['surface']['draw']['res-fine']).GetValue()
self.mapWindow.update.append('surface:draw:resolution')
data['surface']['draw']['resolution'] = { 'coarse' : coarse,
'fine' : fine,
'all' : all }
@@ -2175,7 +2391,7 @@
value, desc = self.SetSurfaceMode()
self.mapWindow.update.append('surface:draw:mode')
data['surface']['draw']['mode'] = { 'value' : value,
'all' : False,
'desc' : desc }
@@ -2204,7 +2420,7 @@
self.SetSurfaceWireColor(event.GetValue())
self.mapWindow.update.append('surface:draw:wire-color')
data['surface']['draw']['wire-color'] = { 'value' : value,
'all' : all }
self.mapWindow.UpdateLayerProperties()
@@ -2215,7 +2431,7 @@
def OnSurfaceAxis(self, event):
"""Surface position, axis changed"""
mapLayer = self.mapWindow.GetSelectedLayer()
axis = self.FindWindowById(self.win['surface']['position']['axis']).GetSelection()
@@ -2239,7 +2455,7 @@
value = event.GetInt()
x, y, z = self.mapWindow.nvizClass.GetSurfacePosition(id)
@@ -2251,7 +2467,7 @@
z = value
self.mapWindow.update.append('surface:position')
data['surface']['position']['x'] = x
data['surface']['position']['y'] = y
data['surface']['position']['z'] = z
@@ -2300,23 +2516,23 @@
return
checked = event.IsChecked()
- mapLayer = self.mapWindow.GetSelectedLayer()
+ item = self.mapWindow.GetSelectedLayer(type='item')
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']
+ if checked:
+ self.mapWindow.LoadVector(item, (vecType,))
+ else:
+ self.mapWindow.UnloadVector(item, (vecType,))
- if vecType == 'lines':
- if checked:
- self.mapWindow.LoadVector(mapLayer)
- else:
- self.mapWindow.UnloadVector(id)
- else: # points
- if checked:
- self.mapWindow.LoadVector(mapLayer, points=True)
- else:
- self.mapWindow.UnloadVector(id, points=True)
self.UpdateVectorShow(vecType, checked)
+ if checked:
+ id = data[vecType]['object']['id']
+ self.mapWindow.SetLayerData(item, id)
+ self.mapWindow.UpdateLayerProperties(item)
if self.parent.autoRender.IsChecked():
self.mapWindow.Refresh(False)
@@ -2331,7 +2547,7 @@
self.FindWindowById(self.win['vector']['lines']['surface']).Enable(True)
# set first found surface
data['vector']['lines']['mode']['surface'] = self.mapWindow.layers['raster']['name'][0]
self.FindWindowById(self.win['vector']['lines']['surface']).SetStringSelection( \
self.mapWindow.layers['raster']['name'][0])
@@ -2360,7 +2576,7 @@
self.mapWindow.update.append('vector:lines:width')
self.mapWindow.update.append('vector:lines:color')
self.mapWindow.update.append('vector:lines:mode')
data['vector']['lines']['width'] = width
data['vector']['lines']['color'] = color
data['vector']['lines']['mode'] = mode
@@ -2372,41 +2588,91 @@
def OnVectorHeight(self, event):
+ id = event.GetId()
+ if id == self.win['vector']['lines']['height']['spin'] or \
+ id == self.win['vector']['lines']['height']['slider']:
+ vtype = 'lines'
+ else:
+ vtype = 'points'
if type(event) == type(wx.ScrollEvent()):
# slider
- win = self.FindWindowById(self.win['vector']['lines']['height']['spin'])
+ win = self.FindWindowById(self.win['vector'][vtype]['height']['spin'])
else:
# spin
- win = self.FindWindowById(self.win['vector']['lines']['height']['slider'])
+ win = self.FindWindowById(self.win['vector'][vtype]['height']['slider'])
win.SetValue(value)
- self.mapWindow.update.append('vector:lines:height')
+ self.mapWindow.update.append('vector:%s:height' % vtype)
- data['vector']['lines']['height'] = value
+ data['vector'][vtype]['height'] = value
- if self.parent.autoRender.IsChecked():
- self.mapWindow.Refresh(False)
+ self.mapWindow.render = False
+ self.mapWindow.Refresh(False)
+ def OnVectorHeightFull(self, event):
+ """Vector height changed, render in full resolution"""
+ self.mapWindow.render = True
+ def OnVectorHeightSpin(self, event):
+ # TODO: use step value instead
+ self.OnVectorHeight(event)
+ self.OnVectorHeightFull(None)
def OnVectorSurface(self, event):
- """Reference surface for vector map"""
- self.mapWindow.update.append('vector:lines:surface')
+ """Reference surface for vector map (lines/points)"""
+ if id == self.win['vector']['lines']['surface']:
+ vtype = 'lines'
+ else:
+ vtype = 'points'
+ self.mapWindow.update.append('vector:%s:surface' % vtype)
- data['vector']['lines']['mode']['surface'] = event.GetValue()
+ data['vector'][vtype]['mode']['surface'] = event.GetValue()
+ def OnVectorPoints(self, event):
+ """Set vector points mode, apply changes if auto-rendering is enabled"""
+ size = self.FindWindowById(self.win['vector']['points']['size']).GetValue()
+ width = self.FindWindowById(self.win['vector']['points']['width']).GetValue()
+ color = self.FindWindowById(self.win['vector']['points']['color']).GetColour()
+ color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
+ marker = self.FindWindowById(self.win['vector']['points']['marker']).GetSelection()
+ self.mapWindow.update.append('vector:points:size')
+ self.mapWindow.update.append('vector:points:width')
+ self.mapWindow.update.append('vector:points:color')
+ self.mapWindow.update.append('vector:points:marker')
+ data = self.mapWindow.GetSelectedLayer(type='nviz')['vector']['points']
+ data['size'] = size
+ data['width'] = width
+ data['marker'] = marker
+ self.mapWindow.UpdateLayerProperties()
+ if self.parent.autoRender.IsChecked():
def UpdatePage(self, pageId):
"""Update dialog (selected page)"""
self.pageChanging = True
layer = self.mapWindow.GetSelectedLayer()
if pageId == 'view':
max = self.mapWindow.view['z-exag']['value'] * 10
for control in ('spin', 'slider'):
@@ -2531,19 +2797,38 @@
color = self.FindWindowById(self.win['vector']['lines']['color'])
color.SetValue(map(int, data['lines']['color'].split(':')))
- display = self.FindWindowById(self.win['vector']['lines']['flat'])
- display.SetSelection(1)
- else:
- display.SetSelection(0)
- surface = self.FindWindowById(self.win['vector']['lines']['surface'])
- if len(surface.GetItems()) > 0:
- surface.SetSelection(0)
+ for vtype in ('lines', 'points'):
+ display = self.FindWindowById(self.win['vector']['lines']['flat'])
+ if data[vtype]['mode']['type'] == 'flat':
+ display.SetSelection(1)
+ else:
+ display.SetSelection(0)
+ if data[vtype]['mode']['type'] == 'surface' and \
+ len(self.mapWindow.layers['raster']['name']) > 0:
+ surface = self.FindWindowById(self.win['vector'][vtype]['surface'])
+ surface.SetItems(self.mapWindow.layers['raster']['name'])
+ surface.SetStringSelection(data[vtype]['mode']['surface'])
for type in ('slider', 'spin'):
win = self.FindWindowById(self.win['vector']['lines']['height'][type])
win.SetValue(data['lines']['height'])
+ # points
+ win = self.FindWindowById(self.win['vector']['points'][prop])
+ name = win.GetName()
+ if name == 'selection':
+ win.SetSelection(data['points'][prop])
+ elif name == 'color':
+ color = map(int, data['points'][prop].split(':'))
+ win.SetValue(color)
+ else:
+ win.SetValue(data['points'][prop])
def SetPage(self, name):
"""Get named page"""
self.notebook.SetSelection(self.page[name]['id'])
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-23 13:50:23 UTC (rev 32226)
@@ -397,8 +397,10 @@
'points' : {
'show' : False,
'size' : 100,
- 'symbol' : 1,
+ 'width' : 2,
+ 'marker' : 2,
'color' : (0, 0, 255, 255), # blue
+ 'height' : 0,
'settings': {
@@ -461,14 +463,16 @@
self.internalSettings['nviz']['view']['height']['value'] = -1
self.internalSettings['nviz']['vector'] = {}
self.internalSettings['nviz']['vector']['points'] = {}
- self.internalSettings['nviz']['vector']['points']['icon'] = ('x',
- _("sphere"),
- _("diamond"),
- _("cube"),
- _("box"),
- _("gyro"),
- _("aster"),
- _("histogram"))
+ self.internalSettings['nviz']['vector']['points']['marker'] = ("x",
+ _("box"),
+ _("sphere"),
+ _("cube"),
+ _("diamond"),
+ _("dtree"),
+ _("ctree"),
+ _("aster"),
+ _("gyro"),
+ _("histogram"))
def ReadSettingsFile(self, settings=None):
"""Reads settings file (mapset, location, gisdbase)"""
if settings is None:
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-07-23 13:50:23 UTC (rev 32226)
@@ -829,43 +829,32 @@
# nviz - load/unload data layer
mapLayer = self.GetPyData(item)[0]['maplayer']
- busy = wx.BusyInfo(message=_("Please wait, updating data..."),
- parent=self.mapdisplay)
+ self.mapdisplay.SetStatusText(_("Please wait, updating data..."), 0)
- wx.Yield()
if checked: # enable
- id = -1
- id = self.mapdisplay.MapWindow.LoadRaster(mapLayer)
+ self.mapdisplay.MapWindow.LoadRaster(item)
- id = self.mapdisplay.MapWindow.LoadVector(mapLayer)
+ self.mapdisplay.MapWindow.LoadVector(item)
- if id > 0:
- self.mapdisplay.MapWindow.SetLayerData(item, id)
- self.mapdisplay.MapWindow.UpdateLayerProperties(item)
else: # disable
data = self.GetPyData(item)[0]['nviz']
- self.mapdisplay.MapWindow.UnloadRaster(id)
+ self.mapdisplay.MapWindow.UnloadRaster(item)
- self.mapdisplay.MapWindow.UnloadVector(id)
+ self.mapdisplay.MapWindow.UnloadVector(item)
- toolWin = self.parent.nvizToolWin
+ if hasattr(self.mapdisplay, "nvizToolWin"):
+ toolWin = self.mapdisplay.nvizToolWin
# remove vector page
if toolWin.notebook.GetSelection() == toolWin.page['vector']['id']:
toolWin.notebook.RemovePage(toolWin.page['vector']['id'])
toolWin.page['vector']['id'] = -1
- data.pop('object')
- data.pop('view')
+ self.mapdisplay.SetStatusText("", 0)
- busy.Destroy()
# redraw map if auto-rendering is enabled
if self.mapdisplay.autoRender.GetValue():
self.mapdisplay.OnRender(None)
@@ -1169,14 +1158,8 @@
id = -1
if not mapWin.IsLoaded(layer):
- id = mapWin.LoadRaster(mapLayer)
- if id > 0:
- self.mapdisplay.MapWindow.SetLayerData(layer, id)
- self.mapdisplay.MapWindow.UpdateLayerProperties(layer)
+ mapWin.LoadRaster(layer)
- self.mapdisplay.nvizToolWin.UpdatePage('surface')
- self.mapdisplay.nvizToolWin.SetPage('surface')
id = mapWin.LoadVector(mapLayer)
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/nviz/nviz.h 2008-07-23 13:50:23 UTC (rev 32226)
@@ -85,8 +85,11 @@
/* vector */
int SetVectorLineMode(int, const char *, int, int);
- int SetVectorHeight(int, float);
- int SetVectorSurface(int, int);
+ int SetVectorLineHeight(int, float);
+ int SetVectorLineSurface(int, int);
+ int SetVectorPointMode(int, const char*, int, float, int);
+ int SetVectorPointHeight(int, float);
+ int SetVectorPointSurface(int, int);
#endif /* WXNVIZ_H */
Modified: grass/trunk/gui/wxpython/nviz/nviz_types.i
--- grass/trunk/gui/wxpython/nviz/nviz_types.i 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/nviz/nviz_types.i 2008-07-23 13:50:23 UTC (rev 32226)
@@ -36,4 +36,14 @@
#define DM_GRID_WIRE 0x00000400
#define DM_GRID_SURF 0x00000800
-#define WC_COLOR_ATT 0xFF000000
+/* site markers */
+#define ST_X 1
+#define ST_BOX 2
+#define ST_SPHERE 3
+#define ST_CUBE 4
+#define ST_DIAMOND 5
+#define ST_DEC_TREE 6
+#define ST_CON_TREE 7
+#define ST_ASTER 8
+#define ST_GYRO 9
+#define ST_HISTOGRAM 10
Modified: grass/trunk/gui/wxpython/nviz/vector.cpp
--- grass/trunk/gui/wxpython/nviz/vector.cpp 2008-07-23 12:46:15 UTC (rev 32225)
+++ grass/trunk/gui/wxpython/nviz/vector.cpp 2008-07-23 13:50:23 UTC (rev 32226)
@@ -19,12 +19,16 @@
#include "nviz.h"
- \brief Set mode of vector overlay
+ \brief Set mode of vector line overlay
\param id vector id
\param color_str color string
\param width line width
- \param flat
+ \param flat display flat or on surface
+ \return -1 vector set not found
+ \return -2 on failure
+ \return 1 on success
int Nviz::SetVectorLineMode(int id, const char *color_str,
int width, int flat)
@@ -32,7 +36,7 @@
int color;
if(!GV_vect_exists(id))
- return 0;
+ return -1;
G_debug(1, "Nviz::SetVectorMode(): id=%d, color=%s, width=%d, flat=%d",
id, color_str, width, flat);
@@ -42,26 +46,26 @@
/* use memory by default */
if (GV_set_vectmode(id, 1, color, width, flat) < 0)
- return 0;
+ return -2;
return 1;
- \brief Set vector height above surface
+ \brief Set vector height above surface (lines)
\param id vector set id
\param height
- \return 0 on failure
-int Nviz::SetVectorHeight(int id, float height)
+int Nviz::SetVectorLineHeight(int id, float height)
- return 0;
+ return -1;
- G_debug(1, "Nviz::SetVectorHeight(): id=%d, height=%f",
+ G_debug(1, "Nviz::SetVectorLineHeight(): id=%d, height=%f",
id, height);
GV_set_trans(id, 0.0, 0.0, height);
@@ -70,21 +74,105 @@
- \brief Set reference surface of vector set
+ \brief Set reference surface of vector set (lines)
\param surf_id surface id
+ \return -2 surface not found
+ \return -3 on failure
-int Nviz::SetVectorSurface(int id, int surf_id)
+int Nviz::SetVectorLineSurface(int id, int surf_id)
- if (!GS_surf_exists(surf_id) || !GV_vect_exists(id))
- return 0;
+ if (!GV_vect_exists(id))
+ return -1;
+ if (!GS_surf_exists(surf_id))
+ return -2;
if (GV_select_surf(id, surf_id) < 0)
- return 0;
+ return -3;
return 1;
+ \brief Set mode of vector point overlay
+ \param id vector id
+ \param color_str color string
+ \param width line width
+ \param flat
+int Nviz::SetVectorPointMode(int id, const char *color_str,
+ int width, float size, int marker)
+ int color;
+ if(!GP_site_exists(id))
+ return -1;
+ G_debug(1, "Nviz::SetVectorPointMode(): id=%d, color=%s, "
+ "width=%d, size=%f, marker=%d",
+ id, color_str, width, size, marker);
+ color = Nviz_color_from_str(color_str);
+ if (GP_set_sitemode(id, ST_ATT_NONE,
+ color, width, size, marker) < 0)
+ return -2;
+ return 1;
+ \brief Set vector height above surface (points)
+ \param id vector set id
+ \param height
+int Nviz::SetVectorPointHeight(int id, float height)
+ return -1;
+ G_debug(1, "Nviz::SetVectorPointHeight(): id=%d, height=%f",
+ id, height);
+ GP_set_trans(id, 0.0, 0.0, height);
+ return 1;
+ \brief Set reference surface of vector set (points)
+ \param surf_id surface id
+int Nviz::SetVectorPointSurface(int id, int surf_id)
+ if (!GP_site_exists(id))
+ return -1;
+ return -2;
+ if (GP_select_surf(id, surf_id) < 0)
+ return -3;
+ return 1;
