[GRASS-SVN] r32275 - grass-addons/gipe/i.eb.h_SEBAL95
svn_grass at osgeo.org
Thu Jul 24 21:03:00 EDT 2008
Author: ychemin
Date: 2008-07-24 21:02:59 -0400 (Thu, 24 Jul 2008)
New Revision: 32275
Added:
grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
Removed:
grass-addons/gipe/i.eb.h_SEBAL95/sensi_h.c
grass-addons/gipe/i.eb.h_SEBAL95/main.c
Added more control to SEBAL parameters
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-07-25 00:30:03 UTC (rev 32274)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-07-25 01:02:59 UTC (rev 32275)
@@ -26,7 +26,8 @@
/*#include <omp.h>*/
-double sensi_h( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
+double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
+double sensi_h_noz0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double dtair0, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
int main(int argc, char *argv[])
@@ -35,7 +36,8 @@
/* buffer for in out raster */
void *inrast_T,*inrast_ndvi,*inrast_u2,*inrast_dem;
- void *inrast_Rn,*inrast_g0,*inrast_albedo;
+ void *inrast_Rn,*inrast_g0,*inrast_albedo,*inrast_dT;
+ void *inrast_z0m;
DCELL *outrast;
int nrows, ncols;
@@ -44,18 +46,22 @@
int row_dry, col_dry;
double m_row_wet, m_col_wet;
double m_row_dry, m_col_dry;
- int infd_T,infd_ndvi,infd_u2,infd_dem,infd_Rn,infd_g0,infd_albedo;
+ int infd_T,infd_ndvi,infd_u2,infd_dem;
+ int infd_Rn,infd_g0,infd_albedo,infd_dT;
+ int infd_z0m;
int outfd;
char *mapset_T,*mapset_ndvi,*mapset_u2,*mapset_dem;
- char *mapset_Rn,*mapset_g0,*mapset_albedo;
- char *T, *ndvi, *u2, *dem, *Rn, *g0, *albedo;
+ char *mapset_Rn,*mapset_g0,*mapset_albedo,*mapset_dT;
+ char *mapset_z0m;
+ char *T, *ndvi, *u2, *dem, *Rn, *g0, *albedo, *dT, *z0m;
char *h0;
struct History history;
struct GModule *module;
struct Option *input_T, *input_ndvi, *input_u2, *input_dem;
- struct Option *input_Rn, *input_g0, *input_albedo, *output;
+ struct Option *input_Rn, *input_g0, *input_albedo, *input_dT;
+ struct Option *input_z0m, *output;
struct Option *input_row_wet, *input_col_wet;
struct Option *input_row_dry, *input_col_dry;
struct Option *input_iter;
@@ -68,6 +74,8 @@
RASTER_MAP_TYPE data_type_Rn;
RASTER_MAP_TYPE data_type_g0;
RASTER_MAP_TYPE data_type_albedo;
+ RASTER_MAP_TYPE data_type_dT;
+ RASTER_MAP_TYPE data_type_z0m;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
int iteration = 10; /*SEBAL95 loop number*/
@@ -92,6 +100,18 @@
input_T->key = "T";
input_T->description = _("Name of Surface Skin Temperature input map [K]");
+ input_dT = G_define_standard_option(G_OPT_R_INPUT);
+ input_dT->key = "dT";
+ input_dT->required = NO;
+ input_dT->description = _("Name of Surface Skin Temperature difference (soil-air/canopy) input map [K]");
+ input_dT->guisection = _("Optional");
+ input_z0m = G_define_standard_option(G_OPT_R_INPUT);
+ input_z0m->key = "z0m";
+ input_z0m->required = NO;
+ input_z0m->description = _("Name of aerodynamic resistance to heat momentum [s/m]");
+ input_z0m->guisection = _("Optional");
input_u2 = G_define_standard_option(G_OPT_R_INPUT);
input_u2->key = "u2m";
input_u2->description = _("Name of Wind Speed input map [m/s]");
@@ -182,12 +202,17 @@
/* get entered parameters */
T = input_T->answer;
+ if(input_dT->answer)
+ dT = input_dT->answer;
+ if(input_z0m->answer)
+ z0m = input_z0m->answer;
u2 = input_u2->answer;
dem = input_dem->answer;
ndvi = input_ndvi->answer;
Rn = input_Rn->answer;
g0 = input_g0->answer;
albedo = input_albedo->answer;
h0 = output->answer;
if(input_iter->answer){
@@ -212,6 +237,16 @@
mapset_T = G_find_cell2 (T, "");
if (mapset_T == NULL)
G_fatal_error (_("cell file [%s] not found"), T);
+ if(input_dT->answer){
+ mapset_dT = G_find_cell2 (dT, "");
+ if (mapset_dT == NULL)
+ G_fatal_error (_("cell file [%s] not found"), dT);
+ if(input_z0m->answer){
+ mapset_z0m = G_find_cell2 (z0m, "");
+ if (mapset_z0m == NULL)
+ G_fatal_error (_("cell file [%s] not found"), z0m);
mapset_u2 = G_find_cell2 (u2, "");
if (mapset_u2 == NULL)
G_fatal_error (_("cell file [%s] not found"), u2);
@@ -237,6 +272,12 @@
/* determine the input map type (CELL/FCELL/DCELL) */
data_type_T = G_raster_map_type(T, mapset_T);
+ data_type_dT = G_raster_map_type(dT, mapset_dT);
+ data_type_z0m = G_raster_map_type(z0m, mapset_z0m);
data_type_u2 = G_raster_map_type(u2, mapset_u2);
data_type_dem = G_raster_map_type(dem, mapset_dem);
data_type_ndvi = G_raster_map_type(ndvi, mapset_ndvi);
@@ -246,6 +287,14 @@
if ( (infd_T = G_open_cell_old (T, mapset_T)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"), T);
+ if ( (infd_dT = G_open_cell_old (dT, mapset_dT)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), dT);
+ if ( (infd_z0m = G_open_cell_old (z0m, mapset_z0m)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), z0m);
if ( (infd_u2 = G_open_cell_old (u2, mapset_u2)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),u2);
if ( (infd_dem = G_open_cell_old (dem, mapset_dem)) < 0)
@@ -261,6 +310,14 @@
if (G_get_cellhd (T, mapset_T, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), T);
+ if (G_get_cellhd (dT, mapset_dT, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), dT);
+ if (G_get_cellhd (z0m, mapset_z0m, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), z0m);
if (G_get_cellhd (u2, mapset_u2, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), u2);
if (G_get_cellhd (dem, mapset_dem, &cellhd) < 0)
@@ -276,6 +333,12 @@
/* Allocate input buffer */
inrast_T = G_allocate_raster_buf(data_type_T);
+ inrast_dT = G_allocate_raster_buf(data_type_dT);
+ inrast_z0m = G_allocate_raster_buf(data_type_z0m);
inrast_u2 = G_allocate_raster_buf(data_type_u2);
inrast_dem = G_allocate_raster_buf(data_type_dem);
inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
@@ -799,6 +862,8 @@
DCELL d_dem;
DCELL d_t0dem;
DCELL d_u2m; /* Input raster */
+ DCELL d_dT; /* Optional Input raster */
+ DCELL d_z0m; /* Optional Input raster */
DCELL d; /* Output pixel */
G_percent(row,nrows,2);
/* read a line input maps into buffers*/
@@ -806,6 +871,14 @@
G_fatal_error(_("Could not read from <%s>"),albedo);
if(G_get_raster_row(infd_T,inrast_T,row,data_type_T)<0)
G_fatal_error(_("Could not read from <%s>"),T);
+ if(G_get_raster_row(infd_dT,inrast_dT,row,data_type_dT)<0)
+ G_fatal_error(_("Could not read from <%s>"),dT);
+ if(G_get_raster_row(infd_z0m,inrast_z0m,row,data_type_z0m)<0)
+ G_fatal_error(_("Could not read from <%s>"),z0m);
if(G_get_raster_row(infd_u2,inrast_u2,row,data_type_u2) < 0)
G_fatal_error(_("Could not read from <%s>"),u2);
if(G_get_raster_row(infd_dem,inrast_dem,row,data_type_dem)<0)
@@ -829,6 +902,32 @@
d_albedo = (double) ((DCELL *) inrast_albedo)[col];
break;
+ switch(data_type_dT){
+ case CELL_TYPE:
+ d_dT = (double) ((CELL *) inrast_dT)[col];
+ break;
+ case FCELL_TYPE:
+ d_dT = (double) ((FCELL *) inrast_dT)[col];
+ break;
+ case DCELL_TYPE:
+ d_dT = (double) ((DCELL *) inrast_dT)[col];
+ break;
+ switch(data_type_z0m){
+ case CELL_TYPE:
+ d_z0m = (double) ((CELL *) inrast_z0m)[col];
+ break;
+ case FCELL_TYPE:
+ d_z0m = (double) ((FCELL *) inrast_z0m)[col];
+ break;
+ case DCELL_TYPE:
+ d_z0m = (double) ((DCELL *) inrast_z0m)[col];
+ break;
switch(data_type_T){
case CELL_TYPE:
d_tempk = (double) ((CELL *) inrast_T)[col];
@@ -901,6 +1000,8 @@
G_is_d_null_value(&d_ndvi) ||
G_is_d_null_value(&d_Rn) ||
G_is_d_null_value(&d_g0) ||
+ (input_dT->answer&&G_is_d_null_value(&d_dT)) ||
+ (input_z0m->answer&&G_is_d_null_value(&d_z0m)) ||
d_g0<0.0 || d_Rn<0.0 ||
d_dem<=-100.0 || d_dem>9000.0 ||
d_tempk<200.0){
@@ -921,7 +1022,24 @@
G_message(" d_ndvi=%5.3f",d_ndvi);
G_message(" d_u2m=%5.3f",d_u2m);
*/ /* Calculate sensible heat flux */
- d = sensi_h(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+ //d = sensi_h(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+ /* do nothing */
+ } else {
+ /* let the internal constant take over */
+ d_dT = -1.0;
+ d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+ } else {
+ /* do nothing */
+ } else {
+ d_dT = -1.0;
+ d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
// G_message(" d_h0=%5.3f",d);
if (zero->answer && d<0.0){
d=0.0;
@@ -934,6 +1052,14 @@
G_free(inrast_T);
G_close_cell (infd_T);
+ G_free(inrast_dT);
+ G_close_cell (infd_dT);
+ G_free(inrast_z0m);
+ G_close_cell (infd_z0m);
G_free(inrast_u2);
G_close_cell (infd_u2);
G_free(inrast_dem);
Deleted: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h.c 2008-07-25 00:30:03 UTC (rev 32274)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h.c 2008-07-25 01:02:59 UTC (rev 32275)
@@ -1,112 +0,0 @@
-/* This is the main loop used in SEBAL */
-/* ychemin at yahoo.com - yann.chemin at ait.ac.th */
-/* GPL >= 2 - April 2004 */
-#include<stdio.h>
-#include<math.h>
-#include<stdlib.h>
-#include "functions.h"
-/* Arrays Declarations */
-#define ITER_MAX 10
- /* Arrays Declarations */
- double dtair[ITER_MAX], roh_air[ITER_MAX], rah[ITER_MAX];
- double h[ITER_MAX];
- double ustar[ITER_MAX], zom[ITER_MAX];
- /* Declarations */
- int i, j, ic, debug=0;
- double u_0, zom0;
- double h_desert, rah_desert, roh_air_desert;
- double dtair_desert;
- double psih_desert,ustar_desert,ustar_desertold,zom_desert;
- double psih;
- double result;
- /* Fat-free junk food */
- if (iteration>ITER_MAX){
- iteration=ITER_MAX;
- if(debug==1){
- printf("*****************************\n");
- printf("t0_dem = %5.3f\n",t0_dem);
- printf("ndvi = %5.3f ndvimax = %5.3f\n",ndvi,ndvi_max);
-// dtair[0] = dt_air_0(t0_dem, tempk_water, tempk_desert);
- dtair[0] = 5.0;
-// printf("*****************************dtair = %5.3f\n",dtair[0]);
- roh_air[0] = roh_air_0(tempk);
-// printf("*****************************rohair=%5.3f\n",roh_air[0]);
- roh_air_desert = roh_air_0(tempk_desert);
-// printf("**rohairdesert = %5.3f\n",roh_air_desert);
- zom0 = zom_0(ndvi, ndvi_max);
-// printf("*****************************zom = %5.3f\n",zom0);
- u_0 = U_0(zom0, u2m);
-// printf("*****************************u0\n");
- rah[0] = rah_0(zom0, u_0);
-// printf("*****************************rah = %5.3f\n",rah[0]);
- h[0] = h_0(roh_air[0], rah[0], dtair[0]);
-// printf("*****************************h\n");
- if(debug==1){
- printf("dtair[0] = %5.3f K\n", dtair[0]);
- printf("roh_air[0] = %5.3f kg/m3\n", roh_air[0]);
- printf("roh_air_desert0 = %5.3f kg/m3\n", roh_air_desert);
- printf("zom_0 = %5.3f\n", zom0);
- printf("u_0 = %5.3f\n", u_0);
- printf("rah[0] = %5.3f s/m\n", rah[0]);
- printf("h[0] = %5.3f W/m2\n", h[0]);
-/*Main iteration loop of SEBAL*/
- zom[0] = zom0;
- for(ic=1;ic<iteration+1;ic++){
- if(debug==1){
- printf("\n ******** ITERATION %i *********\n",ic);
- /* Where is roh_air[i]? */
- psih = psi_h(t0_dem,h[ic-1],u_0,roh_air[ic-1]);
- ustar[ic] = u_star(t0_dem,h[ic-1],u_0,roh_air[ic-1],zom[0],u2m);
- rah[ic] = rah1(psih, ustar[ic]);
- /* get desert point values from maps */
- if(ic==1){
- h_desert = rnet_desert - g0_desert;
- zom_desert = 0.002;
- psih_desert = psi_h(t0_dem_desert,h_desert,u_0,roh_air_desert);
- ustar_desert = u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u2m);
- } else {
- roh_air_desert = rohair(dem_desert,tempk_desert,dtair_desert);
- h_desert = h1(roh_air_desert,rah_desert,dtair_desert);
- ustar_desertold = ustar_desert;
- psih_desert = psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert);
- ustar_desert = u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u2m);
- rah_desert = rah1(psih_desert,ustar_desert);
- dtair_desert = dt_air_desert(h_desert, roh_air_desert, rah_desert);
- /* This should find the new dtair from inversed h equation...*/
- dtair[ic] = dt_air(t0_dem, tempk_water, tempk_desert, dtair_desert);
- /* This produces h[ic] and roh_air[ic+1] */
- roh_air[ic] = rohair(dem, tempk, dtair[ic]);
- h[ic] = h1(roh_air[ic], rah[ic], dtair[ic]);
- /* Output values of the iteration parameters */
- if(debug==1){
- printf("psih[%i] = %5.3f\n", ic, psih);
- printf("ustar[%i] = %5.3f\n", ic, ustar[ic]);
- printf("rah[%i] = %5.3f s/m\n",ic, rah[ic]);
- printf("h_desert = %5.3f\n", h_desert);
- printf("rohair_desert = %5.3f\n", roh_air_desert);
- printf("psih_desert = %5.3f\tustar_desert = %5.3f\trah_desert = %5.3f\n", psih_desert, ustar_desert, rah_desert);
- printf("dtair_desert = %8.5f\n", dtair_desert);
- printf("dtair[%i] = %5.3f K\n", ic, dtair[ic]);
- printf("roh_air[%i] = %5.3f kg/m3\n", ic, roh_air[ic]);
- printf("h[%i] = %5.3f W/m2\n",ic, h[ic]);
- return h[iteration];
Added: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c (rev 0)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c 2008-07-25 01:02:59 UTC (rev 32275)
@@ -0,0 +1,112 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+#include "functions.h"
+/* Arrays Declarations */
+#define ITER_MAX 10
+ /* Arrays Declarations */
+ double dtair[ITER_MAX], roh_air[ITER_MAX], rah[ITER_MAX];
+ double h[ITER_MAX];
+ double ustar[ITER_MAX], zom[ITER_MAX];
+ /* Declarations */
+ int i, j, ic, debug=0;
+ double u_0, zom0;
+ double h_desert, rah_desert, roh_air_desert;
+ double dtair_desert;
+ double psih_desert,ustar_desert,ustar_desertold,zom_desert;
+ double psih;
+ double result;
+ /* Fat-free junk food */
+ if (iteration>ITER_MAX){
+ iteration=ITER_MAX;
+ if(debug==1){
+ printf("*****************************\n");
+ printf("t0_dem = %5.3f\n",t0_dem);
+ printf("ndvi = %5.3f ndvimax = %5.3f\n",ndvi,ndvi_max);
+// dtair[0] = dt_air_0(t0_dem, tempk_water, tempk_desert);
+ if(dtair0 < 0){
+ dtair[0] = 5.0;
+ } else {
+ dtair[0] = dtair0;
+// printf("*****************************dtair = %5.3f\n",dtair[0]);
+ roh_air[0] = roh_air_0(tempk);
+// printf("*****************************rohair=%5.3f\n",roh_air[0]);
+ roh_air_desert = roh_air_0(tempk_desert);
+// printf("**rohairdesert = %5.3f\n",roh_air_desert);
+ zom0 = zom_0(ndvi, ndvi_max);
+// printf("*****************************zom = %5.3f\n",zom0);
+ u_0 = U_0(zom0, u2m);
+// printf("*****************************u0\n");
+ rah[0] = rah_0(zom0, u_0);
+// printf("*****************************rah = %5.3f\n",rah[0]);
+ h[0] = h_0(roh_air[0], rah[0], dtair[0]);
+// printf("*****************************h\n");
+ if(debug==1){
+ printf("dtair[0] = %5.3f K\n", dtair[0]);
+ printf("roh_air[0] = %5.3f kg/m3\n", roh_air[0]);
+ printf("roh_air_desert0 = %5.3f kg/m3\n", roh_air_desert);
+ printf("zom_0 = %5.3f\n", zom0);
+ printf("u_0 = %5.3f\n", u_0);
+ printf("rah[0] = %5.3f s/m\n", rah[0]);
+ printf("h[0] = %5.3f W/m2\n", h[0]);
+/*Main iteration loop of SEBAL*/
+ zom[0] = zom0;
+ for(ic=1;ic<iteration+1;ic++){
+ if(debug==1){
+ printf("\n ******** ITERATION %i *********\n",ic);
+ /* Where is roh_air[i]? */
+ psih = psi_h(t0_dem,h[ic-1],u_0,roh_air[ic-1]);
+ ustar[ic] = u_star(t0_dem,h[ic-1],u_0,roh_air[ic-1],zom[0],u2m);
+ rah[ic] = rah1(psih, ustar[ic]);
+ /* get desert point values from maps */
+ if(ic==1){
+ h_desert = rnet_desert - g0_desert;
+ zom_desert = 0.002;
+ psih_desert = psi_h(t0_dem_desert,h_desert,u_0,roh_air_desert);
+ ustar_desert = u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u2m);
+ } else {
+ roh_air_desert = rohair(dem_desert,tempk_desert,dtair_desert);
+ h_desert = h1(roh_air_desert,rah_desert,dtair_desert);
+ ustar_desertold = ustar_desert;
+ psih_desert = psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert);
+ ustar_desert = u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u2m);
+ rah_desert = rah1(psih_desert,ustar_desert);
+ dtair_desert = dt_air_desert(h_desert, roh_air_desert, rah_desert);
+ /* This should find the new dtair from inversed h equation...*/
+ dtair[ic] = dt_air(t0_dem, tempk_water, tempk_desert, dtair_desert);
+ /* This produces h[ic] and roh_air[ic+1] */
+ roh_air[ic] = rohair(dem, tempk, dtair[ic]);
+ h[ic] = h1(roh_air[ic], rah[ic], dtair[ic]);
+ /* Output values of the iteration parameters */
+ if(debug==1){
+ printf("psih[%i] = %5.3f\n", ic, psih);
+ printf("ustar[%i] = %5.3f\n", ic, ustar[ic]);
+ printf("rah[%i] = %5.3f s/m\n",ic, rah[ic]);
+ printf("h_desert = %5.3f\n", h_desert);
+ printf("rohair_desert = %5.3f\n", roh_air_desert);
+ printf("psih_desert = %5.3f\tustar_desert = %5.3f\trah_desert = %5.3f\n", psih_desert, ustar_desert, rah_desert);
+ printf("dtair_desert = %8.5f\n", dtair_desert);
+ printf("dtair[%i] = %5.3f K\n", ic, dtair[ic]);
+ printf("roh_air[%i] = %5.3f kg/m3\n", ic, roh_air[ic]);
+ printf("h[%i] = %5.3f W/m2\n",ic, h[ic]);
+ return h[iteration];
Added: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c (rev 0)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c 2008-07-25 01:02:59 UTC (rev 32275)
@@ -0,0 +1,110 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+ double u_0;
+ double psih;
+ double result;
+ if(debug==1){
+ printf("z0m0 = %5.3f\n",zom0);
+ if(dtair0 < 0){
+ dtair[0] = 5.0;
+ } else {
+ if(debug==1){
+ zom[0] = zom0;
+ if(debug==1){
+ if(ic==1){
+ } else {
+ if(debug==1){
