[GRASS-SVN] r32276 - in grass-addons/gipe: . i.eb.z0m0
r.hydro.CASC2D
svn_grass at osgeo.org
Thu Jul 24 22:16:45 EDT 2008
Author: ychemin
Date: 2008-07-24 22:16:44 -0400 (Thu, 24 Jul 2008)
New Revision: 32276
Added:
grass-addons/gipe/i.eb.z0m0/
grass-addons/gipe/i.eb.z0m0/Makefile
grass-addons/gipe/i.eb.z0m0/description.html
grass-addons/gipe/i.eb.z0m0/main.c
grass-addons/gipe/i.eb.z0m0/zom_0.c
grass-addons/gipe/Makefile.imagery
grass-addons/gipe/gmmenu.tcl
grass-addons/gipe/menudata.py
grass-addons/gipe/r.hydro.CASC2D/readme
Added i.eb.z0m0, which permits a generic z0m estimation from NDVI
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery 2008-07-25 01:02:59 UTC (rev 32275)
+++ grass-addons/gipe/Makefile.imagery 2008-07-25 02:16:44 UTC (rev 32276)
@@ -28,11 +28,13 @@
i.eb.ustar \
i.eb.wetdrypix \
i.eb.z0m \
+ i.eb.z0m0 \
i.emissivity \
i.evapo.potrad \
i.evapo.PT \
i.evapo.SENAY \
i.evapo.TSA \
+ i.qc.modis \
i.latitude \
i.lmf \
i.longitude \
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl 2008-07-25 01:02:59 UTC (rev 32275)
+++ grass-addons/gipe/gmmenu.tcl 2008-07-25 02:16:44 UTC (rev 32276)
@@ -582,6 +582,8 @@
{command {[G_msg "Longitude map"]} {} "i.longitude" {} -command {execute i.longitude }}
{command {[G_msg "Sunshine hours (potential)"]} {} "i.sunhours" {} -command {execute i.sunhours }}
{command {[G_msg "Satellite overpass time"]} {} "i.sattime" {} -command {execute i.sattime }}
+ {separator}
+ {command {[G_msg "LMF temporal splinning"]} {} "i.lmf" {} -command {execute i.lmf }}
{separator}
{cascad {[G_msg "ETo, ETP, ETa"]} {} "" $tmenu {
@@ -598,7 +600,8 @@
{command {[G_msg "Actual ET (TSA)"]} {} "i.evapo.TSA" {} -command {execute i.evapo.TSA }}
{cascad {[G_msg "Energy Balance"]} {} "" $tmenu {
- {command {[G_msg "Surface roughness"]} {} "i.eb.z0m" {} -command {execute i.eb.z0m }}
+ {command {[G_msg "Surface roughness (generic)"]} {} "i.eb.z0m0" {} -command {execute i.eb.z0m0 }}
+ {command {[G_msg "Surface roughness (savi/Pawan04)"]} {} "i.eb.z0m" {} -command {execute i.eb.z0m }}
{command {[G_msg "Delta T"]} {} "i.eb.deltat" {} -command {execute i.eb.deltat }}
{command {[G_msg "Net radiation"]} {} "i.eb.netrad" {} -command {execute i.eb.netrad }}
{separator}
Added: grass-addons/gipe/i.eb.z0m0/Makefile
--- grass-addons/gipe/i.eb.z0m0/Makefile (rev 0)
+++ grass-addons/gipe/i.eb.z0m0/Makefile 2008-07-25 02:16:44 UTC (rev 32276)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+PGM = i.eb.z0m0
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+ EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/i.eb.z0m0/description.html
--- grass-addons/gipe/i.eb.z0m0/description.html (rev 0)
+++ grass-addons/gipe/i.eb.z0m0/description.html 2008-07-25 02:16:44 UTC (rev 32276)
@@ -0,0 +1,32 @@
+<H2>DESCRIPTION</H2>
+<EM>i.eb.z0m0</EM> calculates the momentum roughness length (z0m) and optionally the surface roughness for heat transport (z0h) as per SEBAL requirements from bastiaanssen (1995).
+This version is calculating from a NDVI with an deterministic equation, as seen in Bastiaanssen (1995).
+This is a typical input to sensible heat flux computations of any energy balance modeling.
+<H2>NOTES</H2>
+The NDVI map input and the ndvi_max operation set, is only to get a linear relationship from NDVI to vegetation height. The latter being related to z0m by a factor 7.
+If you happen to have a vegetation height (hv) map, then z0m=hv/7 and z0h=0.1*z0m. There, fixed.
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.eb.h0.html">i.eb.h0</A><br>
+<A HREF="i.eb.h_SEBAL95.html">i.eb.h_SEBAL95</A><br>
+<A HREF="i.eb.h_iter.html">i.eb.h_iter</A><br>
+<A HREF="i.eb.z0m.html">i.eb.z0m</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
+<p>
+<i>Last changed: $Date: 2008/07/25 09:52:24 $</i>
Added: grass-addons/gipe/i.eb.z0m0/main.c
--- grass-addons/gipe/i.eb.z0m0/main.c (rev 0)
+++ grass-addons/gipe/i.eb.z0m0/main.c 2008-07-25 02:16:44 UTC (rev 32276)
@@ -0,0 +1,251 @@
+ * MODULE: i.eb.z0m0
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Calculates the momentum roughness length
+ * as seen in Bastiaanssen (1995)
+ * COPYRIGHT: (C) 2002-2006 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+double zom_0(double ndvi, double ndvi_max, double hv_ndvimax, double hv_desert);
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; //region+header info
+ char *mapset; // mapset name
+ int nrows, ncols;
+ int row,col;
+ int heat=0;//Flag for surf. roughness for heat transport output
+ struct GModule *module;
+ struct Option *input1, *input2, *input3, *input4;
+ struct Option *output1, *output2;
+ struct Flag *flag1, *flag2;
+ struct History history; //metadata
+ /* FMEO Declarations*****************/
+ char *name; // input raster name
+ char *result1, *result2; //output raster name
+ //File Descriptors
+ int infd_ndvi;
+ int outfd1, outfd2;
+ char *ndvi;
+ char *z0m, *z0h;
+ double coef_z0h, hv_max, hmr;
+ int i=0,j=0;
+ void *inrast_ndvi;
+ DCELL *outrast1, *outrast2;
+ RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
+ RASTER_MAP_TYPE data_type_ndvi;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("roughness length, energy balance, SEBAL");
+ module->description = _("Momentum roughness length (z0m) and surface roughness for heat transport (z0h) as seen in Bastiaanssen (2004)");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+ input1->key = _("ndvi");
+ input1->description=_("Name of the NDVI map [-1.0;1.0]");
+ input1->answer =_("ndvi");
+ input2 = G_define_option() ;
+ input2->key =_("coef");
+ input2->type = TYPE_DOUBLE;
+ input2->required = NO;
+ input2->gisprompt =_("parameter,value");
+ input2->description=_("Value of the converion factor from z0m and z0h (Bastiaanssen (2005) used 0.1)");
+ input2->answer =_("0.1");
+ input3 = G_define_option() ;
+ input3->key =_("hv_max");
+ input3->type = TYPE_DOUBLE;
+ input3->required = YES;
+ input3->gisprompt =_("parameter,value");
+ input3->description=_("Value of the vegetation height at max(NDVI) i.e. standard C3 crop could be 1.5m");
+ input3->answer =_("1.5");
+ input4 = G_define_option() ;
+ input4->key =_("hmr");
+ input4->type = TYPE_DOUBLE;
+ input4->required = YES;
+ input4->gisprompt =_("parameter,value");
+ input4->description=_("Value of the micro-relief height (h.m-r.) on flat bare ground, most references point to 2cm");
+ input4->answer =_("0.02");
+ output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
+ output1->key =_("z0m");
+ output1->description=_("Name of the output z0m layer");
+ output1->answer =_("z0m");
+ output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
+ output2->key =_("z0h");
+ output2->required = NO;
+ output2->description=_("Name of the output z0h layer");
+ output2->answer =_("z0h");
+ flag1 = G_define_flag();
+ flag1->key = 'h';
+ flag1->description = _("z0h output (You have to input a coef value)");
+ if (G_parser(argc, argv))
+ exit (EXIT_FAILURE);
+ ndvi = input1->answer;
+ if(input2->answer)
+ coef_z0h = atof(input2->answer);
+ hv_max = atof(input3->answer);
+ hmr = atof(input4->answer);
+ result1 = output1->answer;
+ if(output2->answer)
+ result2 = output2->answer;
+ if(flag1->answer)
+ heat = flag1->answer;
+ mapset = G_find_cell2(ndvi, "");
+ if (mapset == NULL) {
+ G_fatal_error(_("cell file [%s] not found"), ndvi);
+ data_type_ndvi = G_raster_map_type(ndvi,mapset);
+ if ( (infd_ndvi = G_open_cell_old (ndvi,mapset)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), ndvi);
+ if (G_get_cellhd (ndvi, mapset, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s])"), ndvi);
+ inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
+ G_debug(3, "number of rows %d",cellhd.rows);
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ outrast1 = G_allocate_raster_buf(data_type_output);
+ if(input2->answer&&output2->answer){
+ outrast2 = G_allocate_raster_buf(data_type_output);
+ /* Create New raster files */
+ if ( (outfd1 = G_open_raster_new (result1,data_type_output)) < 0)
+ G_fatal_error(_("Could not open <%s>"),result1);
+ if ( (outfd2 = G_open_raster_new (result2,data_type_output)) < 0)
+ G_fatal_error(_("Could not open <%s>"),result2);
+ DCELL d_ndvi; /* Input raster */
+ DCELL d_ndvi_max = 0.0; /* Generated here */
+ /* THREAD 1 */
+ /* NDVI Max */
+ for (row = 0; row < nrows; row++)
+ G_percent (row, nrows, 2);
+ if (G_get_d_raster_row (infd_ndvi, inrast_ndvi, row) < 0)
+ G_fatal_error (_("Could not read from <%s>"),ndvi);
+ /* #pragma omp for parallel default (shared) \
+ shared(ncols,nrows) \
+ private (col,row,d_ndvi)*/
+ for (col=0; col < ncols; col++)
+ switch(data_type_ndvi){
+ case CELL_TYPE:
+ d_ndvi = (double) ((CELL *) inrast_ndvi)[col];
+ break;
+ case FCELL_TYPE:
+ d_ndvi = (double) ((FCELL *) inrast_ndvi)[col];
+ break;
+ case DCELL_TYPE:
+ d_ndvi = (double) ((DCELL *) inrast_ndvi)[col];
+ break;
+ //d_ndvi = ((DCELL *) inrast_ndvi)[col];
+ if(G_is_d_null_value(&d_ndvi)){
+ /* do nothing */
+ } else if ((d_ndvi)>d_ndvi_max&&(d_ndvi)<0.98){
+ d_ndvi_max = d_ndvi;
+ G_message("ndvi_max=%f\n",d_ndvi_max);
+ /* Process pixels */
+ DCELL d;
+ DCELL d_z0h;
+ G_percent(row,nrows,2);
+ /* read soil input maps */
+ if(G_get_raster_row(infd_ndvi,inrast_ndvi,row,data_type_ndvi)<0)
+ G_fatal_error(_("Could not read from <%s>"),ndvi);
+ /*process the data */
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ G_set_d_null_value(&outrast1[col],1);
+ G_set_d_null_value(&outrast2[col],1);
+ }else {
+ /* calculate z0m */
+ d = zom_0( d_ndvi, d_ndvi_max, hv_max, hmr );
+ outrast1[col] = d;
+ d_z0h = d * coef_z0h;
+ outrast2[col] = d_z0h;
+ if (G_put_raster_row(outfd1,outrast1,data_type_output)<0)
+ G_fatal_error(_("Cannot write to output z0m raster file"));
+ if (G_put_raster_row(outfd2,outrast2,data_type_output)<0)
+ G_fatal_error(_("Cannot write to output z0h raster file"));
+ G_free (inrast_ndvi);
+ G_close_cell (infd_ndvi);
+ G_free (outrast1);
+ G_close_cell (outfd1);
+ G_free (outrast2);
+ G_close_cell (outfd2);
+ G_short_history(result1, "raster", &history);
+ G_command_history(&history);
+ G_write_history(result1,&history);
+ G_short_history(result2, "raster", &history);
+ G_write_history(result2,&history);
+ exit(EXIT_SUCCESS);
Added: grass-addons/gipe/i.eb.z0m0/zom_0.c
--- grass-addons/gipe/i.eb.z0m0/zom_0.c (rev 0)
+++ grass-addons/gipe/i.eb.z0m0/zom_0.c 2008-07-25 02:16:44 UTC (rev 32276)
@@ -0,0 +1,16 @@
+#include<stdio.h>
+#include<math.h>
+double zom_0(double ndvi, double ndvi_max, double hv_ndvimax, double hv_desert )
+ double a, b, z0m;
+ //double hv_ndvimax=1.5; /* crop vegetation height (m) */
+ //double hv_desert=0.002; /* desert base vegetation height (m) */
+ a = (log10(hv_desert)-((log10(hv_ndvimax/7)-log10(hv_desert))/(ndvi_max-0.02)*0.02));
+ b = (log10(hv_ndvimax/7)-log10(hv_desert))/(ndvi_max-0.02)* ndvi;
+ z0m = exp(a+b);
+ return (z0m);
Property changes on: grass-addons/gipe/i.eb.z0m0/zom_0.c
___________________________________________________________________
Modified: grass-addons/gipe/menudata.py
--- grass-addons/gipe/menudata.py 2008-07-25 01:02:59 UTC (rev 32275)
+++ grass-addons/gipe/menudata.py 2008-07-25 02:16:44 UTC (rev 32276)
@@ -1458,6 +1458,11 @@
_("Satellite overpass time"),
"self.RunMenuCmd",
"i.sattime"),
+ (_("LMF temporal splinning"),
+ _("LMF temporal splinning"),
+ "self.RunMenuCmd",
+ "i.lmf"),
(_("RS Processing (Advanced)"), (
@@ -1503,9 +1508,13 @@
(_("Energy Balance"), (
- (_("Surface roughness"),
+ (_("Surface roughness (generic)"),
_("surface roughness"),
"self.RunMenuCmd",
+ "i.eb.z0m0"),
+ (_("Surface roughness (savi/Pawan04)"),
+ _("surface roughness (savi/Pawan04)"),
"i.eb.z0m"),
(_("Delta T"),
_("delta T"),
Modified: grass-addons/gipe/r.hydro.CASC2D/readme
--- grass-addons/gipe/r.hydro.CASC2D/readme 2008-07-25 01:02:59 UTC (rev 32275)
+++ grass-addons/gipe/r.hydro.CASC2D/readme 2008-07-25 02:16:44 UTC (rev 32276)
@@ -46,3 +46,7 @@
read_gage_file.c function to read raingage file
write_files.c function to write output raster maps
+To try in Spearfish Dataset
+r.hydro.CASC2D elevation=elevation.10m at PERMANENT outlet_eastNnorthNslope=601220.607477,4927674.62617,0.1 Manning_n=0.1 unif_rain_int=50 time_step=1 rain_duration=10800 tot_time=10800 write_time_step=600 discharge=try depth_map=CASC2D_depth
