[GRASS-SVN] r32363 - in grass/trunk: . include include/Make
Tue Jul 29 09:44:31 EDT 2008
Author: glynn
Date: 2008-07-29 09:44:13 -0400 (Tue, 29 Jul 2008)
New Revision: 32363
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/include/config.h.in
Remove Tcl/Tk framework flags (don't work, apparently)
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-07-29 13:19:00 UTC (rev 32362)
+++ grass/trunk/configure	2008-07-29 13:44:13 UTC (rev 32363)
@@ -111,9 +111,6 @@
 ac_help="$ac_help
   --with-tcltk-libs=DIRS  Tcl/Tk library files are in DIRS"
 ac_help="$ac_help
-  --with-tcltk-framework=DIR
-                          Tcl/Tk framework is in DIR"
-ac_help="$ac_help
   --with-postgres-includes=DIRS
                           PostgreSQL include files are in DIRS"
 ac_help="$ac_help
@@ -727,7 +724,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:731: checking host system type" >&5
+echo "configure:728: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -750,7 +747,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:754: checking for $ac_word" >&5
+echo "configure:751: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -777,7 +774,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:781: checking for $ac_word" >&5
+echo "configure:778: checking for $ac_word" >&5
@@ -825,7 +822,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:829: checking for $ac_word" >&5
+echo "configure:826: checking for $ac_word" >&5
@@ -854,7 +851,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:858: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:855: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -865,12 +862,12 @@
 cat > conftest.$ac_ext << EOF
-#line 869 "configure"
+#line 866 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -896,19 +893,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:900: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:897: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:905: checking whether we are using GNU C" >&5
+echo "configure:902: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -926,7 +923,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:930: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:927: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -955,10 +952,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:959: checking for Cygwin environment" >&5
+echo "configure:956: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 962 "configure"
+#line 959 "configure"
 int main() {
@@ -969,7 +966,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:973: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -985,17 +982,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:989: checking for mingw32 environment" >&5
+echo "configure:986: checking for mingw32 environment" >&5
-#line 992 "configure"
+#line 989 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:999: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1013,7 +1010,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1017: checking for executable suffix" >&5
+echo "configure:1014: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1032,23 +1029,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1036: checking for full floating-point support" >&5
+echo "configure:1033: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1041: checking whether "cc -mieee" works" >&5
+echo "configure:1038: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1045 "configure"
+#line 1042 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1064,7 +1061,7 @@
 else
-#line 1068 "configure"
+#line 1065 "configure"
 #include <float.h>
@@ -1078,7 +1075,7 @@
 EOF
-if { (eval echo configure:1082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1091,14 +1088,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1095: checking for full floating-point support with -mieee" >&5
+echo "configure:1092: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1102 "configure"
+#line 1099 "configure"
 #include <float.h>
@@ -1112,7 +1109,7 @@
 EOF
-if { (eval echo configure:1116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1149,7 +1146,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1153: checking for $ac_word" >&5
+echo "configure:1150: checking for $ac_word" >&5
 case "$pwd" in
@@ -1187,7 +1184,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1191: checking for source directory" >&5
+echo "configure:1188: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1198,7 +1195,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1202: checking for build directory" >&5
+echo "configure:1199: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1283,7 +1280,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1287: checking for MacOSX App" >&5
+echo "configure:1284: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1306,7 +1303,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1310: checking how to build libraries" >&5
+echo "configure:1307: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1349,7 +1346,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1353: checking for $ac_word" >&5
+echo "configure:1350: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1374,7 +1371,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1378: checking how to run the C preprocessor" >&5
+echo "configure:1375: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1387,13 +1384,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1391 "configure"
+#line 1388 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1397: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1404,13 +1401,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1408 "configure"
+#line 1405 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1421,13 +1418,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1425 "configure"
+#line 1422 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1455,7 +1452,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1459: checking if 64bit support is requested" >&5
+echo "configure:1456: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1475,7 +1472,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1479: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1476: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1499,7 +1496,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1503: checking system version (for dynamic loading)" >&5
+echo "configure:1500: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1525,13 +1522,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1529: checking for dlopen in -ldl" >&5
+echo "configure:1526: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1535 "configure"
+#line 1532 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1542,7 +1539,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1589,7 +1586,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1593: checking for $ac_word" >&5
+echo "configure:1590: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1718,13 +1715,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1722: checking for gettimeofday in -lbsd" >&5
+echo "configure:1719: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1728 "configure"
+#line 1725 "configure"
@@ -1735,7 +1732,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1776,13 +1773,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1780: checking for inet_ntoa in -lbind" >&5
+echo "configure:1777: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1786 "configure"
+#line 1783 "configure"
@@ -1793,7 +1790,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1854,13 +1851,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1858: checking for shl_load in -ldld" >&5
+echo "configure:1855: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1864 "configure"
+#line 1861 "configure"
@@ -1871,7 +1868,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1936,13 +1933,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1940: checking for shl_load in -ldld" >&5
+echo "configure:1937: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1946 "configure"
+#line 1943 "configure"
@@ -1953,7 +1950,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2075,15 +2072,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2079: checking for dld.h" >&5
+echo "configure:2076: checking for dld.h" >&5
-#line 2082 "configure"
+#line 2079 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2143,15 +2140,15 @@
 	    else
-echo "configure:2147: checking for dld.h" >&5
+echo "configure:2144: checking for dld.h" >&5
-#line 2150 "configure"
+#line 2147 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2155: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2248,9 +2245,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2252: checking for ELF" >&5
+echo "configure:2249: checking for ELF" >&5
-#line 2254 "configure"
+#line 2251 "configure"
 #ifdef __ELF__
@@ -2280,15 +2277,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2284: checking for dlfcn.h" >&5
+echo "configure:2281: checking for dlfcn.h" >&5
-#line 2287 "configure"
+#line 2284 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2312,9 +2309,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2316: checking for ELF" >&5
+echo "configure:2313: checking for ELF" >&5
-#line 2318 "configure"
+#line 2315 "configure"
 #ifdef __ELF__
@@ -2638,17 +2635,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2642: checking for ld accepts -Bexport flag" >&5
+echo "configure:2639: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2645 "configure"
+#line 2642 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3138,15 +3135,7 @@
-# Check whether --with-tcltk-framework or --without-tcltk-framework was given.
-if test "${with_tcltk_framework+set}" = set; then
-  withval="$with_tcltk_framework"
-fi
 # Check whether --with-postgres-includes or --without-postgres-includes was given.
 if test "${with_postgres_includes+set}" = set; then
   withval="$with_postgres_includes"
@@ -3409,7 +3398,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3413: checking for additional include dirs" >&5
+echo "configure:3402: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3432,7 +3421,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3436: checking for additional library dirs" >&5
+echo "configure:3425: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3466,7 +3455,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3470: checking for a BSD compatible install" >&5
+echo "configure:3459: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3519,7 +3508,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3523: checking for $ac_word" >&5
+echo "configure:3512: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3550,13 +3539,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3554: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3543: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3560 "configure"
+#line 3549 "configure"
@@ -3567,7 +3556,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3592,7 +3581,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3596: checking for $ac_word" >&5
+echo "configure:3585: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3632,7 +3621,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3636: checking for $ac_word" >&5
+echo "configure:3625: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3663,7 +3652,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3667: checking for $ac_word" >&5
+echo "configure:3656: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3701,7 +3690,7 @@
-echo "configure:3705: checking for $ac_word" >&5
+echo "configure:3694: checking for $ac_word" >&5
@@ -3730,7 +3719,7 @@
-echo "configure:3734: checking for $ac_word" >&5
+echo "configure:3723: checking for $ac_word" >&5
@@ -3761,7 +3750,7 @@
-echo "configure:3765: checking for $ac_word" >&5
+echo "configure:3754: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3790,7 +3779,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3794: checking for $ac_word" >&5
+echo "configure:3783: checking for $ac_word" >&5
 case "$PERL" in
@@ -3821,10 +3810,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3825: checking for ANSI C header files" >&5
+echo "configure:3814: checking for ANSI C header files" >&5
-#line 3828 "configure"
+#line 3817 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3832,7 +3821,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3849,7 +3838,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3853 "configure"
+#line 3842 "configure"
 #include <string.h>
 EOF
@@ -3867,7 +3856,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3871 "configure"
+#line 3860 "configure"
 #include <stdlib.h>
 EOF
@@ -3888,7 +3877,7 @@
 else
-#line 3892 "configure"
+#line 3881 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3899,7 +3888,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3926,15 +3915,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3930: checking for $ac_hdr" >&5
+echo "configure:3919: checking for $ac_hdr" >&5
-#line 3933 "configure"
+#line 3922 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3963,15 +3952,15 @@
 do
-echo "configure:3967: checking for $ac_hdr" >&5
+echo "configure:3956: checking for $ac_hdr" >&5
-#line 3970 "configure"
+#line 3959 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3975: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4000,15 +3989,15 @@
 do
-echo "configure:4004: checking for $ac_hdr" >&5
+echo "configure:3993: checking for $ac_hdr" >&5
-#line 4007 "configure"
+#line 3996 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4037,15 +4026,15 @@
 do
-echo "configure:4041: checking for $ac_hdr" >&5
+echo "configure:4030: checking for $ac_hdr" >&5
-#line 4044 "configure"
+#line 4033 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4049: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4074,15 +4063,15 @@
 do
-echo "configure:4078: checking for $ac_hdr" >&5
+echo "configure:4067: checking for $ac_hdr" >&5
-#line 4081 "configure"
+#line 4070 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4086: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4108,10 +4097,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4112: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4101: checking whether time.h and sys/time.h may both be included" >&5
-#line 4115 "configure"
+#line 4104 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4120,7 +4109,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4140,10 +4129,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4144: checking for off_t" >&5
+echo "configure:4133: checking for off_t" >&5
-#line 4147 "configure"
+#line 4136 "configure"
 #if STDC_HEADERS
@@ -4170,10 +4159,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4174: checking for uid_t in sys/types.h" >&5
+echo "configure:4163: checking for uid_t in sys/types.h" >&5
-#line 4177 "configure"
+#line 4166 "configure"
 EOF
@@ -4201,10 +4190,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4205: checking return type of signal handlers" >&5
+echo "configure:4194: checking return type of signal handlers" >&5
-#line 4208 "configure"
+#line 4197 "configure"
 #include <signal.h>
@@ -4221,7 +4210,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4214: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4239,10 +4228,10 @@
-echo "configure:4243: checking for Cygwin environment" >&5
+echo "configure:4232: checking for Cygwin environment" >&5
-#line 4246 "configure"
+#line 4235 "configure"
 int main() {
@@ -4253,7 +4242,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4257: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4271,10 +4260,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4275: checking for $ac_func" >&5
+echo "configure:4264: checking for $ac_func" >&5
-#line 4278 "configure"
+#line 4267 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4297,7 +4286,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4323,10 +4312,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4327: checking for $ac_func" >&5
+echo "configure:4316: checking for $ac_func" >&5
-#line 4330 "configure"
+#line 4319 "configure"
@@ -4349,7 +4338,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4375,10 +4364,10 @@
 for ac_func in drand48
 do
-echo "configure:4379: checking for $ac_func" >&5
+echo "configure:4368: checking for $ac_func" >&5
-#line 4382 "configure"
+#line 4371 "configure"
@@ -4401,7 +4390,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4427,10 +4416,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4431: checking for $ac_func" >&5
+echo "configure:4420: checking for $ac_func" >&5
-#line 4434 "configure"
+#line 4423 "configure"
@@ -4453,7 +4442,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4479,10 +4468,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4483: checking for $ac_func" >&5
+echo "configure:4472: checking for $ac_func" >&5
-#line 4486 "configure"
+#line 4475 "configure"
@@ -4505,7 +4494,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4530,13 +4519,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4534: checking whether setpgrp takes no argument" >&5
+echo "configure:4523: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4540 "configure"
+#line 4529 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4556,7 +4545,7 @@
 EOF
-if { (eval echo configure:4560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4584,16 +4573,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4588: checking for long long int" >&5
+echo "configure:4577: checking for long long int" >&5
-#line 4590 "configure"
+#line 4579 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4597: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4613,7 +4602,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4617: checking for W11" >&5
+echo "configure:4606: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4641,7 +4630,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4645: checking for X" >&5
+echo "configure:4634: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4701,12 +4690,12 @@
   # First, try using that file with no special directory specified.
-#line 4705 "configure"
+#line 4694 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4775,14 +4764,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4779 "configure"
+#line 4768 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4887,17 +4876,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4891: checking whether -R must be followed by a space" >&5
+echo "configure:4880: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4894 "configure"
+#line 4883 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4913,14 +4902,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4917 "configure"
+#line 4906 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4952,13 +4941,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4956: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4945: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4962 "configure"
+#line 4951 "configure"
@@ -4969,7 +4958,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4990,13 +4979,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4994: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4983: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5000 "configure"
+#line 4989 "configure"
@@ -5007,7 +4996,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5035,10 +5024,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5039: checking for gethostbyname" >&5
+echo "configure:5028: checking for gethostbyname" >&5
-#line 5042 "configure"
+#line 5031 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5061,7 +5050,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5081,13 +5070,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5085: checking for gethostbyname in -lnsl" >&5
+echo "configure:5074: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5091 "configure"
+#line 5080 "configure"
@@ -5098,7 +5087,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5127,10 +5116,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5131: checking for connect" >&5
+echo "configure:5120: checking for connect" >&5
-#line 5134 "configure"
+#line 5123 "configure"
     which can conflict with char connect(); below.  */
@@ -5153,7 +5142,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5173,13 +5162,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5177: checking for connect in -lsocket" >&5
+echo "configure:5166: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5183 "configure"
+#line 5172 "configure"
@@ -5190,7 +5179,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5213,10 +5202,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5217: checking for remove" >&5
+echo "configure:5206: checking for remove" >&5
-#line 5220 "configure"
+#line 5209 "configure"
     which can conflict with char remove(); below.  */
@@ -5239,7 +5228,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5259,13 +5248,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5263: checking for remove in -lposix" >&5
+echo "configure:5252: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5269 "configure"
+#line 5258 "configure"
@@ -5276,7 +5265,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5299,10 +5288,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5303: checking for shmat" >&5
+echo "configure:5292: checking for shmat" >&5
-#line 5306 "configure"
+#line 5295 "configure"
     which can conflict with char shmat(); below.  */
@@ -5325,7 +5314,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5345,13 +5334,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5349: checking for shmat in -lipc" >&5
+echo "configure:5338: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5355 "configure"
+#line 5344 "configure"
@@ -5362,7 +5351,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5394,13 +5383,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5398: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5387: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5404 "configure"
+#line 5393 "configure"
@@ -5411,7 +5400,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5449,7 +5438,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5453: checking whether to use Curses" >&5
+echo "configure:5442: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5468,15 +5457,15 @@
 do
-echo "configure:5472: checking for $ac_hdr" >&5
+echo "configure:5461: checking for $ac_hdr" >&5
-#line 5475 "configure"
+#line 5464 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5507,10 +5496,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5511: checking curses.h WINDOW structure component" >&5
+echo "configure:5500: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5514 "configure"
+#line 5503 "configure"
 #include <curses.h>
@@ -5519,7 +5508,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5523: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5512: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5528,7 +5517,7 @@
 fi
 rm -f conftest*
-#line 5532 "configure"
+#line 5521 "configure"
 #include <curses.h>
@@ -5537,7 +5526,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5541: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5530: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5553,13 +5542,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5557: checking for initscr in -lncurses" >&5
+echo "configure:5546: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5563 "configure"
+#line 5552 "configure"
@@ -5570,7 +5559,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5589,13 +5578,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5593: checking for initscr in -lcurses" >&5
+echo "configure:5582: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5599 "configure"
+#line 5588 "configure"
@@ -5606,7 +5595,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5635,13 +5624,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5639: checking for keypad in -lncurses" >&5
+echo "configure:5628: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5645 "configure"
+#line 5634 "configure"
@@ -5652,7 +5641,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5674,13 +5663,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5678: checking for keypad in -lcurses" >&5
+echo "configure:5667: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5684 "configure"
+#line 5673 "configure"
@@ -5691,7 +5680,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5721,13 +5710,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5725: checking for gtty in -lcompat" >&5
+echo "configure:5714: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5731 "configure"
+#line 5720 "configure"
@@ -5738,7 +5727,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5757,13 +5746,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5761: checking for gtty in -lbsd-compat" >&5
+echo "configure:5750: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5767 "configure"
+#line 5756 "configure"
@@ -5774,7 +5763,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5793,13 +5782,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5797: checking for gtty in -lbsd" >&5
+echo "configure:5786: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5803 "configure"
+#line 5792 "configure"
@@ -5810,7 +5799,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5844,12 +5833,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5848: checking for library containing cuserid" >&5
+echo "configure:5837: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5853 "configure"
+#line 5842 "configure"
@@ -5860,7 +5849,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5871,7 +5860,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5875 "configure"
+#line 5864 "configure"
@@ -5882,7 +5871,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5908,10 +5897,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5912: checking for xdrmem_create" >&5
+echo "configure:5901: checking for xdrmem_create" >&5
-#line 5915 "configure"
+#line 5904 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5934,7 +5923,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5952,13 +5941,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5956: checking for xdrmem_create in -lsun" >&5
+echo "configure:5945: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5962 "configure"
+#line 5951 "configure"
@@ -5969,7 +5958,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5988,13 +5977,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5992: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5981: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5998 "configure"
+#line 5987 "configure"
@@ -6005,7 +5994,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6024,13 +6013,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6028: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6017: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6034 "configure"
+#line 6023 "configure"
@@ -6041,7 +6030,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6060,13 +6049,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6064: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6053: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6070 "configure"
+#line 6059 "configure"
@@ -6077,7 +6066,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6111,10 +6100,10 @@
 for ac_func in asprintf
 do
-echo "configure:6115: checking for $ac_func" >&5
+echo "configure:6104: checking for $ac_func" >&5
-#line 6118 "configure"
+#line 6107 "configure"
@@ -6137,7 +6126,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6164,10 +6153,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6168: checking for atan" >&5
+echo "configure:6157: checking for atan" >&5
-#line 6171 "configure"
+#line 6160 "configure"
     which can conflict with char atan(); below.  */
@@ -6190,7 +6179,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6208,13 +6197,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6212: checking for atan in -lm" >&5
+echo "configure:6201: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6218 "configure"
+#line 6207 "configure"
@@ -6225,7 +6214,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6252,10 +6241,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6256: checking for dlsym" >&5
+echo "configure:6245: checking for dlsym" >&5
-#line 6259 "configure"
+#line 6248 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6278,7 +6267,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6296,13 +6285,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6300: checking for dlsym in -ldl" >&5
+echo "configure:6289: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6306 "configure"
+#line 6295 "configure"
@@ -6313,7 +6302,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6340,10 +6329,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6344: checking for iconv" >&5
+echo "configure:6333: checking for iconv" >&5
-#line 6347 "configure"
+#line 6336 "configure"
     which can conflict with char iconv(); below.  */
@@ -6366,7 +6355,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6384,13 +6373,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6388: checking for iconv in -liconv" >&5
+echo "configure:6377: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6394 "configure"
+#line 6383 "configure"
@@ -6401,7 +6390,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6420,13 +6409,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6424: checking for iconv in -lgiconv" >&5
+echo "configure:6413: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6430 "configure"
+#line 6419 "configure"
@@ -6437,7 +6426,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6456,10 +6445,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6460: checking for libiconv" >&5
+echo "configure:6449: checking for libiconv" >&5
-#line 6463 "configure"
+#line 6452 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6482,7 +6471,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6500,13 +6489,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6504: checking for libiconv in -liconv" >&5
+echo "configure:6493: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6510 "configure"
+#line 6499 "configure"
@@ -6517,7 +6506,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6536,13 +6525,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6540: checking for libiconv in -lgiconv" >&5
+echo "configure:6529: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6546 "configure"
+#line 6535 "configure"
@@ -6553,7 +6542,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6590,10 +6579,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6594: checking for socket" >&5
+echo "configure:6583: checking for socket" >&5
-#line 6597 "configure"
+#line 6586 "configure"
     which can conflict with char socket(); below.  */
@@ -6616,7 +6605,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6634,13 +6623,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6638: checking for socket in -lsocket" >&5
+echo "configure:6627: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6644 "configure"
+#line 6633 "configure"
@@ -6651,7 +6640,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6699,7 +6688,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6703: checking for location of zlib includes" >&5
+echo "configure:6692: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6725,15 +6714,15 @@
 do
-echo "configure:6729: checking for $ac_hdr" >&5
+echo "configure:6718: checking for $ac_hdr" >&5
-#line 6732 "configure"
+#line 6721 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6767,7 +6756,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6771: checking for location of zlib library" >&5
+echo "configure:6760: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6792,13 +6781,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6796: checking for deflate in -lz" >&5
+echo "configure:6785: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6802 "configure"
+#line 6791 "configure"
@@ -6809,7 +6798,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6857,7 +6846,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6861: checking for location of External PROJ.4 includes" >&5
+echo "configure:6850: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6883,15 +6872,15 @@
 do
-echo "configure:6887: checking for $ac_hdr" >&5
+echo "configure:6876: checking for $ac_hdr" >&5
-#line 6890 "configure"
+#line 6879 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6895: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6928,7 +6917,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6932: checking External PROJ.4 version" >&5
+echo "configure:6921: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6936,7 +6925,7 @@
 else
-#line 6940 "configure"
+#line 6929 "configure"
 #include <stdio.h>
@@ -6948,7 +6937,7 @@
 EOF
-if { (eval echo configure:6952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6973,7 +6962,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6977: checking for location of External PROJ.4 library" >&5
+echo "configure:6966: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6998,13 +6987,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7002: checking for pj_get_def in -lproj" >&5
+echo "configure:6991: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7008 "configure"
+#line 6997 "configure"
@@ -7015,7 +7004,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7049,7 +7038,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7053: checking for location of External PROJ.4 data files" >&5
+echo "configure:7042: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7073,14 +7062,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7077: checking for epsg" >&5
+echo "configure:7066: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7084: checking for $PROJSHARE/epsg" >&5
+echo "configure:7073: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7112,7 +7101,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7116: checking for $ac_word" >&5
+echo "configure:7105: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7152,7 +7141,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7156: checking whether to use Readline" >&5
+echo "configure:7145: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7173,7 +7162,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7177: checking for location of Readline includes" >&5
+echo "configure:7166: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7199,15 +7188,15 @@
 do
-echo "configure:7203: checking for $ac_hdr" >&5
+echo "configure:7192: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7206 "configure"
+#line 7195 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7243,15 +7232,15 @@
 do
-echo "configure:7247: checking for $ac_hdr" >&5
+echo "configure:7236: checking for $ac_hdr" >&5
-#line 7250 "configure"
+#line 7239 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7285,7 +7274,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7289: checking for location of Readline library" >&5
+echo "configure:7278: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7310,13 +7299,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7314: checking for readline in -lreadline" >&5
+echo "configure:7303: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7320 "configure"
+#line 7309 "configure"
@@ -7327,7 +7316,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7362,13 +7351,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7366: checking for add_history in -lhistory" >&5
+echo "configure:7355: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7372 "configure"
+#line 7361 "configure"
@@ -7379,7 +7368,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7422,7 +7411,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7426: checking whether to use JPEG" >&5
+echo "configure:7415: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7442,7 +7431,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7446: checking for location of JPEG includes" >&5
+echo "configure:7435: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7468,15 +7457,15 @@
 do
-echo "configure:7472: checking for $ac_hdr" >&5
+echo "configure:7461: checking for $ac_hdr" >&5
-#line 7475 "configure"
+#line 7464 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7510,7 +7499,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7514: checking for location of JPEG library" >&5
+echo "configure:7503: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7537,13 +7526,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7541: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7530: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7547 "configure"
+#line 7536 "configure"
@@ -7554,7 +7543,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7573,13 +7562,13 @@
-echo "configure:7577: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7566: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7583 "configure"
+#line 7572 "configure"
@@ -7590,7 +7579,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7639,7 +7628,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7643: checking whether to use GDAL" >&5
+echo "configure:7632: checking whether to use GDAL" >&5
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
@@ -7652,7 +7641,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7656: checking for $ac_word" >&5
+echo "configure:7645: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7712,14 +7701,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7716 "configure"
+#line 7705 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7728,14 +7717,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7732 "configure"
+#line 7721 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7763,7 +7752,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7767: checking whether to use TIFF" >&5
+echo "configure:7756: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7783,7 +7772,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7787: checking for location of TIFF includes" >&5
+echo "configure:7776: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7809,15 +7798,15 @@
 do
-echo "configure:7813: checking for $ac_hdr" >&5
+echo "configure:7802: checking for $ac_hdr" >&5
-#line 7816 "configure"
+#line 7805 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7851,7 +7840,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7855: checking for location of TIFF library" >&5
+echo "configure:7844: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7882,13 +7871,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7886: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7892 "configure"
+#line 7881 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7899,7 +7888,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7918,13 +7907,13 @@
-echo "configure:7922: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7928 "configure"
+#line 7917 "configure"
@@ -7935,7 +7924,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7954,13 +7943,13 @@
-echo "configure:7958: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7964 "configure"
+#line 7953 "configure"
@@ -7971,7 +7960,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7990,13 +7979,13 @@
-echo "configure:7994: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8000 "configure"
+#line 7989 "configure"
@@ -8007,7 +7996,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8026,13 +8015,13 @@
-echo "configure:8030: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8036 "configure"
+#line 8025 "configure"
@@ -8043,7 +8032,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8062,13 +8051,13 @@
-echo "configure:8066: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8072 "configure"
+#line 8061 "configure"
@@ -8079,7 +8068,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8098,13 +8087,13 @@
-echo "configure:8102: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8108 "configure"
+#line 8097 "configure"
@@ -8115,7 +8104,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8134,13 +8123,13 @@
-echo "configure:8138: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8127: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8144 "configure"
+#line 8133 "configure"
@@ -8151,7 +8140,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8249,7 +8238,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8253: checking whether to use PNG" >&5
+echo "configure:8242: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8268,7 +8257,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8272: checking for location of PNG includes" >&5
+echo "configure:8261: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8294,15 +8283,15 @@
 do
-echo "configure:8298: checking for $ac_hdr" >&5
+echo "configure:8287: checking for $ac_hdr" >&5
-#line 8301 "configure"
+#line 8290 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8306: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8336,7 +8325,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8340: checking for location of PNG library" >&5
+echo "configure:8329: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8361,13 +8350,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8365: checking for png_read_image in -lpng" >&5
+echo "configure:8354: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8371 "configure"
+#line 8360 "configure"
@@ -8378,7 +8367,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8418,186 +8407,29 @@
 # Enable TCLTK option
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8427: checking whether to use Tcl/Tk" >&5
+echo "configure:8413: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
-	n|no)
-		TCLTK_TYPE=none
-	y|yes|x|x11)
-		TCLTK_TYPE=X11
-		USE_TCLTK=1
-		TCLTK_X11=1
-	aqua|mac|osx|macosx)
-		TCLTK_TYPE=Aqua
-		USE_TCLTK=1
-		TCLTK_AQUA=1
-	win|windows|mswin)
-		TCLTK_TYPE=Windows
-		USE_TCLTK=1
-		TCLTK_WINDOWS=1
-		{ echo "configure: error: *** Valid arguments for --with-tcltk= are yes,no,x11,aqua,windows." 1>&2; exit 1; }
+	"no")	USE_TCLTK=	;;
+	"yes")	USE_TCLTK="1"	;;
+	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
 esac
-if test -n "$USE_TCLTK"; then
-if test -n "$TCLTK_AQUA" ; then
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
-echo $ac_n "checking for location of Tcl/Tk framework""... $ac_c" 1>&6
-echo "configure:8459: checking for location of Tcl/Tk framework" >&5
-case "$with_tcltk_framework" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-tcltk-framework." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_tcltk_framework" 1>&6
+if test -n "$USE_TCLTK"; then
-if test -n "$with_tcltk_framework"; then
-    if test -d $with_tcltk_framework; then
-        TCLTKPATH="$TCLTKPATH -F$with_tcltk_framework"
-    else
-        { echo "configure: error: *** Tcl/Tk framework directory $dir does not exist." 1>&2; exit 1; }
-    fi
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$TCLTKPATH $CPPFLAGS"
-for ac_hdr in Tk/tk.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8483: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 8486 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tcl/Tk includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-ac_save_libs="$LIBS"
-ac_save_ldflags="$LDFLAGS"
-LIBS="-framework Tcl -framework Tk  $LIBS"
-LDFLAGS="$TCLTKPATH $LDFLAGS"
-echo $ac_n "checking for Tk_MainWindow""... $ac_c" 1>&6
-echo "configure:8527: checking for Tk_MainWindow" >&5
-#line 8530 "configure"
-/* System header to define __stub macros and hopefully few prototypes,
-    which can conflict with char Tk_MainWindow(); below.  */
-#include <assert.h>
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char Tk_MainWindow();
-int main() {
-/* The GNU C library defines this for functions which it implements
-    to always fail with ENOSYS.  Some functions are actually named
-    something starting with __ and the normal name is an alias.  */
-#if defined (__stub_Tk_MainWindow) || defined (__stub___Tk_MainWindow)
-choke me
-#else
-Tk_MainWindow();
-#endif
-; return 0; }
-EOF
-if { (eval echo configure:8553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_func_Tk_MainWindow=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_func_Tk_MainWindow=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_func_'Tk_MainWindow`\" = yes"; then
-    TCLTKLIBS="$TCLTKLIBS -framework Tcl -framework Tk"
-else
-{ echo "configure: error: *** Unable to locate Tk_MainWindow." 1>&2; exit 1; }
-fi
-LIBS=${ac_save_libs}
-LDFLAGS=${ac_save_ldflags}
-TCLINCDIR="$TCLTKPATH"
-TCLTKLIBPATH="$TCLTKPATH"
-cat >> confdefs.h <<\EOF
-#define TCLTK_AQUA 1
-EOF
-fi # TCLTK_AQUA
-if test -n "$TCLTK_X11" -o -n "$TCLTK_WINDOWS" ; then
 # With Tcl/Tk includes directory
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8601: checking for location of Tcl/Tk includes" >&5
+echo "configure:8433: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8623,15 +8455,15 @@
 do
-echo "configure:8627: checking for $ac_hdr" >&5
+echo "configure:8459: checking for $ac_hdr" >&5
-#line 8630 "configure"
+#line 8462 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8668,15 +8500,15 @@
 do
-echo "configure:8672: checking for $ac_hdr" >&5
+echo "configure:8504: checking for $ac_hdr" >&5
-#line 8675 "configure"
+#line 8507 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8710,7 +8542,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8714: checking Tcl version" >&5
+echo "configure:8546: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8718,7 +8550,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8722 "configure"
+#line 8554 "configure"
 #include <stdio.h>
@@ -8730,7 +8562,7 @@
 EOF
-if { (eval echo configure:8734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8748,7 +8580,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8752: checking Tk version" >&5
+echo "configure:8584: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8756,7 +8588,7 @@
 else
-#line 8760 "configure"
+#line 8592 "configure"
 #include <stdio.h>
@@ -8768,7 +8600,7 @@
 EOF
-if { (eval echo configure:8772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8797,7 +8629,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8801: checking for location of Tcl/Tk library" >&5
+echo "configure:8633: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8827,13 +8659,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8831: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8663: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8837 "configure"
+#line 8669 "configure"
@@ -8844,7 +8676,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8863,13 +8695,13 @@
-echo "configure:8867: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8699: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8873 "configure"
+#line 8705 "configure"
@@ -8880,7 +8712,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8907,13 +8739,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8911: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8743: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8917 "configure"
+#line 8749 "configure"
@@ -8924,7 +8756,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8943,13 +8775,13 @@
-echo "configure:8947: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8779: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8953 "configure"
+#line 8785 "configure"
@@ -8960,7 +8792,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8987,13 +8819,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8991: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8823: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8997 "configure"
+#line 8829 "configure"
@@ -9004,7 +8836,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9023,13 +8855,13 @@
-echo "configure:9027: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8859: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9033 "configure"
+#line 8865 "configure"
@@ -9040,7 +8872,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9118,13 +8950,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9122: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8954: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9128 "configure"
+#line 8960 "configure"
@@ -9135,7 +8967,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9154,13 +8986,13 @@
-echo "configure:9158: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8990: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9164 "configure"
+#line 8996 "configure"
@@ -9171,7 +9003,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9198,13 +9030,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9202: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9034: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9208 "configure"
+#line 9040 "configure"
@@ -9215,7 +9047,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9234,13 +9066,13 @@
-echo "configure:9238: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9070: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9244 "configure"
+#line 9076 "configure"
@@ -9251,7 +9083,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9278,13 +9110,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9282: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9114: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9288 "configure"
+#line 9120 "configure"
@@ -9295,7 +9127,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9314,13 +9146,13 @@
-echo "configure:9318: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9150: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9324 "configure"
+#line 9156 "configure"
@@ -9331,7 +9163,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9401,49 +9233,29 @@
-TCLTKLIBS="$TKLIB $TCLLIB"
-if test -n "$TCLTK_X11" ; then
+TCLTKLIBS="$TKLIB $TCLLIB"
-#define TCLTK_X11 1
-EOF
-fi
-if test -n "$TCLTK_WINDOWS" ; then
-#define TCLTK_WINDOWS 1
-EOF
-fi
-fi # TCLTK_X11 || TCLTK_WINDOWS
 #define HAVE_TCLTK 1
 EOF
 fi # $USE_TCLTK
-TKINCDIR="$TCLINCDIR"
+TKINCDIR=$TCLINCDIR
 # Done checking Tcl/Tk
 # Enable PostgreSQL option
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9447: checking whether to use PostgreSQL" >&5
+echo "configure:9259: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9470,7 +9282,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9474: checking for location of PostgreSQL includes" >&5
+echo "configure:9286: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9496,15 +9308,15 @@
 do
-echo "configure:9500: checking for $ac_hdr" >&5
+echo "configure:9312: checking for $ac_hdr" >&5
-#line 9503 "configure"
+#line 9315 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9542,7 +9354,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9546: checking for location of PostgreSQL library" >&5
+echo "configure:9358: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9571,13 +9383,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9575: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9387: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9581 "configure"
+#line 9393 "configure"
@@ -9588,7 +9400,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9607,13 +9419,13 @@
-echo "configure:9611: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9423: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9617 "configure"
+#line 9429 "configure"
@@ -9624,7 +9436,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9643,13 +9455,13 @@
-echo "configure:9647: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9459: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9653 "configure"
+#line 9465 "configure"
@@ -9660,7 +9472,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9679,13 +9491,13 @@
-echo "configure:9683: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9495: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9689 "configure"
+#line 9501 "configure"
@@ -9696,7 +9508,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9753,13 +9565,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9757: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9569: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9763 "configure"
+#line 9575 "configure"
@@ -9770,7 +9582,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9792,13 +9604,13 @@
-echo "configure:9796: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9608: checking for PQcmdTuples in -lpq" >&5
-#line 9802 "configure"
+#line 9614 "configure"
@@ -9809,7 +9621,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9852,7 +9664,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9856: checking whether to use MySQL" >&5
+echo "configure:9668: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9872,7 +9684,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9876: checking for location of MySQL includes" >&5
+echo "configure:9688: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9898,15 +9710,15 @@
 do
-echo "configure:9902: checking for $ac_hdr" >&5
+echo "configure:9714: checking for $ac_hdr" >&5
-#line 9905 "configure"
+#line 9717 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9943,7 +9755,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9947: checking for location of MySQL library" >&5
+echo "configure:9759: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9974,13 +9786,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9978: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9790: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9984 "configure"
+#line 9796 "configure"
@@ -9991,7 +9803,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10010,13 +9822,13 @@
-echo "configure:10014: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9826: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10020 "configure"
+#line 9832 "configure"
@@ -10027,7 +9839,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10046,13 +9858,13 @@
-echo "configure:10050: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9862: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10056 "configure"
+#line 9868 "configure"
@@ -10063,7 +9875,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10082,13 +9894,13 @@
-echo "configure:10086: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9898: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10092 "configure"
+#line 9904 "configure"
@@ -10099,7 +9911,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10118,13 +9930,13 @@
-echo "configure:10122: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9934: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10128 "configure"
+#line 9940 "configure"
@@ -10135,7 +9947,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10154,13 +9966,13 @@
-echo "configure:10158: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9970: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10164 "configure"
+#line 9976 "configure"
@@ -10171,7 +9983,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10190,13 +10002,13 @@
-echo "configure:10194: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10006: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10200 "configure"
+#line 10012 "configure"
@@ -10207,7 +10019,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10226,13 +10038,13 @@
-echo "configure:10230: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10042: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10236 "configure"
+#line 10048 "configure"
@@ -10243,7 +10055,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10333,7 +10145,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10337: checking for $ac_word" >&5
+echo "configure:10149: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10374,10 +10186,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10378: checking for mysql_server_init" >&5
+echo "configure:10190: checking for mysql_server_init" >&5
-#line 10381 "configure"
+#line 10193 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -10400,7 +10212,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10438,7 +10250,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10442: checking whether to use SQLite" >&5
+echo "configure:10254: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10458,7 +10270,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10462: checking for location of SQLite includes" >&5
+echo "configure:10274: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10484,15 +10296,15 @@
 do
-echo "configure:10488: checking for $ac_hdr" >&5
+echo "configure:10300: checking for $ac_hdr" >&5
-#line 10491 "configure"
+#line 10303 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10496: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10308: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10535,7 +10347,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10539: checking for location of SQLite library" >&5
+echo "configure:10351: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10562,13 +10374,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10566: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10378: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10572 "configure"
+#line 10384 "configure"
@@ -10579,7 +10391,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10598,13 +10410,13 @@
-echo "configure:10602: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10414: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10608 "configure"
+#line 10420 "configure"
@@ -10615,7 +10427,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10668,7 +10480,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10672: checking whether to use FFMPEG" >&5
+echo "configure:10484: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10688,7 +10500,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10692: checking for location of FFMPEG includes" >&5
+echo "configure:10504: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10714,15 +10526,15 @@
 do
-echo "configure:10718: checking for $ac_hdr" >&5
+echo "configure:10530: checking for $ac_hdr" >&5
-#line 10721 "configure"
+#line 10533 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10538: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10758,15 +10570,15 @@
 do
-echo "configure:10762: checking for $ac_hdr" >&5
+echo "configure:10574: checking for $ac_hdr" >&5
-#line 10765 "configure"
+#line 10577 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10802,15 +10614,15 @@
 do
-echo "configure:10806: checking for $ac_hdr" >&5
+echo "configure:10618: checking for $ac_hdr" >&5
-#line 10809 "configure"
+#line 10621 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10626: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10853,7 +10665,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10857: checking for location of FFMPEG library" >&5
+echo "configure:10669: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10880,13 +10692,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10884: checking for av_free in -lavutil" >&5
+echo "configure:10696: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10890 "configure"
+#line 10702 "configure"
@@ -10897,7 +10709,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10916,13 +10728,13 @@
-echo "configure:10920: checking for av_free in -lavutil" >&5
+echo "configure:10732: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10926 "configure"
+#line 10738 "configure"
@@ -10933,7 +10745,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10978,13 +10790,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10982: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10794: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10988 "configure"
+#line 10800 "configure"
@@ -10995,7 +10807,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11014,13 +10826,13 @@
-echo "configure:11018: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10830: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11024 "configure"
+#line 10836 "configure"
@@ -11031,7 +10843,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11076,13 +10888,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11080: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10892: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11086 "configure"
+#line 10898 "configure"
@@ -11093,7 +10905,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11112,13 +10924,13 @@
-echo "configure:11116: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10928: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11122 "configure"
+#line 10934 "configure"
@@ -11129,7 +10941,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11189,7 +11001,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11193: checking whether to use OpenGL" >&5
+echo "configure:11005: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11223,7 +11035,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11227: checking for location of OpenGL includes" >&5
+echo "configure:11039: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11249,15 +11061,15 @@
 do
-echo "configure:11253: checking for $ac_hdr" >&5
+echo "configure:11065: checking for $ac_hdr" >&5
-#line 11256 "configure"
+#line 11068 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11291,7 +11103,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11295: checking for location of OpenGL library" >&5
+echo "configure:11107: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11320,13 +11132,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11324: checking for glBegin in -lGL" >&5
+echo "configure:11136: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11330 "configure"
+#line 11142 "configure"
@@ -11337,7 +11149,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11356,13 +11168,13 @@
-echo "configure:11360: checking for glBegin in -lGL" >&5
+echo "configure:11172: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11366 "configure"
+#line 11178 "configure"
@@ -11373,7 +11185,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11392,13 +11204,13 @@
-echo "configure:11396: checking for glBegin in -lGL" >&5
+echo "configure:11208: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11402 "configure"
+#line 11214 "configure"
@@ -11409,7 +11221,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11428,13 +11240,13 @@
-echo "configure:11432: checking for glBegin in -lGL" >&5
+echo "configure:11244: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11438 "configure"
+#line 11250 "configure"
@@ -11445,7 +11257,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11507,13 +11319,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11511: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11323: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11517 "configure"
+#line 11329 "configure"
@@ -11524,7 +11336,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11543,13 +11355,13 @@
-echo "configure:11547: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11359: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11553 "configure"
+#line 11365 "configure"
@@ -11560,7 +11372,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11607,10 +11419,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11611: checking for glXCreatePbuffer" >&5
+echo "configure:11423: checking for glXCreatePbuffer" >&5
-#line 11614 "configure"
+#line 11426 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11633,7 +11445,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11670,10 +11482,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11674: checking for glXCreateGLXPixmap" >&5
+echo "configure:11486: checking for glXCreateGLXPixmap" >&5
-#line 11677 "configure"
+#line 11489 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11696,7 +11508,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11739,7 +11551,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11743: checking for location of OpenGL framework" >&5
+echo "configure:11555: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11763,15 +11575,15 @@
 do
-echo "configure:11767: checking for $ac_hdr" >&5
+echo "configure:11579: checking for $ac_hdr" >&5
-#line 11770 "configure"
+#line 11582 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11587: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11807,10 +11619,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11811: checking for glBegin" >&5
+echo "configure:11623: checking for glBegin" >&5
-#line 11814 "configure"
+#line 11626 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11833,7 +11645,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11870,10 +11682,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11874: checking for gluBeginCurve" >&5
+echo "configure:11686: checking for gluBeginCurve" >&5
-#line 11877 "configure"
+#line 11689 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11896,7 +11708,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11944,7 +11756,7 @@
-echo "configure:11948: checking for location of OpenGL includes" >&5
+echo "configure:11760: checking for location of OpenGL includes" >&5
@@ -11970,15 +11782,15 @@
 do
-echo "configure:11974: checking for $ac_hdr" >&5
+echo "configure:11786: checking for $ac_hdr" >&5
-#line 11977 "configure"
+#line 11789 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11982: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12012,7 +11824,7 @@
-echo "configure:12016: checking for location of OpenGL library" >&5
+echo "configure:11828: checking for location of OpenGL library" >&5
@@ -12037,18 +11849,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12041: checking for OpenGL library" >&5
+echo "configure:11853: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 12045 "configure"
+#line 11857 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:12052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -12072,18 +11884,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12076: checking for GLU library" >&5
+echo "configure:11888: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 12080 "configure"
+#line 11892 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12132,7 +11944,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12136: checking whether to use ODBC" >&5
+echo "configure:11948: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12151,7 +11963,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12155: checking for location of ODBC includes" >&5
+echo "configure:11967: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12177,15 +11989,15 @@
 do
-echo "configure:12181: checking for $ac_hdr" >&5
+echo "configure:11993: checking for $ac_hdr" >&5
-#line 12184 "configure"
+#line 11996 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12219,7 +12031,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12223: checking for location of ODBC library" >&5
+echo "configure:12035: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12244,13 +12056,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12248: checking for SQLConnect in -lodbc" >&5
+echo "configure:12060: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12254 "configure"
+#line 12066 "configure"
@@ -12261,7 +12073,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12286,13 +12098,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12290: checking for SQLConnect in -liodbc" >&5
+echo "configure:12102: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12296 "configure"
+#line 12108 "configure"
@@ -12303,7 +12115,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12328,11 +12140,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12332: checking for ODBC library" >&5
+echo "configure:12144: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12336 "configure"
+#line 12148 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12340,7 +12152,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12389,7 +12201,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12393: checking whether to use FFTW" >&5
+echo "configure:12205: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12408,7 +12220,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12412: checking for location of FFTW includes" >&5
+echo "configure:12224: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12434,15 +12246,15 @@
 do
-echo "configure:12438: checking for $ac_hdr" >&5
+echo "configure:12250: checking for $ac_hdr" >&5
-#line 12441 "configure"
+#line 12253 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12446: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12470,15 +12282,15 @@
 do
-echo "configure:12474: checking for $ac_hdr" >&5
+echo "configure:12286: checking for $ac_hdr" >&5
-#line 12477 "configure"
+#line 12289 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12506,15 +12318,15 @@
 do
-echo "configure:12510: checking for $ac_hdr" >&5
+echo "configure:12322: checking for $ac_hdr" >&5
-#line 12513 "configure"
+#line 12325 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12518: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12560,7 +12372,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12564: checking for location of FFTW library" >&5
+echo "configure:12376: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12585,13 +12397,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12589: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12401: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12595 "configure"
+#line 12407 "configure"
@@ -12602,7 +12414,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12627,13 +12439,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12631: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12443: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12637 "configure"
+#line 12449 "configure"
@@ -12644,7 +12456,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12669,13 +12481,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12673: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12485: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12679 "configure"
+#line 12491 "configure"
@@ -12686,7 +12498,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12743,7 +12555,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12747: checking whether to use BLAS" >&5
+echo "configure:12559: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12764,7 +12576,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12768: checking for location of BLAS includes" >&5
+echo "configure:12580: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12784,7 +12596,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12788: checking for location of BLAS library" >&5
+echo "configure:12600: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12810,15 +12622,15 @@
 do
-echo "configure:12814: checking for $ac_hdr" >&5
+echo "configure:12626: checking for $ac_hdr" >&5
-#line 12817 "configure"
+#line 12629 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12853,13 +12665,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12857: checking for dnrm2_ in -lblas" >&5
+echo "configure:12669: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12863 "configure"
+#line 12675 "configure"
@@ -12870,7 +12682,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12889,13 +12701,13 @@
-echo "configure:12893: checking for dnrm2_ in -lblas" >&5
+echo "configure:12705: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12899 "configure"
+#line 12711 "configure"
@@ -12906,7 +12718,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12950,13 +12762,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12954: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12766: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12960 "configure"
+#line 12772 "configure"
@@ -12967,7 +12779,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12982,13 +12794,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12986: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12798: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12992 "configure"
+#line 12804 "configure"
@@ -12999,7 +12811,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13014,13 +12826,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13018: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12830: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13024 "configure"
+#line 12836 "configure"
@@ -13031,7 +12843,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13076,16 +12888,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13080: checking for sgemm in $vlib_flags" >&5
+echo "configure:12892: checking for sgemm in $vlib_flags" >&5
-#line 13082 "configure"
+#line 12894 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13103,13 +12915,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13107: checking for sgemm_ in -lblas" >&5
+echo "configure:12919: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13113 "configure"
+#line 12925 "configure"
@@ -13120,7 +12932,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13135,13 +12947,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13139: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12951: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13145 "configure"
+#line 12957 "configure"
@@ -13152,7 +12964,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13167,13 +12979,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13171: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12983: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13177 "configure"
+#line 12989 "configure"
@@ -13184,7 +12996,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13218,13 +13030,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13222: checking for acosp in -lsunmath" >&5
+echo "configure:13034: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13228 "configure"
+#line 13040 "configure"
@@ -13235,7 +13047,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13250,13 +13062,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13254: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13066: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13260 "configure"
+#line 13072 "configure"
@@ -13267,7 +13079,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13297,13 +13109,13 @@
 # Generic BLAS library
-echo "configure:13301: checking for sgemm_ in -lblas" >&5
+echo "configure:13113: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 13307 "configure"
+#line 13119 "configure"
 #include "confdefs.h"
@@ -13314,7 +13126,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13353,7 +13165,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13357: checking whether to use LAPACK" >&5
+echo "configure:13169: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13378,7 +13190,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13382: checking for location of LAPACK includes" >&5
+echo "configure:13194: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13398,7 +13210,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13402: checking for location of LAPACK library" >&5
+echo "configure:13214: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13424,15 +13236,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13428: checking for $ac_hdr" >&5
+echo "configure:13240: checking for $ac_hdr" >&5
-#line 13431 "configure"
+#line 13243 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13248: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13464,10 +13276,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13468: checking for dsegv_" >&5
+echo "configure:13280: checking for dsegv_" >&5
-#line 13471 "configure"
+#line 13283 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char dsegv_(); below.  */
@@ -13490,7 +13302,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13517,13 +13329,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13521: checking for desgv_ in -llapack" >&5
+echo "configure:13333: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13527 "configure"
+#line 13339 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13534,7 +13346,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13566,13 +13378,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13570: checking for dgesv_ in -llapack" >&5
+echo "configure:13382: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13576 "configure"
+#line 13388 "configure"
@@ -13583,7 +13395,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13602,13 +13414,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13606: checking for dgesv_ in -llapack" >&5
+echo "configure:13418: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13612 "configure"
+#line 13424 "configure"
@@ -13619,7 +13431,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13675,7 +13487,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13679: checking whether to use Motif" >&5
+echo "configure:13491: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13694,7 +13506,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13698: checking for location of Motif includes" >&5
+echo "configure:13510: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13720,15 +13532,15 @@
 do
-echo "configure:13724: checking for $ac_hdr" >&5
+echo "configure:13536: checking for $ac_hdr" >&5
-#line 13727 "configure"
+#line 13539 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13762,7 +13574,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13766: checking for location of Motif library" >&5
+echo "configure:13578: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13787,13 +13599,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13791: checking for XmStringCreate in -lXm" >&5
+echo "configure:13603: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13797 "configure"
+#line 13609 "configure"
@@ -13804,7 +13616,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13845,7 +13657,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13849: checking whether to use Cairo" >&5
+echo "configure:13661: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13871,15 +13683,15 @@
 do
-echo "configure:13875: checking for $ac_hdr" >&5
+echo "configure:13687: checking for $ac_hdr" >&5
-#line 13878 "configure"
+#line 13690 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13919,10 +13731,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13923: checking for cairo_create" >&5
+echo "configure:13735: checking for cairo_create" >&5
-#line 13926 "configure"
+#line 13738 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13945,7 +13757,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13986,7 +13798,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13990: checking whether to use GLw" >&5
+echo "configure:13802: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14005,7 +13817,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14009: checking for location of GLw includes" >&5
+echo "configure:13821: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14031,15 +13843,15 @@
 do
-echo "configure:14035: checking for $ac_hdr" >&5
+echo "configure:13847: checking for $ac_hdr" >&5
-#line 14038 "configure"
+#line 13850 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14043: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14067,15 +13879,15 @@
 do
-echo "configure:14071: checking for $ac_hdr" >&5
+echo "configure:13883: checking for $ac_hdr" >&5
-#line 14074 "configure"
+#line 13886 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14079: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14115,7 +13927,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14119: checking for location of GLw library" >&5
+echo "configure:13931: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14140,13 +13952,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14144: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13956: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14150 "configure"
+#line 13962 "configure"
@@ -14157,7 +13969,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14182,13 +13994,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14186: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13998: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14192 "configure"
+#line 14004 "configure"
@@ -14199,7 +14011,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14224,13 +14036,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14228: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14040: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14234 "configure"
+#line 14046 "configure"
@@ -14241,7 +14053,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14266,13 +14078,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14270: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14082: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14276 "configure"
+#line 14088 "configure"
@@ -14283,7 +14095,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14308,13 +14120,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14312: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14124: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14318 "configure"
+#line 14130 "configure"
@@ -14325,7 +14137,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14350,13 +14162,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14354: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14166: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14360 "configure"
+#line 14172 "configure"
@@ -14367,7 +14179,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14394,13 +14206,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14398: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14210: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14404 "configure"
+#line 14216 "configure"
@@ -14411,7 +14223,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14430,13 +14242,13 @@
-echo "configure:14434: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14246: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14440 "configure"
+#line 14252 "configure"
@@ -14447,7 +14259,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14474,13 +14286,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14478: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14290: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14484 "configure"
+#line 14296 "configure"
@@ -14491,7 +14303,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14510,13 +14322,13 @@
-echo "configure:14514: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14326: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14520 "configure"
+#line 14332 "configure"
@@ -14527,7 +14339,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14640,7 +14452,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14644: checking whether to use FreeType" >&5
+echo "configure:14456: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14659,7 +14471,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14663: checking for location of FreeType includes" >&5
+echo "configure:14475: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14685,15 +14497,15 @@
 do
-echo "configure:14689: checking for $ac_hdr" >&5
+echo "configure:14501: checking for $ac_hdr" >&5
-#line 14692 "configure"
+#line 14504 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14509: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14727,7 +14539,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14731: checking for location of FreeType library" >&5
+echo "configure:14543: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14752,13 +14564,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14756: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14568: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14762 "configure"
+#line 14574 "configure"
@@ -14769,7 +14581,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14810,7 +14622,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14814: checking whether to use NLS" >&5
+echo "configure:14626: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14830,10 +14642,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14834: checking for gettext" >&5
+echo "configure:14646: checking for gettext" >&5
-#line 14837 "configure"
+#line 14649 "configure"
     which can conflict with char gettext(); below.  */
@@ -14856,7 +14668,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14874,13 +14686,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14878: checking for gettext in -lintl" >&5
+echo "configure:14690: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14884 "configure"
+#line 14696 "configure"
@@ -14891,7 +14703,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14926,7 +14738,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14930: checking whether to use C++" >&5
+echo "configure:14742: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14942,7 +14754,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14946: checking for $ac_word" >&5
+echo "configure:14758: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14971,7 +14783,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14975: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14787: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14982,12 +14794,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14986 "configure"
+#line 14798 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15013,19 +14825,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15017: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14829: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15022: checking whether we are using GNU C++" >&5
+echo "configure:14834: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15043,7 +14855,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15047: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14859: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15084,7 +14896,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15088: checking whether to use openDWG" >&5
+echo "configure:14900: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15104,7 +14916,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15108: checking for location of openDGW includes" >&5
+echo "configure:14920: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15130,15 +14942,15 @@
 do
-echo "configure:15134: checking for $ac_hdr" >&5
+echo "configure:14946: checking for $ac_hdr" >&5
-#line 15137 "configure"
+#line 14949 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15172,7 +14984,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15176: checking for location of openDWG library" >&5
+echo "configure:14988: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15219,7 +15031,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15223: checking for special C compiler options needed for large files" >&5
+echo "configure:15035: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15227,7 +15039,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15231 "configure"
+#line 15043 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15243,7 +15055,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15252,7 +15064,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15256 "configure"
+#line 15068 "configure"
@@ -15268,7 +15080,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15272: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15288,11 +15100,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15292: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15104: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15296 "configure"
+#line 15108 "configure"
@@ -15308,14 +15120,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15312: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15319 "configure"
+#line 15131 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15333,7 +15145,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15337: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15149: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15352,11 +15164,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15356: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15168: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15360 "configure"
+#line 15172 "configure"
@@ -15372,14 +15184,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15376: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15188: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15383 "configure"
+#line 15195 "configure"
 #define _LARGE_FILES 1
@@ -15397,7 +15209,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15416,25 +15228,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15420: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15232: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15424 "configure"
+#line 15236 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15243: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15438 "configure"
+#line 15250 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15443,7 +15255,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15447: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15464,10 +15276,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15468: checking if system supports Large Files at all" >&5
+echo "configure:15280: checking if system supports Large Files at all" >&5
-#line 15471 "configure"
+#line 15283 "configure"
 #include <stdio.h>
@@ -15499,7 +15311,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15503: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15315: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15528,7 +15340,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15532: checking whether to use Python" >&5
+echo "configure:15344: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15548,7 +15360,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15552: checking for $ac_word" >&5
+echo "configure:15364: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15593,15 +15405,15 @@
 do
-echo "configure:15597: checking for $ac_hdr" >&5
+echo "configure:15409: checking for $ac_hdr" >&5
-#line 15600 "configure"
+#line 15412 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15641,7 +15453,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15645: checking for $ac_word" >&5
+echo "configure:15457: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15687,7 +15499,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15691: checking whether to use wxWidgets" >&5
+echo "configure:15503: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15707,7 +15519,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15711: checking for $ac_word" >&5
+echo "configure:15523: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15755,7 +15567,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15759: checking wxWidgets version" >&5
+echo "configure:15571: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15778,15 +15590,15 @@
 do
-echo "configure:15782: checking for $ac_hdr" >&5
+echo "configure:15594: checking for $ac_hdr" >&5
-#line 15785 "configure"
+#line 15597 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15822,15 +15634,15 @@
 do
-echo "configure:15826: checking for $ac_hdr" >&5
+echo "configure:15638: checking for $ac_hdr" >&5
-#line 15829 "configure"
+#line 15641 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16078,10 +15890,6 @@
 s%@PNGINC@%$PNGINC%g
 s%@PNGLIB@%$PNGLIB%g
 s%@USE_PNG@%$USE_PNG%g
-s%@USE_TCLTK@%$USE_TCLTK%g
-s%@TCLTK_X11@%$TCLTK_X11%g
-s%@TCLTK_AQUA@%$TCLTK_AQUA%g
-s%@TCLTK_WINDOWS@%$TCLTK_WINDOWS%g
 s%@TCLINCDIR@%$TCLINCDIR%g
 s%@TKINCDIR@%$TKINCDIR%g
 s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
@@ -16421,9 +16229,6 @@
 echo "  OpenGL platform:             ${OPENGL_TYPE}"
-echo "  Tcl/Tk platform:             ${TCLTK_TYPE}"
 echo "  MacOSX application:         `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
 echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-07-29 13:19:00 UTC (rev 32362)
+++ grass/trunk/configure.in	2008-07-29 13:44:13 UTC (rev 32363)
@@ -233,7 +233,6 @@
 LOC_ARG_WITH_INC(tcltk, Tcl/Tk)
 LOC_ARG_WITH_LIB(tcltk, Tcl/Tk)
-LOC_ARG_WITH_FRAMEWORK(tcltk, Tcl/Tk)
 LOC_ARG_WITH_INC(postgres, PostgreSQL)
 LOC_ARG_WITH_LIB(postgres, PostgreSQL)
@@ -792,55 +791,14 @@
 # Enable TCLTK option
+LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
 TCLINCDIR=
 TCLTKLIBPATH=
 TCLTKLIBS=
-AC_MSG_CHECKING(whether to use Tcl/Tk)
-AC_MSG_RESULT("$with_tcltk")
-case "$with_tcltk" in
-	n|no)
-		TCLTK_TYPE=none
-	y|yes|x|x11)
-		TCLTK_TYPE=X11
-		USE_TCLTK=1
-		TCLTK_X11=1
-	aqua|mac|osx|macosx)
-		TCLTK_TYPE=Aqua
-		USE_TCLTK=1
-		TCLTK_AQUA=1
-	win|windows|mswin)
-		TCLTK_TYPE=Windows
-		USE_TCLTK=1
-		TCLTK_WINDOWS=1
-		AC_MSG_ERROR([*** Valid arguments for --with-tcltk= are yes,no,x11,aqua,windows.])
-esac
 if test -n "$USE_TCLTK"; then
-if test -n "$TCLTK_AQUA" ; then
-LOC_CHECK_FRAMEWORK_PATH(tcltk,Tcl/Tk,TCLTKPATH)
-LOC_CHECK_INCLUDES(Tk/tk.h,Tcl/Tk,$TCLTKPATH)
-LOC_CHECK_FUNC(Tk_MainWindow,Tcl/Tk framework,TCLTKLIBS,-framework Tcl -framework Tk,$TCLTKPATH)
-TCLINCDIR="$TCLTKPATH"
-TCLTKLIBPATH="$TCLTKPATH"
-AC_DEFINE(TCLTK_AQUA)
-fi # TCLTK_AQUA
-if test -n "$TCLTK_X11" -o -n "$TCLTK_WINDOWS" ; then
 # With Tcl/Tk includes directory
 LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
@@ -885,28 +843,14 @@
 ],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
-TCLTKLIBS="$TKLIB $TCLLIB"
-if test -n "$TCLTK_X11" ; then
-AC_DEFINE(TCLTK_X11)
-fi
-if test -n "$TCLTK_WINDOWS" ; then
-AC_DEFINE(TCLTK_WINDOWS)
-fi
-fi # TCLTK_X11 || TCLTK_WINDOWS
+TCLTKLIBS="$TKLIB $TCLLIB"
 AC_DEFINE(HAVE_TCLTK)
 fi # $USE_TCLTK
-TKINCDIR="$TCLINCDIR"
+TKINCDIR=$TCLINCDIR
-AC_SUBST(USE_TCLTK)
-AC_SUBST(TCLTK_X11)
-AC_SUBST(TCLTK_AQUA)
-AC_SUBST(TCLTK_WINDOWS)
 AC_SUBST(TCLINCDIR)
 AC_SUBST(TKINCDIR)
 AC_SUBST(TCLTKLIBPATH)
@@ -1817,7 +1761,6 @@
 LOC_MSG([  Building shared libraries:   ${shared_ok}])
 LOC_MSG([  64bit support:               ${do64bit}])
 LOC_MSG([  OpenGL platform:             ${OPENGL_TYPE}])
-LOC_MSG([  Tcl/Tk platform:             ${TCLTK_TYPE}])
 LOC_MSG_USE(MacOSX application,MACOSX_APP)
 LOC_MSG()
 LOC_MSG_USE(NVIZ,USE_TOGL)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2008-07-29 13:19:00 UTC (rev 32362)
+++ grass/trunk/include/Make/Platform.make.in	2008-07-29 13:44:13 UTC (rev 32363)
@@ -170,9 +170,6 @@
 TKINCDIR            = @TKINCDIR@
 TCLTKLIBPATH        = @TCLTKLIBPATH@
 TCLTKLIBS           = @TCLTKLIBS@
-TCLTK_X11           = @TCLTK_X11@
-TCLTK_AQUA          = @TCLTK_AQUA@
-TCLTK_WINDOWS       = @TCLTK_WINDOWS@
 USE_TCLTK           = @USE_TCLTK@
 #FFTW:
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2008-07-29 13:19:00 UTC (rev 32362)
+++ grass/trunk/include/config.h.in	2008-07-29 13:44:13 UTC (rev 32363)
@@ -245,15 +245,6 @@
 /* define if OpenGL uses Windows */
 #undef OPENGL_WINDOWS
-/* define if Tcl/Tk uses X11 */
-#undef TCLTK_X11
-/* define if Tcl/Tk uses Aqua (MacOS X) */
-#undef TCLTK_AQUA
-/* define if Tcl/Tk uses Windows */
-#undef TCLTK_WINDOWS
  * configuration information solely dependent on the above
  * nothing below this point should need changing
