[GRASS-SVN] r32364 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jul 29 19:31:59 EDT 2008
Author: martinl
Date: 2008-07-29 19:31:59 -0400 (Tue, 29 Jul 2008)
New Revision: 32364
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: general goutput module reconstruction, event-based (fix problems with the last wxPython versions) -- experimental (TODO: abort, clean up gcmd module, use
grass module)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-07-29 13:44:13 UTC (rev 32363)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-07-29 23:31:59 UTC (rev 32364)
@@ -491,8 +491,8 @@
@param stdout redirect standard output or None
@param stderr redirect standard error output or None
- def __init__ (self, cmd, stdin=None,
- stdout=None, stderr=sys.stderr):
+ def __init__ (self, cmd,
+ stdin=None, stdout=None, stderr=sys.stderr):
Thread.__init__(self)
@@ -517,6 +517,7 @@
return
self.startTime = time.time()
# TODO: wx.Exectute/wx.Process (?)
try:
self.module = Popen(self.cmd,
@@ -526,8 +527,7 @@
except OSError, e:
self.rerr = str(e)
return
- # raise CmdError(self.cmd[0], str(e))
if self.stdin: # read stdin if requested ...
self.module.stdin.write(self.stdin)
self.module.stdin.close()
@@ -536,21 +536,6 @@
if self.stdout or self.stderr:
self.__redirect_stream()
- def __read_all(self, fd):
- out = ""
- while True:
- try:
- bytes = fd.read(4096)
- except IOError, e:
- if e[0] != errno.EAGAIN:
- raise
- break
- if not bytes:
- break
- out += bytes
- return out
def __redirect_stream(self):
"""Redirect stream"""
if self.stdout:
@@ -569,31 +554,27 @@
# wait for the process to end, sucking in stuff until it does end
while self.module.poll() is None:
- time.sleep(.1)
if self._want_abort: # abort running process
self.module.kill()
self.aborted = True
if hasattr(self.stderr, "gmstc"):
# -> GMConsole
wx.PostEvent(self.stderr.gmstc.parent, ResultEvent(self))
+ pass
return
if self.stdout:
- # line = self.__read_all(self.module.stdout)
line = recv_some(self.module, e=0, stderr=0)
self.stdout.write(line)
if self.stderr:
- # line = self.__read_all(self.module.stderr)
line = recv_some(self.module, e=0, stderr=1)
self.stderr.write(line)
self.rerr = line
# get the last output
if self.stdout:
if self.stderr:
if len(line) > 0:
@@ -602,11 +583,94 @@
# -> GMConsole
+ pass
+ def abort(self):
+ """Abort running process, used by main thread to signal an abort"""
+ self._want_abort = True
+class RunCommand:
+ """Run command in separate thread
+ @param cmd GRASS command (given as list)
+ @param stdin standard input stream
+ @param stdout redirect standard output or None
+ @param stderr redirect standard error output or None
+ def __init__ (self, cmd, stdin=None,
+ stdout=sys.stdout, stderr=sys.stderr):
+ self.cmd = cmd
+ self.stdin = stdin
+ self.stdout = stdout
+ self.stderr = stderr
+ self._want_abort = False
+ self.aborted = False
+ self.startTime = time.time()
+ try:
+ self.module = Popen(self.cmd,
+ stdin=subprocess.PIPE,
+ stdout=subprocess.PIPE,
+ stderr=subprocess.PIPE)
+ except OSError, e:
+ self.rerr = str(e)
+ return 1
+ if self.stdin: # read stdin if requested ...
+ self.module.stdin.write(self.stdin)
+ self.module.stdin.close()
+ # redirect standard outputs...
+ if self.stdout or self.stderr:
+ self.__redirect_stream()
+ def __redirect_stream(self):
+ """Redirect stream"""
+ if self.stdout:
+ # make module stdout/stderr non-blocking
+ out_fileno = self.module.stdout.fileno()
+ if not subprocess.mswindows:
+ flags = fcntl.fcntl(out_fileno, fcntl.F_GETFL)
+ fcntl.fcntl(out_fileno, fcntl.F_SETFL, flags| os.O_NONBLOCK)
+ if self.stderr:
+ out_fileno = self.module.stderr.fileno()
+ # wait for the process to end, sucking in stuff until it does end
+ while self.module.poll() is None:
+ if self._want_abort: # abort running process
+ self.module.kill()
+ return
+ if self.stdout:
+ line = recv_some(self.module, e=0, stderr=0)
+ self.stdout.write(line)
+ if self.stderr:
+ line = recv_some(self.module, e=0, stderr=1)
+ self.stderr.write(line)
+ self.rerr = line
+ # get the last output
+ if self.stdout:
+ if self.stderr:
+ if len(line) > 0:
+ self.rerr = line
def abort(self):
+ print 'a'
# testing ...
if __name__ == "__main__":
SEP = "-----------------------------------------------------------------------------"
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-07-29 13:44:13 UTC (rev 32363)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-07-29 23:31:59 UTC (rev 32364)
@@ -15,21 +15,72 @@
for details.
@author Michael Barton (Arizona State University)
-Martin Landa <landa.martin gmail.com>
+ at author Martin Landa <landa.martin gmail.com>
import os
import sys
import textwrap
import time
+import threading
+import Queue
import wx
import wx.stc
+from wx.lib.newevent import NewEvent
import globalvar
import gcmd
from debug import Debug as Debug
+wxCmdOutput, EVT_CMD_OUTPUT = NewEvent()
+wxCmdProgress, EVT_CMD_PROGRESS = NewEvent()
+wxCmdDone, EVT_CMD_DONE = NewEvent()
+wxCmdAbort, EVT_CMD_ABORT = NewEvent()
+def GrassCmd(cmd, stdout, stderr):
+ """Run GRASS command on background"""
+ return gcmd.RunCommand(cmd=cmd,
+ stdout=stdout, stderr=stderr)
+class CmdThread(threading.Thread):
+ """Thread for GRASS commands"""
+ requestId = 0
+ def __init__(self, parent, requestQ, resultQ, **kwds):
+ threading.Thread.__init__(self, **kwds)
+ self.setDaemon(True)
+ self.parent = parent # GMConsole
+ self.requestQ = requestQ
+ self.resultQ = resultQ
+ self.start()
+ def RunCmd(self, callable, *args, **kwds):
+ CmdThread.requestId += 1
+ self.requestTime = time.time()
+ self.requestQ.put((CmdThread.requestId, callable, args, kwds))
+ return CmdThread.requestId
+ def run(self):
+ while True:
+ requestId, callable, args, kwds = self.requestQ.get()
+ self.resultQ.put((requestId, callable(*args, **kwds)))
+ event = wxCmdDone(aborted=False,
+ time=self.requestTime,
+ pid=requestId)
+ wx.PostEvent(self.parent, event)
+ def abort(self):
+ # TODO
+ print self.resultQ.get_()
class GMConsole(wx.Panel):
Create and manage output console for commands entered on the
@@ -43,33 +94,58 @@
# initialize variables
self.Map = None
self.parent = parent # GMFrame
- self.cmdThreads = {} # cmdThread : cmdPID
self.lineWidth = 80
self.pageid = pageid
+ # create queues
+ self.requestQ = Queue.Queue()
+ self.resultQ = Queue.Queue()
# progress bar
self.console_progressbar = wx.Gauge(parent=self, id=wx.ID_ANY,
range=100, pos=(110, 50), size=(-1, 25),
style=wx.GA_HORIZONTAL)
+ self.console_progressbar.Bind(EVT_CMD_PROGRESS, self.OnCmdProgress)
# text control for command output
self.cmd_output = GMStc(parent=self, id=wx.ID_ANY, margin=margin,
wrap=None)
+ self.cmd_output_timer = wx.Timer(self.cmd_output, id=wx.ID_ANY)
+ self.cmd_output.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
+ self.cmd_output.Bind(wx.EVT_TIMER, self.OnProcessPendingOutputWindowEvents)
+ self.Bind(EVT_CMD_DONE, self.OnCmdDone)
- # redirect
- self.cmd_stdout = GMStdout(self.cmd_output)
- self.cmd_stderr = GMStderr(self.cmd_output,
- self.console_progressbar,
- self.parent.notebook,
- pageid)
+ # stream redirection
+ self.cmd_stdout = GMStdout(self)
+ self.cmd_stderr = GMStderr(self)
+ # thread
+ self.cmdThread = CmdThread(self, self.requestQ, self.resultQ)
# buttons
self.console_clear = wx.Button(parent=self, id=wx.ID_CLEAR)
self.console_save = wx.Button(parent=self, id=wx.ID_SAVE)
self.Bind(wx.EVT_BUTTON, self.ClearHistory, self.console_clear)
self.Bind(wx.EVT_BUTTON, self.SaveHistory, self.console_save)
- # output control layout
+ self.Bind(EVT_CMD_ABORT, self.OnCmdDone)
+ self.__layout()
+ def __layout(self):
+ """Do layout"""
boxsizer1 = wx.BoxSizer(wx.VERTICAL)
gridsizer1 = wx.GridSizer(rows=1, cols=2, vgap=0, hgap=0)
boxsizer1.Add(item=self.cmd_output, proportion=1,
@@ -89,9 +165,6 @@
boxsizer1.Fit(self)
boxsizer1.SetSizeHints(self)
- # set up event handler for any command thread results
- gcmd.EVT_RESULT(self, self.OnResult)
# layout
self.SetAutoLayout(True)
self.SetSizer(boxsizer1)
@@ -104,8 +177,9 @@
if Debug.get_level() == 0:
# don't redirect when debugging is enabled
- sys.stdout = self.cmd_stdout
- sys.stderr = self.cmd_stderr
+ #sys.stdout = self.cmd_stdout
+ #sys.stderr = self.cmd_stderr
+ pass
return True
@@ -122,7 +196,7 @@
if not style:
style = self.cmd_output.StyleDefault
- self.cmd_output.GotoPos(self.cmd_output.GetEndStyled())
+ self.cmd_output.GotoPos(self.cmd_output.GetLength())
p1 = self.cmd_output.GetCurrentPos()
# fill space
@@ -131,16 +205,17 @@
line += diff * ' '
self.cmd_output.AddTextWrapped(line, wrap=wrap) # adds os.linesep
- self.cmd_output.EnsureCaretVisible()
p2 = self.cmd_output.GetCurrentPos()
self.cmd_output.StartStyling(p1, 0xff)
self.cmd_output.SetStyling(p2 - p1, style)
+ self.cmd_output.EnsureCaretVisible()
def WriteCmdLog(self, line, pid=None):
"""Write out line in selected style"""
if pid:
line = '(' + str(pid) + ') ' + line
self.WriteLog(line, self.cmd_output.StyleCommand)
def RunCmd(self, command):
@@ -164,7 +239,7 @@
except:
curr_disp = None
- if len(self.GetListOfCmdThreads()) > 0:
+ if not self.requestQ.empty():
# only one running command enabled (per GMConsole instance)
busy = wx.BusyInfo(message=_("Unable to run the command, another command is running..."),
parent=self)
@@ -228,16 +303,15 @@
menuform.GUI().ParseCommand(cmdlist, parentframe=self)
else:
# process GRASS command with argument
- cmdPID = len(self.cmdThreads.keys())+1
+ cmdPID = self.cmdThread.requestId + 1
self.WriteCmdLog('%s' % ' '.join(cmdlist), pid=cmdPID)
+ self.cmdThread.RunCmd(GrassCmd,
+ cmdlist, self.cmd_stdout, self.cmd_stderr)
- grassCmd = gcmd.Command(cmdlist, wait=False,
- stdout=self.cmd_stdout,
- stderr=self.cmd_stderr)
- self.cmdThreads[grassCmd.cmdThread] = { 'cmdPID' : cmdPID }
- return grassCmd
+ self.cmd_output_timer.Start(50)
+ return None
# deactivate computational region and return to display settings
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
@@ -291,38 +365,68 @@
dlg.Destroy()
- def GetListOfCmdThreads(self, onlyAlive=True):
- """Return list of command threads)"""
- list = []
- for t in self.cmdThreads.keys():
- Debug.msg (4, "GMConsole.GetListOfCmdThreads(): name=%s, alive=%s" %
- (t.getName(), t.isAlive()))
- if onlyAlive and not t.isAlive():
- continue
- list.append(t)
+ def GetCmd(self):
+ """Get running command or None"""
+ return self.requestQ.get()
+ def OnCmdOutput(self, event):
+ """Print command output"""
+ message = event.text
+ type = event.type
- return list
+ # message prefix
+ if type == 'warning':
+ messege = 'WARNING: ' + message
+ elif type == 'error':
+ message = 'ERROR: ' + message
+ p1 = self.cmd_output.GetCurrentPos()
- def OnResult(self, event):
- """Show result status"""
+ if os.linesep not in message:
+ self.cmd_output.AddTextWrapped(message, wrap=60)
+ else:
+ self.cmd_output.AppendText(message)
+ p2 = self.cmd_output.GetCurrentPos()
+ self.cmd_output.StartStyling(p1, 0xff)
+ if type == 'error':
+ self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleError)
+ elif type == 'warning':
+ self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleWarning)
+ elif type == 'message':
+ self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleMessage)
+ else: # unknown
+ self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleUnknown)
- if event.cmdThread.aborted:
+ def OnCmdProgress(self, event):
+ """Update progress message info"""
+ self.console_progressbar.SetValue(event.value)
+ def OnCmdDone(self, event):
+ """Command done (or aborted)"""
+ if event.aborted:
+ self.cmdThread.abort()
# Thread aborted (using our convention of None return)
self.WriteLog(_('Please note that the data are left in incosistent stage '
'and can be corrupted'), self.cmd_output.StyleWarning)
self.WriteCmdLog(_('Command aborted'),
- pid=self.cmdThreads[event.cmdThread]['cmdPID'])
+ pid=self.cmdThread.requestId)
else:
try:
# Process results here
- self.WriteCmdLog(_('Command finished (%d sec)') % (time.time() - event.cmdThread.startTime),
+ self.WriteCmdLog(_('Command finished (%d sec)') % (time.time() - event.time),
+ pid=event.pid)
except KeyError:
# stopped deamon
pass
self.console_progressbar.SetValue(0) # reset progress bar on '0%'
+ self.cmd_output_timer.Stop()
# updated command dialog
if hasattr(self.parent.parent, "btn_run"):
dialog = self.parent.parent
@@ -340,12 +444,17 @@
dialog.btn_help.Enable(True)
dialog.btn_run.Enable(True)
if dialog.get_dcmd is None and \
dialog.closebox.IsChecked():
time.sleep(1)
dialog.Close()
+ event.Skip()
+ def OnProcessPendingOutputWindowEvents(self, event):
+ self.ProcessPendingEvents()
class GMStdout:
"""GMConsole standard output
@@ -357,22 +466,20 @@
Copyright: (c) 2005-2007 Jean-Michel Fauth
Licence: GPL
- def __init__(self, gmstc):
- self.gmstc = gmstc
+ def __init__(self, parent):
def write(self, s):
if len(s) == 0 or s == '\n':
return
s = s.replace('\n', os.linesep)
for line in s.split(os.linesep):
- p1 = self.gmstc.GetCurrentPos() # get caret position
- self.gmstc.AddTextWrapped(line, wrap=None) # no wrapping && adds os.linesep
- self.gmstc.EnsureCaretVisible()
- p2 = self.gmstc.GetCurrentPos()
- self.gmstc.StartStyling(p1, 0xff)
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleOutput)
-class GMStderr(object):
+ evt = wxCmdOutput(text=line + os.linesep,
+ type='')
+ wx.PostEvent(self.parent.cmd_output, evt)
+class GMStderr:
"""GMConsole standard error output
Based on FrameOutErr.py
@@ -383,37 +490,29 @@
Licence: GPL
- def __init__(self, gmstc, gmgauge, notebook, pageid):
- self.gmgauge = gmgauge
- self.notebook = notebook
- self.pageid = pageid
self.type = ''
self.message = ''
self.printMessage = False
def write(self, s):
- if self.pageid > -1:
- # swith notebook page to 'command output'
- if self.notebook.GetSelection() != self.pageid:
- self.notebook.SetSelection(self.pageid)
# remove/replace escape sequences '\b' or '\r' from stream
s = s.replace('\b', '').replace('\r', '%s' % os.linesep)
+ progressValue = -1
if len(line) == 0:
continue
if 'GRASS_INFO_PERCENT' in line:
- # 'GRASS_INFO_PERCENT: 10' -> value=10
value = int(line.rsplit(':', 1)[1].strip())
if value >= 0 and value < 100:
- self.gmgauge.SetValue(value)
+ progressValue = value
else:
- self.gmgauge.SetValue(0) # reset progress bar on '0%'
+ progressValue = 0
elif 'GRASS_INFO_MESSAGE' in line:
self.type = 'message'
self.message = line.split(':', 1)[1].strip()
@@ -427,39 +526,28 @@
self.printMessage = True
elif not self.type:
if len(line) > 0:
- self.gmstc.AddTextWrapped(line, wrap=60) # wrap && add os.linesep
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleUnknown)
+ continue
+ evt = wxCmdOutput(text=line,
+ type='')
elif len(line) > 0:
self.message += line.strip() + os.linesep
if self.printMessage and len(self.message) > 0:
- if self.type == 'warning':
- self.message = 'WARNING: ' + self.message
- elif self.type == 'error':
- self.message = 'ERROR: ' + self.message
- if os.linesep not in self.message:
- self.gmstc.AddTextWrapped(self.message, wrap=60) #wrap && add os.linesep
- else:
- self.gmstc.AddText(self.message)
- if self.type == 'error':
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleError)
- elif self.type == 'warning':
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleWarning)
- elif self.type == 'self.message':
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleSelf.Message)
+ evt = wxCmdOutput(text=self.message,
+ type=self.type)
self.type = ''
self.message = ''
+ # update progress message
+ if progressValue > -1:
+ # self.gmgauge.SetValue(progressValue)
+ evt = wxCmdProgress(value=progressValue)
+ wx.PostEvent(self.parent.console_progressbar, evt)
class GMStc(wx.stc.StyledTextCtrl):
"""Styled GMConsole
@@ -542,7 +630,7 @@
wx.TheClipboard.Flush()
evt.Skip()
- def AddTextWrapped(self, str, wrap=None):
+ def AddTextWrapped(self, txt, wrap=None):
"""Add string to text area.
String is wrapped and linesep is also added to the end
@@ -551,12 +639,13 @@
wrap = self.wrap
if wrap is not None:
- str = textwrap.fill(str, wrap) + os.linesep
+ txt = textwrap.fill(txt, wrap) + os.linesep
else:
- str += os.linesep
+ txt += os.linesep
- self.AddText(str)
+ self.AddText(txt)
def SetWrap(self, wrap):
"""Set wrapping value
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-07-29 13:44:13 UTC (rev 32363)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-07-29 23:31:59 UTC (rev 32364)
@@ -773,7 +773,7 @@
def OnRun(self, event):
"""Run the command"""
- if len(self.goutput.GetListOfCmdThreads()) > 0:
+ if not self.goutput.resultQ.empty():
return
cmd = self.createCmd()
@@ -807,10 +807,8 @@
def OnAbort(self, event):
"""Abort running command"""
- try:
- self.goutput.GetListOfCmdThreads()[0].abort()
- except IndexError:
- pass
+ event = goutput.wxCmdAbort(aborted=True)
+ wx.PostEvent(self.goutput, event)
def OnCopy(self, event):
"""Copy the command"""
