[GRASS-SVN] r32395 - in grass/branches/develbranch_6:
lib/vector/Vlib vector/v.random
svn_grass at osgeo.org
Thu Jul 31 01:48:39 EDT 2008
Author: martinl
Date: 2008-07-31 01:48:39 -0400 (Thu, 31 Jul 2008)
New Revision: 32395
grass/branches/develbranch_6/lib/vector/Vlib/open.c
grass/branches/develbranch_6/vector/v.random/main.c
glynn: Allow fully qualified names in Vect_open_new()
Don't call G_legal_filename() on qualified names
(merged from trunk, r32389)
Modified: grass/branches/develbranch_6/lib/vector/Vlib/open.c
--- grass/branches/develbranch_6/lib/vector/Vlib/open.c 2008-07-31 00:36:39 UTC (rev 32394)
+++ grass/branches/develbranch_6/lib/vector/Vlib/open.c 2008-07-31 05:48:39 UTC (rev 32395)
@@ -481,6 +481,7 @@
int ret, ferror;
char errmsg[2000], buf[200];
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
G_debug ( 2, "Vect_open_new(): name = %s", name);
@@ -488,6 +489,16 @@
ferror = Vect_get_fatal_error ();
Vect_set_fatal_error (GV_FATAL_EXIT);
+ if (G__name_is_fully_qualified(name, xname, xmapset))
+ if (strcmp(xmapset, G_mapset()) != 0)
+ sprintf ( errmsg, _("%s is not in the current mapset (%s)"), name, G_mapset());
+ fatal_error (ferror , errmsg );
+ name = xname;
/* check for [A-Za-z][A-Za-z0-9_]* in name */
if (Vect_legal_filename(name) < 0 ) {
sprintf ( errmsg, _("Vector map name is not SQL compliant") );
Modified: grass/branches/develbranch_6/vector/v.random/main.c
--- grass/branches/develbranch_6/vector/v.random/main.c 2008-07-31 00:36:39 UTC (rev 32394)
+++ grass/branches/develbranch_6/vector/v.random/main.c 2008-07-31 05:48:39 UTC (rev 32395)
@@ -119,11 +119,6 @@
n = atoi(parm.nsites->answer);
b = (flag.drand48->answer == '\0') ? 0 : 1;
- if (G_legal_filename(output) == -1) {
- G_fatal_error(_("<%s> is an illegal file name"),
- output);
if (n <= 0) {
G_fatal_error(_("Number of points must be > 0 (%d given)"),
n);
