[GRASS-SVN] r32396 - in grass/branches/develbranch_6: include
lib/g3d
svn_grass at osgeo.org
Thu Jul 31 01:57:23 EDT 2008
Author: martinl
Date: 2008-07-31 01:57:23 -0400 (Thu, 31 Jul 2008)
New Revision: 32396
Removed:
grass/branches/develbranch_6/lib/g3d/g3dkeys.h
grass/branches/develbranch_6/include/G3d.h
grass/branches/develbranch_6/lib/g3d/G3d_intern.h
grass/branches/develbranch_6/lib/g3d/cache.c
grass/branches/develbranch_6/lib/g3d/changeprecision.c
grass/branches/develbranch_6/lib/g3d/changetype.c
grass/branches/develbranch_6/lib/g3d/filecompare.c
grass/branches/develbranch_6/lib/g3d/filename.c
grass/branches/develbranch_6/lib/g3d/g3dalloc.c
grass/branches/develbranch_6/lib/g3d/g3dcache.c
grass/branches/develbranch_6/lib/g3d/g3dcats.c
grass/branches/develbranch_6/lib/g3d/g3dclose.c
grass/branches/develbranch_6/lib/g3d/g3dcolor.c
grass/branches/develbranch_6/lib/g3d/g3ddefaults.c
grass/branches/develbranch_6/lib/g3d/g3ddoubleio.c
grass/branches/develbranch_6/lib/g3d/g3derror.c
grass/branches/develbranch_6/lib/g3d/g3dfpxdr.c
grass/branches/develbranch_6/lib/g3d/g3dhistory.c
grass/branches/develbranch_6/lib/g3d/g3dintio.c
grass/branches/develbranch_6/lib/g3d/g3dkeys.c
grass/branches/develbranch_6/lib/g3d/g3dmapset.c
grass/branches/develbranch_6/lib/g3d/g3dmask.c
grass/branches/develbranch_6/lib/g3d/g3dmisc.c
grass/branches/develbranch_6/lib/g3d/g3dnull.c
grass/branches/develbranch_6/lib/g3d/g3dopen2.c
grass/branches/develbranch_6/lib/g3d/g3dparam.c
grass/branches/develbranch_6/lib/g3d/g3drange.c
grass/branches/develbranch_6/lib/g3d/g3dregion.c
grass/branches/develbranch_6/lib/g3d/g3dresample.c
grass/branches/develbranch_6/lib/g3d/g3dvolume.c
grass/branches/develbranch_6/lib/g3d/g3dwindow.c
grass/branches/develbranch_6/lib/g3d/g3dwindowio.c
grass/branches/develbranch_6/lib/g3d/getblock.c
grass/branches/develbranch_6/lib/g3d/header.c
grass/branches/develbranch_6/lib/g3d/retile.c
grass/branches/develbranch_6/lib/g3d/tilealloc.c
grass/branches/develbranch_6/lib/g3d/tileio.c
grass/branches/develbranch_6/lib/g3d/tilenull.c
grass/branches/develbranch_6/lib/g3d/tileread.c
grass/branches/develbranch_6/lib/g3d/tilewrite.c
grass/branches/develbranch_6/lib/g3d/writeascii.c
glynn: Use "const" where appropriate
Use void* instead of char* for generic pointers
Include parameter lists in callback function types
Use memcpy/memcmp where appropriate instead of loops
Use loop counters instead of end pointers
Remove local copies of G3D_Map structure
Use G{NAME,MAPSET,PATH}_MAX for buffer sizes
Replace K&R function definitions with ANSI syntax
Fix typo in function names: Alligned -> Aligned
Change G3d_error() to accept printf-style format string and arguments
(merged from trunk, r32392)
Modified: grass/branches/develbranch_6/include/G3d.h
--- grass/branches/develbranch_6/include/G3d.h 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/include/G3d.h 2008-07-31 05:57:23 UTC (rev 32396)
@@ -62,9 +62,14 @@
+struct G3D_Map;
-typedef struct {
+typedef void resample_fn(struct G3D_Map *, int, int, int, void *, int);
+typedef struct G3D_Map {
char *fileName;
char *tempName;
char *mapset;
@@ -79,7 +84,7 @@
G3D_Region window;
/* resmapling function used for map. default is nearest neighbor */
- void (*resampleFun) ();
+ resample_fn *resampleFun;
/* units */
char *unit;
@@ -225,14 +230,18 @@
+typedef int write_fn(int, const void *, void *);
+typedef int read_fn(int, void *, void *);
/* grass/src/libes/g3d/cache.c */
void G3d_cache_reset(G3D_cache *);
void G3d_cache_dispose(G3D_cache *);
-void *G3d_cache_new(int, int, int, int (*)(), void *, int (*)(), void *);
-void G3d_cache_set_removeFun(G3D_cache *, int (*)(), void *);
-void G3d_cache_set_loadFun(G3D_cache *, int (*)(), void *);
-void *G3d_cache_new_read(int, int, int, int (*)(), void *);
+void *G3d_cache_new(int, int, int, write_fn *, void *, read_fn *, void *);
+void G3d_cache_set_removeFun(G3D_cache *, write_fn *, void *);
+void G3d_cache_set_loadFun(G3D_cache *, read_fn *, void *);
+void *G3d_cache_new_read(int, int, int, read_fn *, void *);
int G3d_cache_lock(G3D_cache *, int);
void G3d_cache_lock_intern(G3D_cache *, int);
int G3d_cache_unlock(G3D_cache *, int);
@@ -245,10 +254,10 @@
int G3d_cache_flush(G3D_cache *, int);
int G3d_cache_remove_all(G3D_cache *);
int G3d_cache_flush_all(G3D_cache *);
-char *G3d_cache_elt_ptr(G3D_cache *, int);
+void *G3d_cache_elt_ptr(G3D_cache *, int);
int G3d_cache_load(G3D_cache *, int);
-int G3d_cache_get_elt(G3D_cache *, int, char *);
-int G3d_cache_put_elt(G3D_cache *, int, char *);
+int G3d_cache_get_elt(G3D_cache *, int, void *);
+int G3d_cache_put_elt(G3D_cache *, int, const void *);
/* grass/src/libes/g3d/cachehash.c */
void G3d_cache_hash_reset(G3d_cache_hash *);
void G3d_cache_hash_dispose(G3d_cache_hash *);
@@ -257,13 +266,13 @@
void G3d_cache_hash_load_name(G3d_cache_hash *, int, int);
int G3d_cache_hash_name2index(G3d_cache_hash *, int);
/* grass/src/libes/g3d/changeprecision.c */
-void G3d_changePrecision(void *, int, char *);
+void G3d_changePrecision(void *, int, const char *);
/* grass/src/libes/g3d/changetype.c */
-void G3d_changeType(void *, char *);
+void G3d_changeType(void *, const char *);
/* grass/src/libes/g3d/filecompare.c */
-void G3d_compareFiles(char *, char *, char *, char *);
+void G3d_compareFiles(const char *, const char *, const char *, const char *);
/* grass/src/libes/g3d/filename.c */
-void G3d_filename(char *, char *, char *, char *);
+void G3d_filename(char *, const char *, const char *, const char *);
/* grass/src/libes/g3d/find_grid3.c */
char *G_find_grid3(const char *, const char *);
/* grass/src/libes/g3d/fpcompress.c */
@@ -284,8 +293,8 @@
int G3d_disposeCache(G3D_Map *);
int G3d_flushAllTiles(G3D_Map *);
/* grass/src/libes/g3d/g3dcats.c */
-int G3d_writeCats(char *, struct Categories *);
-int G3d_readCats(char *, char *, struct Categories *);
+int G3d_writeCats(const char *, struct Categories *);
+int G3d_readCats(const char *, const char *, struct Categories *);
/* grass/src/libes/g3d/g3dclose.c */
int G3d_closeCell(G3D_Map *);
/* grass/src/libes/g3d/g3dcolor.c */
@@ -304,49 +313,49 @@
void G3d_setTileDimension(int, int, int);
void G3d_getTileDimension(int *, int *, int *);
void G3d_setErrorFun(void (*)(const char *));
-void G3d_setUnit(char *);
+void G3d_setUnit(const char *);
void G3d_initDefaults(void);
/* grass/src/libes/g3d/g3ddoubleio.c */
-int G3d_writeDoubles(int, int, double *, int);
+int G3d_writeDoubles(int, int, const double *, int);
int G3d_readDoubles(int, int, double *, int);
/* grass/src/libes/g3d/g3derror.c */
void G3d_skipError(const char *);
void G3d_printError(const char *);
void G3d_fatalError(const char *, ...);
void G3d_fatalError_noargs(const char *);
-void G3d_error(const char *);
+void G3d_error(const char *, ...);
/* grass/src/libes/g3d/g3dfpxdr.c */
-int G3d_isXdrNullNum(unsigned char *, int);
-int G3d_isXdrNullFloat(float *);
-int G3d_isXdrNullDouble(double *);
-void G3d_setXdrNullNum(unsigned char *, int);
+int G3d_isXdrNullNum(const void *, int);
+int G3d_isXdrNullFloat(const float *);
+int G3d_isXdrNullDouble(const double *);
+void G3d_setXdrNullNum(void *, int);
void G3d_setXdrNullDouble(double *);
void G3d_setXdrNullFloat(float *);
int G3d_initFpXdr(G3D_Map *, int);
int G3d_initCopyToXdr(G3D_Map *, int);
-int G3d_copyToXdr(char *, int);
+int G3d_copyToXdr(const void *, int);
int G3d_initCopyFromXdr(G3D_Map *, int);
-int G3d_copyFromXdr(int, char *);
+int G3d_copyFromXdr(int, void *);
/* grass/src/libes/g3d/g3dhistory.c */
-int G3d_writeHistory(char *, struct History *);
-int G3d_readHistory(char *, char *, struct History *);
+int G3d_writeHistory(const char *, struct History *);
+int G3d_readHistory(const char *, const char *, struct History *);
/* grass/src/libes/g3d/g3dintio.c */
-int G3d_writeInts(int, int, int *, int);
+int G3d_writeInts(int, int, const int *, int);
int G3d_readInts(int, int, int *, int);
/* grass/src/libes/g3d/g3dkeys.c */
-int G3d_keyGetInt(struct Key_Value *, char *, int *);
-int G3d_keyGetDouble(struct Key_Value *, char *, double *);
-int G3d_keyGetString(struct Key_Value *, char *, char **);
-int G3d_keyGetValue(struct Key_Value *, char *, char *, char *, int, int, int *);
-int G3d_keySetInt(struct Key_Value *, char *, int *);
-int G3d_keySetDouble(struct Key_Value *, char *, double *);
-int G3d_keySetString(struct Key_Value *, char *, char **);
-int G3d_keySetValue(struct Key_Value *, char *, char *, char *, int, int, int *);
+int G3d_keyGetInt (struct Key_Value *, const char *, int *);
+int G3d_keyGetDouble (struct Key_Value *, const char *, double *);
+int G3d_keyGetString (struct Key_Value *, const char *, char **);
+int G3d_keyGetValue (struct Key_Value *, const char *, char *, char *, int, int, int *);
+int G3d_keySetInt (struct Key_Value *, const char *, const int *);
+int G3d_keySetDouble (struct Key_Value *, const char *, const double *);
+int G3d_keySetString (struct Key_Value *, const char *, char * const *);
+int G3d_keySetValue (struct Key_Value *, const char *, const char *, const char *, int, int, const int *);
/* grass/src/libes/g3d/g3dlong.c */
int G3d_longEncode(long *, unsigned char *, int);
void G3d_longDecode(unsigned char *, long *, int, int);
/* grass/src/libes/g3d/g3dmapset.c */
-void G3d_makeMapsetMapDirectory(char *);
+void G3d_makeMapsetMapDirectory(const char *);
/* grass/src/libes/g3d/g3dmask.c */
int G3d_maskClose(void);
int G3d_maskFileExists(void);
@@ -356,22 +365,22 @@
void G3d_maskNum(G3D_Map *, int, int, int, void *, int);
void G3d_maskFloat(G3D_Map *, int, int, int, float *);
void G3d_maskDouble(G3D_Map *, int, int, int, double *);
-void G3d_maskTile(G3D_Map *, int, char *, int);
+void G3d_maskTile(G3D_Map *, int, void *, int);
void G3d_maskOn(G3D_Map *);
void G3d_maskOff(G3D_Map *);
int G3d_maskIsOn(G3D_Map *);
int G3d_maskIsOff(G3D_Map *);
-char *G3d_maskFile(void);
+const char *G3d_maskFile(void);
int G3d_maskMapExists(void);
/* grass/src/libes/g3d/g3dmisc.c */
int G3d_g3dType2cellType(int);
-void G3d_copyFloat2Double(float *, int, double *, int, int);
-void G3d_copyDouble2Float(double *, int, float *, int, int);
-void G3d_copyValues(char *, int, int, char *, int, int, int);
+void G3d_copyFloat2Double(const float *, int, double *, int, int);
+void G3d_copyDouble2Float(const double *, int, float *, int, int);
+void G3d_copyValues(const void *, int, int, void *, int, int, int);
int G3d_length(int);
int G3d_externLength(int);
/* grass/src/libes/g3d/g3dnull.c */
-int G3d_isNullValueNum(void *, int);
+int G3d_isNullValueNum(const void *, int);
void G3d_setNullValue(void *, int, int);
/* grass/src/libes/g3d/g3dopen2.c */
/* grass/src/libes/g3d/g3dopen.c */
@@ -384,14 +393,14 @@
void G3d_setWindowParams(void);
char *G3d_getWindowParams(void);
/* grass/src/libes/g3d/g3drange.c */
-void G3d_range_updateFromTile(G3D_Map *, char *, int, int, int, int, int, int, int, int);
+void G3d_range_updateFromTile(G3D_Map *, const void *, int, int, int, int, int, int, int, int);
int G3d_readRange(const char *, const char *, struct FPRange *);
int G3d_range_load(G3D_Map *);
void G3d_range_min_max(G3D_Map *, double *, double *);
int G3d_range_write(G3D_Map *);
int G3d_range_init(G3D_Map *);
/* grass/src/libes/g3d/g3dregion.c */
-void G3d_getRegionValue(G3D_Map *, double, double, double, char *, int);
+void G3d_getRegionValue(G3D_Map *, double, double, double, void *, int);
void G3d_adjustRegion (G3D_Region *);
void G3d_regionCopy (G3D_Region *,G3D_Region *);
void G3d_incorporate2dRegion (struct Cell_head *, G3D_Region *);
@@ -399,18 +408,18 @@
void G3d_adjustRegionRes (G3D_Region *);
void G3d_extract2dRegion (G3D_Region *, struct Cell_head *);
void G3d_regionToCellHead (G3D_Region *, struct Cell_head *);
-int G3d_readRegionMap (char *, char *,G3D_Region *);
+int G3d_readRegionMap (const char *, const char *,G3D_Region *);
/* grass/src/libes/g3d/g3dresample.c */
-void G3d_nearestNeighbor(G3D_Map *, int, int, int, char *, int);
+void G3d_nearestNeighbor(G3D_Map *, int, int, int, void *, int);
void G3d_setResamplingFun(G3D_Map *, void (*)());
void G3d_getResamplingFun(G3D_Map *, void (**)());
void G3d_getNearestNeighborFunPtr(void (**)());
/* grass/src/libes/g3d/g3dvolume.c */
-void G3d_getVolumeA(void *, double [2][2][2][3], int, int, int, char *, int);
-void G3d_getVolume(void *, double, double, double, double, double, double, double, double, double, double, double, double, int, int, int, char *, int);
-void G3d_getAllignedVolume(void *, double, double, double, double, double, double, int, int, int, char *, int);
-void G3d_makeAllignedVolumeFile(void *, char *, double, double, double, double, double, double, int, int, int);
+void G3d_getVolumeA(void *, double [2][2][2][3], int, int, int, void *, int);
+void G3d_getVolume(void *, double, double, double, double, double, double, double, double, double, double, double, double, int, int, int, void *, int);
+void G3d_getAlignedVolume(void *, double, double, double, double, double, double, int, int, int, void *, int);
+void G3d_makeAlignedVolumeFile(void *, const char *, double, double, double, double, double, double, int, int, int);
/* grass/src/libes/g3d/g3dwindow.c */
void G3d_getValue(G3D_Map *, int, int, int, void *, int);
float G3d_getFloat(G3D_Map *, int, int, int);
@@ -422,11 +431,11 @@
/* grass/src/libes/g3d/g3dwindowio.c */
void G3d_useWindowParams(void);
-int G3d_readWindow (G3D_Region *, char *);
+int G3d_readWindow (G3D_Region *, const char *);
/* int G3d_writeWindow (G3D_Region *, char *); */
/* grass/src/libes/g3d/getblock.c */
void G3d_getBlockNocache(G3D_Map *, int, int, int, int, int, int, void *, int);
-void G3d_getBlock(G3D_Map *, int, int, int, int, int, int, char *, int);
+void G3d_getBlock(G3D_Map *, int, int, int, int, int, int, void *, int);
/* grass/src/libes/g3d/header.c */
int G3d_readHeader(G3D_Map *, int *, int *, double *, double *, double *, double *, double *, double *, int *, int *, int *, double *, double *, double *, int *, int *, int *, int *, int *, int *, int *, int *, int *, int *, int *, char **);
int G3d_writeHeader(G3D_Map *, int, int, double, double, double, double, double, double, int, int, int, double, double, double, int, int, int, int, int, int, int, int, int, int, int, char *);
@@ -450,17 +459,17 @@
int G3d_flushIndex(G3D_Map *);
int G3d_initIndex(G3D_Map *, int);
/* grass/src/libes/g3d/retile.c */
-void G3d_retile(void *, char *, int, int, int);
+void G3d_retile(void *, const char *, int, int, int);
/* grass/src/libes/g3d/rle.c */
int G_rle_count_only(char *, int, int);
void G_rle_encode(char *, char *, int, int);
void G_rle_decode(char *, char *, int, int, int *, int *);
/* grass/src/libes/g3d/tilealloc.c */
-char *G3d_allocTilesType(G3D_Map *, int, int);
-char *G3d_allocTiles(G3D_Map *, int);
-void G3d_freeTiles(char *);
+void *G3d_allocTilesType(G3D_Map *, int, int);
+void *G3d_allocTiles(G3D_Map *, int);
+void G3d_freeTiles(void *);
/* grass/src/libes/g3d/tileio.c */
-char *G3d_getTilePtr(G3D_Map *, int);
+void *G3d_getTilePtr(G3D_Map *, int);
int G3d_tileLoad(G3D_Map *, int);
int G3d__removeTile(G3D_Map *, int);
float G3d_getFloatRegion(G3D_Map *, int, int, int);
@@ -480,12 +489,12 @@
int G3d_isValidLocation(G3D_Map *, double, double, double);
void G3d_location2coord(G3D_Map *, double, double, double, int *, int *, int *);
/* grass/src/libes/g3d/tilenull.c */
-void G3d_setNullTileType(G3D_Map *, char *, int);
-void G3d_setNullTile(G3D_Map *, char *);
+void G3d_setNullTileType(G3D_Map *, void *, int);
+void G3d_setNullTile(G3D_Map *, void *);
/* grass/src/libes/g3d/tileread.c */
-int G3d_readTile(G3D_Map *, int, char *, int);
-int G3d_readTileFloat(G3D_Map *, int, char *);
-int G3d_readTileDouble(G3D_Map *, int, char *);
+int G3d_readTile(G3D_Map *, int, void *, int);
+int G3d_readTileFloat(G3D_Map *, int, void *);
+int G3d_readTileDouble(G3D_Map *, int, void *);
int G3d_lockTile(G3D_Map *, int);
int G3d_unlockTile(G3D_Map *, int);
int G3d_unlockAll(G3D_Map *);
@@ -495,16 +504,16 @@
int G3d_beginCycle(G3D_Map *);
int G3d_endCycle(G3D_Map *);
/* grass/src/libes/g3d/tilewrite.c */
-int G3d_writeTile(G3D_Map *, int, char *, int);
-int G3d_writeTileFloat(G3D_Map *, int, char *);
-int G3d_writeTileDouble(G3D_Map *, int, char *);
+int G3d_writeTile(G3D_Map *, int, const void *, int);
+int G3d_writeTileFloat(G3D_Map *, int, const void *);
+int G3d_writeTileDouble(G3D_Map *, int, const void *);
int G3d_flushTile(G3D_Map *, int);
int G3d_flushTileCube(G3D_Map *, int, int, int, int, int, int);
int G3d_flushTilesInCube(G3D_Map *, int, int, int, int, int, int);
int G3d_putFloat(G3D_Map *, int, int, int, float);
int G3d_putDouble(G3D_Map *, int, int, int, double);
-int G3d_putValue(G3D_Map *, int, int, int, char *, int);
+int G3d_putValue(G3D_Map *, int, int, int, const void *, int);
/* grass/src/libes/g3d/writeascii.c */
-void G3d_writeAscii(void *, char *);
+void G3d_writeAscii(void *, const char *);
#endif /* #ifndef GRASS_G3D_H */
Modified: grass/branches/develbranch_6/lib/g3d/G3d_intern.h
--- grass/branches/develbranch_6/lib/g3d/G3d_intern.h 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/G3d_intern.h 2008-07-31 05:57:23 UTC (rev 32396)
@@ -35,127 +35,11 @@
-#ifndef GRASS_G3D_H
-typedef struct {
- char *fileName;
- char *tempName;
- char *mapset;
- /* operation performed on map */
- int operation; /* G3D_WRITE_DATA or G3D_READ_DATA */
- /* region */
- G3D_Region region;
- /* window for map */
- G3D_Region window;
- /* resmapling function used for map. default is nearest neighbor */
- /* units */
- char *unit;
- /* dimension of a single tile in "cells" */
- int tileX, tileY, tileZ;
- /* # of tiles in x, y, and z direction */
- int nx, ny, nz;
- /* data file specific information */
- /* file descriptor */
- int data_fd; /* file descriptor */
- /* type in which data is stored on file */
- int type; /* DCELL_TYPE or FCELL_TYPE */
- /* data concering the compression */
- int precision; /* G3D_MAX_PRECISION or, 0 .. 23 for float,
- 0 .. 52 for double */
- int compression; /* G3D_NO_COMPRESSION or G3D_USE_COMPRESSION */
- int useLzw; /* G3D_USE_LZW or G3D_NO_LZW */
- int useRle; /* G3D_USE_RLE or G3D_NO_RLE */
- int useXdr; /* G3D_USE_XDR or G3D_NO_XDR */
- /* pointer to first tile in file */
- int offset;
- /* pointer to the first index entry in file */
- long indexOffset;
- /* sizeof (long) of the system on which the file is/was written */
- int indexLongNbytes;
- /* max # bytes used in the representation of indices; this is equal to */
- /* # bytes used in the representation of "indexOffset" */
- int indexNbytesUsed;
- /* pointer to the last entry in the file */
- int fileEndPtr;
- /* indicates if index is stored in file; used for G3D_READ_DATA only */
- int hasIndex; /* G3D_HAS_INDEX or G3D_NO_INDEX */
- /* information concerning internal storage of data */
- /* index specific information */
- /* index[i] == the offset of tile "i" in the data file */
- long *index;
- /* tileLength[i] == # bytes used to store tile "i" */
- int *tileLength;
- /* tile specific information */
- /* type in which data is stored in memory */
- int typeIntern; /* DCELL_TYPE or FCELL_TYPE */
- /* in non-cache mode the "data" array is used to store one tile */
- char *data;
- /* index of tile currently stored in "data"; -1 if none */
- int currentIndex;
- /* cache related variables */
- int useCache; /* 1 if cache is used */
- void *cache; /* pointer to cache structure */
- int cacheFD; /* file discriptor of cache file -- write mode only */
- char *cacheFileName; /* filename of cache file -- write mode only */
- long cachePosLast; /* position of last entry in cache file -- write */
- /* mode only*/
- /* range info */
- struct FPRange range;
- /* some constants stored for efficiency */
- /* number of bytes required to store a single value of "type" */
- int numLengthExtern;
- /* number of bytes required to store a single value of "typeIntern" */
- int numLengthIntern;
- /* see header.c for details */
- int clipX, clipY, clipZ;
- int tileXY, tileSize;
- int nxy, nTiles;
- /* mask related information */
- int useMask; /* 1 if mask is used; 0 otherwise */
-} G3D_Map;
-#endif
/* global arrays */
-extern char *tmpCompress; /* compression support array */
+extern void *tmpCompress; /* compression support array */
extern int tmpCompressLength; /* in bytes */
-extern char *xdr;/* xdr support array */
+extern void *xdr;/* xdr support array */
extern int xdrLength; /* in bytes */
Modified: grass/branches/develbranch_6/lib/g3d/cache.c
--- grass/branches/develbranch_6/lib/g3d/cache.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/cache.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -1,5 +1,6 @@
#include <stdio.h>
#include <stdlib.h>
+#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <grass/G3d.h>
@@ -7,41 +8,7 @@
#include "cachehash.h"
-typedef struct {
- char *elts; /* ptr to array of elts */
- int nofElts; /* size of "elts" */
- int eltSize; /* size of elt in "elts" */
- int *names; /* name[i] is the name of elts[i] */
- char *locks; /* lock[i] == 1 iff elts[i] is locked
- lock[i] == 0 iff elts[i] is unlocked but active
- lock[i] == 2 iff elts[i] doesn't contain valid data */
- int autoLock; /* 1 if auto locking is turned on */
- int nofUnlocked; /* nof tiles which are unlocked */
- int minUnlocked; /* min nof elts which have to remain unlocked. min = 1 */
- int *next, *prev; /* prev/next pointers for fifo */
- int first, last; /* index (into next) of first and last elt in fifo */
- /* first == -1 iff fifo is empty */
- int (* eltRemoveFun) (); /* callback activated if the contents of an
- elt needs to be removed */
- void *eltRemoveFunData; /* pointer to user data passed along with
- eltRemoveFun */
- int (* eltLoadFun) (); /* callback activated to load contents of an elt */
- void *eltLoadFunData; /* pointer to user data passed along with
- eltLoadFun */
- void *hash; /* ptr to hashTable used to relate external names to
- internal indices (elts) */
-} G3D_cache;
-#endif
#define IS_ACTIVE_ELT(elt) (c->locks[elt] != 2)
#define IS_NOT_ACTIVE_ELT(elt) (c->locks[elt] == 2)
#define IS_LOCKED_ELT(elt) (c->locks[elt] == 1)
@@ -91,7 +58,7 @@
static int
-cache_dummy_fun ()
+cache_dummy_fun(int tileIndex, const void *tileBuf, void *map)
return 1;
@@ -188,7 +155,7 @@
void *
-G3d_cache_new_read (int nofElts, int sizeOfElts, int nofNames, int (*eltLoadFun)(), void *eltLoadFunData)
+G3d_cache_new_read (int nofElts, int sizeOfElts, int nofNames, read_fn *eltLoadFun, void *eltLoadFunData)
return G3d_cache_new (nofElts, sizeOfElts, nofNames,
@@ -515,7 +482,7 @@
-char *
+void *
G3d_cache_elt_ptr (G3D_cache *c, int name)
@@ -539,7 +506,7 @@
if (! c->eltRemoveFun (oldName, c->elts + c->eltSize * index,
c->eltRemoveFunData)) {
G3d_error ("G3d_cache_elt_ptr: error in c->eltRemoveFun");
- return (char *) NULL;
+ return NULL;
@@ -554,13 +521,13 @@
if (doUnlock)
if (! G3d_cache_unlock (c, name)) {
G3d_error ("G3d_cache_elt_ptr: error in G3d_cache_unlock");
+ return NULL;
if (! c->eltLoadFun (name, c->elts + c->eltSize * index,
c->eltLoadFunData)) {
G3d_error("G3d_cache_elt_ptr: error in c->eltLoadFun");
+ return NULL;
return c->elts + c->eltSize * index;
@@ -583,10 +550,10 @@
int
-G3d_cache_get_elt (G3D_cache *c, int name, char *dst)
+G3d_cache_get_elt (G3D_cache *c, int name, void *dst)
- char *elt, *eltStop;
+ const void *elt;
elt = G3d_cache_elt_ptr (c, name);
if (elt == NULL) {
@@ -594,8 +561,7 @@
return 0;
- eltStop = elt + c->eltSize;
- while (elt != eltStop) *dst++ = *elt++;
+ memcpy(dst, elt, c->eltSize);
return 1;
@@ -603,10 +569,10 @@
int
-G3d_cache_put_elt (G3D_cache *c, int name, char *src)
+G3d_cache_put_elt (G3D_cache *c, int name, const void *src)
+ void *elt;
if (elt == NULL) {
@@ -614,8 +580,7 @@
return 0;
- while (elt != eltStop) *elt++ = *src++;
+ memcpy(elt, src, c->eltSize);
return 1;
@@ -660,10 +625,10 @@
static int
-cache_test_flush_fun (int name, int *eltPtr, void *data)
+cache_test_flush_fun (int name, const void *eltPtr, void *data)
- printf ("flushing name %d value %d\n", name, eltPtr[17]);
+ printf ("flushing name %d value %d\n", name, ((const int *)eltPtr)[17]);
return 0;
@@ -677,17 +642,17 @@
} cache_test_data_type;
static int
-cache_test_load_fun (int name, char *eltPtr, void *data)
+cache_test_load_fun (int name, void *eltPtr, void *data)
- char *eltStop, *src;
+ const void *src;
printf ("loading name %d value %d\n", name,
((cache_test_data_type *) data)->value[17]);
- src = (char *) ((cache_test_data_type *) data)->value;
- eltStop = eltPtr + ((cache_test_data_type *) data)->size;
- while (eltPtr != eltStop) *eltPtr++ = *src++;
+ src = ((cache_test_data_type *) data)->value;
+ memcpy(eltPtr, src, ((cache_test_data_type *) data)->size);
return 0;
Modified: grass/branches/develbranch_6/lib/g3d/changeprecision.c
--- grass/branches/develbranch_6/lib/g3d/changeprecision.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/changeprecision.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -21,7 +21,7 @@
void
-G3d_changePrecision (void *map, int precision, char *nameOut)
+G3d_changePrecision (void *map, int precision, const char *nameOut)
void *map2;
Modified: grass/branches/develbranch_6/lib/g3d/changetype.c
--- grass/branches/develbranch_6/lib/g3d/changetype.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/changetype.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -22,12 +22,12 @@
void
-G3d_changeType (void *map, char *nameOut)
+G3d_changeType (void *map, const char *nameOut)
void *map2;
int x, y, z, saveType;
- char *data, *data2;
+ void *data, *data2;
G3D_Region region;
int tileSize;
int tileX, tileY, tileZ, typeIntern, typeIntern2;
Modified: grass/branches/develbranch_6/lib/g3d/filecompare.c
--- grass/branches/develbranch_6/lib/g3d/filecompare.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/filecompare.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -338,8 +338,8 @@
for (y = 0; y < ny * tileY; y++) {
for (x = 0; x < nx * tileX; x++) {
- G3d_getBlock (map, x, y, z, 1, 1, 1, (char *)n1p, typeIntern);
- G3d_getBlock (map2, x, y, z, 1, 1, 1, (char *)n2p, typeIntern2);
+ G3d_getBlock (map, x, y, z, 1, 1, 1, n1p, typeIntern);
+ G3d_getBlock (map2, x, y, z, 1, 1, 1, n2p, typeIntern2);
if (typeIntern == FCELL_TYPE)
@@ -395,7 +395,7 @@
void
-G3d_compareFiles (char *f1, char *mapset1, char *f2, char *mapset2)
+G3d_compareFiles (const char *f1, const char *mapset1, const char *f2, const char *mapset2)
void *map, *map2;
@@ -472,8 +472,8 @@
for (x = 0; x < cols; x++)
- G3d_getValueRegion (map, x, y, z, (char *)n1p, typeIntern);
- G3d_getValueRegion (map2, x, y, z, (char *)n2p, typeIntern2);
+ G3d_getValueRegion (map, x, y, z, n1p, typeIntern);
+ G3d_getValueRegion (map2, x, y, z, n2p, typeIntern2);
G3d_isNullValueNum (n1p, typeIntern);
G3d_isNullValueNum (n2p, typeIntern2);
Modified: grass/branches/develbranch_6/lib/g3d/filename.c
--- grass/branches/develbranch_6/lib/g3d/filename.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/filename.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -7,11 +7,8 @@
void
-G3d_filename (char *path, char *elementName, char *mapName, char *mapset)
+G3d_filename (char *path, const char *elementName, const char *mapName, const char *mapset)
- char map[300];
- sprintf(map, "%s/%s", G3D_DIRECTORY, mapName);
- G__file_name (path, map, elementName, mapset);
+ G__file_name_misc(path, G3D_DIRECTORY, elementName, mapName, mapset);
Modified: grass/branches/develbranch_6/lib/g3d/g3dalloc.c
--- grass/branches/develbranch_6/lib/g3d/g3dalloc.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dalloc.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -25,7 +25,7 @@
G3d_malloc (int nBytes)
- char *buf;
+ void *buf;
if (nBytes <= 0) nBytes = 1;
if ((buf = malloc (nBytes)) != NULL) return buf;
Modified: grass/branches/develbranch_6/lib/g3d/g3dcache.c
--- grass/branches/develbranch_6/lib/g3d/g3dcache.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dcache.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -8,9 +8,10 @@
static int
-cacheRead_readFun (int tileIndex, char *tileBuf, G3D_Map *map)
+cacheRead_readFun (int tileIndex, void *tileBuf, void *closure)
+ G3D_Map *map = closure;
if (! G3d_readTile (map, tileIndex, tileBuf, map->typeIntern)) {
G3d_error ("cacheRead_readFun: error in G3d_readTile");
return 0;
@@ -57,9 +58,10 @@
static int
-cacheWrite_readFun (int tileIndex, char *tileBuf, G3D_Map *map)
+cacheWrite_readFun (int tileIndex, void *tileBuf, void *closure)
int index, nBytes;
long pos, offs, offsLast;
@@ -137,9 +139,10 @@
static int
-cacheWrite_writeFun (int tileIndex, char *tileBuf, G3D_Map *map)
+cacheWrite_writeFun (int tileIndex, const void *tileBuf, void *closure)
int nBytes;
long offs;
@@ -276,9 +279,10 @@
static int
-cacheFlushFun (int tileIndex, char *tileBuf, G3D_Map *map)
+cacheFlushFun (int tileIndex, const void *tileBuf, void *closure)
if (! G3d_writeTile (map, tileIndex, tileBuf, map->typeIntern)) {
G3d_error ("cacheFlushFun: error in G3d_writeTile");
return 0;
Modified: grass/branches/develbranch_6/lib/g3d/g3dcats.c
--- grass/branches/develbranch_6/lib/g3d/g3dcats.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dcats.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -24,7 +24,7 @@
int
-G3d_writeCats (char *name, struct Categories *cats)
+G3d_writeCats (const char *name, struct Categories *cats)
/* adapted from G_write_cats */
@@ -33,9 +33,9 @@
FILE *fd;
int i;
- char *descr;
+ const char *descr;
DCELL val1, val2;
- char str1[100], str2[100], buf[200], buf2[200], xname[512], xmapset[512];
+ char str1[100], str2[100], buf[200], buf2[200], xname[GNAME_MAX], xmapset[GMAPSET_MAX];
if (G__name_is_fully_qualified (name, xname, xmapset)) {
sprintf (buf, "%s/%s", G3D_DIRECTORY, xname);
@@ -82,7 +82,7 @@
static int
-read_cats (char *name, char *mapset, struct Categories *pcats)
+read_cats (const char *name, const char *mapset, struct Categories *pcats)
/* adapted from G__read_cats */
@@ -183,7 +183,7 @@
int
-G3d_readCats (char *name, char *mapset, struct Categories *pcats)
+G3d_readCats (const char *name, const char *mapset, struct Categories *pcats)
/* adapted from G_read_cats */
@@ -191,9 +191,7 @@
- char err[100];
- char *type;
- CELL G__read_cats();
+ const char *type;
switch (read_cats (name, mapset, pcats)) {
case -2:
@@ -206,8 +204,7 @@
return 0;
- sprintf(err,"category support for [%s] in mapset [%s] %s",
+ G_warning ("category support for [%s] in mapset [%s] %s",
name, mapset, type);
- G_warning (err);
return -1;
Modified: grass/branches/develbranch_6/lib/g3d/g3dclose.c
--- grass/branches/develbranch_6/lib/g3d/g3dclose.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dclose.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -13,14 +13,14 @@
G3d_closeNew (G3D_Map *map)
- char path[4096], buf[4096];
+ char path[GPATH_MAX];
struct Categories cats;
struct History hist;
G3d_removeColor (map->fileName);
/* create empty cats file */
- G_init_raster_cats ((char *) NULL, &cats);
+ G_init_raster_cats (NULL, &cats);
G3d_writeCats (map->fileName, &cats);
G_free_cats (&cats);
@@ -30,8 +30,7 @@
/*Use the G3d function to write the history file,
* otherwise the path is wrong */
if (!G3d_writeHistory(map->fileName, &hist)) {
- sprintf(buf, "G3d_closeNew: can't write raster3d history");
- G3d_error(buf);
+ G3d_error("G3d_closeNew: can't write raster3d history");
@@ -47,10 +46,8 @@
if (link (map->tempName, path) < 0) {
#endif
if(rename(map->tempName, path)) {
- sprintf (buf,
- "G3d_closeNew: can't move temp raster map %s\nto 3d data file %s",
+ G3d_error ("G3d_closeNew: can't move temp raster map %s\nto 3d data file %s",
map->tempName, path);
- G3d_error (buf);
return 0;
} else
Modified: grass/branches/develbranch_6/lib/g3d/g3dcolor.c
--- grass/branches/develbranch_6/lib/g3d/g3dcolor.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dcolor.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -53,8 +53,8 @@
char buf[512], buf2[200];
- char *err;
- char xname[512], xmapset[512];
+ const char *err;
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
struct FPRange drange;
DCELL dmin, dmax;
@@ -97,8 +97,7 @@
return 1;
- sprintf(buf,"color support for [%s] in mapset [%s] %s", name, mapset, err);
- G_warning (buf);
+ G_warning ("color support for [%s] in mapset [%s] %s", name, mapset, err);
return -1;
Modified: grass/branches/develbranch_6/lib/g3d/g3ddefaults.c
--- grass/branches/develbranch_6/lib/g3d/g3ddefaults.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3ddefaults.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -61,7 +61,6 @@
int g3d_tile_dimension[3] = {G3D_NO_DEFAULT, G3D_NO_DEFAULT, G3D_NO_DEFAULT};
void (*g3d_error_fun)(const char *) = NULL;
char *g3d_unit_default = NULL;
-extern char * G3d_getWindowParams(void);
@@ -335,7 +334,7 @@
void
-G3d_setUnit (char *unit)
+G3d_setUnit (const char *unit)
G3d_free (g3d_unit_default);
@@ -357,11 +356,11 @@
void
-G3d_initDefaults ()
+G3d_initDefaults (void)
static int firstTime = 1;
- char *value, *windowName;
+ const char *value, *windowName;
G3D_Region window;
if (! firstTime) return;
@@ -614,7 +613,7 @@
value = getenv (G3D_DEFAULT_WINDOW3D);
if (value != NULL)
- if (*value != 0) windowName = G_store (value);
+ if (*value != 0) windowName = value;
if (! G3d_readWindow (&window, windowName))
Modified: grass/branches/develbranch_6/lib/g3d/g3ddoubleio.c
--- grass/branches/develbranch_6/lib/g3d/g3ddoubleio.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3ddoubleio.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -9,7 +9,7 @@
int
-G3d_writeDoubles (int fd, int useXdr, double *i, int nofNum)
+G3d_writeDoubles (int fd, int useXdr, const double *i, int nofNum)
int firstTime = 1;
Modified: grass/branches/develbranch_6/lib/g3d/g3derror.c
--- grass/branches/develbranch_6/lib/g3d/g3derror.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3derror.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -81,8 +81,15 @@
void
-G3d_error (const char *msg)
+G3d_error (const char *msg, ...)
- (*g3d_error_fun) (msg);
+ char buffer[2000]; /* No novels to the error logs, OK? */
+ va_list ap;
+ va_start(ap,msg);
+ vsprintf(buffer,msg,ap);
+ va_end(ap);
+ (*g3d_error_fun) (buffer);
Modified: grass/branches/develbranch_6/lib/g3d/g3dfpxdr.c
--- grass/branches/develbranch_6/lib/g3d/g3dfpxdr.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dfpxdr.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -1,5 +1,6 @@
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <rpc/types.h>
@@ -8,67 +9,46 @@
-#define XDR_NULL_BYTE_0 255
-#define XDR_NULL_BYTE_1 255
-#define XDR_NULL_BYTE_2 255
-#define XDR_NULL_BYTE_3 255
-#define XDR_NULL_BYTE_4 255
-#define XDR_NULL_BYTE_5 255
-#define XDR_NULL_BYTE_6 255
-#define XDR_NULL_BYTE_7 255
int
-G3d_isXdrNullNum (unsigned char *num, int isFloat)
+G3d_isXdrNullNum (const void *num, int isFloat)
- if (*num++ != XDR_NULL_BYTE_0) return 0;
- if (*num++ != XDR_NULL_BYTE_1) return 0;
- if (*num++ != XDR_NULL_BYTE_2) return 0;
- if (*num++ != XDR_NULL_BYTE_3) return 0;
+ static const char null_bytes[8] = {
+ 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
- if (isFloat) return 1;
- if (*num++ != XDR_NULL_BYTE_4) return 0;
- if (*num++ != XDR_NULL_BYTE_5) return 0;
- if (*num++ != XDR_NULL_BYTE_6) return 0;
- return (*num == XDR_NULL_BYTE_7);
+ return memcmp(num, null_bytes, isFloat ? 4 : 8) == 0;
int
-G3d_isXdrNullFloat (float *f)
+G3d_isXdrNullFloat (const float *f)
- return G3d_isXdrNullNum ((unsigned char *) f, 1);
+ return G3d_isXdrNullNum (f, 1);
int
-G3d_isXdrNullDouble (double *d)
+G3d_isXdrNullDouble (const double *d)
- return G3d_isXdrNullNum ((unsigned char *) d, 0);
+ return G3d_isXdrNullNum (d, 0);
void
-G3d_setXdrNullNum (unsigned char *num, int isFloat)
+G3d_setXdrNullNum (void *num, int isFloat)
- *num++ = XDR_NULL_BYTE_0;
- *num++ = XDR_NULL_BYTE_1;
- *num++ = XDR_NULL_BYTE_2;
- *num++ = XDR_NULL_BYTE_3;
- if (isFloat) return;
- *num++ = XDR_NULL_BYTE_4;
- *num++ = XDR_NULL_BYTE_5;
- *num++ = XDR_NULL_BYTE_6;
- *num = XDR_NULL_BYTE_7;
+ memcpy(num, null_bytes, isFloat ? 4 : 8);
@@ -77,7 +57,7 @@
G3d_setXdrNullDouble (double *d)
- G3d_setXdrNullNum ((unsigned char *) d, 0);
+ G3d_setXdrNullNum (d, 0);
@@ -86,7 +66,7 @@
G3d_setXdrNullFloat (float *f)
- G3d_setXdrNullNum ((unsigned char *) f, 1);
+ G3d_setXdrNullNum (f, 1);
@@ -143,7 +123,7 @@
-char *xdrTmp;
+static void *xdrTmp;
static int dstType, srcType, type, externLength, eltLength, isFloat, useXdr;
static int (* xdrFun) ();
static XDR *xdrs;
@@ -178,23 +158,21 @@
int
-G3d_copyToXdr (char *src, int nofNum)
+G3d_copyToXdr (const void *src, int nofNum)
- char *srcLast;
+ int i;
if (useXdr == G3D_NO_XDR) {
G3d_copyValues (src, 0, srcType, xdrTmp, 0, type, nofNum);
- xdrTmp += nofNum * G3d_externLength (type);
+ xdrTmp = G_incr_void_ptr(xdrTmp, nofNum * G3d_externLength (type));
return 1;
- srcLast = src + nofNum * eltLength;
+ for (i = 0 ; i < nofNum ; i++, src = G_incr_void_ptr(src, eltLength)) {
- for ( ; src != srcLast ; src += eltLength) {
if (G3d_isNullValueNum (src, srcType)) {
- G3d_setXdrNullNum ((unsigned char *) xdrTmp, isFloat);
+ G3d_setXdrNullNum (xdrTmp, isFloat);
if (! xdr_setpos (xdrs, xdr_getpos (xdrs) + externLength)) {
G3d_error ("G3d_copyToXdr: positioning xdr failed");
return 0;
@@ -217,7 +195,7 @@
- xdrTmp += externLength;
+ xdrTmp = G_incr_void_ptr(xdrTmp, externLength);
return 1;
@@ -254,22 +232,20 @@
int
-G3d_copyFromXdr (int nofNum, char *dst)
+G3d_copyFromXdr (int nofNum, void *dst)
- char *dstLast;
+ int i;
G3d_copyValues (xdrTmp, 0, type, dst, 0, dstType, nofNum);
return 1;
- dstLast = dst + nofNum * eltLength;
+ for (i = 0 ; i < nofNum; i++, dst = G_incr_void_ptr(dst, eltLength)) {
- for ( ; dst != dstLast ; dst += eltLength) {
- if (G3d_isXdrNullNum ((unsigned char *) xdrTmp, isFloat)) {
+ if (G3d_isXdrNullNum (xdrTmp, isFloat)) {
G3d_setNullValue (dst, 1, dstType);
G3d_error ("G3d_copyFromXdr: positioning xdr failed");
@@ -293,7 +269,7 @@
return 1;
Modified: grass/branches/develbranch_6/lib/g3d/g3dhistory.c
--- grass/branches/develbranch_6/lib/g3d/g3dhistory.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dhistory.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -33,12 +33,8 @@
#include <grass/glocale.h>
#include "G3d_intern.h"
-/*local prototype */
-void SimpleErrorMessage(FILE * fd, char *name, char *mapset);
/*simple error message */
+void SimpleErrorMessage(FILE * fd, const char *name, const char *mapset)
if (fd != NULL)
fclose(fd);
@@ -64,11 +60,11 @@
* \return int
-int G3d_readHistory(char *name, char *mapset, struct History *hist)
+int G3d_readHistory(const char *name, const char *mapset, struct History *hist)
/* This function is adapted from G_read_history */
FILE *fd;
- char buff[1024], buf2[200], xname[512], xmapset[512];
+ char buff[1024], buf2[200], xname[GNAME_MAX], xmapset[GMAPSET_MAX];
G_zero(hist, sizeof(struct History));
@@ -162,12 +158,12 @@
* \return int
-int G3d_writeHistory(char *name, struct History *hist)
+int G3d_writeHistory(const char *name, struct History *hist)
/* This function is adapted from G_write_history */
FILE *fd;
int i;
- char buf[200], buf2[200], xname[512], xmapset[512];
+ char buf[200], buf2[200], xname[GNAME_MAX], xmapset[GMAPSET_MAX];
if (G__name_is_fully_qualified(name, xname, xmapset)) {
sprintf(buf, "%s/%s", G3D_DIRECTORY, xname);
Modified: grass/branches/develbranch_6/lib/g3d/g3dintio.c
--- grass/branches/develbranch_6/lib/g3d/g3dintio.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dintio.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -9,7 +9,7 @@
int
-G3d_writeInts (int fd, int useXdr, int *i, int nofNum)
+G3d_writeInts (int fd, int useXdr, const int *i, int nofNum)
int firstTime = 1;
Modified: grass/branches/develbranch_6/lib/g3d/g3dkeys.c
--- grass/branches/develbranch_6/lib/g3d/g3dkeys.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dkeys.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -1,71 +1,55 @@
#include <stdio.h>
#include <string.h>
-#include "g3dkeys.h"
int
-G3d_keyGetInt (struct Key_Value *keys, char *key, int *i)
+G3d_keyGetInt (struct Key_Value *keys, const char *key, int *i)
- char msg[1024];
char *str;
if ((str = G_find_key_value (key, keys)) == NULL) {
- sprintf (msg,
- "G3d_keyGetInt: cannot find field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetInt: cannot find field %s in key structure", key);
return 0;
- G_strip(str);
if (sscanf (str, "%d", i) == 1) return 1;
- sprintf (msg,
- "G3d_keyGetInt: invalid value: field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetInt: invalid value: field %s in key structure", key);
return 0;
int
-G3d_keyGetDouble (struct Key_Value *keys, char *key, double *d)
+G3d_keyGetDouble (struct Key_Value *keys, const char *key, double *d)
- char msg[1024];
char *str;
- sprintf (msg,
- "G3d_keyGetDouble: cannot find field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetDouble: cannot find field %s in key structure", key);
return 0;
- G_strip(str);
if (sscanf (str, "%lf", d) == 1) return 1;
- sprintf (msg,
- "G3d_keyGetDouble: invalid value: field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetDouble: invalid value: field %s in key structure", key);
return 0;
int
-G3d_keyGetString (struct Key_Value *keys, char *key, char **returnStr)
+G3d_keyGetString (struct Key_Value *keys, const char *key, char **returnStr)
- char msg[1024];
char *str;
- sprintf (msg,
- "G3d_keyGetString: cannot find field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetString: cannot find field %s in key structure", key);
return 0;
@@ -77,16 +61,13 @@
int
-G3d_keyGetValue (struct Key_Value *keys, char *key, char *val1, char *val2, int result1, int result2, int *resultVar)
+G3d_keyGetValue (struct Key_Value *keys, const char *key, char *val1, char *val2, int result1, int result2, int *resultVar)
- char msg[1024];
char *str;
- sprintf (msg,
- "G3d_keyGetValue: cannot find field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetValue: cannot find field %s in key structure", key);
return 0;
@@ -100,16 +81,14 @@
return 1;
- sprintf (msg,
- "G3d_keyGetValue: invalid type: field %s in key structure", key);
- G3d_error (msg);
+ G3d_error ("G3d_keyGetValue: invalid type: field %s in key structure", key);
return 0;
int
-G3d_keySetInt (struct Key_Value *keys, char *key, int *i)
+G3d_keySetInt (struct Key_Value *keys, const char *key, const int *i)
char keyValStr[200];
@@ -121,7 +100,7 @@
int
-G3d_keySetDouble (struct Key_Value *keys, char *key, double *d)
+G3d_keySetDouble (struct Key_Value *keys, const char *key, const double *d)
@@ -133,7 +112,7 @@
int
-G3d_keySetString (struct Key_Value *keys, char *key, char **keyValStr)
+G3d_keySetString (struct Key_Value *keys, const char *key, char * const *keyValStr)
return (G_set_key_value (key, *keyValStr, keys) != 0);
@@ -142,7 +121,7 @@
int
-G3d_keySetValue (struct Key_Value *keys, char *key, char *val1, char *val2, int keyval1, int keyval2, int *keyvalVar)
+G3d_keySetValue (struct Key_Value *keys, const char *key, const char *val1, const char *val2, int keyval1, int keyval2, const int *keyvalVar)
if (*keyvalVar == keyval1)
Deleted: grass/branches/develbranch_6/lib/g3d/g3dkeys.h
--- grass/branches/develbranch_6/lib/g3d/g3dkeys.h 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dkeys.h 2008-07-31 05:57:23 UTC (rev 32396)
@@ -1,9 +0,0 @@
-int G3d_keyGetInt (/* keys, key, i */);
-int G3d_keyGetDouble (/* keys, key, d */);
-int G3d_keyGetString (/* keys, key, returnStr */);
-int G3d_keyGetValue (/* keys, key, val1, val2, result1, result2, resultVar */);
-int G3d_keySetInt (/* keys, key, i */);
-int G3d_keySetDouble (/* keys, key, d */);
-int G3d_keySetString (/* keys, key, keyValStr */);
-int G3d_keySetValue (/* keys, key, val1, val2, keyval1, keyval2, keyvalVar */);
Modified: grass/branches/develbranch_6/lib/g3d/g3dmapset.c
--- grass/branches/develbranch_6/lib/g3d/g3dmapset.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dmapset.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -7,10 +7,10 @@
void
-G3d_makeMapsetMapDirectory (char *mapName)
+G3d_makeMapsetMapDirectory (const char *mapName)
- char buf[200];
+ char buf[GNAME_MAX + sizeof(G3D_DIRECTORY) + 2];
sprintf(buf, "%s/%s", G3D_DIRECTORY, mapName);
G__make_mapset_element (buf);
Modified: grass/branches/develbranch_6/lib/g3d/g3dmask.c
--- grass/branches/develbranch_6/lib/g3d/g3dmask.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dmask.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -120,7 +120,7 @@
top = ((double) z + 0.5) / (double) map->window.depths *
(map->window.top - map->window.bottom) + map->window.bottom;
- G3d_getRegionValue (G3d_maskMap, north, east, top, (char *)&value, FCELL_TYPE);
+ G3d_getRegionValue (G3d_maskMap, north, east, top, &value, FCELL_TYPE);
return value;
@@ -283,7 +283,7 @@
void
-G3d_maskTile (G3D_Map *map, int tileIndex, char *tile, int type)
+G3d_maskTile (G3D_Map *map, int tileIndex, void *tile, int type)
int nofNum, rows, cols, depths, xRedundant, yRedundant, zRedundant;
@@ -410,7 +410,7 @@
* \return char *
-char *
+const char *
G3d_maskFile (void)
return G3D_MASK_MAP;
Modified: grass/branches/develbranch_6/lib/g3d/g3dmisc.c
--- grass/branches/develbranch_6/lib/g3d/g3dmisc.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dmisc.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -1,5 +1,6 @@
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
@@ -19,59 +20,57 @@
void
-G3d_copyFloat2Double (float *src, int offsSrc, double *dst, int offsDst, int nElts)
+G3d_copyFloat2Double (const float *src, int offsSrc, double *dst, int offsDst, int nElts)
- float *srcStop;
+ int i;
src += offsSrc;
dst += offsDst;
- srcStop = src + nElts;
- while (src != srcStop) *dst++ = *src++;
+ for (i = 0; i < nElts; i++)
+ dst[i] = (double) src[i];
void
-G3d_copyDouble2Float (double *src, int offsSrc, float *dst, int offsDst, int nElts)
+G3d_copyDouble2Float (const double *src, int offsSrc, float *dst, int offsDst, int nElts)
- double *srcStop;
+ int i;
src += offsSrc;
dst += offsDst;
+ dst[i] = (float) src[i];
void
-G3d_copyValues (char *src, int offsSrc, int typeSrc, char *dst, int offsDst, int typeDst, int nElts)
+G3d_copyValues (const void *src, int offsSrc, int typeSrc, void *dst, int offsDst, int typeDst, int nElts)
- char *srcStop;
int eltLength;
if ((typeSrc == FCELL_TYPE) && (typeDst == DCELL_TYPE)) {
- G3d_copyFloat2Double ((float *) src, offsSrc, (double *) dst,
- offsDst, nElts);
+ G3d_copyFloat2Double (src, offsSrc, dst, offsDst, nElts);
return;
if ((typeSrc == DCELL_TYPE) && (typeDst == FCELL_TYPE)) {
- G3d_copyDouble2Float ((double *) src, offsSrc, (float *) dst,
- offsDst, nElts);
+ G3d_copyDouble2Float (src, offsSrc, dst, offsDst, nElts);
return;
eltLength = G3d_length (typeSrc);
- src += eltLength * offsSrc;
- dst += eltLength * offsDst;
+ src = G_incr_void_ptr(src, eltLength * offsSrc);
+ dst = G_incr_void_ptr(dst, eltLength * offsDst);
- srcStop = src + nElts * eltLength;
+ memcpy(dst, src, nElts * eltLength);
Modified: grass/branches/develbranch_6/lib/g3d/g3dnull.c
--- grass/branches/develbranch_6/lib/g3d/g3dnull.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dnull.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -7,7 +7,7 @@
int
-G3d_isNullValueNum (void *n, int type)
+G3d_isNullValueNum (const void *n, int type)
if (type == FCELL_TYPE)
Modified: grass/branches/develbranch_6/lib/g3d/g3dopen2.c
--- grass/branches/develbranch_6/lib/g3d/g3dopen2.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dopen2.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -4,7 +4,7 @@
void *
-G3d_openNewParam (char *name, int typeIntern, int cache, G3D_Region *region, int type, int doLzw, int doRle, int precision, int tileX, int tileY, int tileZ)
+G3d_openNewParam (const char *name, int typeIntern, int cache, G3D_Region *region, int type, int doLzw, int doRle, int precision, int tileX, int tileY, int tileZ)
void *map;
Modified: grass/branches/develbranch_6/lib/g3d/g3dparam.c
--- grass/branches/develbranch_6/lib/g3d/g3dparam.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dparam.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -159,7 +159,7 @@
static struct Option *windowParam = NULL;
void
-G3d_setWindowParams()
+G3d_setWindowParams(void)
windowParam = G_define_option();
@@ -173,7 +173,7 @@
-char * G3d_getWindowParams()
+char * G3d_getWindowParams(void)
if (windowParam == NULL) return NULL;
Modified: grass/branches/develbranch_6/lib/g3d/g3drange.c
--- grass/branches/develbranch_6/lib/g3d/g3drange.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3drange.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -10,7 +10,7 @@
void
-G3d_range_updateFromTile (G3D_Map *map, char *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
+G3d_range_updateFromTile (G3D_Map *map, const void *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
int y, z, cellType;
struct FPRange *range;
@@ -27,9 +27,10 @@
for (z = 0; z < depths; z++) {
for (y = 0; y < rows; y++) {
G_row_update_fp_range (tile, cols, range, cellType);
- tile += map->tileX * G3d_length (type);
+ tile = G_incr_void_ptr(tile, map->tileX * G3d_length (type));
- if (yRedundant) tile += map->tileX * yRedundant * G3d_length (type);
+ if (yRedundant)
+ tile = G_incr_void_ptr(tile, map->tileX * yRedundant * G3d_length (type));
return;
@@ -37,7 +38,7 @@
if (yRedundant) {
G_row_update_fp_range (tile, map->tileX * rows, range, cellType);
- tile += map->tileXY * G3d_length (type);
+ tile = G_incr_void_ptr(tile, map->tileXY * G3d_length (type));
return;
@@ -52,7 +53,9 @@
/* adapted from G_read_fp_range */
int fd;
- char buf[200], xdr_buf[100], buf2[200], xname[512], xmapset[512];
+ char buf[GNAME_MAX + sizeof(G3D_DIRECTORY) + 2], buf2[GMAPSET_MAX + sizeof(G3D_RANGE_ELEMENT) + 2];
+ char xdr_buf[100];
DCELL dcell1, dcell2;
XDR xdr_str;
@@ -90,8 +93,7 @@
error:
if (fd > 0) close(fd);
- sprintf (buf, "can't read range file for [%s in %s]", name, mapset);
- G_warning (buf);
+ G_warning ("can't read range file for [%s in %s]", name, mapset);
return -1;
@@ -144,11 +146,13 @@
static int
-writeRange (char *name, struct FPRange *range)
+writeRange (const char *name, struct FPRange *range)
/* adapted from G_write_fp_range */
int fd;
XDR xdr_str;
Modified: grass/branches/develbranch_6/lib/g3d/g3dregion.c
--- grass/branches/develbranch_6/lib/g3d/g3dregion.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dregion.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -156,7 +156,7 @@
struct Cell_head region2d;
- char *err;
+ const char *err;
G3d_regionToCellHead (region, ®ion2d);
if ( (err = G_adjust_Cell_head3 (®ion2d, 1, 1, 1)) != NULL ) {
@@ -187,7 +187,7 @@
- char *err;
+ const char *err;
@@ -246,7 +246,7 @@
void
-G3d_getRegionValue (G3D_Map *map, double north, double east, double top, char *value, int type)
+G3d_getRegionValue (G3D_Map *map, double north, double east, double top, void *value, int type)
int row, col, depth;
@@ -276,14 +276,14 @@
int
-G3d_readRegionMap (char *name, char *mapset, G3D_Region *region)
+G3d_readRegionMap (const char *name, const char *mapset, G3D_Region *region)
- char fullName[1000];
+ char fullName[GPATH_MAX];
- G3d_filename (fullName, G3D_HEADER_ELEMENT, xname, mapset);
+ G3d_filename (fullName, G3D_HEADER_ELEMENT, xname, xmapset);
else
G3d_filename (fullName, G3D_HEADER_ELEMENT, name, mapset);
return G3d_readWindow (region, fullName);
Modified: grass/branches/develbranch_6/lib/g3d/g3dresample.c
--- grass/branches/develbranch_6/lib/g3d/g3dresample.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dresample.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -21,7 +21,7 @@
void
-G3d_nearestNeighbor (G3D_Map *map, int row, int col, int depth, char *value, int type)
+G3d_nearestNeighbor (G3D_Map *map, int row, int col, int depth, void *value, int type)
Modified: grass/branches/develbranch_6/lib/g3d/g3dvolume.c
--- grass/branches/develbranch_6/lib/g3d/g3dvolume.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dvolume.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -50,14 +50,7 @@
void
-G3d_getVolumeA (map, u, nx, ny, nz, volumeBuf, type)
- void *map;
- double u[2][2][2][3];
- int nx, ny, nz;
- char *volumeBuf;
- int type;
+G3d_getVolumeA (void *map, double u[2][2][2][3], int nx, int ny, int nz, void *volumeBuf, int type)
typedef double doubleArray[3];
@@ -140,23 +133,13 @@
void
-G3d_getVolume (map,
- originNorth, originWest, originBottom,
- vxNorth, vxWest, vxBottom,
- vyNorth, vyWest, vyBottom,
- vzNorth, vzWest, vzBottom,
- nx, ny, nz,
- volumeBuf, type)
- void *map;
- double originNorth, originWest, originBottom;
- double vxNorth, vxWest, vxBottom;
- double vyNorth, vyWest, vyBottom;
- double vzNorth, vzWest, vzBottom;
- int nx, ny, nz;
- char *volumeBuf;
- int type;
+G3d_getVolume (void *map,
+ double originNorth, double originWest, double originBottom,
+ double vxNorth, double vxWest, double vxBottom,
+ double vyNorth, double vyWest, double vyBottom,
+ double vzNorth, double vzWest, double vzBottom,
+ int nx, int ny, int nz,
+ void *volumeBuf, int type)
@@ -198,19 +181,11 @@
void
-G3d_getAllignedVolume (map,
- lengthNorth, lengthWest, lengthBottom,
- nx, ny, nz,
- volumeBuf, type)
- void *map;
- double lengthNorth, lengthWest, lengthBottom;
- int nx, ny, nz;
- char *volumeBuf;
- int type;
+G3d_getAlignedVolume (void *map,
+ double lengthNorth, double lengthWest, double lengthBottom,
G3d_getVolume (map,
@@ -224,28 +199,21 @@
void
-G3d_makeAllignedVolumeFile (map, fileName,
- nx, ny, nz)
- void *map;
- char *fileName;
- int nx, ny, nz;
+G3d_makeAlignedVolumeFile (void *map, const char *fileName,
+ int nx, int ny, int nz)
- char *volumeBuf;
+ void *volumeBuf;
void *mapVolume;
int x, y, z, eltLength;
G3D_Region region;
- volumeBuf = (char *) G3d_malloc (nx * ny * nz * sizeof (G3d_getFileType ()));
+ volumeBuf = G3d_malloc (nx * ny * nz * sizeof (G3d_getFileType ()));
if (volumeBuf == NULL)
- G3d_fatalError ("G3d_makeAllignedVolumeFile: error in G3d_malloc");
+ G3d_fatalError ("G3d_makeAlignedVolumeFile: error in G3d_malloc");
- G3d_getAllignedVolume (map,
+ G3d_getAlignedVolume (map,
nx, ny, nz,
@@ -266,7 +234,7 @@
mapVolume = G3d_openCellNew (fileName, G3d_getFileType (),
G3D_USE_CACHE_DEFAULT, ®ion);
if (mapVolume == NULL)
- G3d_fatalError ("G3d_makeAllignedVolumeFile: error in G3d_openCellNew");
+ G3d_fatalError ("G3d_makeAlignedVolumeFile: error in G3d_openCellNew");
eltLength = G3d_length (G3d_getFileType ());
@@ -275,15 +243,15 @@
for (x = 0; x < nx; x++) {
/* G3d_putValueRegion? */
if (! G3d_putValue (mapVolume, x, y, z,
- volumeBuf + (z * ny * nx + y * nx + x) * eltLength,
+ G_incr_void_ptr(volumeBuf, (z * ny * nx + y * nx + x) * eltLength),
G3d_fileTypeMap (mapVolume)))
- G3d_fatalError ("G3d_makeAllignedVolumeFile: error in G3d_putValue");
+ G3d_fatalError ("G3d_makeAlignedVolumeFile: error in G3d_putValue");
if (! G3d_closeCell (mapVolume))
- G3d_fatalError ("G3d_makeAllignedVolumeFile: error in G3d_closeCell");
+ G3d_fatalError ("G3d_makeAlignedVolumeFile: error in G3d_closeCell");
G3d_free (volumeBuf);
Modified: grass/branches/develbranch_6/lib/g3d/g3dwindow.c
--- grass/branches/develbranch_6/lib/g3d/g3dwindow.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dwindow.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -193,7 +193,7 @@
float value;
- G3d_getValue (map, x, y, z, (char *)&value, FCELL_TYPE);
+ G3d_getValue (map, x, y, z, &value, FCELL_TYPE);
return value;
@@ -219,6 +219,6 @@
double value;
- G3d_getValue (map, x, y, z, (char *)&value, DCELL_TYPE);
+ G3d_getValue (map, x, y, z, &value, DCELL_TYPE);
return value;
Modified: grass/branches/develbranch_6/lib/g3d/g3dwindowio.c
--- grass/branches/develbranch_6/lib/g3d/g3dwindowio.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/g3dwindowio.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -6,7 +6,6 @@
#include <string.h>
#include <grass/gis.h>
@@ -55,10 +54,10 @@
* otherwise G3D_WINDOW_DATABASE ("$MAPSET/windows3d/$NAME")
static void
-G3d_getFullWindowPath (char path[1024], char *windowName)
+G3d_getFullWindowPath (char *path, const char *windowName)
if (windowName == NULL) {
G__file_name (path, "", G3D_WINDOW_ELEMENT, G_mapset ());
@@ -134,7 +133,7 @@
int
-G3d_readWindow (G3D_Region *window, char *windowName)
+G3d_readWindow (G3D_Region *window, const char *windowName)
struct Cell_head win;
Modified: grass/branches/develbranch_6/lib/g3d/getblock.c
--- grass/branches/develbranch_6/lib/g3d/getblock.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/getblock.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -10,7 +10,7 @@
G3d_getBlockNocache (G3D_Map *map, int x0, int y0, int z0, int nx, int ny, int nz, void *block, int type)
- char *tile;
+ void *tile;
int tileX0, tileY0, tileZ0, tileOffsX0, tileOffsY0, tileOffsZ0;
int tileX1, tileY1, tileZ1, tileOffsX1, tileOffsY1, tileOffsZ1;
int tx, ty, tz, dx, dy, dz, x, y, z, rows, cols, depths;
@@ -95,7 +95,7 @@
void
-G3d_getBlock (G3D_Map *map, int x0, int y0, int z0, int nx, int ny, int nz, char *block, int type)
+G3d_getBlock (G3D_Map *map, int x0, int y0, int z0, int nx, int ny, int nz, void *block, int type)
int x, y, z, nNull, x1, y1, z1, length;
@@ -115,15 +115,15 @@
for (y = y0; y < y1; y++) {
for (x = x0; x < x1; x++) {
G3d_getValueRegion (map, x, y, z, block, type);
- block += length;
+ block = G_incr_void_ptr(block, length);
nNull = x0 + nx - x;
G3d_setNullValue (block, nNull, type);
- block += length * nNull;
+ block = G_incr_void_ptr(block, length * nNull);
nNull = (y0 + ny - y) * nx;
nNull = (z0 + nz - z) * ny * nx;
Modified: grass/branches/develbranch_6/lib/g3d/header.c
--- grass/branches/develbranch_6/lib/g3d/header.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/header.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -6,13 +6,12 @@
#include <rpc/xdr.h>
-char *tmpCompress = NULL;
+void *tmpCompress;
-char *xdr = NULL;
+void *xdr;
int xdrLength;
@@ -106,20 +105,18 @@
struct Key_Value *headerKeys;
- char path[1024], msg[1024];
int status;
G3d_filename (path, G3D_HEADER_ELEMENT, map->fileName, map->mapset);
if (access(path, R_OK) != 0) {
- sprintf (msg,"G3d_readHeader: unable to find [%s]", path);
- G3d_error (msg);
+ G3d_error ("G3d_readHeader: unable to find [%s]", path);
return 0;
headerKeys = G_read_key_value_file (path, &status);
if (status != 0) {
- sprintf (msg, "G3d_readHeader: Unable to open %s", path);
- G3d_error (msg);
+ G3d_error ("G3d_readHeader: Unable to open %s", path);
return 0;
@@ -131,9 +128,8 @@
type, compression, useRle, useLzw, precision,
dataOffset, useXdr, hasIndex, unit)) {
- sprintf (msg, "G3d_readHeader: error extracting header key(s) of file %s",
+ G3d_error ("G3d_readHeader: error extracting header key(s) of file %s",
path);
- G3d_error (msg);
return 0;
@@ -148,7 +144,7 @@
int status;
headerKeys = G_create_key_value();
@@ -162,9 +158,8 @@
&type, &compression, &useRle, &useLzw,
&precision, &dataOffset, &useXdr, &hasIndex,
&unit)) {
- sprintf (msg, "G3d_writeHeader: error adding header key(s) for file %s",
+ G3d_error ("G3d_writeHeader: error adding header key(s) for file %s",
path);
- G3d_error (msg);
return 0;
@@ -176,8 +171,7 @@
if (status == 0) return 1;
- sprintf (msg, "G3d_writeHeader: error writing header file %s", path);
- G3d_error (msg);
+ G3d_error ("G3d_writeHeader: error writing header file %s", path);
return 0;
Modified: grass/branches/develbranch_6/lib/g3d/retile.c
--- grass/branches/develbranch_6/lib/g3d/retile.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/retile.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -7,13 +7,13 @@
static void
-retileNocache (void *map, char *nameOut, int tileX, int tileY, int tileZ)
+retileNocache (void *map, const char *nameOut, int tileX, int tileY, int tileZ)
void *map2;
int x, y, z, saveType, nx, ny, nz;
int typeIntern;
- char *data;
+ void *data;
int tileXsave, tileYsave, tileZsave;
G3D_Region region;
@@ -71,7 +71,7 @@
void
-G3d_retile (void *map, char *nameOut, int tileX, int tileY, int tileZ)
+G3d_retile (void *map, const char *nameOut, int tileX, int tileY, int tileZ)
void *map2;
@@ -124,8 +124,8 @@
for (x = 0; x < cols; x++) {
- G3d_getValueRegion (map, x, y, z, (char *)&value, typeIntern);
- if (! G3d_putValue(map2, x, y, z, (char *)&value, typeIntern))
+ G3d_getValueRegion (map, x, y, z, &value, typeIntern);
+ if (! G3d_putValue(map2, x, y, z, &value, typeIntern))
G3d_fatalError ("G3d_retile: error in G3d_putValue");
Modified: grass/branches/develbranch_6/lib/g3d/tilealloc.c
--- grass/branches/develbranch_6/lib/g3d/tilealloc.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/tilealloc.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -19,20 +19,20 @@
* \param map
* \param nofTiles
* \param type
- * \return char * : a pointer to the vector ... if successful,
+ * \return void * : a pointer to the vector ... if successful,
* NULL ... otherwise.
-char *
+void *
G3d_allocTilesType (G3D_Map *map, int nofTiles, int type)
- char *tiles;
+ void *tiles;
tiles = G3d_malloc (map->tileSize * G3d_length (type) * nofTiles);
if (tiles == NULL) {
G3d_error ("G3d_allocTilesType: error in G3d_malloc");
+ return NULL;
return tiles;
@@ -48,19 +48,19 @@
* \param map
* \param nofTiles
- * \return char *
+ * \return void *
-char *
+void *
G3d_allocTiles (G3D_Map *map, int nofTiles)
- char *tiles;
+ void *tiles;
tiles = G3d_allocTilesType (map, nofTiles, map->typeIntern);
G3d_error ("G3d_allocTiles: error in G3d_allocTilesType");
+ return NULL;
return tiles;
@@ -79,7 +79,7 @@
void
-G3d_freeTiles (char *tiles)
+G3d_freeTiles (void *tiles)
G3d_free (tiles);
Modified: grass/branches/develbranch_6/lib/g3d/tileio.c
--- grass/branches/develbranch_6/lib/g3d/tileio.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/tileio.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -66,22 +66,22 @@
-char *
+void *
G3d_getTilePtr (G3D_Map *map, int tileIndex)
- char *ptr;
+ void *ptr;
if ((tileIndex >= map->nTiles) || (tileIndex < 0)) {
G3d_error ("G3d_getTilePtr: tileIndex out of range");
+ return NULL;
if (map->useCache) {
ptr = G3d_cache_elt_ptr (map->cache, tileIndex);
if (ptr == NULL) {
G3d_error ("G3d_getTilePtr: error in G3d_cache_elt_ptr");
+ return NULL;
return ptr;
@@ -91,7 +91,7 @@
map->currentIndex = tileIndex;
if (! G3d_readTile (map, map->currentIndex, map->data, map->typeIntern)) {
G3d_error ("G3d_getTilePtr: error in G3d_readTile");
+ return NULL;
return map->data;
Modified: grass/branches/develbranch_6/lib/g3d/tilenull.c
--- grass/branches/develbranch_6/lib/g3d/tilenull.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/tilenull.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -21,7 +21,7 @@
void
-G3d_setNullTileType (G3D_Map *map, char *tile, int type)
+G3d_setNullTileType (G3D_Map *map, void *tile, int type)
G3d_setNullValue (tile, map->tileSize, type);
@@ -41,7 +41,7 @@
void
-G3d_setNullTile (G3D_Map *map, char *tile)
+G3d_setNullTile (G3D_Map *map, void *tile)
G3d_setNullTileType (map, tile, map->typeIntern);
Modified: grass/branches/develbranch_6/lib/g3d/tileread.c
--- grass/branches/develbranch_6/lib/g3d/tileread.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/tileread.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -7,7 +7,7 @@
static int
-G3d_xdrTile2tile (G3D_Map *map, char *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
+G3d_xdrTile2tile (G3D_Map *map, void *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
int y, z, xLength, yLength, length;
@@ -36,13 +36,13 @@
G3d_error ("G3d_xdrTile2tile: error in G3d_copyFromXdr");
return 0;
- tile += cols * length;
+ tile = G_incr_void_ptr(tile, cols * length);
G3d_setNullValue (tile, xRedundant, type);
- tile += xLength;
+ tile = G_incr_void_ptr(tile, xLength);
if (yRedundant) {
G3d_setNullValue (tile, map->tileX * yRedundant, type);
- tile += yLength;
+ tile = G_incr_void_ptr(tile, yLength);
if (! zRedundant) return 1;
@@ -57,9 +57,9 @@
return 0;
- tile += map->tileX * rows * length;
+ tile = G_incr_void_ptr(tile, map->tileX * rows * length);
- tile += yLength;
@@ -74,7 +74,7 @@
- tile += map->tileXY * depths * length;
+ tile = G_incr_void_ptr(tile, map->tileXY * depths * length);
G3d_setNullValue (tile, map->tileXY * zRedundant, type);
return 1;
@@ -141,7 +141,7 @@
int
-G3d_readTile (G3D_Map *map, int tileIndex, char *tile, int type)
+G3d_readTile (G3D_Map *map, int tileIndex, void *tile, int type)
@@ -202,7 +202,7 @@
int
-G3d_readTileFloat (G3D_Map *map, int tileIndex, char *tile)
+G3d_readTileFloat (G3D_Map *map, int tileIndex, void *tile)
if (! G3d_readTile (map, tileIndex, tile, FCELL_TYPE)) {
@@ -228,7 +228,7 @@
int
-G3d_readTileDouble (G3D_Map *map, int tileIndex, char *tile)
+G3d_readTileDouble (G3D_Map *map, int tileIndex, void *tile)
if (! G3d_readTile (map, tileIndex, tile, DCELL_TYPE)) {
Modified: grass/branches/develbranch_6/lib/g3d/tilewrite.c
--- grass/branches/develbranch_6/lib/g3d/tilewrite.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/tilewrite.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -10,7 +10,7 @@
static int
-G3d_tile2xdrTile (G3D_Map *map, char *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
+G3d_tile2xdrTile (G3D_Map *map, const void *tile, int rows, int cols, int depths, int xRedundant, int yRedundant, int zRedundant, int nofNum, int type)
int y, z;
@@ -36,10 +36,10 @@
G3d_error ("G3d_tile2xdrTile: error in G3d_copyToXdr");
return 0;
if (yRedundant)
- tile += map->tileX * yRedundant * G3d_length (type);
return 1;
@@ -50,7 +50,7 @@
return 0;
return 1;
@@ -124,7 +124,7 @@
int
-G3d_writeTile (G3D_Map *map, int tileIndex, char *tile, int type)
+G3d_writeTile (G3D_Map *map, int tileIndex, const void *tile, int type)
int rows, cols, depths, xRedundant, yRedundant, zRedundant, nofNum;
@@ -190,7 +190,7 @@
int
-G3d_writeTileFloat (G3D_Map *map, int tileIndex, char *tile)
+G3d_writeTileFloat (G3D_Map *map, int tileIndex, const void *tile)
int status;
@@ -216,7 +216,7 @@
int
-G3d_writeTileDouble (G3D_Map *map, int tileIndex, char *tile)
+G3d_writeTileDouble (G3D_Map *map, int tileIndex, const void *tile)
int status;
@@ -255,7 +255,7 @@
G3d_flushTile (G3D_Map *map, int tileIndex)
- char *tile;
+ const void *tile;
tile = G3d_getTilePtr (map, tileIndex);
if (tile == NULL) {
@@ -540,7 +540,7 @@
int
-G3d_putValue (G3D_Map *map, int x, int y, int z, char *value, int type)
+G3d_putValue (G3D_Map *map, int x, int y, int z, const void *value, int type)
if (type == FCELL_TYPE) {
Modified: grass/branches/develbranch_6/lib/g3d/writeascii.c
--- grass/branches/develbranch_6/lib/g3d/writeascii.c 2008-07-31 05:48:39 UTC (rev 32395)
+++ grass/branches/develbranch_6/lib/g3d/writeascii.c 2008-07-31 05:57:23 UTC (rev 32396)
@@ -16,7 +16,7 @@
void
-G3d_writeAscii (void *map, char *fname)
+G3d_writeAscii (void *map, const char *fname)
FILE *fp;
@@ -41,7 +41,7 @@
fprintf (fp, "z y x %d %d (%d - %d)\n", z, y, 0, cols - 1);
- G3d_getValueRegion (map, x, y, z, (char *)d1p, typeIntern);
+ G3d_getValueRegion (map, x, y, z, d1p, typeIntern);
fprintf (fp, "%.18f ", *f1p);
