[GRASS-SVN] r31603 - grass-addons/gipe/i.eb.h_SEBAL95
svn_grass at osgeo.org
Mon Jun 2 02:34:26 EDT 2008
Author: ychemin
Date: 2008-06-02 02:34:26 -0400 (Mon, 02 Jun 2008)
New Revision: 31603
grass-addons/gipe/i.eb.h_SEBAL95/U_0.c
grass-addons/gipe/i.eb.h_SEBAL95/main.c
grass-addons/gipe/i.eb.h_SEBAL95/psi_h.c
grass-addons/gipe/i.eb.h_SEBAL95/rah1.c
grass-addons/gipe/i.eb.h_SEBAL95/rah_0.c
grass-addons/gipe/i.eb.h_SEBAL95/roh_air_0.c
grass-addons/gipe/i.eb.h_SEBAL95/u_star.c
grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c
bug fixing, tested it.
Modified: grass-addons/gipe/i.eb.h_SEBAL95/U_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/U_0.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/U_0.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -6,7 +6,7 @@
double u_0;
- u_0 = u2m*0.41*log(200/(0.15/7))/(log(2/(0.15/7))*log(200/zom_0));
+ u_0 = u2m*0.41*log10(200/(0.15/7))/(log10(2/(0.15/7))*log10(200/zom_0));
// printf("u_0 = %5.3f\n", u_0);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -6,7 +6,7 @@
* Delta T will be reassessed in the iterations !
* This has been seen in Bastiaanssen (1995).
- * COPYRIGHT: (C) 2002-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -25,6 +25,7 @@
#include <grass/glocale.h>
/*#include <omp.h>*/
double sensi_h( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
int main(int argc, char *argv[])
@@ -33,24 +34,25 @@
char *mapset; // mapset name
/* buffer for in out raster */
- DCELL *inrast_T,*inrast_ndvi,*inrast_u2,*inrast_DEM;
- DCELL *inrast_Rn,*inrast_g0,*inrast_albedo,*outrast;
+ void *inrast_T,*inrast_ndvi,*inrast_u2,*inrast_dem;
+ void *inrast_Rn,*inrast_g0,*inrast_albedo;
+ DCELL *outrast;
int nrows, ncols;
int row, col;
int row_wet, col_wet;
int row_dry, col_dry;
- int infd_T,infd_ndvi,infd_u2,infd_DEM,infd_Rn,infd_g0,infd_albedo;
+ int infd_T,infd_ndvi,infd_u2,infd_dem,infd_Rn,infd_g0,infd_albedo;
int outfd;
- char *mapset_T,*mapset_ndvi,*mapset_u2,*mapset_DEM;
+ char *mapset_T,*mapset_ndvi,*mapset_u2,*mapset_dem;
char *mapset_Rn,*mapset_g0,*mapset_albedo;
- char *T, *ndvi, *u2, *DEM, *Rn, *g0, *albedo;
+ char *T, *ndvi, *u2, *dem, *Rn, *g0, *albedo;
char *h0;
struct History history;
struct GModule *module;
- struct Option *input_T, *input_ndvi, *input_u2, *input_DEM;
+ struct Option *input_T, *input_ndvi, *input_u2, *input_dem;
struct Option *input_Rn, *input_g0, *input_albedo, *output;
struct Option *input_row_wet, *input_col_wet;
struct Option *input_row_dry, *input_col_dry;
@@ -60,7 +62,7 @@
RASTER_MAP_TYPE data_type_T;
RASTER_MAP_TYPE data_type_ndvi;
RASTER_MAP_TYPE data_type_u2;
- RASTER_MAP_TYPE data_type_DEM;
+ RASTER_MAP_TYPE data_type_dem;
RASTER_MAP_TYPE data_type_Rn;
RASTER_MAP_TYPE data_type_g0;
RASTER_MAP_TYPE data_type_albedo;
@@ -75,45 +77,37 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->description = _("Sensible Heat Flux iteration from SEBAL 95");
+ module->description = _("Sensible Heat Flux iteration SEBAL 95");
/* Define different options */
input_T = G_define_standard_option(G_OPT_R_INPUT);
input_T->key = "T";
input_T->description = _("Name of Surface Skin Temperature input map [K]");
- input_T->guisection = _("Required");
input_u2 = G_define_standard_option(G_OPT_R_INPUT);
input_u2->key = "u2m";
input_u2->description = _("Name of Wind Speed input map [m/s]");
- input_u2->guisection = _("Required");
- input_DEM = G_define_standard_option(G_OPT_R_INPUT);
- input_DEM->key = "DEM";
- input_DEM->description = _("Name of DEM input map [m a.s.l.]");
- input_DEM->guisection = _("Required");
+ input_dem = G_define_standard_option(G_OPT_R_INPUT);
+ input_dem->key = "dem";
+ input_dem->description = _("Name of dem input map [m a.s.l.]");
input_ndvi = G_define_standard_option(G_OPT_R_INPUT);
input_ndvi->key = "ndvi";
- input_ndvi->description = _("Name of NDVI input map [%]");
- input_ndvi->guisection = _("Required");
+ input_ndvi->description = _("Name of NDVI input map [-]");
+ input_albedo = G_define_standard_option(G_OPT_R_INPUT);
+ input_albedo->key = "albedo";
+ input_albedo->description = _("Name of Albedo input map [-]");
input_Rn = G_define_standard_option(G_OPT_R_INPUT);
- input_Rn->key = "Rn";
- input_Rn->description = _("Name of Diurnal Net Solar Radiation input map [W/m2]");
- input_Rn->guisection = _("Required");
+ input_Rn->key = "rnet";
+ input_Rn->description = _("Name of instantaneous Net Solar Radiation input map [W/m2]");
input_g0 = G_define_standard_option(G_OPT_R_INPUT);
input_g0->key = "g0";
- input_g0->description = _("Name of Soil Heat Flux input map [W/m2]");
- input_g0->guisection = _("Required");
+ input_g0->description = _("Name of instantaneous Soil Heat Flux input map [W/m2]");
- input_albedo = G_define_standard_option(G_OPT_R_INPUT);
- input_albedo->key = "albedo";
- input_albedo->required = NO;
- input_albedo->description = _("With Flag \"-a\": Name of Albedo input map [-]");
- input_albedo->guisection = _("Optional");
input_iter = G_define_option();
input_iter->key = "iteration";
input_iter->type = TYPE_INTEGER;
@@ -156,7 +150,7 @@
output = G_define_standard_option(G_OPT_R_OUTPUT) ;
output->key = "h0";
- output->description= _("Name of output Actual Evapotranspiration layer [mm/d]");
+ output->description= _("Name of output sensible heat flux layer [W/m2]");
output->guisection = _("Required");
/* Define the different flags */
@@ -174,7 +168,7 @@
/* get entered parameters */
T = input_T->answer;
u2 = input_u2->answer;
- DEM = input_DEM->answer;
+ dem = input_dem->answer;
ndvi = input_ndvi->answer;
Rn = input_Rn->answer;
g0 = input_g0->answer;
@@ -197,9 +191,9 @@
mapset_u2 = G_find_cell2 (u2, "");
if (mapset_u2 == NULL)
G_fatal_error (_("cell file [%s] not found"), u2);
- mapset_DEM = G_find_cell2 (DEM, "");
- if (mapset_DEM == NULL)
- G_fatal_error (_("cell file [%s] not found"), DEM);
+ mapset_dem = G_find_cell2 (dem, "");
+ if (mapset_dem == NULL)
+ G_fatal_error (_("cell file [%s] not found"), dem);
mapset_ndvi = G_find_cell2 (ndvi, "");
if (mapset_ndvi == NULL)
G_fatal_error (_("cell file [%s] not found"), ndvi);
@@ -209,11 +203,9 @@
mapset_g0 = G_find_cell2 (g0, "");
if (mapset_g0 == NULL)
G_fatal_error (_("cell file [%s] not found"), g0);
- if(flag1->answer){
- mapset_albedo = G_find_cell2 (albedo, "");
- if (mapset_albedo == NULL)
- G_fatal_error(_("cell file [%s] not found"),albedo);
+ mapset_albedo = G_find_cell2 (albedo, "");
+ if (mapset_albedo == NULL)
+ G_fatal_error(_("cell file [%s] not found"),albedo);
/* check legal output name */
if (G_legal_filename (h0) < 0)
@@ -222,55 +214,51 @@
/* determine the input map type (CELL/FCELL/DCELL) */
data_type_T = G_raster_map_type(T, mapset_T);
data_type_u2 = G_raster_map_type(u2, mapset_u2);
- data_type_DEM = G_raster_map_type(DEM, mapset_DEM);
+ data_type_dem = G_raster_map_type(dem, mapset_dem);
data_type_ndvi = G_raster_map_type(ndvi, mapset_ndvi);
data_type_Rn = G_raster_map_type(Rn, mapset_Rn);
data_type_g0 = G_raster_map_type(g0, mapset_g0);
- data_type_albedo = G_raster_map_type(albedo, mapset_albedo);
+ data_type_albedo = G_raster_map_type(albedo, mapset_albedo);
if ( (infd_T = G_open_cell_old (T, mapset_T)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"), T);
if ( (infd_u2 = G_open_cell_old (u2, mapset_u2)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),u2);
- if ( (infd_DEM = G_open_cell_old (DEM, mapset_DEM)) < 0)
- G_fatal_error (_("Cannot open cell file [%s]"),DEM);
+ if ( (infd_dem = G_open_cell_old (dem, mapset_dem)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"),dem);
if ( (infd_ndvi = G_open_cell_old (ndvi, mapset_ndvi)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),ndvi);
if ( (infd_Rn = G_open_cell_old (Rn, mapset_Rn)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),Rn);
if ( (infd_g0 = G_open_cell_old (g0, mapset_g0)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"),g0);
- if((infd_albedo=G_open_cell_old (albedo,mapset_albedo)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"),albedo);
+ if((infd_albedo=G_open_cell_old (albedo,mapset_albedo)) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"),albedo);
if (G_get_cellhd (T, mapset_T, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), T);
if (G_get_cellhd (u2, mapset_u2, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), u2);
- if (G_get_cellhd (DEM, mapset_DEM, &cellhd) < 0)
- G_fatal_error (_("Cannot read file header of [%s]"), DEM);
+ if (G_get_cellhd (dem, mapset_dem, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), dem);
if (G_get_cellhd (ndvi, mapset_ndvi, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), ndvi);
if (G_get_cellhd (Rn, mapset_Rn, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), Rn);
if (G_get_cellhd (g0, mapset_g0, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s]"), g0);
- if (G_get_cellhd (albedo, mapset_albedo, &cellhd) < 0)
- G_fatal_error (_("Cannot read file header of [%s]"), albedo);
+ if (G_get_cellhd (albedo, mapset_albedo, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s]"), albedo);
/* Allocate input buffer */
- inrast_T = G_allocate_d_raster_buf();
- inrast_u2 = G_allocate_d_raster_buf();
- inrast_DEM = G_allocate_d_raster_buf();
- inrast_ndvi = G_allocate_d_raster_buf();
- inrast_Rn = G_allocate_d_raster_buf();
- inrast_g0 = G_allocate_d_raster_buf();
- inrast_albedo = G_allocate_d_raster_buf();
+ inrast_T = G_allocate_raster_buf(data_type_T);
+ inrast_u2 = G_allocate_raster_buf(data_type_u2);
+ inrast_dem = G_allocate_raster_buf(data_type_dem);
+ inrast_ndvi = G_allocate_raster_buf(data_type_ndvi);
+ inrast_Rn = G_allocate_raster_buf(data_type_Rn);
+ inrast_g0 = G_allocate_raster_buf(data_type_g0);
+ inrast_albedo = G_allocate_raster_buf(data_type_albedo);
/* Allocate output buffer */
nrows = G_window_rows();
ncols = G_window_cols();
@@ -339,11 +327,11 @@
G_fatal_error(_("Could not read from <%s>"),albedo);
if(G_get_raster_row(infd_T,inrast_T,row,data_type_T)<0)
G_fatal_error(_("Could not read from <%s>"),T);
- if(G_get_raster_row(infd_DEM,inrast_DEM,row,data_type_DEM)<0)
- G_fatal_error(_("Could not read from <%s>"),DEM);
- if(G_get_d_raster_row(infd_Rn, inrast_Rn, row) < 0)
+ if(G_get_raster_row(infd_dem,inrast_dem,row,data_type_dem)<0)
+ G_fatal_error(_("Could not read from <%s>"),dem);
+ if(G_get_raster_row(infd_Rn, inrast_Rn, row,data_type_Rn) < 0)
G_fatal_error(_("Could not read from <%s>"),Rn);
- if(G_get_d_raster_row(infd_g0, inrast_g0, row) < 0)
+ if(G_get_raster_row(infd_g0, inrast_g0, row,data_type_g0) < 0)
G_fatal_error(_("Could not read from <%s>"),g0);
/*process the data */
for (col=0; col < ncols; col++)
@@ -370,15 +358,15 @@
d_tempk = (double) ((DCELL *) inrast_T)[col];
break;
- switch(data_type_DEM){
+ switch(data_type_dem){
case CELL_TYPE:
- d_dem = (double) ((CELL *) inrast_DEM)[col];
+ d_dem = (double) ((CELL *) inrast_dem)[col];
break;
case FCELL_TYPE:
- d_dem = (double) ((FCELL *) inrast_DEM)[col];
+ d_dem = (double) ((FCELL *) inrast_dem)[col];
break;
case DCELL_TYPE:
- d_dem = (double) ((DCELL *) inrast_DEM)[col];
+ d_dem = (double) ((DCELL *) inrast_dem)[col];
break;
switch(data_type_Rn){
@@ -458,18 +446,18 @@
G_percent(row,nrows,2);
/* read a line input maps into buffers*/
if(G_get_raster_row(infd_albedo,inrast_albedo,row,data_type_albedo)<0)
- G_fatal_error(_("Could not read from <%s>"),albedo);
+ G_fatal_error(_("Could not read from <%s>"),albedo);
- if(G_get_d_raster_row(infd_u2, inrast_u2, row) < 0)
+ if(G_get_raster_row(infd_u2,inrast_u2,row,data_type_u2) < 0)
G_fatal_error(_("Could not read from <%s>"),u2);
- if(G_get_d_raster_row(infd_DEM, inrast_DEM, row) < 0)
- if(G_get_d_raster_row(infd_ndvi, inrast_ndvi, row) < 0)
+ if(G_get_raster_row(infd_ndvi,inrast_ndvi,row,data_type_ndvi) < 0)
G_fatal_error(_("Could not read from <%s>"),ndvi);
+ if(G_get_raster_row(infd_Rn,inrast_Rn,row,data_type_Rn) < 0)
+ if(G_get_raster_row(infd_g0,inrast_g0,row,data_type_g0) < 0)
/* read every cell in the line buffers */
for (col=0; col < ncols; col++){
@@ -506,15 +494,15 @@
d_u2m = (double) ((DCELL *) inrast_u2)[col];
break;
case CELL_TYPE:
break;
case FCELL_TYPE:
break;
case DCELL_TYPE:
break;
switch(data_type_ndvi){
@@ -550,19 +538,32 @@
d_g0 = (double) ((DCELL *) inrast_g0)[col];
break;
- if(G_is_d_null_value(&d_tempk)||G_is_d_null_value(&d_u2m)||
- G_is_d_null_value(&d_dem)||G_is_d_null_value(&d_ndvi)||
- G_is_d_null_value(&d_Rn)||G_is_d_null_value(&d_g0)||
- d_albedo<0.0){
+ if(G_is_d_null_value(&d_tempk)||
+ G_is_d_null_value(&d_u2m)||
+ G_is_d_null_value(&d_dem)||
+ G_is_d_null_value(&d_ndvi)||
+ G_is_d_null_value(&d_Rn)||
+ G_is_d_null_value(&d_g0)||
+ d_dem<=-100.0||d_dem>9000.0){
G_set_d_null_value(&outrast[col],1);
} else {
+ /* Albedo < 0*/
+ if(d_albedo<0.01){
+ d_albedo=0.01;
/* Calculate T0dem */
d_t0dem = (double)d_tempk + 0.00649*(double)d_dem;
- /*G_message("****InLoop d_t0dem=%5.3f",d_t0dem);
- G_message("****InLoop d_dem=%5.3f",d_dem);
- G_message("****InLoop d_tempk=%5.3f",d_tempk);*/
- /* Calculate sensible heat flux */
+ /* G_message("**InLoop d_t0dem=%5.3f",d_t0dem);
+ G_message(" d_dem=%5.3f",d_dem);
+ G_message(" d_tempk=%5.3f",d_tempk);
+ G_message(" d_albedo=%5.3f",d_albedo);
+ G_message(" d_Rn=%5.3f",d_Rn);
+ G_message(" d_g0=%5.3f",d_g0);
+ G_message(" d_ndvi=%5.3f",d_ndvi);
+ G_message(" d_u2m=%5.3f",d_u2m);
+ */ /* Calculate sensible heat flux */
d = sensi_h(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+ // G_message(" d_h0=%5.3f",d);
if (zero->answer && d<0.0){
d=0.0;
@@ -571,27 +572,24 @@
if (G_put_d_raster_row (outfd, outrast) < 0)
G_fatal_error (_("Cannot write to <%s>"),h0);
G_free(inrast_T);
- G_free(inrast_u2);
- G_free(inrast_DEM);
- G_free(inrast_ndvi);
- G_free(inrast_Rn);
- G_free(inrast_g0);
- if(flag1->answer)
- G_free(inrast_albedo);
- G_free(outrast);
G_close_cell (infd_T);
+ G_free(inrast_u2);
G_close_cell (infd_u2);
- G_close_cell (infd_DEM);
+ G_free(inrast_dem);
+ G_close_cell (infd_dem);
+ G_free(inrast_ndvi);
G_close_cell (infd_ndvi);
+ G_free(inrast_Rn);
G_close_cell (infd_Rn);
+ G_free(inrast_g0);
G_close_cell (infd_g0);
- if(flag1->answer)
- G_close_cell (infd_albedo);
- G_close_cell (outfd);
+ G_free(inrast_albedo);
+ G_close_cell (infd_albedo);
+ G_free(outrast);
+ G_close_cell (outfd);
/* add command line incantation to history file */
G_short_history(h0, "raster", &history);
G_command_history(&history);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/psi_h.c
--- grass-addons/gipe/i.eb.h_SEBAL95/psi_h.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/psi_h.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -19,7 +19,7 @@
if(n5_temp < 0.0){
n12_mem = pow((1-16*(2/n5_temp)),0.25);
- n11_mem = (2*log((1+pow(n12_mem,2))/2));
+ n11_mem = (2*log10((1+pow(n12_mem,2))/2));
} else {
n12_mem = 1.0;
n11_mem = -5*2/n5_temp;
Modified: grass-addons/gipe/i.eb.h_SEBAL95/rah1.c
--- grass-addons/gipe/i.eb.h_SEBAL95/rah1.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/rah1.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -8,7 +8,7 @@
double result;
- result = (log(2/0.01)-psih)/(ustar*0.41);
+ result = (log10(2/0.01)-psih)/(ustar*0.41);
return (result);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/rah_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/rah_0.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/rah_0.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -6,7 +6,7 @@
double result;
- result = log(2/0.01)/(u_0*0.41);
+ result = log10(2/0.01)/(u_0*0.41);
return (result);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/roh_air_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/roh_air_0.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/roh_air_0.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -6,8 +6,8 @@
double A, B, result;
- A = (24*(6.11*exp(17.27*36/(36+237.3)))/100.0);
- B = (24*(6.11*exp(17.27*36/(36+237.3)))/100.0);
+ A = (18*(6.11*exp(17.27*34.8/(34.8+237.3)))/100.0);
+ B = (18*(6.11*exp(17.27*34.8/(34.8+237.3)))/100.0);
result = (1000.0 - A)/(tempk*2.87)+ B/(tempk*4.61);
return result;
Modified: grass-addons/gipe/i.eb.h_SEBAL95/u_star.c
--- grass-addons/gipe/i.eb.h_SEBAL95/u_star.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/u_star.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -29,7 +29,7 @@
if(n5_temp < 0.0){
n31_mem = pow((1-16*(200/n5_temp)),0.25);
- n10_mem = (2*log((1+n31_mem)/2)+log((1+pow(n31_mem,2))/2)-2*atan(n31_mem)+0.5*PI);
+ n10_mem = (2*log10((1+n31_mem)/2)+log10((1+pow(n31_mem,2))/2)-2*atan(n31_mem)+0.5*PI);
} else {
@@ -38,7 +38,7 @@
- result = ((u2m*0.41/log(2/(hv/7)))/0.41*log(bh /(hv/7)*0.41))/(log(bh / zom)-n10_mem);
+ result = ((u2m*0.41/log10(2/(hv/7)))/0.41*log10(bh /(hv/7)*0.41))/(log10(bh / zom)-n10_mem);
return (result);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c 2008-06-01 19:07:05 UTC (rev 31602)
+++ grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c 2008-06-02 06:34:26 UTC (rev 31603)
@@ -8,8 +8,8 @@
double hv_ndvimax=1.5; /* crop vegetation height (m) */
double hv_desert=0.002; /* desert base vegetation height (m) */
- a = (log(hv_desert)-((log(hv_ndvimax/7)-log(hv_desert))/(ndvi_max-0.02)*0.02));
- b = (log(hv_ndvimax/7)-log(hv_desert))/(ndvi_max-0.02)* ndvi;
+ a = (log10(hv_desert)-((log10(hv_ndvimax/7)-log10(hv_desert))/(ndvi_max-0.02)*0.02));
+ b = (log10(hv_ndvimax/7)-log10(hv_desert))/(ndvi_max-0.02)* ndvi;
zom = exp(a+b);
// printf("zom = %5.3f\n", zom);
