[GRASS-SVN] r31604 - grass-addons
svn_grass at osgeo.org
Mon Jun 2 03:02:06 EDT 2008
Author: neteler
Date: 2008-06-02 03:02:05 -0400 (Mon, 02 Jun 2008)
New Revision: 31604
grass-addons/README
make Installation more outstanding
Modified: grass-addons/README
--- grass-addons/README 2008-06-02 06:34:26 UTC (rev 31603)
+++ grass-addons/README 2008-06-02 07:02:05 UTC (rev 31604)
@@ -1,6 +1,21 @@
GRASS Addons SVN repository
+Installation - Code Compilation
+The easiest way to compile GRASS Addons modules into your GRASS code
+is by setting MODULE_TOPDIR on the fly to tell 'make' where to
+find the GRASS source code:
+ make MODULE_TOPDIR=$HOME/grass64/
+(adapt to your /path/to/grass6/)
+Each module/script in the GRASS Addons SVN repository should have
+a Makefile.
To submit your GRASS project here, please write to
Markus Neteler <neteler * cealp.it>
@@ -27,18 +42,6 @@
svn checkout https://svn.osgeo.org/grass/grass-addons grass-addons
-Code Compilation
-The easiest way to compile modules against your GRASS code is
-by setting MODULE_TOPDIR on the fly to tell 'make' where to
-find the GRASS source code:
- make MODULE_TOPDIR=$HOME/grass63/
-(adapt to your /path/to/grass6/)
Mime-types
# To avoid PDF mime-type recognition problems,
