[GRASS-SVN] r31882 - grass-addons/vector/v.surf.icw
svn_grass at osgeo.org
Sun Jun 29 11:02:43 EDT 2008
Author: hamish
Date: 2008-06-29 11:02:43 -0400 (Sun, 29 Jun 2008)
New Revision: 31882
grass-addons/vector/v.surf.icw/v.surf.icw
remove some old commented out GRASS 5 commands, add in some new breadcrumbs
Modified: grass-addons/vector/v.surf.icw/v.surf.icw
--- grass-addons/vector/v.surf.icw/v.surf.icw 2008-06-29 11:44:57 UTC (rev 31881)
+++ grass-addons/vector/v.surf.icw/v.surf.icw 2008-06-29 15:02:43 UTC (rev 31882)
@@ -39,7 +39,6 @@
#%Module
#% description: IDW interpolation, but distance is cost to get to any other site
#%End
#%option
#% key: input
#% type: string
@@ -47,7 +46,6 @@
#% description: Name of existing vector points map containing seed data
#% required : yes
#%end
#%option
#% key: output
#% type: string
@@ -55,14 +53,12 @@
#% description: Name of new raster file to be used for output
#% required : yes
#%end
#%option
#% key: column
#% type: string
#% description: Column name in vector points map that contains data values
#% required : yes
#%end
#%option
#% key: cost_map
#% type: string
@@ -70,7 +66,6 @@
#% description: Name of existing raster file containing cost information
#% required : yes
#%end
#%option
#% key: post_mask
#% type: string
@@ -78,7 +73,6 @@
#% description: Name of existing raster file to be used as post-processing MASK
#% required : no
#%end
#%option
#% key: friction
#% type: integer
@@ -88,7 +82,7 @@
#% required : no
#%end
-### needed?
+### still needed? (left-over from GRASS 5 sites format)
#%option
#% key: null_string
#% type: string
@@ -96,13 +90,11 @@
#% answer: nan
#% required : no
#%end
-# in the above, s.out.ascii changes a "%NaN" to "nan" so we use lower case
#%flag
#% key: r
#% description: Use (d^n)*log(d) instead of 1/(d^n) for radial basis function
#%end
#%flag
#% key: v
#% description: Verbose mode
@@ -143,13 +135,12 @@
if [ "$FRICTION" -eq 5 ] ; then DIVISOR=" / 100.0" ; fi
if [ "$FRICTION" -eq 6 ] ; then DIVISOR=" / 500.0" ; fi
-#COLMN=$(( 4 + $GIS_OPT_index )) # skip over e,n,|,cat ### wrong for 3D+
-# maybe it's better to do for i=1:index sed delete line upto & incl. "%" then |cut -f1 ?
NULL="$GIS_OPT_NULL_STRING"
POINTS_FILE="$GIS_OPT_INPUT"
unset VERBOSE
+# test to see if G_V exists before integer compare?
if [ $GIS_FLAG_V -eq 1 ] || [ "$GRASS_VERBOSE" -gt 1 ] ; then
VERBOSE="-v"
fi
@@ -184,10 +175,9 @@
echo "ERROR: unable to create temporary files" 1>&2
exit 1
fi
-#s.out.ascii -d "$GIS_OPT_sites" > /tmp/idw_tmp.$$
-#s.out.ascii -d "$GIS_OPT_sites" > "$TMP_SITES"
#crop out only points in region
+# GRASS 6.3+: use v.out.ascii -r ?
v.in.region output=tmp_icw_region_$$ > /dev/null
v.select ainput="$POINTS_FILE" binput=tmp_icw_region_$$ \
atype=point btype=area output=tmp_icw_points_$$
@@ -196,9 +186,6 @@
#db.select tmp_icw_points_$$ > "$TMP_TABLE"
# find n
-#N=`wc -l /tmp/idw_tmp.$$ | awk '{print $1}'`
-#N=`wc -l "$TMP_SITES" | awk '{print $1}'`
-#N=`s.out.ascii "$SITES_FILE" | wc -l`
#N="`v.info tmp_icw_points_$$ | grep "Number of points" | cut -f2 -d: | awk '{print $1}'`"
N="`cat "$TMP_POINTS" | wc -l`"
@@ -215,16 +202,12 @@
# gen cost maps for each site in range
echo "Generating cost maps.." 1>&2
NUM=1
-#for POS in `cat /tmp/idw_tmp.$$ | sed -e 's/ /|/g'` ; do
-#for POS in `cat "$TMP_SITES" | sed -e 's/ /|/g'` ; do
-#for POS in `s.out.ascii -d "$SITES_FILE" | sed -e 's/ /|/g'` ; do
for POS in `cat "$TMP_POINTS"` ; do
# echo "POS=[$POS]"
EASTING=`echo "$POS" | cut -f1 -d"|"`
NORTHING=`echo "$POS" | cut -f2 -d"|"`
CAT=`echo "$POS" | cut -f"$CATCOL" -d"|"`
-# DATA_VALUE=`echo "$POS" | cut -f"$COLMN" -d"|"`
# DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select * from tmp_icw_points_$$ where cat = $CAT" | cut -f"$COLMN" -d'|'`"
DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select $COL_NAME from tmp_icw_points_$$ where cat=${CAT}"`"
@@ -280,8 +263,6 @@
NUM="`expr $NUM + 1`"
done
-#r.mapcalc resolution_mask="if(fjords_mask at all == 9 )"
-#r.mapcalc MASK="$FJORD"_mask # @all
if [ -n "$GIS_OPT_POST_MASK" ] ; then
echo "Setting post_mask [$GIS_OPT_POST_MASK]" 1>&2
r.mapcalc MASK="$GIS_OPT_POST_MASK"
@@ -299,9 +280,6 @@
echo 1>&2
echo "Creating partial weights.." 1>&2
NUM=1
-#for POS in `v.out.ascii -d "$SITES_FILE" | sed -e 's/ /|/g'` ; do
@@ -347,6 +325,8 @@
echo "Calculating final values.." 1>&2
r.series method=sum in=$INPUT_MAPS out="$GIS_OPT_OUTPUT"
+#TODO: r.patch in v.to.rast of values at exact seed site locations. currently set to null
r.colors "$GIS_OPT_OUTPUT" rule=bcyr
if [ 0 -eq 1 ] ; then
r.colors "$GIS_OPT_OUTPUT" col=rules << EOF
@@ -372,22 +352,35 @@
fi
-# 5) rm cost and cost_sq maps, site_tmp, /tmp/idw_tmp.$$, etc
-#exit ######
-echo "Cleanup .." 1>&2
-g.mremove -f rast=cost_site.* | grep REMOVE
-g.mremove -f rast=1by_cost_site_sqrd.* | grep REMOVE
-g.mremove -f rast=partial_icw.* | grep REMOVE
-#g.mremove -f rast=tmp_icw_*_$$
-#g.mremove -f vect=tmp_icw_*_$$
-g.remove rast=sum_of_1by_cost_sqs | grep REMOVE
-#g.remove vect=tmp_idw_cost_site_$$
-g.remove rast=tmp_icw_area_$$ | grep REMOVE
-g.remove vect=tmp_icw_region_$$,tmp_icw_points_$$
-#rm /tmp/idw_tmp.$$
-#rm "$TMP_SITES"
-rm -f "$TMP_POINTS"
+# 5) rm cost and cost_sq maps, tmp_icw_points, etc
+cleanup()
+ echo "Cleanup .." 1>&2
+ g.mremove -f rast=cost_site.* | grep REMOVE
+ g.mremove -f rast=1by_cost_site_sqrd.* | grep REMOVE
+ g.mremove -f rast=partial_icw.* | grep REMOVE
+ #g.mremove -f rast=tmp_icw_*_$$
+ #g.mremove -f vect=tmp_icw_*_$$
+ g.remove rast=sum_of_1by_cost_sqs | grep REMOVE
+ #g.remove vect=tmp_idw_cost_site_$$
+ g.remove rast=tmp_icw_area_$$ | grep REMOVE
+ g.remove vect=tmp_icw_region_$$,tmp_icw_points_$$
+ rm -f "$TMP_POINTS"
+# TODO: trap ^C
+# what to do in case of user break:
+#exitprocedure()
+# g.message -e 'User break!'
+# cleanup
+# exit 1
+# shell check for user break (signal list: trap -l)
+#trap "exitprocedure" 2 3 15
+cleanup
# 6) done!
echo "Done! Wrote results to <${GIS_OPT_OUTPUT}>." 1>&2
exit 0
