[GRASS-SVN] r31883 - grass-addons/vector/v.surf.icw
Sun Jun 29 12:03:55 EDT 2008
Author: hamish
Date: 2008-06-29 12:03:55 -0400 (Sun, 29 Jun 2008)
New Revision: 31883
   grass-addons/vector/v.surf.icw/v.surf.icw
remove obsolete null_data option
Modified: grass-addons/vector/v.surf.icw/v.surf.icw
--- grass-addons/vector/v.surf.icw/v.surf.icw	2008-06-29 15:02:43 UTC (rev 31882)
+++ grass-addons/vector/v.surf.icw/v.surf.icw	2008-06-29 16:03:55 UTC (rev 31883)
@@ -81,16 +81,6 @@
 #% options: 1-6
 #% required : no
 #%end
-### still needed? (left-over from GRASS 5 sites format)
-#%option
-#% key: null_string
-#% type: string
-#% description: Text string that represents "no data" in input data
-#% answer: nan
-#% required : no
-#%end
 #%flag
 #% key: r
 #% description: Use (d^n)*log(d) instead of 1/(d^n) for radial basis function
@@ -136,7 +126,6 @@
 if [ "$FRICTION" -eq 6 ] ; then DIVISOR=" / 500.0" ; fi
-NULL="$GIS_OPT_NULL_STRING"
 POINTS_FILE="$GIS_OPT_INPUT"
 unset VERBOSE
@@ -213,7 +202,7 @@
     echo site $NUM of $N  e=$EASTING  n=$NORTHING data=$DATA_VALUE
-    if [ -z "$DATA_VALUE" ] || [ "$DATA_VALUE" = "$NULL" ] ; then
+    if [ -z "$DATA_VALUE" ] ; then
 	echo "  Skipping, no data here." 1>&2
 	N=`expr $N - 1`
 	continue
@@ -290,7 +279,7 @@
     echo "site $NUM of $N  data value = $DATA_VALUE" 1>&2
 	continue
     fi
