[GRASS-SVN] r31884 - grass-addons/vector/v.surf.icw
svn_grass at osgeo.org
Sun Jun 29 12:17:01 EDT 2008
Author: hamish
Date: 2008-06-29 12:17:01 -0400 (Sun, 29 Jun 2008)
New Revision: 31884
grass-addons/vector/v.surf.icw/v.surf.icw
more removal of dead code and comments
Modified: grass-addons/vector/v.surf.icw/v.surf.icw
--- grass-addons/vector/v.surf.icw/v.surf.icw 2008-06-29 16:03:55 UTC (rev 31883)
+++ grass-addons/vector/v.surf.icw/v.surf.icw 2008-06-29 16:17:01 UTC (rev 31884)
@@ -134,13 +134,6 @@
VERBOSE="-v"
fi
-#figure out which column number we are after
-#COLMN="`db.columns "$POINTS_FILE" | grep -n "^${GIS_OPT_COLUMN}$" | cut -f1 -d:`"
-#if [ -z "$COLMN" ] || [ "$COLMN" -le 0 ] ; then
-# echo "Data column [$GIS_OPT_COLUMN] not found in [$POINTS_FILE]." 1>&2
-# exit
-#fi
### Check that we have the column and it is the correct type
COL_NAME=`v.info -c "$POINTS_FILE" 2> /dev/null | grep "|${GIS_OPT_COLUMN}$" | cut -f2 -d'|'`
if [ -z "$COL_NAME" ] ; then
@@ -197,7 +190,6 @@
EASTING=`echo "$POS" | cut -f1 -d"|"`
NORTHING=`echo "$POS" | cut -f2 -d"|"`
CAT=`echo "$POS" | cut -f"$CATCOL" -d"|"`
-# DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select * from tmp_icw_points_$$ where cat = $CAT" | cut -f"$COLMN" -d'|'`"
DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select $COL_NAME from tmp_icw_points_$$ where cat=${CAT}"`"
echo site $NUM of $N e=$EASTING n=$NORTHING data=$DATA_VALUE
@@ -228,6 +220,8 @@
# r.mapcalc 1by_cost_site_sqrd.$NUM=" 1.0 / exp(cost_site.$NUM , $FRICTION)"
EXPRESSION="1.0 / pow(cost_site.$NUM $DIVISOR, $FRICTION )"
+ # use log10() or ln() ?
if [ "$GIS_FLAG_R" -eq 1 ] ; then
echo "Using (d^n)*log(d) radial basis function." 1>&2
EXPRESSION="pow(cost_site.$NUM, $FRICTION) * log (cost_site.$NUM)"
@@ -237,8 +231,8 @@
r.mapcalc "1by_cost_site_sqrd.$NUM = $EXPRESSION"
# r.patch in=1by_cost_site_sqrd.${NUM},tmp_idw_cost_val_$$ out=1by_cost_site_sqrd.${NUM} --o
# g.remove rast=cost_site.$NUM
NUM="`expr $NUM + 1`"
done
@@ -274,10 +268,9 @@
- echo "site $NUM of $N data value = $DATA_VALUE" 1>&2
+ echo "Site $NUM of $N data value = $DATA_VALUE" 1>&2
if [ -z "$DATA_VALUE" ] ; then
echo " Skipping, no data here." 1>&2
@@ -317,17 +310,6 @@
#TODO: r.patch in v.to.rast of values at exact seed site locations. currently set to null
r.colors "$GIS_OPT_OUTPUT" rule=bcyr
-if [ 0 -eq 1 ] ; then
-r.colors "$GIS_OPT_OUTPUT" col=rules << EOF
- 0 magenta
- 10 red
- 20 brown
- 25 yellow
- 30 green
- 35 blue
- 40 white
-EOF
-fi
r.support "$GIS_OPT_OUTPUT" title="Inverse cost-weighted interpolation" history=""
r.support "$GIS_OPT_OUTPUT" history="v.surf.icw interpolation:"
