[GRASS-SVN] r30461 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Mar 4 08:56:33 EST 2008
Author: martinl
Date: 2008-03-04 08:56:33 -0500 (Tue, 04 Mar 2008)
New Revision: 30461
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI (dbm) various (minor) improvements (update/insert dialog layout, use wx.Panel as container for widgets, set icon)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-03-04 12:25:15 UTC (rev 30460)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-03-04 13:56:33 UTC (rev 30461)
@@ -365,8 +365,11 @@
self.pointdata = pointdata
self.parent = parent # GMFrame
- wx.Frame.__init__(self, parent, id, title, size=(900,600), style=style)
+ wx.Frame.__init__(self, parent, id, title, style=style)
+ # icon
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
try:
@@ -434,25 +437,25 @@
dbmStyle = globalvar.FNPageStyle
- self.browsePage = FN.FlatNotebook(self, id=wx.ID_ANY,
+ self.browsePage = FN.FlatNotebook(self.panel, id=wx.ID_ANY,
style=dbmStyle)
# self.notebook.AddPage(self.browsePage, caption=_("Browse data"))
self.notebook.AddPage(self.browsePage, text=_("Browse data")) # FN
self.browsePage.SetTabAreaColour(globalvar.FNPageColor)
- self.manageTablePage = FN.FlatNotebook(self, id=wx.ID_ANY,
+ self.manageTablePage = FN.FlatNotebook(self.panel, id=wx.ID_ANY,
style=dbmStyle)
#self.notebook.AddPage(self.manageTablePage, caption=_("Manage tables"))
self.notebook.AddPage(self.manageTablePage, text=_("Manage tables")) # FN
self.manageTablePage.SetTabAreaColour(globalvar.FNPageColor)
- self.manageLayerPage = FN.FlatNotebook(self, id=wx.ID_ANY,
+ self.manageLayerPage = FN.FlatNotebook(self.panel, id=wx.ID_ANY,
style=dbmStyle)
#self.notebook.AddPage(self.manageLayerPage, caption=_("Manage layers"))
self.notebook.AddPage(self.manageLayerPage, text=_("Manage layers")) # FN
self.manageLayerPage.SetTabAreaColour(globalvar.FNPageColor)
- self.settingsPage = FN.FlatNotebook(self, id=wx.ID_ANY,
+ self.settingsPage = FN.FlatNotebook(self.panel, id=wx.ID_ANY,
style=dbmStyle)
#self.notebook.AddPage(self.settingsPage, caption=_("Settings"))
self.notebook.AddPage(self.settingsPage, text=_("Settings")) # FN
@@ -485,7 +488,7 @@
self.__layout()
# self.SetMinSize(self.GetBestSize())
- self.SetSize((680, 520))
+ self.SetSize((680, 550)) # FIXME hard-coded size
self.SetMinSize(self.GetSize())
def __createBrowsePage(self, onlyLayer=-1):
@@ -538,7 +541,9 @@
win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
win.Bind(wx.EVT_RIGHT_UP, self.OnDataRightUp) #wxGTK
+ win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
+ win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
listSizer.Add(item=win, proportion=1,
flag=wx.EXPAND | wx.ALL,
border=3)
@@ -687,6 +692,7 @@
"double",
"varchar",
"date"]) # FIXME
+ type.SetSelection(0)
type.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
self.layerPage[layer]['addColType'] = type.GetId()
subSizer.Add(item=type,
@@ -909,10 +915,9 @@
mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND)
mainSizer.Add(item=btnSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=5)
- self.SetAutoLayout(True)
- self.SetSizer(mainSizer)
- # FIXME
- # mainSizer.Fit(self) # problem connected to aui
+ self.panel.SetAutoLayout(True)
+ self.panel.SetSizer(mainSizer)
+ mainSizer.Fit(self.panel)
self.Layout()
def OnDataRightUp(self, event):
@@ -1043,16 +1048,20 @@
missingKey = False
# add other visible columns
+ colIdx = 0
+ keyId = -1
for col in columnName:
if col == keyColumn: # key
if missingKey is False:
data.append((col, str(maxCat + 1)))
+ keyId = colIdx
else:
data.append((col, ''))
+ colIdx += 1
dlg = ModifyTableRecord(parent=self, id=wx.ID_ANY,
title=_("Insert new record"),
- data=data)
+ data=data, keyEditable=(keyId, True))
if dlg.ShowModal() == wx.ID_OK:
try: # get category number
@@ -1068,7 +1077,7 @@
values = dlg.GetValues() # values (need to be casted)
columnsString = ''
valuesString = ''
for i in range(len(values)):
if len(values[i]) == 0: # NULL
if columnName[i] == keyColumn:
@@ -3179,41 +3188,68 @@
wx.Dialog.__init__(self, parent, id, title, style=style)
- self.panel = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY,
+ self.keyId = keyEditable[0]
+ self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.dataPanel = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY,
style=wx.TAB_TRAVERSAL)
+ self.dataPanel.SetupScrolling(scroll_x=False)
- self.btnCancel = wx.Button(self, wx.ID_CANCEL)
- self.btnSubmit = wx.Button(self, wx.ID_OK)
+ # buttons
+ self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
+ self.btnSubmit = wx.Button(self.panel, wx.ID_OK)
self.btnSubmit.SetDefault()
+ # data area
self.widgets = []
id = 0
+ self.box = False
+ self.cat = None
for column, value in data:
- label = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ if keyEditable[0] == id:
+ self.cat = int(value)
+ if keyEditable[1] == False:
+ self.box = True
+ id += 1
+ continue
+ else:
+ valueWin = wx.SpinCtrl(parent=self.dataPanel, id=wx.ID_ANY,
+ value=value, min=-1e9, max=1e9, size=(250, -1))
+ else:
+ valueWin = wx.TextCtrl(parent=self.dataPanel, id=wx.ID_ANY,
+ value=value, size=(250, -1))
+ label = wx.StaticText(parent=self.dataPanel, id=wx.ID_ANY,
label=column + ":")
- value = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY,
- value=value, size=(250, -1))
- if keyEditable[0] > -1: # id given
- if keyEditable[0] == id:
- value.Enable(keyEditable[1])
self.widgets.append((label.GetId(),
- value.GetId()))
+ valueWin.GetId()))
id += 1
self.__Layout()
- winSize = self.GetSize()
+ # winSize = self.GetSize()
# fix height of window frame if needed
- if winSize[1] > 480:
- winSize[1] = 480
- self.SetSize(winSize)
- self.SetMinSize(winSize)
+ # if winSize[1] > 480:
+ # winSize[1] = 480
+ # self.SetSize(winSize)
+ # self.SetMinSize(winSize)
def __Layout(self):
"""Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
+ if self.box:
+ box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+ label=" %s %d " % (_("Category"), self.cat))
+ boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
# data area
dataSizer = wx.FlexGridSizer (cols=2, hgap=3, vgap=3)
dataSizer.AddGrowableCol(1)
@@ -3225,29 +3261,55 @@
dataSizer.Add(label, proportion=0,
flag=wx.ALIGN_CENTER_VERTICAL)
dataSizer.Add(value, proportion=0,
- flag=wx.EXPAND)
+ flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
- self.panel.SetSizer(dataSizer)
- self.panel.SetAutoLayout(1)
- self.panel.SetupScrolling(scroll_x=False)
+ self.dataPanel.SetAutoLayout(True)
+ self.dataPanel.SetSizer(dataSizer)
+ dataSizer.Fit(self.dataPanel)
+ if self.box:
+ boxSizer.Add(item=self.dataPanel, proportion=1,
+ flag=wx.EXPAND | wx.ALL, border=5)
# buttons
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(self.btnCancel)
btnSizer.AddButton(self.btnSubmit)
btnSizer.Realize()
- sizer.Add(item=self.panel, proportion=1,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ if not self.box:
+ sizer.Add(item=self.dataPanel, proportion=1,
+ else:
+ sizer.Add(item=boxSizer, proportion=1,
sizer.Add(item=btnSizer, proportion=0,
- self.SetSizer(sizer)
- self.SetAutoLayout(1)
+ #sizer.SetSizeHints(self.panel)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self.panel)
+ self.Layout()
+ # set window frame size (min & max)
+ minFrameHeight = 150
+ maxFrameHeight = 2 * minFrameHeight
+ if self.GetSize()[1] > minFrameHeight:
+ self.SetMinSize((self.GetSize()[0], minFrameHeight))
+ else:
+ self.SetMinSize(self.GetSize())
+ if self.GetSize()[1] > maxFrameHeight:
+ self.SetSize((self.GetSize()[0], maxFrameHeight))
+ else:
+ self.SetSize(self.panel.GetSize())
def GetValues(self, columns=None):
- """Return list of values (as string).
+ """Return list of values (casted to string).
If columns is given (list), return only values of given columns.
@@ -3255,9 +3317,13 @@
for labelId, valueId in self.widgets:
column = self.FindWindowById(labelId).GetLabel().replace(':', '')
if columns is None or column in columns:
- value = self.FindWindowById(valueId).GetValue()
+ value = str(self.FindWindowById(valueId).GetValue()) # -> string
valueList.append(value)
+ # add key value
+ if self.box:
+ valueList.insert(self.keyId, str(self.cat))
return valueList
class NewVectorDialog(wx.Dialog):
