[GRASS-SVN] r30462 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Tue Mar 4 09:06:32 EST 2008
Author: hamish
Date: 2008-03-04 09:06:31 -0500 (Tue, 04 Mar 2008)
New Revision: 30462
grass/trunk/scripts/r.in.wms/r.in.gdalwarp
more fixes for single band tiles. different GIF/PNG tiles would have different 8bit color palettes so r.patch is useless and the colors go wonky. use r.mapcacl rgb# and r.composite to sanitize. Maybe d.out.file + r.in.png + r.region could be a better way?
Modified: grass/trunk/scripts/r.in.wms/r.in.gdalwarp
--- grass/trunk/scripts/r.in.wms/r.in.gdalwarp 2008-03-04 13:56:33 UTC (rev 30461)
+++ grass/trunk/scripts/r.in.wms/r.in.gdalwarp 2008-03-04 14:06:31 UTC (rev 30462)
@@ -206,6 +206,7 @@
# run r.mapcalc to crop to region
GRASS_VERBOSE=1 \
r.mapcalc "${MAP}${sfx} = ${TMPMAPNAME}${sfx}"
+ r.colors map=${MAP}${sfx} rast=${TMPMAPNAME}${sfx} --quiet
fi
# Remove the old channels:
@@ -318,12 +319,18 @@
# If there's more than one tile patch them together, otherwise just rename that tile.
if [ $NUM_TILES -eq 1 ] ; then
- for SUFFIX in $CHANNEL_SUFFIXES ; do
+ if [ -n "$CHANNEL_SUFFIXES" ] ; then
+ for SUFFIX in $CHANNEL_SUFFIXES ; do
eval "$SUFFIX"
#Rename tile 0 to be the output
GRASS_VERBOSE=1 \
g.rename rast="${GIS_OPT_OUTPUT}_tile_0${sfx}","${GIS_OPT_OUTPUT}${sfx}"
- done
+ done
+ else # single-band, single-tile
+ #Rename tile 0 to be the output
+ GRASS_VERBOSE=1 \
+ g.rename rast="${GIS_OPT_OUTPUT}_tile_0${sfx}","${GIS_OPT_OUTPUT}${sfx}" --quiet
+ fi
else
# Patch together each channel:
g.message -d message="SUFFIXES: [$SUFFIXES]"
@@ -343,11 +350,34 @@
done
else
# single-band data
- g.message "Patching tiles"
+ g.message "Patching tiles (this may take some time)"
g.message -d message="patch list = [$MAPLIST]"
- r.patch input="$MAPLIST" output="${GIS_OPT_OUTPUT}"
+ # HACK: for 8nig PNG, GIF all the different tiles can have different color tables
+ # so patches output end up all freaky. r.mapcalc r#,g#,b# manual patching + r.composite?
+ #r.patch input="$MAPLIST" output="${GIS_OPT_OUTPUT}"
+ IFS=" "
+ for COLOR in r g b ; do
+ for MAP in `echo "$MAPLIST" | tr ',' ' '` ; do
+ GRASS_VERBOSE=0 \
+ r.mapcalc "${MAP}_${COLOR} = ${COLOR}#$MAP"
+ r.colors map="${MAP}_${COLOR}" color="grey255" --quiet
+ r.null "${MAP}_${COLOR}" setnull=255 --quiet # so patching works
+ done
+ GRASS_VERBOSE=1\
+ r.patch input=`echo "$MAPLIST" | sed -e "s/,/_${COLOR},/g" -e "s/$/_${COLOR}/"` \
+ output="${MAP}_${COLOR}_all"
+ done
+ r.composite red="${MAP}_r_all" green="${MAP}_g_all" blue="${MAP}_b_all" \
+ output="${GIS_OPT_OUTPUT}"
if [ $? -eq 0 ] ; then
- g.remove rast="$MAPLIST" --quiet
+ IFS=','
+ for MAP in $MAPLIST ; do
+ g.mremove -f rast="${MAP}*" --quiet
+ done
fi
fi
fi
@@ -355,7 +385,7 @@
# Set up color counter
COLORS=0
-IFS=$defaultIFS
+IFS="$defaultIFS"
for SUFFIX in $SUFFIXES ; do
eval "$SUFFIX"
# Keep track of colors
