[GRASS-SVN] r30596 - in grass-addons/gipe: . r.out.vic_soil
Mon Mar 17 01:40:26 EDT 2008
Author: ychemin
Date: 2008-03-17 01:40:25 -0400 (Mon, 17 Mar 2008)
New Revision: 30596
Added:
   grass-addons/gipe/r.out.vic_soil/
   grass-addons/gipe/r.out.vic_soil/main.c
Removed:
   grass-addons/gipe/r.out.vic_soil/Makefile
   grass-addons/gipe/r.out.vic_soil/description.html
renamed r.vic_soil to r.out.vic_soil, cleaned a bit
Copied: grass-addons/gipe/r.out.vic_soil (from rev 30592, grass-addons/gipe/r.vic_soil)
Modified: grass-addons/gipe/r.out.vic_soil/Makefile
--- grass-addons/gipe/r.vic_soil/Makefile	2008-03-17 02:39:57 UTC (rev 30592)
+++ grass-addons/gipe/r.out.vic_soil/Makefile	2008-03-17 05:40:25 UTC (rev 30596)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.vic_soil
+PGM = r.out.vic_soil
 LIBES =  $(GPROJLIB) $(GISLIB)
 DEPENDENCIES = $(GPROJDEP) $(GISDEP)
Modified: grass-addons/gipe/r.out.vic_soil/description.html
--- grass-addons/gipe/r.vic_soil/description.html	2008-03-17 02:39:57 UTC (rev 30592)
+++ grass-addons/gipe/r.out.vic_soil/description.html	2008-03-17 05:40:25 UTC (rev 30596)
@@ -1,6 +1,6 @@
 <H2>DESCRIPTION</H2>
-<EM>r.vic_soil</EM> creates a VIC hydrological model soil input ascii file.
+<EM>r.out.vic_soil</EM> creates a VIC hydrological model soil input ascii file.
 This is an input to VIC (Variable Infiltration Capacity).
 <H2>NOTES</H2>
Deleted: grass-addons/gipe/r.out.vic_soil/main.c
--- grass-addons/gipe/r.vic_soil/main.c	2008-03-17 02:39:57 UTC (rev 30592)
+++ grass-addons/gipe/r.out.vic_soil/main.c	2008-03-17 05:40:25 UTC (rev 30596)
@@ -1,173 +0,0 @@
- * MODULE:       r.vic_soil
- * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
- * PURPOSE:      Creates a VIC soil input file.
- * 		 Filling only lat/long and add dummy data from VIC website.
- * 		 Will add raster layer input as they become available later.
- * 		 Like soil texture, etc...
- * COPYRIGHT:    (C) 2008 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/gprojects.h>
-#include <grass/glocale.h>
-int main(int argc, char *argv[])
-	struct Cell_head cellhd; //region+header info
-	char *mapset; // mapset name
-	int nrows, ncols;
-	int row,col;
-	int verbose=1;
-	int not_ll=0;//if proj is not lat/long, it will be 1.
-	struct GModule *module;
-	struct Option *input1, *output1;
-	struct Flag *flag1;
-	struct History history; //metadata
-	struct pj_info iproj;
-	struct pj_info oproj;
-	/* FMEO Declarations*****************/
-	char 	*name;   	// input raster name
-	char 	*result1; 	//output raster name
-	//File Descriptors
-	int 	infd;
-	char 	*in;
-	int 	i=0,j=0;
-	double 	xp, yp;
-	double 	xmin, ymin;
-	double 	xmax, ymax;
-	double 	stepx,stepy;
-	double 	latitude, longitude;
-	void 			*inrast;
-	RASTER_MAP_TYPE 	data_type_inrast;
-	FILE	*f; 		// output ascii file
-	int 	process; 	// process grid cell switch
-	int 	grid_count; 	// grid cell count
-	char 	*dummy_data1; 	// dummy data part 1
-	G_gisinit(argv[0]);
-	module = G_define_module();
-	module->keywords = _("VIC, hydrology, soil");
-	module->description = _("creates a soil ascii file taking lat/long from a map");
-	/* Define the different options */
-	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input1->key	   = _("input");
-	input1->description=_("Name of the input map to take the lat/lon from");
-	input1->answer     =_("input");
-	output1 = G_define_option() ;
-	output1->key        =_("output");
-	output1->description=_("Name of the output vic soil ascii file");
-	output1->answer     =_("vic_soil");
-	if (G_parser(argc, argv))
-		exit (EXIT_FAILURE);
-	in	 	= input1->answer;
-	result1  	= output1->answer;
-	mapset = G_find_cell2(in, "");
-	if (mapset == NULL) {
-		G_fatal_error(_("cell file [%s] not found"), in);
-	data_type_inrast = G_raster_map_type(in,mapset);
-	if ( (infd = G_open_cell_old (in,mapset)) < 0)
-		G_fatal_error (_("Cannot open cell file [%s]"), in);
-	if (G_get_cellhd (in, mapset, &cellhd) < 0)
-		G_fatal_error (_("Cannot read file header of [%s])"), in);
-	inrast = G_allocate_raster_buf(data_type_inrast);
-	G_debug(3, "number of rows %d",cellhd.rows);
-	stepx=cellhd.ew_res;
-	stepy=cellhd.ns_res;
-	xmin=cellhd.west;
-	xmax=cellhd.east;
-	ymin=cellhd.south;
-	ymax=cellhd.north;
-	nrows = G_window_rows();
-	ncols = G_window_cols();
-	/*Initialize grid cell process switch*/
-	f=fopen(result1,"w");
-	/*If =1 then process, if =0 then skip*/
-	process = 1;
-	/*Initialize grid cell count*/
-	grid_count = 1;
-	/*Initialize output file */
-	fprintf(f,"#RUN\tGRID\tLAT\tLNG\tINFILT\tDs\tDs_MAX\tWs\tC\tEXPT_1\tEXPT_2\tEXPT_3\tKsat_1\tKsat_2\tKsat_3\tPHI_1\tPHI_2\tPHI_3\tMOIST_1\tMOIST_2\tMOIST_3\tELEV\tDEPTH_1\tDEPTH_2\tDEPTH_3\tAVG_T\tDP\tBUBLE1\tBUBLE2\tBUBLE3\tQUARZ1\tQUARZ2\tQUARZ3\tBULKDN1\tBULKDN2\tBULKDN3\tPARTDN1\tPARTDN2\tPARTDN3\tOFF_GMT\tWcrFT1\tWcrFT2\tWcrFT3\tWpFT1\tWpFT2\tWpFT3\tZ0_SOIL\tZ0_SNOW\tPRCP\tRESM1\tRESM2\tRESM3\tFS_ACTV\tJULY_TAVG\n");
-	/*Initialize dummy data*/
-	dummy_data1 = "0.010\t1.e-4\t3.05\t0.93\t2\t4.0\t4.0\t4.0\t250.0\t250.0\t250.0\t-999\t-999\t-999\t0.4\t0.4\t0.4\t306.3\t0.1\t6.90\t2.000\t14.0\t4.0\t75.0\t75.0\t75.0\t0.24\t0.24\t0.24\t1306\t1367\t1367\t2650\t2650\t2650\t-6\t0.330\t0.330\t0.330\t0.133\t0.133\t0.133\t0.001\t0.010\t500\t0.02\t0.02\t0.02\t1\t18.665\n";
-	//Shamelessly stolen from r.sun !!!!
-	/* Set up parameters for projection to lat/long if necessary */
-	if ((G_projection() != PROJECTION_LL)) {
-		not_ll=1;
-		struct Key_Value *in_proj_info, *in_unit_info;
-		if ((in_proj_info = G_get_projinfo()) == NULL)
-			G_fatal_error(_("Can't get projection info of current location"));
-		if ((in_unit_info = G_get_projunits()) == NULL)
-			G_fatal_error(_("Can't get projection units of current location"));
-		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
-			G_fatal_error(_("Can't get projection key values of current location"));
-		G_free_key_value(in_proj_info);
-		G_free_key_value(in_unit_info);
-		/* Set output projection to latlong w/ same ellipsoid */
-		oproj.zone = 0;
-		oproj.meters = 1.;
-		sprintf(oproj.proj, "ll");
-		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
-			G_fatal_error(_("Unable to set up lat/long projection parameters"));
-	}//End of stolen from r.sun :P
-	for (row = 0; row < nrows/100; row++)
-		G_percent(row,nrows,2);
-		if(G_get_raster_row(infd,inrast,row,data_type_inrast)<0)
-			G_fatal_error(_("Could not read from <%s>"),in);
-		for (col=0; col < ncols; col++)
-			latitude = ymax - ( row * stepy );
-			longitude = xmin + ( col * stepx );
-			if(not_ll){
-				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
-				    G_fatal_error(_("Error in pj_do_proj"));
-			}else{
-				//Do nothing
-			fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\n", process, grid_count, latitude, longitude, dummy_data1);
-			grid_count=grid_count+1;
-	G_free (inrast);
-	G_close_cell (infd);
-	fclose(f);
-	exit(EXIT_SUCCESS);
Copied: grass-addons/gipe/r.out.vic_soil/main.c (from rev 30595, grass-addons/gipe/r.vic_soil/main.c)
--- grass-addons/gipe/r.out.vic_soil/main.c	                        (rev 0)
@@ -0,0 +1,195 @@
+ * MODULE:       r.out.vic_soil
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates a VIC soil input file.
+ * 		 Filling only elevation and lat/long.
+ * 		 Add remaining as dummy data from VIC website.
+ * 		 Will add more like data that can be processed from
+ * 		 elevation/lat/longraster or specific raster layer
+ * 		 inputs as they become available later.
+ * 		 Like:
+ * 		 	- Time zone offset from GMT,
+ * 		 	etc...
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	int verbose=1;
+	int not_ll=0;//if proj is not lat/long, it will be 1.
+	struct GModule *module;
+	struct Option *input1, *output1;
+	struct Flag *flag1;
+	struct History history; //metadata
+	struct pj_info iproj;
+	struct pj_info oproj;
+	/* FMEO Declarations*****************/
+	char 	*name;   	// input raster name
+	char 	*result1; 	//output raster name
+	//File Descriptors
+	int 	infd;
+	char 	*in;
+	int 	i=0,j=0;
+	double 	xp, yp;
+	double 	xmin, ymin;
+	double 	xmax, ymax;
+	double 	stepx,stepy;
+	double 	latitude, longitude;
+	void 			*inrast_elevation;
+	RASTER_MAP_TYPE 	data_type_inrast_elevation;
+	FILE	*f; 		// output ascii file
+	int 	process; 	// process grid cell switch
+	int 	grid_count; 	// grid cell count
+	char 	*dummy_data1; 	// dummy data part 1
+	char 	*dummy_data2; 	// dummy data part 2
+	double	elevation;	// average evevation of grid cell
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("VIC, hydrology, soil");
+	module->description = _("creates a soil ascii file taking elevation and lat/long from an elevation map");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input1->key	   = _("input");
+	input1->description=_("Name of the elevation input map");
+	output1 = G_define_option() ;
+	output1->key        =_("output");
+	output1->description=_("Name of the output vic soil ascii file");
+	output1->answer     =_("vic_soil.asc");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	in	 	= input1->answer;
+	result1  	= output1->answer;
+	mapset = G_find_cell2(in, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"), in);
+	data_type_inrast_elevation = G_raster_map_type(in,mapset);
+	if ( (infd = G_open_cell_old (in,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), in);
+	if (G_get_cellhd (in, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), in);
+	inrast_elevation = G_allocate_raster_buf(data_type_inrast_elevation);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	stepx=cellhd.ew_res;
+	stepy=cellhd.ns_res;
+	xmin=cellhd.west;
+	xmax=cellhd.east;
+	ymin=cellhd.south;
+	ymax=cellhd.north;
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	/*Initialize grid cell process switch*/
+	f=fopen(result1,"w");
+	/*If =1 then process, if =0 then skip*/
+	process = 1;
+	/*Initialize grid cell count*/
+	grid_count = 1;
+	/*Initialize output file */
+	fprintf(f,"#RUN\tGRID\tLAT\tLNG\tINFILT\tDs\tDs_MAX\tWs\tC\tEXPT_1\tEXPT_2\tEXPT_3\tKsat_1\tKsat_2\tKsat_3\tPHI_1\tPHI_2\tPHI_3\tMOIST_1\tMOIST_2\tMOIST_3\tELEV\tDEPTH_1\tDEPTH_2\tDEPTH_3\tAVG_T\tDP\tBUBLE1\tBUBLE2\tBUBLE3\tQUARZ1\tQUARZ2\tQUARZ3\tBULKDN1\tBULKDN2\tBULKDN3\tPARTDN1\tPARTDN2\tPARTDN3\tOFF_GMT\tWcrFT1\tWcrFT2\tWcrFT3\tWpFT1\tWpFT2\tWpFT3\tZ0_SOIL\tZ0_SNOW\tPRCP\tRESM1\tRESM2\tRESM3\tFS_ACTV\tJULY_TAVG\n");
+	/*Initialize dummy data*/
+	dummy_data1 = "0.010\t1.e-4\t3.05\t0.93\t2\t4.0\t4.0\t4.0\t250.0\t250.0\t250.0\t-999\t-999\t-999\t0.4\t0.4\t0.4";
+	dummy_data2 = "0.1\t6.90\t2.000\t14.0\t4.0\t75.0\t75.0\t75.0\t0.24\t0.24\t0.24\t1306\t1367\t1367\t2650\t2650\t2650\t-6\t0.330\t0.330\t0.330\t0.133\t0.133\t0.133\t0.001\t0.010\t500\t0.02\t0.02\t0.02\t1\t18.665\n";
+	//Shamelessly stolen from r.sun !!!!
+	/* Set up parameters for projection to lat/long if necessary */
+	if ((G_projection() != PROJECTION_LL)) {
+		not_ll=1;
+		struct Key_Value *in_proj_info, *in_unit_info;
+		if ((in_proj_info = G_get_projinfo()) == NULL)
+			G_fatal_error(_("Can't get projection info of current location"));
+		if ((in_unit_info = G_get_projunits()) == NULL)
+			G_fatal_error(_("Can't get projection units of current location"));
+		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+			G_fatal_error(_("Can't get projection key values of current location"));
+		G_free_key_value(in_proj_info);
+		G_free_key_value(in_unit_info);
+		/* Set output projection to latlong w/ same ellipsoid */
+		oproj.zone = 0;
+		oproj.meters = 1.;
+		sprintf(oproj.proj, "ll");
+		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+			G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	}//End of stolen from r.sun :P
+	for (row = 0; row < nrows; row++)
+		DCELL d_elevation;
+		G_percent(row,nrows,2);
+		if(G_get_raster_row(infd,inrast_elevation,row,data_type_inrast_elevation)<0)
+			G_fatal_error(_("Could not read from <%s>"),in);
+		for (col=0; col < ncols; col++)
+			/*Extract lat/long data*/
+			latitude = ymax - ( row * stepy );
+			longitude = xmin + ( col * stepx );
+			if(not_ll){
+				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+				    G_fatal_error(_("Error in pj_do_proj"));
+			}else{
+				//Do nothing
+			/*Extract elevation data*/
+			switch(data_type_inrast_elevation){
+				case CELL_TYPE:
+					d_elevation = (double) ((CELL *) inrast_elevation)[col];
+					break;
+				case FCELL_TYPE:
+					d_elevation = (double) ((FCELL *) inrast_elevation)[col];
+					break;
+				case DCELL_TYPE:
+					d_elevation = ((DCELL *) inrast_elevation)[col];
+					break;
+			/*Print to ascii file*/
+			fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
+			grid_count=grid_count+1;
+	G_free (inrast_elevation);
+	G_close_cell (infd);
+	fclose(f);
+	exit(EXIT_SUCCESS);
