[GRASS-SVN] r30597 - in grass-addons/gipe: . r.out.vic_veg
svn_grass at osgeo.org
Mon Mar 17 04:42:52 EDT 2008
Author: ychemin
Date: 2008-03-17 04:42:52 -0400 (Mon, 17 Mar 2008)
New Revision: 30597
Added:
grass-addons/gipe/r.out.vic_veg/
grass-addons/gipe/r.out.vic_veg/Makefile
grass-addons/gipe/r.out.vic_veg/description.html
grass-addons/gipe/r.out.vic_veg/main.c
Removed:
grass-addons/gipe/r.vic_soil/
grass-addons/gipe/Makefile
Added r.out.vic_veg
Modified: grass-addons/gipe/Makefile
--- grass-addons/gipe/Makefile 2008-03-17 05:40:25 UTC (rev 30596)
+++ grass-addons/gipe/Makefile 2008-03-17 08:42:52 UTC (rev 30597)
@@ -62,6 +62,8 @@
r.out.ppm \
r.out.ppm3 \
r.out.vrml \
+ r.out.vic_soil \
+ r.out.vic_veg \
r.out.vtk \
r.param.scale \
r.patch \
Added: grass-addons/gipe/r.out.vic_veg/Makefile
--- grass-addons/gipe/r.out.vic_veg/Makefile (rev 0)
+++ grass-addons/gipe/r.out.vic_veg/Makefile 2008-03-17 08:42:52 UTC (rev 30597)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.vic_soil
+LIBES = $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+ EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/r.out.vic_veg/description.html
--- grass-addons/gipe/r.out.vic_veg/description.html (rev 0)
+++ grass-addons/gipe/r.out.vic_veg/description.html 2008-03-17 08:42:52 UTC (rev 30597)
@@ -0,0 +1,22 @@
+<H2>DESCRIPTION</H2>
+<EM>r.out.vic_veg</EM> creates a VIC hydrological model vegetation input ascii file.
+This is an input to VIC (Variable Infiltration Capacity).
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin<BR>
+<p>
+<i>Last changed: $Date: 2007/06/09 22:19:55 $</i>
Added: grass-addons/gipe/r.out.vic_veg/main.c
--- grass-addons/gipe/r.out.vic_veg/main.c (rev 0)
+++ grass-addons/gipe/r.out.vic_veg/main.c 2008-03-17 08:42:52 UTC (rev 30597)
@@ -0,0 +1,231 @@
+ * MODULE: r.out.vic_veg
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Creates a VIC vegetation input file.
+ * Filling only Land cover class, with only one class,
+ * and one standard root system.
+ * Option to add monthly LAI (12 maps).
+ * COPYRIGHT: (C) 2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; //region+header info
+ char *mapset; // mapset name
+ int nrows, ncols;
+ int row,col;
+ int verbose=1;
+ int not_ll=0;//if proj is not lat/long, it will be 1.
+ struct GModule *module;
+ struct Option *input1, *input2, *output1;
+ struct Flag *flag1;
+ struct History history; //metadata
+ struct pj_info iproj;
+ struct pj_info oproj;
+ /* FMEO Declarations*****************/
+ char *landcover_name;// input raster name
+ char lai_name[12]; // input monthly raster files name
+ char *result1; //output raster name
+ //File Descriptors
+ int infd, infd_lai[12];
+ int i=0,j=0;
+ double xp, yp;
+ double xmin, ymin;
+ double xmax, ymax;
+ double stepx,stepy;
+ double latitude, longitude;
+ void *inrast_landcover;
+ void *inrast_lai[12];
+ RASTER_MAP_TYPE data_type_inrast_landcover;
+ RASTER_MAP_TYPE data_type_inrast_lai[12];
+ FILE *f; // output ascii file
+ int grid_count; // grid cell count
+ char *dummy_data1; // dummy data part 1
+ char *dummy_data2; // dummy data part 2
+ double *lai[12]; // lAI data for each month
+ char **lai_ptr; // pointer to get the input2->answers
+ int nfiles; // count LAI input files
+ char **test, **ptr; // test number of LAI input files
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("VIC, hydrology, soil");
+ module->description = _("creates a vegetation ascii file from land cover map. \
+ Optionally LAI data from 12 LAI maps.");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+ input1->key = _("input");
+ input1->description=_("Name of the land cover input map");
+ input2 = G_define_standard_option(G_OPT_R_INPUT) ;
+ input2->key = _("LAI");
+ input2->multiple = YES;
+ input2->required = NO;
+ input2->description=_("Name of the LAI input maps (12 of them!)");
+ output1 = G_define_option() ;
+ output1->key =_("output");
+ output1->description=_("Name of the output vic soil ascii file");
+ output1->answer =_("vic_soil.asc");
+ if (G_parser(argc, argv))
+ exit (EXIT_FAILURE);
+ landcover_name = input1->answer;
+ result1 = output1->answer;
+ if (input2->answer){
+ test = input2->answers;
+ for (ptr = test, nfiles = 0; *ptr != NULL; ptr++, nfiles++)
+ if (nfiles < 12)
+ G_fatal_error(_("The exact number of LAI input maps is 12"));
+ lai_ptr = input2->answers;
+ for(; *lai_ptr != NULL; lai_ptr++){
+ strcpy(lai_name,*lai_ptr);
+ for(i=0;i<12;i++){
+ mapset = G_find_cell2(&lai_name[i], "");
+ if (mapset == NULL) {
+ G_fatal_error(_("cell file [%s] not found"), lai_name[i]);
+ data_type_inrast_lai[i] = G_raster_map_type(&lai_name[i],mapset);
+ if ((infd_lai[i] = G_open_cell_old (&lai_name[i],mapset)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), lai_name[i]);
+ if (G_get_cellhd (&lai_name[i], mapset, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s])"), lai_name[i]);
+ inrast_lai[i] = G_allocate_raster_buf(data_type_inrast_lai[i]);
+ mapset = G_find_cell2(landcover_name, "");
+ G_fatal_error(_("cell file [%s] not found"), landcover_name);
+ data_type_inrast_landcover = G_raster_map_type(landcover_name,mapset);
+ if ( (infd = G_open_cell_old (landcover_name,mapset)) < 0)
+ G_fatal_error (_("Cannot open cell file [%s]"), landcover_name);
+ if (G_get_cellhd (landcover_name, mapset, &cellhd) < 0)
+ G_fatal_error (_("Cannot read file header of [%s])"), landcover_name);
+ inrast_landcover = G_allocate_raster_buf(data_type_inrast_landcover);
+ G_debug(3, "number of rows %d",cellhd.rows);
+ stepx=cellhd.ew_res;
+ stepy=cellhd.ns_res;
+ xmin=cellhd.west;
+ xmax=cellhd.east;
+ ymin=cellhd.south;
+ ymax=cellhd.north;
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ /*Initialize grid cell process switch*/
+ f=fopen(result1,"w");
+ /*Initialize grid cell count*/
+ grid_count = 1;
+ /*Initialize dummy data*/
+ dummy_data1 = "0.10\t0.1\t1.00\t0.65\t0.50\t0.25";
+ dummy_data2 = "0.312\t0.413\t0.413\t0.413\t0.413\t0.488\t0.975\t1.150\t0.625\t0.312\t0.312\t0.312";
+ for (row = 0; row < nrows; row++){
+ CELL c_landcover;
+ DCELL d_lai[12];
+ G_percent(row,nrows,2);
+ if(G_get_raster_row(infd,inrast_landcover,row,data_type_inrast_landcover)<0)
+ G_fatal_error(_("Could not read from <%s>"),landcover_name);
+ if(input2->answer){
+ if(G_get_raster_row(infd_lai[i],inrast_lai[i],row,data_type_inrast_lai[i])<0)
+ G_fatal_error(_("Could not read from <%s>"),lai_name[i]);
+ for (col=0; col < ncols; col++){
+ /*Extract landcover data*/
+ switch(data_type_inrast_landcover){
+ case CELL_TYPE:
+ c_landcover= ((CELL *) inrast_landcover)[col];
+ break;
+ case FCELL_TYPE:
+ c_landcover= (int) ((FCELL *) inrast_landcover)[col];
+ break;
+ case DCELL_TYPE:
+ c_landcover= (int) ((DCELL *) inrast_landcover)[col];
+ break;
+ /*Extract lai monthly data*/
+ switch(data_type_inrast_lai[i]){
+ case CELL_TYPE:
+ d_lai[i]= (double) ((CELL *) inrast_lai[i])[col];
+ break;
+ case FCELL_TYPE:
+ d_lai[i]= (double) ((FCELL *) inrast_lai[i])[col];
+ break;
+ case DCELL_TYPE:
+ d_lai[i]= (double) ((DCELL *) inrast_lai[i])[col];
+ break;
+ /*Print to ascii file*/
+ /*Grid cell count and number of classes in that grid cell (=1)*/
+ fprintf(f,"%d\t1\n", grid_count);
+ /*Class number, percentage that this class covers in the
+ * grid cell(=1.0, full grid cell)
+ * 3 root zones with depths of 10cm, 10cm and 1.0m
+ * for those 3 root zone depths, how much root in each (%)
+ * here we have 0.65, 0.50 and 0.25
+ fprintf(f,"\t\t%d\t1.0\t%s\n", c_landcover, dummy_data1);
+ /*Load monthly LAI maps data if available*/
+ fprintf(f,"\t\t\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\t%5.3f\n", lai[0], lai[1], lai[2], lai[3], lai[4], lai[5], lai[6], lai[7], lai[8], lai[9], lai[10], lai[11]);
+ } else {
+ fprintf(f,"\t\t\t%s\n", dummy_data2);
+ grid_count=grid_count+1;
+ G_free (inrast_landcover);
+ G_close_cell (infd);
+ G_free (inrast_lai[i]);
+ G_close_cell (infd_lai[i]);
+ fclose(f);
+ exit(EXIT_SUCCESS);
