[GRASS-SVN] r30701 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sat Mar 22 20:47:26 EDT 2008
Author: martinl
Date: 2008-03-22 20:47:26 -0400 (Sat, 22 Mar 2008)
New Revision: 30701
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: (render/preferences) cairo driver also supported (initial)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-03-22 21:16:14 UTC (rev 30700)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-03-23 00:47:26 UTC (rev 30701)
@@ -326,8 +326,8 @@
self.notebook = notebook
def write(self, s):
- # if self.notebook.GetSelection() != 1: # command output
- # self.notebook.SetSelection(1)
+ if self.notebook.GetSelection() != 1: # command output
+ self.notebook.SetSelection(1)
s = s.replace('\n', os.linesep)
# remove/replace escape sequences '\b' or '\r' from stream
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-22 21:16:14 UTC (rev 30700)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-23 00:47:26 UTC (rev 30701)
@@ -62,6 +62,7 @@
'display': {
'displayFont' : { 'value' : '' },
+ 'driver': { 'type': 'default' },
# advanced
@@ -165,7 +166,8 @@
self.internalSettings['cmd']['verbosity']['choices'] = ['grassenv',
'verbose',
'quiet']
+ self.internalSettings['display']['driver']['choices'] = ['default']
def GetMapsetPath(self):
"""Store mapset search path"""
all, access = utils.ListOfMapsets()
@@ -493,6 +495,32 @@
wx.ALIGN_CENTER_VERTICAL,
pos=(row, 1))
+ # display driver
+ row = 1
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Display driver:")),
+ flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 0))
+ listOfDrivers = self.settings.Get(group='display', key='driver', subkey='choices', internal=True)
+ # check if cairo is available
+ if 'cairo' not in listOfDrivers:
+ for line in gcmd.Command(['d.mon', '-l']).ReadStdOutput():
+ if 'cairo' in line:
+ listOfDrivers.append('cairo')
+ break
+ driver = wx.Choice(parent=panel, id=wx.ID_ANY, size=(150, -1),
+ choices=listOfDrivers,
+ name="GetStringSelection")
+ driver.SetStringSelection(self.settings.Get(group='display', key='driver', subkey='type'))
+ self.winId['display:driver:type'] = driver.GetId()
+ gridSizer.Add(item=driver,
+ pos=(row, 1))
sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-22 21:16:14 UTC (rev 30700)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-23 00:47:26 UTC (rev 30701)
@@ -34,6 +34,7 @@
import utils
import gcmd
from debug import Debug as Debug
+from preferences import globalSettings as UserSettings
# use g.pnmcomp for creating image composition or
@@ -115,8 +116,14 @@
# start monitor
- os.environ["GRASS_PNGFILE"] = self.mapfile
+ if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
+ os.environ["GRASS_CAIROFILE"] = self.mapfile
+ if 'cairo' not in gcmd.Command(['d.mon', '-p']).ReadStdOutput()[0]:
+ gcmd.Command(['d.mon',
+ 'start=cairo'], stderr=None)
+ else:
+ os.environ["GRASS_PNGFILE"] = self.mapfile
# execute command
@@ -135,7 +142,12 @@
# stop monitor
- os.unsetenv("GRASS_PNGFILE")
+ 'stop=cairo'], stderr=None)
+ os.unsetenv("GRASS_CAIROFILE")
+ else:
+ os.unsetenv("GRASS_PNGFILE")
return self.mapfile
@@ -199,7 +211,6 @@
# environment settings
self.env = {} # enviroment variables, like MAPSET, LOCATION_NAME, etc.
- self.verbosity = 0 # --q
# generated file for rendering the map
@@ -209,15 +220,8 @@
# setting some initial env. variables
self.InitGisEnv() # g.gisenv
self.InitRegion()
- os.environ["GRASS_TRANSPARENT"] = "TRUE"
+ os.environ["GRASS_TRANSPARENT"] = "TRUE"
os.environ["GRASS_BACKGROUNDCOLOR"] = "ffffff"
- os.environ["GRASS_HEIGHT"] = str(self.height)
- os.environ["GRASS_WIDTH"] = str(self.width)
- os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
- os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
- os.environ["GRASS_TRUECOLOR"] = "TRUE"
- os.environ["GRASS_COMPRESSION"] = "0"
- os.environ["GRASS_VERBOSE"] = str(self.verbosity)
def InitRegion(self):
@@ -612,6 +616,14 @@
os.environ["GRASS_REGION"] = self.SetRegion()
+ os.environ["GRASS_AUTO_WRITE"] = "TRUE"
+ os.unsetenv("GRASS_RENDER_IMMEDIATE")
+ else:
+ os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
+ os.environ["GRASS_COMPRESSION"] = "0"
+ os.environ["GRASS_TRUECOLOR"] = "TRUE"
+ os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
# render map layers
for layer in self.layers + self.overlays:
@@ -657,15 +669,6 @@
maskstr = maskstr.rstrip(',')
mapoutstr = self.mapfile.replace('\\', '/')
- compstring = "g.pnmcomp" + globalvar.EXT_BIN + \
- " in=" + mapstr + \
- " mask=" + maskstr + \
- " opacity=" + ",".join(opacities)+ \
- " background=255:255:255" + \
- " width=" + str(self.width) + \
- " height=" + str(self.height) + \
- " output=" + mapoutstr
# compose command
complist = ["g.pnmcomp",
"in=%s" % ",".join(maps),
@@ -687,7 +690,6 @@
# run g.pngcomp to get composite image
try:
gcmd.Command(complist)
- # os.system(compstring)
except gcmd.CmdError, e:
print >> sys.stderr, e
return None
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-03-22 21:16:14 UTC (rev 30700)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-03-23 00:47:26 UTC (rev 30701)
@@ -128,9 +128,6 @@
self.toolbar = self.__createToolBar()
self.statusbar = self.CreateStatusBar(number=1)
- # set environmental variables
- os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
# bindings
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
self.Bind(wx.EVT_LEFT_DOWN, self.AddRaster, self.notebook)
