[GRASS-SVN] r30702 - in grass-addons/gipe: . i.eb.g0 r.out.vic_met
Sun Mar 23 02:07:33 EDT 2008
Author: ychemin
Date: 2008-03-23 02:07:32 -0400 (Sun, 23 Mar 2008)
New Revision: 30702
Added:
   grass-addons/gipe/r.out.vic_met/
   grass-addons/gipe/r.out.vic_met/Makefile
   grass-addons/gipe/r.out.vic_met/description.html
   grass-addons/gipe/r.out.vic_met/main.c
   grass-addons/gipe/Makefile
   grass-addons/gipe/gmmenu.tcl
   grass-addons/gipe/i.eb.g0/main.c
   grass-addons/gipe/menudata.py
Added meteorological .dat grid files creations for VIC hydromodel, r.out.vic_met. Modified Makefile, gmmenu.tcl and menudata.py accordingly for GUIs
Modified: grass-addons/gipe/Makefile
--- grass-addons/gipe/Makefile	2008-03-23 00:47:26 UTC (rev 30701)
+++ grass-addons/gipe/Makefile	2008-03-23 06:07:32 UTC (rev 30702)
@@ -63,6 +63,7 @@
 	r.out.ppm3 \
 	r.out.vrml \
 	r.out.vic_mask \
+	r.out.vic_met \
 	r.out.vic_soil \
 	r.out.vic_veg \
 	r.out.vtk \
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl	2008-03-23 00:47:26 UTC (rev 30701)
+++ grass-addons/gipe/gmmenu.tcl	2008-03-23 06:07:32 UTC (rev 30702)
@@ -145,6 +145,7 @@
 		{command {[G_msg "POV-Ray"]} {} "r.out.pov: Export POV-Ray height-field" {} -command { execute r.out.pov }}
 		{command {[G_msg "TIFF"]} {} "r.out.tiff: Export TIFF image (8/24bit)" {} -command { execute r.out.tiff }}
 		{command {[G_msg "VIC Mask"]} {} "r.out.vic_mask: Export VIC mask ASCII file" {} -command { execute r.out.vic_mask }}
+		{command {[G_msg "VIC Mask"]} {} "r.out.vic_met: Export VIC meteorological ASCII files" {} -command { execute r.out.vic_met }}
 		{command {[G_msg "VIC Soil"]} {} "r.out.vic_soil: Export VIC soil ASCII file" {} -command { execute r.out.vic_soil }}
 		{command {[G_msg "VIC Veg"]} {} "r.out.vic_veg: Export VIC vegetation ASCII file" {} -command { execute r.out.vic_veg }}
 		{command {[G_msg "VRML"]} {} "r.out.vrml: Export VRML file" {} -command { execute r.out.vrml }}
Modified: grass-addons/gipe/i.eb.g0/main.c
--- grass-addons/gipe/i.eb.g0/main.c	2008-03-23 00:47:26 UTC (rev 30701)
+++ grass-addons/gipe/i.eb.g0/main.c	2008-03-23 06:07:32 UTC (rev 30702)
@@ -67,51 +67,33 @@
 	module->description = _("soil heat flux approximation (Bastiaanssen, 1995)");
 	/* Define the different options */
-	input1 = G_define_option() ;
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input1->key	   = _("albedo");
-	input1->type       = TYPE_STRING;
-	input1->required   = YES;
-	input1->gisprompt  =_("old,cell,raster") ;
 	input1->description=_("Name of the Albedo map [0.0;1.0]");
 	input1->answer     =_("albedo");
-	input2 = G_define_option() ;
+	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input2->key        =_("ndvi");
-	input2->type       = TYPE_STRING;
-	input2->required   = YES;
-	input2->gisprompt  =_("old,cell,raster");
 	input2->description=_("Name of the ndvi map [-1.0;+1.0]");
 	input2->answer     =_("ndvi");
-	input3 = G_define_option() ;
+	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input3->key        =_("tempk");
-	input3->type       = TYPE_STRING;
-	input3->required   = YES;
-	input3->gisprompt  =_("old,cell,raster");
 	input3->description=_("Name of the Surface temperature map [degree Kelvin]");
 	input3->answer     =_("tempk");
-	input4 = G_define_option() ;
+	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input4->key        =_("rnet");
-	input4->type       = TYPE_STRING;
-	input4->required   = YES;
-	input4->gisprompt  =_("old,cell,raster");
 	input4->description=_("Name of the Net Radiation map [W/m2]");
 	input4->answer     =_("rnet");
-	input5 = G_define_option() ;
+	input5 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input5->key        =_("time");
-	input5->type       = TYPE_STRING;
-	input5->required   = YES;
-	input5->gisprompt  =_("old,cell,raster");
 	input5->description=_("Name of the time of satellite overpass map [local UTC]");
 	input5->answer     =_("time");
-	output1 = G_define_option() ;
+	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
 	output1->key        =_("g0");
-	output1->type       = TYPE_STRING;
-	output1->required   = YES;
-	output1->gisprompt  =_("new,cell,raster");
 	output1->description=_("Name of the output g0 layer");
 	output1->answer     =_("g0");
@@ -135,7 +117,6 @@
 	result  = output1->answer;
 	roerink = flag1->answer;
-	verbose = (!flag2->answer);
 	mapset = G_find_cell2(albedo, "");
 	if (mapset == NULL) {
@@ -208,9 +189,7 @@
 		DCELL d_tempk;
 		DCELL d_rnet;
 		DCELL d_time;
-		if(verbose)
-			G_percent(row,nrows,2);
-//		printf("row = %i/%i\n",row,nrows);
+		G_percent(row,nrows,2);
 		/* read soil input maps */
 		if(G_get_raster_row(infd_albedo,inrast_albedo,row,data_type_albedo)<0)
 			G_fatal_error(_("Could not read from <%s>"),albedo);
Modified: grass-addons/gipe/menudata.py
--- grass-addons/gipe/menudata.py	2008-03-23 00:47:26 UTC (rev 30701)
+++ grass-addons/gipe/menudata.py	2008-03-23 06:07:32 UTC (rev 30702)
@@ -226,6 +226,10 @@
                                  _("Export VIC Mask ASCII file"),
                                  "self.OnMenuCmd",
                                  "r.out.vic_mask"),
+                                (_("VIC Meteo export"),
+                                 _("Export VIC Meteorological .dat ASCII files"),
+                                 "self.OnMenuCmd",
+                                 "r.out.vic_met"),
                                 (_("VIC Soil export"),
                                  _("Export VIC Soil ASCII file"),
                                  "self.OnMenuCmd",
Added: grass-addons/gipe/r.out.vic_met/Makefile
--- grass-addons/gipe/r.out.vic_met/Makefile	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_met/Makefile	2008-03-23 06:07:32 UTC (rev 30702)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.vic_met
+LIBES =  $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/r.out.vic_met/description.html
--- grass-addons/gipe/r.out.vic_met/description.html	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_met/description.html	2008-03-23 06:07:32 UTC (rev 30702)
@@ -0,0 +1,33 @@
+<H2>DESCRIPTION</H2>
+<EM>r.out.vic_met</EM> creates a set of VIC hydrological model meteorological input ascii files.
+Files are $prefix_latitude_longitude.dat.
+Format is:
+"%.2f  %.2f  %.2f\n"
+with:
+double precipitation
+double Tmax
+double Tmin
+This is an input to VIC (Variable Infiltration Capacity) in forcing/ of TEST example.
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin<BR>
+<p>
+<i>Last changed: $Date: 2008/03/23 09:39:55 $</i>
Added: grass-addons/gipe/r.out.vic_met/main.c
--- grass-addons/gipe/r.out.vic_met/main.c	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_met/main.c	2008-03-23 06:07:32 UTC (rev 30702)
@@ -0,0 +1,326 @@
+ * MODULE:       r.out.vic_met
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates a VIC meteorological input file.
+ * 		 Three time series of GIS data are needed:
+ * 		 Precipitation (mm/d), Tmax(C) and Tmin(C)
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+/* daily one year is: 	*/
+#define MAXFILES 366
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	int verbose=1;
+	int not_ll=0;//if proj is not lat/long, it will be 1.
+	struct GModule *module;
+	struct Option *input1, *input2, *input3, *output1;
+	struct Flag *flag1;
+	struct History history; //metadata
+	struct pj_info iproj;
+	struct pj_info oproj;
+	/* FMEO Declarations*****************/
+	char 	prcp_name[MAXFILES];// input first time-series raster files names
+	char 	tmax_name[MAXFILES];// input second time_series raster files names
+	char 	tmin_name[MAXFILES];// input third time_series raster files names
+	char 	*result1; 	//output file base name
+	char 	*result_lat_long; 	//output file name
+	//File Descriptors
+	int 	infd_prcp[MAXFILES], infd_tmax[MAXFILES], infd_tmin[MAXFILES];
+	int 	i=0,j=0;
+	double 	xp, yp;
+	double 	xmin, ymin;
+	double 	xmax, ymax;
+	double 	stepx,stepy;
+	double 	latitude, longitude;
+	void 			*inrast_prcp[MAXFILES];
+	void 			*inrast_tmax[MAXFILES];
+	void 			*inrast_tmin[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_prcp[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_tmax[MAXFILES];
+	RASTER_MAP_TYPE 	data_type_inrast_tmin[MAXFILES];
+	FILE	*f; 		// output ascii file
+	int 	grid_count; 	// grid cell count
+	double	*prcp[MAXFILES];	// Precipitation data
+	double	*tmax[MAXFILES];	// Tmax data
+	double	*tmin[MAXFILES];	// Tmin data
+	char 	**prcp_ptr;	// pointer to get the input1->answers
+	char 	**tmax_ptr;	// pointer to get the input2->answers
+	char 	**tmin_ptr;	// pointer to get the input3->answers
+	int	nfiles; 	// count number of input files
+	char	**test, **ptr;	// test number of input files
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("VIC, hydrology, precipitation, Tmax, Tmin");
+	module->description = _("creates a meteorological ascii file \
+			from 3 time series maps: precipitation, Tmax and Tmin.");
+	/* Define the different options */
+	input1->key	   = _("prcp");
+	input1->multiple   = YES;
+	input1->description=_("Names of the precipitation input maps");
+	input2->key	   = _("tmax");
+	input2->multiple   = YES;
+	input2->description=_("Names of the Tmax input maps");
+	input3->key	   = _("tmin");
+	input3->multiple   = YES;
+	input3->description=_("Names of the Tmin input maps");
+	output1 = G_define_option() ;
+	output1->key      	=_("output");
+	output1->description	=_("Base Name of the output vic meteorological ascii files");
+	output1->answer     	=_("data_");
+	flag1 = G_define_flag() ;
+	flag1->key		= 'a';
+	flag1->description	=_("append data if file already exists \
+				(useful if adding additional year of data)");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	result1 	 	= output1->answer;
+	/* LOADING TMAX TIME SERIES MAPS 		*/
+	test = input1->answers;
+	for (ptr = test, nfiles = 0; *ptr != NULL; ptr++, nfiles++)
+	if (nfiles > MAXFILES)
+		G_fatal_error(_("Too many input files, change MAX_FILES and recompile."));
+	prcp_ptr = input2->answers;
+	for(; *prcp_ptr != NULL; prcp_ptr++){
+		strcpy(prcp_name,*prcp_ptr);
+	for(i=0;i<nfiles+1;i++){
+		mapset = G_find_cell2(&prcp_name[i], "");
+		if (mapset == NULL) {
+			G_fatal_error(_("cell file [%s] not found"), prcp_name[i]);
+		data_type_inrast_prcp[i] = G_raster_map_type(&prcp_name[i],mapset);
+		if ((infd_prcp[i] = G_open_cell_old (&prcp_name[i],mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"), prcp_name[i]);
+		if (G_get_cellhd (&prcp_name[i], mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), prcp_name[i]);
+		inrast_prcp[i] = G_allocate_raster_buf(data_type_inrast_prcp[i]);
+	test = input2->answers;
+	tmax_ptr = input2->answers;
+	for(; *tmax_ptr != NULL; tmax_ptr++){
+		strcpy(tmax_name,*tmax_ptr);
+		mapset = G_find_cell2(&tmax_name[i], "");
+			G_fatal_error(_("cell file [%s] not found"), tmax_name[i]);
+		data_type_inrast_tmax[i] = G_raster_map_type(&tmax_name[i],mapset);
+		if ((infd_tmax[i] = G_open_cell_old (&tmax_name[i],mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"), tmax_name[i]);
+		if (G_get_cellhd (&tmax_name[i], mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), tmax_name[i]);
+		inrast_tmax[i] = G_allocate_raster_buf(data_type_inrast_tmax[i]);
+	/* LOADING TMIN TIME SERIES MAPS 		*/
+	test = input3->answers;
+	tmin_ptr = input3->answers;
+	for(; *tmin_ptr != NULL; tmin_ptr++){
+		strcpy(tmin_name,*tmin_ptr);
+		mapset = G_find_cell2(&tmin_name[i], "");
+			G_fatal_error(_("cell file [%s] not found"), tmin_name[i]);
+		data_type_inrast_tmin[i] = G_raster_map_type(&tmin_name[i],mapset);
+		if ((infd_tmin[i] = G_open_cell_old (&tmin_name[i],mapset)) < 0)
+			G_fatal_error (_("Cannot open cell file [%s]"), tmin_name[i]);
+		if (G_get_cellhd (&tmin_name[i], mapset, &cellhd) < 0)
+			G_fatal_error (_("Cannot read file header of [%s])"), tmin_name[i]);
+		inrast_tmax[i] = G_allocate_raster_buf(data_type_inrast_tmin[i]);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	stepx=cellhd.ew_res;
+	stepy=cellhd.ns_res;
+	xmin=cellhd.west;
+	xmax=cellhd.east;
+	ymin=cellhd.south;
+	ymax=cellhd.north;
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	//Shamelessly stolen from r.sun !!!!
+	/* Set up parameters for projection to lat/long if necessary */
+	if ((G_projection() != PROJECTION_LL)) {
+		not_ll=1;
+		struct Key_Value *in_proj_info, *in_unit_info;
+		if ((in_proj_info = G_get_projinfo()) == NULL)
+			G_fatal_error(_("Can't get projection info of current location"));
+		if ((in_unit_info = G_get_projunits()) == NULL)
+			G_fatal_error(_("Can't get projection units of current location"));
+		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+			G_fatal_error(_("Can't get projection key values of current location"));
+		G_free_key_value(in_proj_info);
+		G_free_key_value(in_unit_info);
+		/* Set output projection to latlong w/ same ellipsoid */
+		oproj.zone = 0;
+		oproj.meters = 1.;
+		sprintf(oproj.proj, "ll");
+		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+			G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	}//End of stolen from r.sun :P
+	/*Initialize grid cell count*/
+	grid_count = 1;
+	for (row = 0; row < nrows; row++){
+		DCELL d_prcp[MAXFILES];
+		DCELL d_tmax[MAXFILES];
+		DCELL d_tmin[MAXFILES];
+		for(i=0;i<nfiles;i++){
+			if(G_get_raster_row(infd_prcp[i],inrast_prcp[i],row,data_type_inrast_prcp[i])<0)
+				G_fatal_error(_("Could not read from <%s>"),prcp_name[i]);
+			if(G_get_raster_row(infd_tmax[i],inrast_tmax[i],row,data_type_inrast_tmax[i])<0)
+				G_fatal_error(_("Could not read from <%s>"),tmax_name[i]);
+			if(G_get_raster_row(infd_tmin[i],inrast_tmin[i],row,data_type_inrast_tmin[i])<0)
+				G_fatal_error(_("Could not read from <%s>"),tmin_name[i]);
+		for (col=0; col < ncols; col++){
+			/*Extract prcp time series data*/
+				switch(data_type_inrast_prcp[i]){
+				case CELL_TYPE:
+					d_prcp[i]= (double) ((CELL *) inrast_prcp[i])[col];
+					break;
+				case FCELL_TYPE:
+					d_prcp[i]= (double) ((FCELL *) inrast_prcp[i])[col];
+					break;
+				case DCELL_TYPE:
+					d_prcp[i]= (double) ((DCELL *) inrast_prcp[i])[col];
+					break;
+			/*Extract tmax time series data*/
+				switch(data_type_inrast_tmax[i]){
+				case CELL_TYPE:
+					d_tmax[i]= (double) ((CELL *) inrast_tmax[i])[col];
+					break;
+				case FCELL_TYPE:
+					d_tmax[i]= (double) ((FCELL *) inrast_tmax[i])[col];
+					break;
+				case DCELL_TYPE:
+					d_tmax[i]= (double) ((DCELL *) inrast_tmax[i])[col];
+					break;
+			/*Extract tmin time series data*/
+				switch(data_type_inrast_tmin[i]){
+				case CELL_TYPE:
+					d_tmin[i]= (double) ((CELL *) inrast_tmin[i])[col];
+					break;
+				case FCELL_TYPE:
+					d_tmin[i]= (double) ((FCELL *) inrast_tmin[i])[col];
+					break;
+				case DCELL_TYPE:
+					d_tmin[i]= (double) ((DCELL *) inrast_tmin[i])[col];
+					break;
+			/*Extract lat/long data*/
+			latitude = ymax - ( row * stepy );
+			longitude = xmin + ( col * stepx );
+			if(not_ll){
+				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+				    G_fatal_error(_("Error in pj_do_proj"));
+			}else{
+				//Do nothing
+			/* Make the output .dat file name */
+			sprintf(result_lat_long,"%s%s%s%s%s",result1,"_",latitude,"_",longitude,".dat");
+			/*Open new ascii file*/
+			if (flag1->answer){
+				/*Initialize grid cell in append mode*/
+				f=fopen(result_lat_long,"a");
+			} else {
+				/*Initialize grid cell in new file mode*/
+				f=fopen(result_lat_long,"w");
+			/* Force clearing of file name var */
+			result_lat_long=NULL;
+			/*Print data into the file maps data if available*/
+				fprintf(f,"%.2f  %.2f  %.2f\n", prcp[i], tmax[i], tmin[i]);
+			fclose(f);
+			grid_count=grid_count+1;
+	G_message(_("Created %d VIC meteorological files"),grid_count);
+		G_free (inrast_prcp[i]);
+		G_close_cell (infd_prcp[i]);
+		G_free (inrast_tmax[i]);
+		G_close_cell (infd_tmax[i]);
+		G_free (inrast_tmin[i]);
+		G_close_cell (infd_tmin[i]);
+	exit(EXIT_SUCCESS);
