[GRASS-SVN] r30716 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Mon Mar 24 16:51:48 EDT 2008
Author: martinl
Date: 2008-03-24 16:51:48 -0400 (Mon, 24 Mar 2008)
New Revision: 30716
grass/trunk/gui/wxpython/gis_set.py
wxGUI (welcome screen): mapset with no user permission non-selectable (TODO: different style for non-selectable items)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2008-03-24 20:47:33 UTC (rev 30715)
+++ grass/trunk/gui/wxpython/gis_set.py 2008-03-24 20:51:48 UTC (rev 30716)
@@ -55,6 +55,7 @@
self.listOfLocations = []
self.listOfMapsets = []
+ self.listOfMapsetsEnabled = []
wx.Frame.__init__(self, parent=parent, id=id, style=style)
@@ -534,18 +535,30 @@
def UpdateMapsets(self, location):
"""Update list of mapsets"""
+ self.FormerSelection = wx.NOT_FOUND # for non-selectable item
for mapset in glob.glob(os.path.join(self.gisdbase, location, "*")):
if os.path.isdir(mapset) and os.path.basename(mapset) != 'PERMANENT':
self.listOfMapsets.append(os.path.basename(mapset))
utils.ListSortLower(self.listOfMapsets)
- self.listOfMapsets.insert(0,'PERMANENT')
+ self.listOfMapsets.insert(0, 'PERMANENT')
self.lbmapsets.Clear()
- self.lbmapsets.InsertItems(self.listOfMapsets,0)
+ self.lbmapsets.InsertItems(self.listOfMapsets, 0)
+ # disable mapset with no permission
+ for line in gcmd.Command(['g.mapset',
+ '-l',
+ 'location=%s' % os.path.basename(location),
+ 'gisdbase=%s' % self.gisdbase]).ReadStdOutput():
+ self.listOfMapsetsEnabled += line.split(' ')
+ # TODO: non-selectable items in different style
return self.listOfMapsets
def OnSelectLocation(self, event):
@@ -562,8 +575,11 @@
def OnSelectMapset(self,event):
"""Mapset selected"""
- # self.bstart.Enable(True)
- event.Skip()
+ if event.GetString() not in self.listOfMapsetsEnabled:
+ self.lbmapsets.SetSelection(self.FormerSelection)
+ else:
+ self.FormerSelection = event.GetSelection()
+ event.Skip()
def OnSetDatabase(self,event):
"""Database set"""
