[GRASS-SVN] r30717 - grass/trunk/lib/gis
svn_grass at osgeo.org
Mon Mar 24 17:13:11 EDT 2008
Author: martinl
Date: 2008-03-24 17:13:11 -0400 (Mon, 24 Mar 2008)
New Revision: 30717
grass/trunk/lib/gis/mapset_msc.c
gislib (mapset_msc.c): Doxygen docs updated
Modified: grass/trunk/lib/gis/mapset_msc.c
--- grass/trunk/lib/gis/mapset_msc.c 2008-03-24 20:51:48 UTC (rev 30716)
+++ grass/trunk/lib/gis/mapset_msc.c 2008-03-24 21:13:11 UTC (rev 30717)
@@ -1,13 +1,14 @@
- * G__make_mapset_element (element)
- * char *element element to be created in mapset
- * make the specified element in the current mapset
- * will check for the existence of the element and
- * do nothing if it is found so this routine
- * can be called even if the element already exists
+ \file mapset_msc.c
+ \brief GIS library - Mapset user permission routines.
+ (C) 1999-2008 The GRASS development team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
#include <string.h>
#include <unistd.h>
#include <stdlib.h>
@@ -16,6 +17,19 @@
#include <grass/gis.h>
#include <grass/glocale.h>
+ \brief Create element in the current mapset.
+ Make the specified element in the current mapset
+ will check for the existence of the element and
+ do nothing if it is found so this routine
+ can be called even if the element already exists.
+ \param element element to be created in mapset
+ \return 0 ?
+ \return ?
int G__make_mapset_element (const char *p_element)
char path[GPATH_MAX];
@@ -24,7 +38,7 @@
element = p_element;
if (*element == 0)
- return 0;
+ return 0;
G__file_name (p = path, "", "", G_mapset());
while (*p)
@@ -46,7 +60,7 @@
if (access (path, 0) != 0)
G_mkdir(path);
- G_fatal_error (_("can't make mapset element %s (%s)"), p_element, path);
+ G_fatal_error (_("Unable to make mapset element %s (%s)"), p_element, path);
if (*element == 0)
return 1;
@@ -54,6 +68,15 @@
+ \brief Create misc element in the current mapset.
+ \param dir directory path
+ \param name element name
+ \return 0 ?
+ \return ?
int G__make_mapset_element_misc (const char *dir, const char *name)
char buf[GNAME_MAX*2+1];
@@ -62,13 +85,15 @@
return G__make_mapset_element(buf);
-* G__mapset_permissions (mapset)
-* returns: 1 mapset exists, and user has permission
-* 0 mapset exists, BUT user denied permission
-* -1 mapset does not exist
+ \brief Check for user mapset permission
+ \param mapset mapset name
+ \return 1 mapset exists, and user has permission
+ \return 0 mapset exists, BUT user denied permission
+ \return -1 mapset does not exist
int G__mapset_permissions (const char *mapset)
@@ -91,15 +116,17 @@
return 1;
-* G__mapset_permissions2 ( gisdbase, location, mapset)
-* mapset_path is full path to mapset directory
+ \param gisdbase full path to GISDBASE
+ \param location location name
int G__mapset_permissions2 ( const char * gisdbase, const char * location, const char *mapset )
@@ -121,4 +148,3 @@
return 1;
