Author: martinl
Date: 2008-03-24 17:46:54 -0400 (Mon, 24 Mar 2008)
New Revision: 30718
grass/trunk/lib/gis/mapset_nme.c
gislib (mapset_nme.c): Doxygen strings updated
Modified: grass/trunk/lib/gis/mapset_nme.c
--- grass/trunk/lib/gis/mapset_nme.c 2008-03-24 21:13:11 UTC (rev 30717)
+++ grass/trunk/lib/gis/mapset_nme.c 2008-03-24 21:46:54 UTC (rev 30718)
@@ -1,20 +1,14 @@
- * G__mapset_name(n)
- * given the index, return the char string name of the n'th mapset
- * from the mapset_name[] list. The first call will initialize
- * the list.
- * Internal routines
- * get_list_of_mapsets()
- * sets up the mapset_name[] list from the mapset
- * Data structures
- * mapset_name[] list of mapset names
- * nmapset number of names in the above list
+ \file mapset_nme.c
+ \brief GIS library - Mapset name, search path routines.
+ (C) 1999-2008 The GRASS development team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
#include <sys/types.h>
#include <sys/stat.h>
#include <string.h>
@@ -29,6 +23,16 @@
static int new_mapset(const char *);
static int get_list_of_mapsets(void);
+ \brief Get name of the n'th mapset from the mapset_name[] list.
+ The first call will initialize the list.
+ \param n mapset index
+ \return mapset name
+ \return NULL if mapset not found
char *G__mapset_name (int n)
@@ -95,7 +99,11 @@
return 0;
+ \brief Define alternative mapset search path
+ \return 0
int G__create_alt_search_path(void)
nmapset2 = nmapset;
@@ -103,10 +111,16 @@
nmapset = 0;
- return 0;
+ return 0; /* ??? */
get_list_of_mapsets();
+ \brief Switch mapset search path
+ \return 0
int G__switch_search_path(void)
int n;
@@ -124,6 +138,11 @@
return 0;
+ \brief Reset number of mapsets
+ \return 0
int G_reset_mapsets(void)
nmapset=0;
@@ -131,8 +150,13 @@
return 0;
-/* Returns pointer to zero terminated array of available mapsets.
- * List is updated by each call to this function */
+ \brief Get list of available mapsets for current location
+ List is updated by each call to this function
+ \return pointer to zero terminated array of available mapsets.
char **G_available_mapsets ( void )
int i, n;
@@ -183,10 +207,14 @@
return mapsets;
-/* Add mapset to the list of mapsets in search path.
- * Mapset is add in memory only, not to the SEARCH_PATH file!
- * List is check first if already exists.
+ \brief Add mapset to the list of mapsets in search path.
+ Mapset is add in memory only, not to the SEARCH_PATH file!
+ List is check first if already exists.
+ \param mapset mapset name
void G_add_mapset_to_search_path ( const char *mapset )
int i;
