[GRASS-SVN] r30802 - in grass/trunk/imagery: i.group i.target
    svn_grass at osgeo.org
    Sat Mar 29 23:53:03 EDT 2008
Author: hamish
Date: 2008-03-29 23:53:03 -0400 (Sat, 29 Mar 2008)
New Revision: 30802
   grass/trunk/imagery/i.group/main.c
   grass/trunk/imagery/i.target/main.c
remove @mapset part and test to see if the group is in the current mapset (trac bug #70)
Modified: grass/trunk/imagery/i.group/main.c
--- grass/trunk/imagery/i.group/main.c	2008-03-30 02:48:26 UTC (rev 30801)
+++ grass/trunk/imagery/i.group/main.c	2008-03-30 03:53:03 UTC (rev 30802)
@@ -37,6 +37,7 @@
 int main(int argc, char *argv[])
     char title[80];
+    char group[GNAME_MAX], mapset[GMAPSET_MAX];
     int m, k=0;
     struct Option *grp, *rast, *sgrp;
@@ -93,70 +94,83 @@
 	k++;
     if (k < 1 && !l->answer)  /* remove if input is requirement */
         G_fatal_error( _("No input raster map(s) specified") );
-    I_location_info(title, argv[0]);
+    I_location_info(title, argv[0]);    /* unused? */
+    /* check if current mapset:  (imagery libs are very lacking in this dept)
+	- abort if not,
+	- remove @mapset part if it is
+    if(G__name_is_fully_qualified(grp->answer, group, mapset)) {
+	if(strcmp(mapset, G_mapset()))
+	    G_fatal_error(_("Group must exist in the current mapset"));
+    else {
+	strcpy(group, grp->answer); /* FIXME for buffer overflow (have the parser check that?) */
     if (r->answer) {
 	/* Remove files from Group */
-	if (I_find_group(grp->answer) == 0) {
-	    G_fatal_error(_("Specified group does not exist"));
+	if (I_find_group(group) == 0) {
+	    G_fatal_error(_("Specified group does not exist in current mapset"));
 	if (sgrp->answer) {
 	    G_verbose_message(_("Removing raster maps from subgroup <%s>..."), sgrp->answer);
-	    remove_subgroup_files(grp->answer, sgrp->answer, rast->answers, k);
+	    remove_subgroup_files(group, sgrp->answer, rast->answers, k);
 	else {
-	    G_verbose_message(_("Removing raster maps from group <%s>..."), grp->answer);
-	    remove_group_files(grp->answer, rast->answers, k);
+	    G_verbose_message(_("Removing raster maps from group <%s>..."), group);
+	    remove_group_files(group, rast->answers, k);
     else {
         if (l->answer) {
+	    /* List raster maps in group */
             struct Ref ref;
-	    /* List raster maps */
 	    if (sgrp->answer) {
 		/* list subgroup files */
-	 	I_get_subgroup_ref(grp->answer, sgrp->answer, &ref);
+	 	I_get_subgroup_ref(group, sgrp->answer, &ref);
 		if(simple_flag->answer)
 		    I_list_subgroup_simple(&ref, stdout);
 		else
-		    I_list_subgroup(grp->answer, sgrp->answer, &ref, stdout);
+		    I_list_subgroup(group, sgrp->answer, &ref, stdout);
 	    else {
 		/* list group files */
-		I_get_group_ref(grp->answer, &ref);
+		I_get_group_ref(group, &ref);
 		    I_list_group_simple(&ref, stdout);
 		else
-		    I_list_group(grp->answer, &ref, stdout);
+		    I_list_group(group, &ref, stdout);
 	else {
 	    /* Create or update Group REF */
-		G_verbose_message(_("Group <%s> does not yet exist. Creating..."), grp->answer);
+		G_verbose_message(_("Group <%s> does not yet exist. Creating..."), group);
 	    if (sgrp->answer) {
-		G_verbose_message(_("Adding raster maps to group <%s>..."), grp->answer);
-		add_or_update_group(grp->answer, rast->answers, k);
+		G_verbose_message(_("Adding raster maps to group <%s>..."), group);
+		add_or_update_group(group, rast->answers, k);
 		G_verbose_message(_("Adding raster maps to subgroup <%s>..."), sgrp->answer);
-		add_or_update_subgroup(grp->answer, sgrp->answer, rast->answers, k);
+		add_or_update_subgroup(group, sgrp->answer, rast->answers, k);
 	    else {
Modified: grass/trunk/imagery/i.target/main.c
--- grass/trunk/imagery/i.target/main.c	2008-03-30 02:48:26 UTC (rev 30801)
+++ grass/trunk/imagery/i.target/main.c	2008-03-30 03:53:03 UTC (rev 30802)
@@ -36,6 +36,7 @@
     struct GModule *module;
     struct Flag *c;
     char t_mapset[GMAPSET_MAX], t_location[GMAPSET_MAX];
+    char group_name[GNAME_MAX], mapset_name[GMAPSET_MAX];
     G_gisinit (argv[0]);
@@ -67,14 +68,27 @@
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
+	- abort if not,
+    if(G__name_is_fully_qualified(group->answer, group_name, mapset_name)) {
+	if(strcmp(mapset_name, G_mapset()))
+    else {
+	strcpy(group_name, group->answer); /* FIXME for buffer overflow (have the parser check that?) */
     /* if no setting options are given, print the current target info */
     if( !c->answer && !mapset->answer && !loc->answer ) {
-        if (I_get_target (group->answer, t_location, t_mapset))
+        if (I_get_target (group_name, t_location, t_mapset))
             G_message (_("Group <%s> targeted for location [%s], mapset [%s]"),
-                        group->answer, t_location, t_mapset);
+                        group_name, t_location, t_mapset);
         else
-            G_message (_("Group <%s> has no target"), group->answer);
+            G_message (_("Group <%s> has no target"), group_name);
         exit (EXIT_SUCCESS);
@@ -87,17 +101,17 @@
     if (c->answer) {
         /* point group target to current mapset and location */
-        I_put_target(group->answer, G_location(), G_mapset());
+        I_put_target(group_name, G_location(), G_mapset());
         G_message(_("Group <%s> targeted for location [%s], mapset [%s]"),
-                group->answer, G_location(), G_mapset());
+                group_name, G_location(), G_mapset());
     } else {
         /* point group target to specified mapset and location */
 /* TODO: check if it is in current mapset and strip off @mapset part, if present */
-        I_put_target(group->answer, loc->answer, mapset->answer);
+        I_put_target(group_name, loc->answer, mapset->answer);
-                group->answer, loc->answer, mapset->answer);
+                group_name, loc->answer, mapset->answer);
     G_done_msg(" ");
