[GRASS-SVN] r30803 - grass/trunk/imagery/i.class
svn_grass at osgeo.org
Sun Mar 30 00:01:55 EDT 2008
Author: hamish
Date: 2008-03-30 00:01:55 -0400 (Sun, 30 Mar 2008)
New Revision: 30803
grass/trunk/imagery/i.class/main.c
remove @mapset part and test to see if the group is in the current mapset (trac bug #70)
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c 2008-03-30 03:53:03 UTC (rev 30802)
+++ grass/trunk/imagery/i.class/main.c 2008-03-30 04:01:55 UTC (rev 30803)
@@ -36,6 +36,8 @@
int main (int argc, char *argv[])
char *mapset;
+ char group[GNAME_MAX], grp_mapset[GMAPSET_MAX];
struct Cell_head cellhd;
struct GModule *module;
struct Option *bg_map, *img_grp, *img_subgrp, *out_sig, *in_sig;
@@ -88,9 +90,23 @@
if (G_maskfd() >= 0)
G_fatal_error (_("You have a mask set. Unset mask and run again"));
+ /* check if current mapset: (imagery libs are very lacking in this dept)
+ - abort if not,
+ - remove @mapset part if it is
+ if(G__name_is_fully_qualified(img_grp->answer, group, grp_mapset)) {
+ if(strcmp(grp_mapset, G_mapset()))
+ G_fatal_error(_("Group must exist in the current mapset"));
+ else {
+ strcpy(group, img_grp->answer); /* FIXME for buffer overflow (have the parser check that?) */
/* get group/subgroup, and signature files */
- check_files (img_grp->answer, img_subgrp->answer, out_sig->answer, in_sig->answer);
+ check_files (group, img_subgrp->answer, out_sig->answer, in_sig->answer);
/* initialize the Region structure */
init_region (Region);
