[GRASS-SVN] r30823 - in grass-addons/gipe: i.dn2potrad.l5 i.evapo.SENAY i.latitude
Mon Mar 31 00:06:12 EDT 2008
Author: ychemin
Date: 2008-03-31 00:06:12 -0400 (Mon, 31 Mar 2008)
New Revision: 30823
   grass-addons/gipe/i.dn2potrad.l5/main.c
   grass-addons/gipe/i.evapo.SENAY/main.c
   grass-addons/gipe/i.latitude/main.c
bug fixing
Modified: grass-addons/gipe/i.dn2potrad.l5/main.c
--- grass-addons/gipe/i.dn2potrad.l5/main.c	2008-03-31 02:46:04 UTC (rev 30822)
+++ grass-addons/gipe/i.dn2potrad.l5/main.c	2008-03-31 04:06:12 UTC (rev 30823)
@@ -31,12 +31,12 @@
 #define MAXFILES 7
 //sun exo-atmospheric irradiance
-#define KEXO1 1957.0
-#define KEXO2 1826.0
-#define KEXO3 1554.0
-#define KEXO4 1036.0
-#define KEXO5 215.0
-#define KEXO6 80.67
+#define KEXO1 1969.0
+#define KEXO2 1840.0
+#define KEXO3 1551.0
+#define KEXO4 1044.0
+#define KEXO5 225.7
+#define KEXO6 82.07
 #define PI 3.1415926
@@ -198,21 +198,21 @@
 		temp = year - 2000;
 	if (temp >=10){
-		snprintf(b1, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B1.tif");
-		snprintf(b2, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B2.tif");
-		snprintf(b3, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B3.tif");
-		snprintf(b4, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B4.tif");
-		snprintf(b5, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B5.tif");
-		snprintf(b6, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B6.tif");
-		snprintf(b7, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B7.tif");
+		sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B1.tif");
+		sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B2.tif");
+		sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B3.tif");
+		sprintf(b4, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B4.tif");
+		sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B5.tif");
+		sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B6.tif");
+		sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B7.tif");
 	} else {
-		snprintf(b1, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B1.tif");
-		snprintf(b2, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B2.tif");
-		snprintf(b3, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B3.tif");
-		snprintf(b4, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B4.tif");
-		snprintf(b5, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B5.tif");
-		snprintf(b6, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B6.tif");
-		snprintf(b7, 80, "%s%s%s%s%s%s%s%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B7.tif");
+		sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B1.tif");
+		sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B2.tif");
+		sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B3.tif");
+		sprintf(b4, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B4.tif");
+		sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B5.tif");
+		sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B6.tif");
+		sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B7.tif");
@@ -224,8 +224,7 @@
 	kexo[2]=KEXO3;
 	kexo[3]=KEXO4;
 	kexo[4]=KEXO5;
-	kexo[5]=KEXO6;/*filling*/
-	kexo[6]=KEXO6;
+	kexo[5]=KEXO6;
Modified: grass-addons/gipe/i.evapo.SENAY/main.c
--- grass-addons/gipe/i.evapo.SENAY/main.c	2008-03-31 02:46:04 UTC (rev 30822)
+++ grass-addons/gipe/i.evapo.SENAY/main.c	2008-03-31 04:06:12 UTC (rev 30823)
@@ -70,8 +70,8 @@
 	RASTER_MAP_TYPE data_type_aspect;
 	/* Stats for Senay equation	*/
-	double t0dem_min,t0dem_max;
-	double tempk_min,tempk_max;
+	double t0dem_min=400.0,t0dem_max=200.0;
+	double tempk_min=400.0,tempk_max=200.0;
 	G_gisinit(argv[0]);
@@ -91,9 +91,9 @@
 	input2->answer     =_("tempk");
 	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
-	input3->key        =_("tempk");
-	input3->description=_("Name of the temperature map [Degree Kelvin]");
-	input3->answer     =_("tempk");
+	input3->key        =_("dem");
+	input3->description=_("Name of the elevation map [m]");
+	input3->answer     =_("dem");
 	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input4->key        =_("lat");
@@ -316,9 +316,11 @@
 					/* do nothing */
 				} else {
 					if(d_t0dem<t0dem_min){
+					//if(d_tempk<tempk_min){
 						t0dem_min=d_t0dem;
 						tempk_min=d_tempk;
 					}else if(d_t0dem>t0dem_max){
+					//}else if(d_tempk>tempk_max){
 						t0dem_max=d_t0dem;
 						tempk_max=d_tempk;
@@ -326,6 +328,7 @@
+	G_message("tempk_min=%f\ntempk_max=%f\n",tempk_min, tempk_max);
 	/* Process pixels */
 	for (row = 0; row < nrows; row++)
Modified: grass-addons/gipe/i.latitude/main.c
--- grass-addons/gipe/i.latitude/main.c	2008-03-31 02:46:04 UTC (rev 30822)
+++ grass-addons/gipe/i.latitude/main.c	2008-03-31 04:06:12 UTC (rev 30823)
@@ -1,10 +1,10 @@
- * MODULE:       i.longitude
- * AUTHOR(S):    Yann Chemin - ychemin at gmail.com
+ * MODULE:       i.latitude
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
  * PURPOSE:      Calculates the longitude of the pixels in the map.
- * COPYRIGHT:    (C) 2002-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,7 +26,6 @@
 	int nrows, ncols;
 	int row,col;
-	int verbose=1;
 	int not_ll=0;//if proj is not lat/long, it will be 1.
 	struct GModule *module;
 	struct Option *input1, *output1;
@@ -60,8 +59,8 @@
 	G_gisinit(argv[0]);
 	module = G_define_module();
-	module->keywords = _("longitude, projection");
-	module->description = _("creates a longitude map");
+	module->keywords = _("latitude, projection");
+	module->description = _("creates a latitude map");
 	/* Define the different options */
 	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
@@ -70,20 +69,16 @@
 	input1->answer     =_("input");
 	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
-	output1->key        =_("longitude");
-	output1->description=_("Name of the output longitude layer");
-	output1->answer     =_("longitude");
+	output1->key        =_("latitude");
+	output1->description=_("Name of the output latitude layer");
+	output1->answer     =_("latitude");
-	flag1 = G_define_flag();
-	flag1->key = 'q';
-	flag1->description = _("Quiet");
 	if (G_parser(argc, argv))
 		exit (EXIT_FAILURE);
 	in	 	= input1->answer;
 	result1  	= output1->answer;
-	verbose 	= (!flag1->answer);
 	mapset = G_find_cell2(in, "");
 	if (mapset == NULL) {
@@ -136,9 +131,8 @@
 		DCELL d;
-		DCELL d_lon;
-		if(verbose)
-			G_percent(row,nrows,2);
+		DCELL d_lat;
+		G_percent(row,nrows,2);
 		if(G_get_raster_row(infd,inrast,row,data_type_inrast)<0)
 			G_fatal_error(_("Could not read from <%s>"),in);
 		for (col=0; col < ncols; col++)
@@ -152,8 +146,8 @@
 			}else{
 				//Do nothing
-			d_lon = longitude;
-			((DCELL *) outrast1)[col] = d_lon;
+			d_lat = latitude;
+			((DCELL *) outrast1)[col] = d_lat;
 		if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
 			G_fatal_error(_("Cannot write to output raster file"));
