[GRASS-SVN] r31317 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Sun May 11 08:48:50 EDT 2008
Author: martinl
Date: 2008-05-11 08:48:50 -0400 (Sun, 11 May 2008)
New Revision: 31317
grass/trunk/lib/ogsf/gsd_img_tif.c
grass/trunk/lib/ogsf/ogsflib.dox
ogsf: doxygen strings, list of public function updated (sync'ed with devbr6)
Modified: grass/trunk/lib/ogsf/gsd_img_tif.c
--- grass/trunk/lib/ogsf/gsd_img_tif.c 2008-05-11 12:47:54 UTC (rev 31316)
+++ grass/trunk/lib/ogsf/gsd_img_tif.c 2008-05-11 12:48:50 UTC (rev 31317)
@@ -30,14 +30,22 @@
#include <stdio.h>
#include <sys/types.h>
#include <grass/gis.h>
+#include <grass/gstypes.h>
+#include <grass/glocale.h>
#include "tiffio.h"
-#include <grass/gstypes.h>
unsigned short config = PLANARCONFIG_CONTIG;
unsigned short compression = -1;
unsigned short rowsperstrip = 0;
+ \brief Write data to tif file
+ \param name filename
+ \return 1 on error
+ \return 0 on success
int GS_write_tif(char *name)
TIFF *out;
@@ -51,7 +59,8 @@
out = TIFFOpen(name, "w");
if (out == NULL) {
- G_warning("Cannot open file for output.");
+ G_warning(_("Unable to open file <%s> for writing"),
+ name);
return(1);
@@ -99,11 +108,11 @@
break;
- free(pixbuf);
+ G_free((void *) pixbuf);
(void) TIFFClose(out);
return (0);
#endif /* HAVE_TIFF */
Modified: grass/trunk/lib/ogsf/ogsflib.dox
--- grass/trunk/lib/ogsf/ogsflib.dox 2008-05-11 12:47:54 UTC (rev 31316)
+++ grass/trunk/lib/ogsf/ogsflib.dox 2008-05-11 12:48:50 UTC (rev 31317)
@@ -15,8 +15,8 @@
<b>Overview</b>
<P>
-The OGSF (gsurf) library, consisting of approximately 20,000 lines of
-C code, contains some 180 public functions and about twice as many
+The OGSF (gsurf) library, consisting of approximately 27,000 lines of
+C code, contains some 250 public functions and about twice as many
internal functions for run-time data storage, manipulation, querying,
and visualization using OpenGL. The library handles all drawing and
lighting operations, including use of user-defined clipping planes and
@@ -24,7 +24,7 @@
multiple surfaces, and treats datasets as objects which can be used
for various attributes of the rendering. It allows data sharing
(%e.g., same data for more than one attribute of same or different
-surfaces) , separate masking for each surface, multiple surfaces,
+surfaces), separate masking for each surface, multiple surfaces,
%vector sets, or %point sets, and will also allow multiple volumes. The
library provides all query features such as 3D "point on surface",
keyframe animation routines, and full state saving functionality.
@@ -123,107 +123,125 @@
Also functions for library initialization, setting global variables,
viewer positioning, and lighting.
-GS_Get_ClientData()
+GS_alldraw_cplane_fences()
-GS_P2distance ()
+GS_alldraw_surf()
-GS_Set_ClientData()
+GS_alldraw_wire()
-GS_alldraw_cplane_fences()
+GS_check_cancel()
-GS_alldraw_surf()
+GS_clear()
-GS_alldraw_wire()
+GS_coordpair_repeats()
-GS_background_color()
+GS_delete_list()
-GS_check_cancel()
+GS_delete_surface()
-GS_clear(int col)
+GS_distance()
-GS_default_draw_color()
+GS_done_draw()
-GS_delete_surface(int id)
+GS_draw_all_list()
-GS_distance ()
+GS_draw_cplane()
-GS_done_draw()
+GS_draw_cplane_fence()
-GS_draw_X()
+GS_draw_flowline_at_xy()
-GS_draw_cplane()
+GS_draw_fringe()
-GS_draw_cplane_fence()
+GS_draw_legend()
-GS_draw_lighting_model()
+GS_draw_lighting_model()
-GS_draw_line_onsurf()
+GS_draw_lighting_model1()
-GS_draw_surf(int id)
+GS_draw_line_onsurf()
-GS_draw_wire(int id)
+GS_draw_list()
-GS_dv3norm()
+GS_draw_nline_onsurf()
-GS_geodistance()
+GS_draw_surf()
-GS_get_SDscale()
+GS_draw_wire()
-GS_get_SDsurf()
+GS_draw_X()
-GS_get_aspect()
+GS_dv3norm()
-GS_get_att()
+GS_geodistance()
-GS_get_cat_at_xy()
+GS_get_aspect()
-GS_get_dims()
+GS_get_att()
+GS_get_cat_at_xy()
+GS_get_dims()
GS_get_distance_alongsurf()
-GS_get_drawmode()
+GS_get_drawmode()
-GS_get_drawres()
+GS_get_drawres()
-GS_get_exag_guess()
+GS_get_exag_guess()
-GS_get_fencecolor()
+GS_get_fencecolor()
-GS_get_focus()
+GS_get_focus()
GS_get_fov()
-GS_get_from()
+GS_get_from()
-GS_get_from_real()
+GS_get_from_real()
-GS_get_longdim()
+GS_getlight_ambient()
-GS_get_maskmode()
+GS_getlight_color()
-GS_get_modelposition()
+GS_getlight_position()
-GS_get_nozero()
+GS_get_longdim()
-GS_get_region()
+GS_get_maskmode()
-GS_get_scale()
+GS_get_modelposition()
+GS_get_modelposition1()
+GS_get_norm_at_xy()
+GS_get_nozero()
+GS_get_region()
+GS_get_scale()
+GS_get_SDscale()
+GS_get_SDsurf()
GS_get_selected_point_on_surface()
-GS_get_surf_list()
+GS_get_to()
-GS_get_to()
+GS_get_to_real()
-GS_get_trans()
+GS_get_trans()
-GS_get_twist()
+GS_get_twist()
GS_get_val_at_xy()
-GS_get_viewdir()
+GS_get_viewdir()
-GS_get_wire_color()
+GS_get_wire_color()
GS_get_zextents()
@@ -231,122 +249,134 @@
GS_get_zrange_nz()
-GS_global_exag()
+GS_global_exag()
-GS_has_transparency()
+GS_has_transparency()
-GS_init_view()
+GS_init_view()
-GS_is_masked()
+GS_is_masked()
-GS_libinit()
+GS_libinit()
-GS_lights_off()
+GS_lights_off()
-GS_lights_on()
+GS_lights_on()
-GS_load_3dview()
+GS_load_3dview()
-GS_load_att_map()
+GS_load_att_map()
GS_look_here()
-GS_moveto()
+GS_moveto()
-GS_moveto_real()
+GS_moveto_real()
-GS_new_light()
+GS_new_light()
-GS_new_surface()
+GS_new_surface()
-GS_num_surfs()
+GS_num_surfs()
-GS_ready_draw()
+GS_P2distance()
-GS_save_3dview()
+GS_ready_draw()
-GS_set_SDscale()
+GS_save_3dview()
-GS_set_SDsurf()
+GS_setall_drawmode()
-GS_set_att_const()
+GS_setall_drawres()
-GS_set_att_defaults()
+GS_set_att_const()
-GS_set_cancel()
+GS_set_att_defaults()
-GS_set_cplane()
+GS_set_cancel()
-GS_set_cplane_rot()
+GS_Set_ClientData()
+GS_set_cplane()
+GS_set_cplane_rot()
GS_set_cplane_trans()
GS_set_cxl_func()
GS_set_draw()
-GS_set_drawmode()
+GS_set_drawmode()
-GS_set_drawres()
+GS_set_drawres()
-GS_set_exag()
+GS_set_exag()
-GS_set_fencecolor()
+GS_set_fencecolor()
-GS_set_focus()
+GS_set_focus()
-GS_set_focus_center_map()
+GS_set_focus_center_map()
-GS_set_fov()
+GS_set_focus_real()
-GS_set_global_exag()
+GS_set_fov()
-GS_set_maskmode()
+GS_set_global_exag()
-GS_set_nofocus()
+GS_set_infocus()
-GS_set_nozero()
+GS_setlight_ambient()
-GS_set_swap_func()
+GS_setlight_color()
-GS_set_trans()
+GS_setlight_position()
-GS_set_twist()
+GS_set_maskmode()
-GS_set_viewdir()
+GS_set_Narrow()
-GS_set_viewport()
+GS_set_nofocus()
-GS_set_wire_color(int id, int colr)
+GS_set_nozero()
-GS_setall_drawmode(int mode)
+GS_set_SDscale()
-GS_setall_drawres()
+GS_set_SDsurf()
-GS_setlight_ambient()
+GS_set_swap_func()
-GS_setlight_color()
+GS_set_trans()
-GS_setlight_position()
+GS_set_twist()
+GS_set_viewdir()
+GS_set_viewport()
+GS_set_wire_color()
GS_surf_exists()
GS_switchlight()
-GS_transp_is_set()
+GS_transp_is_set()
-GS_unset_SDsurf()
GS_unset_att()
GS_unset_cplane()
+GS_unset_SDsurf()
GS_update_curmask()
GS_update_normals()
GS_v2dir()
+GS_v2norm()
GS_v3add()
GS_v3cross()
@@ -365,17 +395,21 @@
GS_v3sub()
+GS_write_ppm()
+GS_write_tif()
+GS_write_zoom()
+GS_zoom_setup()
\subsection gv_vect Loading and manipulation of vector maps (GV)
Functions which have to do with loading & manipulating %vector
sets.
-GV_Get_ClientData()
+GV_alldraw_vect()
-GV_Set_ClientData()
-GV_alldraw_vect()
GV_delete_vector()
GV_draw_fastvect()
@@ -384,20 +418,20 @@
GV_get_trans()
-GV_get_vect_list()
GV_get_vectmode()
GV_get_vectname()
GV_load_vector()
-GV_new_vector()
+GV_new_vector()
-GV_num_vects()
+GV_num_vects()
GV_select_surf()
+GV_Set_ClientData()
GV_set_trans()
GV_set_vectmode()
@@ -412,12 +446,8 @@
Functions which have to do with loading & manipulating %point sets.
-GP_Get_ClientData()
+GP_alldraw_site()
-GP_Set_ClientData()
-GP_alldraw_site()
GP_attmode_color()
GP_attmode_none()
@@ -426,8 +456,6 @@
GP_draw_site()
-GP_get_site_list()
GP_get_sitemode()
GP_get_sitename()
@@ -438,12 +466,14 @@
GP_load_site()
-GP_new_site()
+GP_new_site()
-GP_num_sites()
+GP_num_sites()
GP_select_surf()
+GP_Set_ClientData()
GP_set_sitemode()
GP_set_trans()
@@ -471,62 +501,138 @@
GK_move_key()
+GK_print_keys()
GK_set_interpmode()
GK_set_numsteps()
GK_set_tension()
+GK_show_list()
GK_show_path()
-GK_show_site()
+GK_show_site()
-GK_show_vect()
+GK_showtension_start()
-GK_showtension_start()
GK_showtension_stop()
+GK_show_vect()
+GK_show_vol()
GK_update_frames()
-GK_update_tension()
+GK_update_tension()
\subsection gvl_volume Loading and manipulation of volume maps (GVL)
Functions which have to do with loading & manipulating 3D volumes.
-GVL_Get_ClientData()
+GVL_alldraw_vol()
-GVL_Set_ClientData()
+GVL_alldraw_wire()
-GVL_alldraw_vol()
+GVL_delete_vol()
-GVL_delete_volume()
+GVL_draw_vol()
-GVL_draw_fastvol()
+GVL_draw_wire()
-GVL_draw_vol()
+GVL_get_dims()
+GVL_get_region()
GVL_get_trans()
-GVL_get_vol_list()
+GVL_get_volname()
-GVL_get_volmode()
+GVL_libinit()
-GVL_get_volname()
+GVL_load_vol()
-GVL_load_volume()
+GVL_new_vol()
-GVL_new_vol()
+GVL_num_vols()
-GVL_num_vol()
+GVL_Set_ClientData()
+GVL_set_focus_center_map()
GVL_set_trans()
-GVL_set_volmode()
GVL_vol_exists()
+\subsection gvl_volume_isosurf Loading and manipulation of isosurfaces (GVL)
+Functions which have to do with loading & manipulating isosurfaces.
+GVL_isosurf_add()
+GVL_isosurf_del()
+GVL_isosurf_get_att()
+GVL_isosurf_get_drawmode()
+GVL_isosurf_get_drawres()
+GVL_isosurf_get_flags()
+GVL_isosurf_get_maskmode()
+GVL_isosurf_move_down()
+GVL_isosurf_move_up()
+GVL_isosurf_num_isosurfs()
+GVL_isosurf_set_att_const()
+GVL_isosurf_set_att_map()
+GVL_isosurf_set_drawmode()
+GVL_isosurf_set_drawres()
+GVL_isosurf_set_flags()
+GVL_isosurf_set_maskmode()
+GVL_isosurf_unset_att()
+\subsection gvl_volume_slice Loading and manipulation of slices (GVL)
+Functions which have to do with loading & manipulating slices.
+GVL_slice_add()
+GVL_slice_del()
+GVL_slice_get_drawmode()
+GVL_slice_get_drawres()
+GVL_slice_get_pos()
+GVL_slice_get_transp()
+GVL_slice_move_down()
+GVL_slice_move_up()
+GVL_slice_num_slices()
+GVL_slice_set_drawmode()
+GVL_slice_set_drawres()
+GVL_slice_set_pos()
+GVL_slice_set_transp()
\subsection gsurf_h Public include file gsurf.h
See include/gsurf.h
