[GRASS-SVN] r31318 - grass/trunk
svn_grass at osgeo.org
Sun May 11 15:16:33 EDT 2008
Author: glynn
Date: 2008-05-11 15:16:33 -0400 (Sun, 11 May 2008)
New Revision: 31318
grass/trunk/aclocal.m4
grass/trunk/configure
grass/trunk/configure.in
Replace autoconf's broken AC_EXEEXT with LOC_EXEEXT
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2008-05-11 12:48:50 UTC (rev 31317)
+++ grass/trunk/aclocal.m4 2008-05-11 19:16:33 UTC (rev 31318)
@@ -259,6 +259,23 @@
AC_DEFUN([LOC_MSG_USE],[
[echo " $1:]LOC_PAD_26($1)`LOC_YES_NO($2)`"])
+AC_DEFUN(LOC_EXEEXT,
+[AC_REQUIRE([AC_CYGWIN])
+AC_REQUIRE([AC_MINGW32])
+AC_MSG_CHECKING([for executable suffix])
+AC_CACHE_VAL(ac_cv_exeext,
+[if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
+ ac_cv_exeext=.exe
+else
+ ac_cv_exeext=no
+fi])
+EXEEXT=""
+test x"${ac_cv_exeext}" != xno && EXEEXT=${ac_cv_exeext}
+AC_MSG_RESULT(${ac_cv_exeext})
+dnl Setting ac_exeext will implicitly change the ac_link command.
+ac_exeext=$EXEEXT
+AC_SUBST(EXEEXT)])
# SC_ENABLE_SHARED --
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-05-11 12:48:50 UTC (rev 31317)
+++ grass/trunk/configure 2008-05-11 19:16:33 UTC (rev 31318)
@@ -1012,21 +1012,7 @@
ac_cv_exeext=.exe
else
- rm -f conftest*
- echo 'int main () { return 0; }' > conftest.$ac_ext
- ac_cv_exeext=
- if { (eval echo configure:1019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
- for file in conftest.*; do
- case $file in
- *.$ac_ext | *.c | *.o | *.obj) ;;
- *) ac_cv_exeext=`echo $file | sed -e s/conftest//` ;;
- esac
- done
- else
- { echo "configure: error: installation or configuration problem: compiler cannot create executables." 1>&2; exit 1; }
- fi
- rm -f conftest*
- test x"${ac_cv_exeext}" = x && ac_cv_exeext=no
+ ac_cv_exeext=no
fi
EXEEXT=""
@@ -1040,23 +1026,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1044: checking for full floating-point support" >&5
+echo "configure:1030: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1049: checking whether "cc -mieee" works" >&5
+echo "configure:1035: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
cat > conftest.$ac_ext <<EOF
-#line 1053 "configure"
+#line 1039 "configure"
#include "confdefs.h"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1046: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1072,7 +1058,7 @@
else
-#line 1076 "configure"
+#line 1062 "configure"
#include <float.h>
@@ -1086,7 +1072,7 @@
EOF
-if { (eval echo configure:1090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1099,14 +1085,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1103: checking for full floating-point support with -mieee" >&5
+echo "configure:1089: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1110 "configure"
+#line 1096 "configure"
#include <float.h>
@@ -1120,7 +1106,7 @@
EOF
-if { (eval echo configure:1124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1157,7 +1143,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1161: checking for $ac_word" >&5
+echo "configure:1147: checking for $ac_word" >&5
case "$pwd" in
@@ -1195,7 +1181,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1199: checking for source directory" >&5
+echo "configure:1185: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1206,7 +1192,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1210: checking for build directory" >&5
+echo "configure:1196: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1269,7 +1255,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1273: checking for MacOSX App" >&5
+echo "configure:1259: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1292,7 +1278,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1296: checking how to build libraries" >&5
+echo "configure:1282: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1335,7 +1321,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1339: checking for $ac_word" >&5
+echo "configure:1325: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1360,7 +1346,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1364: checking how to run the C preprocessor" >&5
+echo "configure:1350: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1373,13 +1359,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1377 "configure"
+#line 1363 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1383: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1390,13 +1376,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1394 "configure"
+#line 1380 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1400: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1386: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1407,13 +1393,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1411 "configure"
+#line 1397 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1441,7 +1427,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1445: checking if 64bit support is requested" >&5
+echo "configure:1431: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1461,7 +1447,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1465: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1451: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1485,7 +1471,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1489: checking system version (for dynamic loading)" >&5
+echo "configure:1475: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1511,13 +1497,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1515: checking for dlopen in -ldl" >&5
+echo "configure:1501: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1521 "configure"
+#line 1507 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1528,7 +1514,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1575,7 +1561,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1579: checking for $ac_word" >&5
+echo "configure:1565: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1704,13 +1690,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1708: checking for gettimeofday in -lbsd" >&5
+echo "configure:1694: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1714 "configure"
+#line 1700 "configure"
@@ -1721,7 +1707,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1762,13 +1748,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1766: checking for inet_ntoa in -lbind" >&5
+echo "configure:1752: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1772 "configure"
+#line 1758 "configure"
@@ -1779,7 +1765,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1840,13 +1826,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1844: checking for shl_load in -ldld" >&5
+echo "configure:1830: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1850 "configure"
+#line 1836 "configure"
@@ -1857,7 +1843,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1922,13 +1908,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1926: checking for shl_load in -ldld" >&5
+echo "configure:1912: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1932 "configure"
+#line 1918 "configure"
@@ -1939,7 +1925,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2061,15 +2047,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2065: checking for dld.h" >&5
+echo "configure:2051: checking for dld.h" >&5
-#line 2068 "configure"
+#line 2054 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2129,15 +2115,15 @@
else
-echo "configure:2133: checking for dld.h" >&5
+echo "configure:2119: checking for dld.h" >&5
-#line 2136 "configure"
+#line 2122 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2127: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2234,9 +2220,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2238: checking for ELF" >&5
+echo "configure:2224: checking for ELF" >&5
-#line 2240 "configure"
+#line 2226 "configure"
#ifdef __ELF__
@@ -2266,15 +2252,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2270: checking for dlfcn.h" >&5
+echo "configure:2256: checking for dlfcn.h" >&5
-#line 2273 "configure"
+#line 2259 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2298,9 +2284,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2302: checking for ELF" >&5
+echo "configure:2288: checking for ELF" >&5
-#line 2304 "configure"
+#line 2290 "configure"
#ifdef __ELF__
@@ -2624,17 +2610,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2628: checking for ld accepts -Bexport flag" >&5
+echo "configure:2614: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2631 "configure"
+#line 2617 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3379,7 +3365,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3383: checking for additional include dirs" >&5
+echo "configure:3369: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3402,7 +3388,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3406: checking for additional library dirs" >&5
+echo "configure:3392: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3436,7 +3422,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3440: checking for a BSD compatible install" >&5
+echo "configure:3426: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3489,7 +3475,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3493: checking for $ac_word" >&5
+echo "configure:3479: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3520,13 +3506,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3524: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3510: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3530 "configure"
+#line 3516 "configure"
@@ -3537,7 +3523,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3562,7 +3548,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3566: checking for $ac_word" >&5
+echo "configure:3552: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3602,7 +3588,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3606: checking for $ac_word" >&5
+echo "configure:3592: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3633,7 +3619,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3637: checking for $ac_word" >&5
+echo "configure:3623: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3671,7 +3657,7 @@
-echo "configure:3675: checking for $ac_word" >&5
+echo "configure:3661: checking for $ac_word" >&5
@@ -3700,7 +3686,7 @@
-echo "configure:3704: checking for $ac_word" >&5
+echo "configure:3690: checking for $ac_word" >&5
@@ -3731,7 +3717,7 @@
-echo "configure:3735: checking for $ac_word" >&5
+echo "configure:3721: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3760,7 +3746,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3764: checking for $ac_word" >&5
+echo "configure:3750: checking for $ac_word" >&5
case "$PERL" in
@@ -3791,10 +3777,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3795: checking for ANSI C header files" >&5
+echo "configure:3781: checking for ANSI C header files" >&5
-#line 3798 "configure"
+#line 3784 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3802,7 +3788,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3819,7 +3805,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3823 "configure"
+#line 3809 "configure"
#include <string.h>
EOF
@@ -3837,7 +3823,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3841 "configure"
+#line 3827 "configure"
#include <stdlib.h>
EOF
@@ -3858,7 +3844,7 @@
else
-#line 3862 "configure"
+#line 3848 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3869,7 +3855,7 @@
exit (0); }
EOF
-if { (eval echo configure:3873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3896,15 +3882,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3900: checking for $ac_hdr" >&5
+echo "configure:3886: checking for $ac_hdr" >&5
-#line 3903 "configure"
+#line 3889 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3933,15 +3919,15 @@
do
-echo "configure:3937: checking for $ac_hdr" >&5
+echo "configure:3923: checking for $ac_hdr" >&5
-#line 3940 "configure"
+#line 3926 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3945: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3970,15 +3956,15 @@
do
-echo "configure:3974: checking for $ac_hdr" >&5
+echo "configure:3960: checking for $ac_hdr" >&5
-#line 3977 "configure"
+#line 3963 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3982: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3968: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4007,15 +3993,15 @@
do
-echo "configure:4011: checking for $ac_hdr" >&5
+echo "configure:3997: checking for $ac_hdr" >&5
-#line 4014 "configure"
+#line 4000 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4044,15 +4030,15 @@
do
-echo "configure:4048: checking for $ac_hdr" >&5
+echo "configure:4034: checking for $ac_hdr" >&5
-#line 4051 "configure"
+#line 4037 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4056: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4078,10 +4064,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4082: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4068: checking whether time.h and sys/time.h may both be included" >&5
-#line 4085 "configure"
+#line 4071 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4090,7 +4076,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4094: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4110,10 +4096,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4114: checking for off_t" >&5
+echo "configure:4100: checking for off_t" >&5
-#line 4117 "configure"
+#line 4103 "configure"
#if STDC_HEADERS
@@ -4140,10 +4126,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4144: checking for uid_t in sys/types.h" >&5
+echo "configure:4130: checking for uid_t in sys/types.h" >&5
-#line 4147 "configure"
+#line 4133 "configure"
EOF
@@ -4171,10 +4157,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4175: checking return type of signal handlers" >&5
+echo "configure:4161: checking return type of signal handlers" >&5
-#line 4178 "configure"
+#line 4164 "configure"
#include <signal.h>
@@ -4191,7 +4177,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4195: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4181: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4209,10 +4195,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4213: checking for Cygwin environment" >&5
+echo "configure:4199: checking for Cygwin environment" >&5
-#line 4216 "configure"
+#line 4202 "configure"
int main() {
@@ -4223,7 +4209,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4227: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4241,10 +4227,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4245: checking for $ac_func" >&5
+echo "configure:4231: checking for $ac_func" >&5
-#line 4248 "configure"
+#line 4234 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4267,7 +4253,7 @@
; return 0; }
EOF
-if { (eval echo configure:4271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4293,10 +4279,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4297: checking for $ac_func" >&5
+echo "configure:4283: checking for $ac_func" >&5
-#line 4300 "configure"
+#line 4286 "configure"
@@ -4319,7 +4305,7 @@
; return 0; }
EOF
-if { (eval echo configure:4323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4345,10 +4331,10 @@
for ac_func in drand48
do
-echo "configure:4349: checking for $ac_func" >&5
+echo "configure:4335: checking for $ac_func" >&5
-#line 4352 "configure"
+#line 4338 "configure"
@@ -4371,7 +4357,7 @@
; return 0; }
EOF
-if { (eval echo configure:4375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4397,10 +4383,10 @@
for ac_func in putenv setenv
do
-echo "configure:4401: checking for $ac_func" >&5
+echo "configure:4387: checking for $ac_func" >&5
-#line 4404 "configure"
+#line 4390 "configure"
@@ -4423,7 +4409,7 @@
; return 0; }
EOF
-if { (eval echo configure:4427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4449,10 +4435,10 @@
for ac_func in nanosleep
do
-echo "configure:4453: checking for $ac_func" >&5
+echo "configure:4439: checking for $ac_func" >&5
-#line 4456 "configure"
+#line 4442 "configure"
@@ -4475,7 +4461,7 @@
; return 0; }
EOF
-if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4500,13 +4486,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4504: checking whether setpgrp takes no argument" >&5
+echo "configure:4490: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4510 "configure"
+#line 4496 "configure"
#ifdef HAVE_UNISTD_H
@@ -4526,7 +4512,7 @@
EOF
-if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4554,16 +4540,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4558: checking for long long int" >&5
+echo "configure:4544: checking for long long int" >&5
-#line 4560 "configure"
+#line 4546 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4567: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4553: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4583,7 +4569,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4587: checking for W11" >&5
+echo "configure:4573: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4611,7 +4597,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4615: checking for X" >&5
+echo "configure:4601: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4671,12 +4657,12 @@
# First, try using that file with no special directory specified.
-#line 4675 "configure"
+#line 4661 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4745,14 +4731,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4749 "configure"
+#line 4735 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4857,17 +4843,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4861: checking whether -R must be followed by a space" >&5
+echo "configure:4847: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4864 "configure"
+#line 4850 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4883,14 +4869,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4887 "configure"
+#line 4873 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4922,13 +4908,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4926: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4912: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4932 "configure"
+#line 4918 "configure"
@@ -4939,7 +4925,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4960,13 +4946,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4964: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4950: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4970 "configure"
+#line 4956 "configure"
@@ -4977,7 +4963,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5005,10 +4991,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5009: checking for gethostbyname" >&5
+echo "configure:4995: checking for gethostbyname" >&5
-#line 5012 "configure"
+#line 4998 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5031,7 +5017,7 @@
; return 0; }
EOF
-if { (eval echo configure:5035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5051,13 +5037,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5055: checking for gethostbyname in -lnsl" >&5
+echo "configure:5041: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5061 "configure"
+#line 5047 "configure"
@@ -5068,7 +5054,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5097,10 +5083,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5101: checking for connect" >&5
+echo "configure:5087: checking for connect" >&5
-#line 5104 "configure"
+#line 5090 "configure"
which can conflict with char connect(); below. */
@@ -5123,7 +5109,7 @@
; return 0; }
EOF
-if { (eval echo configure:5127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5143,13 +5129,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5147: checking for connect in -lsocket" >&5
+echo "configure:5133: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5153 "configure"
+#line 5139 "configure"
@@ -5160,7 +5146,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5183,10 +5169,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5187: checking for remove" >&5
+echo "configure:5173: checking for remove" >&5
-#line 5190 "configure"
+#line 5176 "configure"
which can conflict with char remove(); below. */
@@ -5209,7 +5195,7 @@
; return 0; }
EOF
-if { (eval echo configure:5213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5229,13 +5215,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5233: checking for remove in -lposix" >&5
+echo "configure:5219: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5239 "configure"
+#line 5225 "configure"
@@ -5246,7 +5232,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5269,10 +5255,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5273: checking for shmat" >&5
+echo "configure:5259: checking for shmat" >&5
-#line 5276 "configure"
+#line 5262 "configure"
which can conflict with char shmat(); below. */
@@ -5295,7 +5281,7 @@
; return 0; }
EOF
-if { (eval echo configure:5299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5315,13 +5301,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5319: checking for shmat in -lipc" >&5
+echo "configure:5305: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5325 "configure"
+#line 5311 "configure"
@@ -5332,7 +5318,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5364,13 +5350,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5368: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5354: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5374 "configure"
+#line 5360 "configure"
@@ -5381,7 +5367,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5419,7 +5405,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5423: checking whether to use Curses" >&5
+echo "configure:5409: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5438,15 +5424,15 @@
do
-echo "configure:5442: checking for $ac_hdr" >&5
+echo "configure:5428: checking for $ac_hdr" >&5
-#line 5445 "configure"
+#line 5431 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5477,10 +5463,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5481: checking curses.h WINDOW structure component" >&5
+echo "configure:5467: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5484 "configure"
+#line 5470 "configure"
#include <curses.h>
@@ -5489,7 +5475,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5493: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5479: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5498,7 +5484,7 @@
fi
rm -f conftest*
-#line 5502 "configure"
+#line 5488 "configure"
#include <curses.h>
@@ -5507,7 +5493,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5497: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5523,13 +5509,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5527: checking for initscr in -lncurses" >&5
+echo "configure:5513: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5533 "configure"
+#line 5519 "configure"
@@ -5540,7 +5526,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5559,13 +5545,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5563: checking for initscr in -lcurses" >&5
+echo "configure:5549: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5569 "configure"
+#line 5555 "configure"
@@ -5576,7 +5562,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5605,13 +5591,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5609: checking for keypad in -lncurses" >&5
+echo "configure:5595: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5615 "configure"
+#line 5601 "configure"
@@ -5622,7 +5608,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5644,13 +5630,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5648: checking for keypad in -lcurses" >&5
+echo "configure:5634: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5654 "configure"
+#line 5640 "configure"
@@ -5661,7 +5647,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5691,13 +5677,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5695: checking for gtty in -lcompat" >&5
+echo "configure:5681: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5701 "configure"
+#line 5687 "configure"
@@ -5708,7 +5694,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5727,13 +5713,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5731: checking for gtty in -lbsd-compat" >&5
+echo "configure:5717: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5737 "configure"
+#line 5723 "configure"
@@ -5744,7 +5730,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5763,13 +5749,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5767: checking for gtty in -lbsd" >&5
+echo "configure:5753: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5773 "configure"
+#line 5759 "configure"
@@ -5780,7 +5766,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5814,12 +5800,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5818: checking for library containing cuserid" >&5
+echo "configure:5804: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5823 "configure"
+#line 5809 "configure"
@@ -5830,7 +5816,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5841,7 +5827,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5845 "configure"
+#line 5831 "configure"
@@ -5852,7 +5838,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5878,10 +5864,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5882: checking for xdrmem_create" >&5
+echo "configure:5868: checking for xdrmem_create" >&5
-#line 5885 "configure"
+#line 5871 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5904,7 +5890,7 @@
; return 0; }
EOF
-if { (eval echo configure:5908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5922,13 +5908,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5926: checking for xdrmem_create in -lsun" >&5
+echo "configure:5912: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5932 "configure"
+#line 5918 "configure"
@@ -5939,7 +5925,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5958,13 +5944,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5962: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5948: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5968 "configure"
+#line 5954 "configure"
@@ -5975,7 +5961,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5994,13 +5980,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5998: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5984: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6004 "configure"
+#line 5990 "configure"
@@ -6011,7 +5997,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6030,13 +6016,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6034: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6020: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6040 "configure"
+#line 6026 "configure"
@@ -6047,7 +6033,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6081,10 +6067,10 @@
for ac_func in asprintf
do
-echo "configure:6085: checking for $ac_func" >&5
+echo "configure:6071: checking for $ac_func" >&5
-#line 6088 "configure"
+#line 6074 "configure"
@@ -6107,7 +6093,7 @@
; return 0; }
EOF
-if { (eval echo configure:6111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6134,10 +6120,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6138: checking for atan" >&5
+echo "configure:6124: checking for atan" >&5
-#line 6141 "configure"
+#line 6127 "configure"
which can conflict with char atan(); below. */
@@ -6160,7 +6146,7 @@
; return 0; }
EOF
-if { (eval echo configure:6164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6178,13 +6164,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6182: checking for atan in -lm" >&5
+echo "configure:6168: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6188 "configure"
+#line 6174 "configure"
@@ -6195,7 +6181,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6222,10 +6208,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6226: checking for dlsym" >&5
+echo "configure:6212: checking for dlsym" >&5
-#line 6229 "configure"
+#line 6215 "configure"
which can conflict with char dlsym(); below. */
@@ -6248,7 +6234,7 @@
; return 0; }
EOF
-if { (eval echo configure:6252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6266,13 +6252,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6270: checking for dlsym in -ldl" >&5
+echo "configure:6256: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6276 "configure"
+#line 6262 "configure"
@@ -6283,7 +6269,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6310,10 +6296,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6314: checking for iconv" >&5
+echo "configure:6300: checking for iconv" >&5
-#line 6317 "configure"
+#line 6303 "configure"
which can conflict with char iconv(); below. */
@@ -6336,7 +6322,7 @@
; return 0; }
EOF
-if { (eval echo configure:6340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6354,13 +6340,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6358: checking for iconv in -liconv" >&5
+echo "configure:6344: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6364 "configure"
+#line 6350 "configure"
@@ -6371,7 +6357,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6390,13 +6376,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6394: checking for iconv in -lgiconv" >&5
+echo "configure:6380: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6400 "configure"
+#line 6386 "configure"
@@ -6407,7 +6393,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6426,10 +6412,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6430: checking for libiconv" >&5
+echo "configure:6416: checking for libiconv" >&5
-#line 6433 "configure"
+#line 6419 "configure"
which can conflict with char libiconv(); below. */
@@ -6452,7 +6438,7 @@
; return 0; }
EOF
-if { (eval echo configure:6456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6470,13 +6456,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6474: checking for libiconv in -liconv" >&5
+echo "configure:6460: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6480 "configure"
+#line 6466 "configure"
@@ -6487,7 +6473,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6506,13 +6492,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6510: checking for libiconv in -lgiconv" >&5
+echo "configure:6496: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6516 "configure"
+#line 6502 "configure"
@@ -6523,7 +6509,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6560,10 +6546,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6564: checking for socket" >&5
+echo "configure:6550: checking for socket" >&5
-#line 6567 "configure"
+#line 6553 "configure"
which can conflict with char socket(); below. */
@@ -6586,7 +6572,7 @@
; return 0; }
EOF
-if { (eval echo configure:6590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6604,13 +6590,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6608: checking for socket in -lsocket" >&5
+echo "configure:6594: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6614 "configure"
+#line 6600 "configure"
@@ -6621,7 +6607,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6669,7 +6655,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6673: checking for location of zlib includes" >&5
+echo "configure:6659: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6695,15 +6681,15 @@
do
-echo "configure:6699: checking for $ac_hdr" >&5
+echo "configure:6685: checking for $ac_hdr" >&5
-#line 6702 "configure"
+#line 6688 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6737,7 +6723,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6741: checking for location of zlib library" >&5
+echo "configure:6727: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6762,13 +6748,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6766: checking for deflate in -lz" >&5
+echo "configure:6752: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6772 "configure"
+#line 6758 "configure"
@@ -6779,7 +6765,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6827,7 +6813,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6831: checking for location of External PROJ.4 includes" >&5
+echo "configure:6817: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6853,15 +6839,15 @@
do
-echo "configure:6857: checking for $ac_hdr" >&5
+echo "configure:6843: checking for $ac_hdr" >&5
-#line 6860 "configure"
+#line 6846 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6898,7 +6884,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6902: checking External PROJ.4 version" >&5
+echo "configure:6888: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6906,7 +6892,7 @@
else
-#line 6910 "configure"
+#line 6896 "configure"
#include <stdio.h>
@@ -6918,7 +6904,7 @@
EOF
-if { (eval echo configure:6922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6943,7 +6929,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6947: checking for location of External PROJ.4 library" >&5
+echo "configure:6933: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6968,13 +6954,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6972: checking for pj_get_def in -lproj" >&5
+echo "configure:6958: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6978 "configure"
+#line 6964 "configure"
@@ -6985,7 +6971,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7019,7 +7005,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7023: checking for location of External PROJ.4 data files" >&5
+echo "configure:7009: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7043,14 +7029,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7047: checking for epsg" >&5
+echo "configure:7033: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7054: checking for $PROJSHARE/epsg" >&5
+echo "configure:7040: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7082,7 +7068,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:7086: checking for $ac_word" >&5
+echo "configure:7072: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7122,7 +7108,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7126: checking whether to use Readline" >&5
+echo "configure:7112: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7143,7 +7129,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7147: checking for location of Readline includes" >&5
+echo "configure:7133: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7169,15 +7155,15 @@
do
-echo "configure:7173: checking for $ac_hdr" >&5
+echo "configure:7159: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 7176 "configure"
+#line 7162 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7213,15 +7199,15 @@
do
-echo "configure:7217: checking for $ac_hdr" >&5
+echo "configure:7203: checking for $ac_hdr" >&5
-#line 7220 "configure"
+#line 7206 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7255,7 +7241,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7259: checking for location of Readline library" >&5
+echo "configure:7245: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7280,13 +7266,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7284: checking for readline in -lreadline" >&5
+echo "configure:7270: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7290 "configure"
+#line 7276 "configure"
@@ -7297,7 +7283,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7332,13 +7318,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7336: checking for add_history in -lhistory" >&5
+echo "configure:7322: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7342 "configure"
+#line 7328 "configure"
@@ -7349,7 +7335,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7392,7 +7378,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7396: checking whether to use JPEG" >&5
+echo "configure:7382: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7412,7 +7398,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7416: checking for location of JPEG includes" >&5
+echo "configure:7402: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7438,15 +7424,15 @@
do
-echo "configure:7442: checking for $ac_hdr" >&5
+echo "configure:7428: checking for $ac_hdr" >&5
-#line 7445 "configure"
+#line 7431 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7480,7 +7466,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7484: checking for location of JPEG library" >&5
+echo "configure:7470: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7507,13 +7493,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7511: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7497: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7517 "configure"
+#line 7503 "configure"
@@ -7524,7 +7510,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7543,13 +7529,13 @@
-echo "configure:7547: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7533: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7553 "configure"
+#line 7539 "configure"
@@ -7560,7 +7546,7 @@
; return 0; }
EOF
-if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7609,7 +7595,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7613: checking whether to use GDAL" >&5
+echo "configure:7599: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7622,7 +7608,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7626: checking for $ac_word" >&5
+echo "configure:7612: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7680,10 +7666,10 @@
ac_save_libs="$LIBS"
LIBS="$LIBS $GDAL_LIBS"
echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7684: checking for GDALOpen" >&5
+echo "configure:7670: checking for GDALOpen" >&5
-#line 7687 "configure"
+#line 7673 "configure"
which can conflict with char GDALOpen(); below. */
@@ -7706,7 +7692,7 @@
; return 0; }
EOF
-if { (eval echo configure:7710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GDALOpen=yes"
else
@@ -7725,10 +7711,10 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7729: checking for GDALOpen" >&5
+echo "configure:7715: checking for GDALOpen" >&5
-#line 7732 "configure"
+#line 7718 "configure"
@@ -7751,7 +7737,7 @@
; return 0; }
EOF
-if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7787,7 +7773,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7791: checking whether to use TIFF" >&5
+echo "configure:7777: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7807,7 +7793,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7811: checking for location of TIFF includes" >&5
+echo "configure:7797: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7833,15 +7819,15 @@
do
-echo "configure:7837: checking for $ac_hdr" >&5
+echo "configure:7823: checking for $ac_hdr" >&5
-#line 7840 "configure"
+#line 7826 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7845: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7831: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7875,7 +7861,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7879: checking for location of TIFF library" >&5
+echo "configure:7865: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7906,13 +7892,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7910: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7896: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7916 "configure"
+#line 7902 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7923,7 +7909,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7942,13 +7928,13 @@
-echo "configure:7946: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7932: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7952 "configure"
+#line 7938 "configure"
@@ -7959,7 +7945,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7978,13 +7964,13 @@
-echo "configure:7982: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7968: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7988 "configure"
+#line 7974 "configure"
@@ -7995,7 +7981,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8014,13 +8000,13 @@
-echo "configure:8018: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8004: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8024 "configure"
+#line 8010 "configure"
@@ -8031,7 +8017,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8050,13 +8036,13 @@
-echo "configure:8054: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8040: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8060 "configure"
+#line 8046 "configure"
@@ -8067,7 +8053,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8086,13 +8072,13 @@
-echo "configure:8090: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8076: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8096 "configure"
+#line 8082 "configure"
@@ -8103,7 +8089,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8122,13 +8108,13 @@
-echo "configure:8126: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8112: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8132 "configure"
+#line 8118 "configure"
@@ -8139,7 +8125,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8158,13 +8144,13 @@
-echo "configure:8162: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8148: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8168 "configure"
+#line 8154 "configure"
@@ -8175,7 +8161,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8273,7 +8259,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8277: checking whether to use PNG" >&5
+echo "configure:8263: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8292,7 +8278,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8296: checking for location of PNG includes" >&5
+echo "configure:8282: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8318,15 +8304,15 @@
do
-echo "configure:8322: checking for $ac_hdr" >&5
+echo "configure:8308: checking for $ac_hdr" >&5
-#line 8325 "configure"
+#line 8311 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8360,7 +8346,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8364: checking for location of PNG library" >&5
+echo "configure:8350: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8385,13 +8371,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8389: checking for png_read_image in -lpng" >&5
+echo "configure:8375: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8395 "configure"
+#line 8381 "configure"
@@ -8402,7 +8388,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8444,7 +8430,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8448: checking whether to use Tcl/Tk" >&5
+echo "configure:8434: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8464,7 +8450,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8468: checking for location of Tcl/Tk includes" >&5
+echo "configure:8454: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8490,15 +8476,15 @@
do
-echo "configure:8494: checking for $ac_hdr" >&5
+echo "configure:8480: checking for $ac_hdr" >&5
-#line 8497 "configure"
+#line 8483 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8535,15 +8521,15 @@
do
-echo "configure:8539: checking for $ac_hdr" >&5
+echo "configure:8525: checking for $ac_hdr" >&5
-#line 8542 "configure"
+#line 8528 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8577,7 +8563,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8581: checking Tcl version" >&5
+echo "configure:8567: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8585,7 +8571,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8589 "configure"
+#line 8575 "configure"
#include <stdio.h>
@@ -8597,7 +8583,7 @@
EOF
-if { (eval echo configure:8601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8615,7 +8601,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8619: checking Tk version" >&5
+echo "configure:8605: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8623,7 +8609,7 @@
else
-#line 8627 "configure"
+#line 8613 "configure"
#include <stdio.h>
@@ -8635,7 +8621,7 @@
EOF
-if { (eval echo configure:8639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8664,7 +8650,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8668: checking for location of Tcl/Tk library" >&5
+echo "configure:8654: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8694,13 +8680,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8698: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8684: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8704 "configure"
+#line 8690 "configure"
@@ -8711,7 +8697,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8730,13 +8716,13 @@
-echo "configure:8734: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8720: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8740 "configure"
+#line 8726 "configure"
@@ -8747,7 +8733,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8774,13 +8760,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8778: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8764: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8784 "configure"
+#line 8770 "configure"
@@ -8791,7 +8777,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8810,13 +8796,13 @@
-echo "configure:8814: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8800: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8820 "configure"
+#line 8806 "configure"
@@ -8827,7 +8813,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8854,13 +8840,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8858: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8844: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8864 "configure"
+#line 8850 "configure"
@@ -8871,7 +8857,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8890,13 +8876,13 @@
-echo "configure:8894: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8880: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8900 "configure"
+#line 8886 "configure"
@@ -8907,7 +8893,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8985,13 +8971,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8989: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8975: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8995 "configure"
+#line 8981 "configure"
@@ -9002,7 +8988,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9021,13 +9007,13 @@
-echo "configure:9025: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9011: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9031 "configure"
+#line 9017 "configure"
@@ -9038,7 +9024,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9065,13 +9051,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9069: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9055: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9075 "configure"
+#line 9061 "configure"
@@ -9082,7 +9068,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9101,13 +9087,13 @@
-echo "configure:9105: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9091: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9111 "configure"
+#line 9097 "configure"
@@ -9118,7 +9104,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9145,13 +9131,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9149: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9135: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9155 "configure"
+#line 9141 "configure"
@@ -9162,7 +9148,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9181,13 +9167,13 @@
-echo "configure:9185: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9171: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9191 "configure"
+#line 9177 "configure"
@@ -9198,7 +9184,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9290,7 +9276,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9294: checking whether to use PostgreSQL" >&5
+echo "configure:9280: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9317,7 +9303,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9321: checking for location of PostgreSQL includes" >&5
+echo "configure:9307: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9343,15 +9329,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9347: checking for $ac_hdr" >&5
+echo "configure:9333: checking for $ac_hdr" >&5
-#line 9350 "configure"
+#line 9336 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9389,7 +9375,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9393: checking for location of PostgreSQL library" >&5
+echo "configure:9379: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9418,13 +9404,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9422: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9408: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9428 "configure"
+#line 9414 "configure"
@@ -9435,7 +9421,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9454,13 +9440,13 @@
-echo "configure:9458: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9444: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9464 "configure"
+#line 9450 "configure"
@@ -9471,7 +9457,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9490,13 +9476,13 @@
-echo "configure:9494: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9480: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9500 "configure"
+#line 9486 "configure"
@@ -9507,7 +9493,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9526,13 +9512,13 @@
-echo "configure:9530: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9516: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9536 "configure"
+#line 9522 "configure"
@@ -9543,7 +9529,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9600,13 +9586,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9604: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9590: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9610 "configure"
+#line 9596 "configure"
@@ -9617,7 +9603,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9639,13 +9625,13 @@
-echo "configure:9643: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9629: checking for PQcmdTuples in -lpq" >&5
-#line 9649 "configure"
+#line 9635 "configure"
@@ -9656,7 +9642,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9699,7 +9685,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9703: checking whether to use MySQL" >&5
+echo "configure:9689: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9719,7 +9705,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9723: checking for location of MySQL includes" >&5
+echo "configure:9709: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9745,15 +9731,15 @@
do
-echo "configure:9749: checking for $ac_hdr" >&5
+echo "configure:9735: checking for $ac_hdr" >&5
-#line 9752 "configure"
+#line 9738 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9757: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9790,7 +9776,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9794: checking for location of MySQL library" >&5
+echo "configure:9780: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9821,13 +9807,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9825: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9811: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9831 "configure"
+#line 9817 "configure"
@@ -9838,7 +9824,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9857,13 +9843,13 @@
-echo "configure:9861: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9847: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9867 "configure"
+#line 9853 "configure"
@@ -9874,7 +9860,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9893,13 +9879,13 @@
-echo "configure:9897: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9883: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9903 "configure"
+#line 9889 "configure"
@@ -9910,7 +9896,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9929,13 +9915,13 @@
-echo "configure:9933: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9919: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9939 "configure"
+#line 9925 "configure"
@@ -9946,7 +9932,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9965,13 +9951,13 @@
-echo "configure:9969: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9955: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9975 "configure"
+#line 9961 "configure"
@@ -9982,7 +9968,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10001,13 +9987,13 @@
-echo "configure:10005: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9991: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10011 "configure"
+#line 9997 "configure"
@@ -10018,7 +10004,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10037,13 +10023,13 @@
-echo "configure:10041: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10027: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10047 "configure"
+#line 10033 "configure"
@@ -10054,7 +10040,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10073,13 +10059,13 @@
-echo "configure:10077: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10063: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10083 "configure"
+#line 10069 "configure"
@@ -10090,7 +10076,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10180,7 +10166,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10184: checking for $ac_word" >&5
+echo "configure:10170: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10221,10 +10207,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10225: checking for mysql_server_init" >&5
+echo "configure:10211: checking for mysql_server_init" >&5
-#line 10228 "configure"
+#line 10214 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10247,7 +10233,7 @@
; return 0; }
EOF
-if { (eval echo configure:10251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10285,7 +10271,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10289: checking whether to use SQLite" >&5
+echo "configure:10275: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10305,7 +10291,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10309: checking for location of SQLite includes" >&5
+echo "configure:10295: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10331,15 +10317,15 @@
do
-echo "configure:10335: checking for $ac_hdr" >&5
+echo "configure:10321: checking for $ac_hdr" >&5
-#line 10338 "configure"
+#line 10324 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10382,7 +10368,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10386: checking for location of SQLite library" >&5
+echo "configure:10372: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10409,13 +10395,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10413: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10399: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10419 "configure"
+#line 10405 "configure"
@@ -10426,7 +10412,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10445,13 +10431,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10449: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10435: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10455 "configure"
+#line 10441 "configure"
@@ -10462,7 +10448,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10515,7 +10501,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10519: checking whether to use FFMPEG" >&5
+echo "configure:10505: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10535,7 +10521,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10539: checking for location of FFMPEG includes" >&5
+echo "configure:10525: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10561,15 +10547,15 @@
do
-echo "configure:10565: checking for $ac_hdr" >&5
+echo "configure:10551: checking for $ac_hdr" >&5
-#line 10568 "configure"
+#line 10554 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10605,15 +10591,15 @@
do
-echo "configure:10609: checking for $ac_hdr" >&5
+echo "configure:10595: checking for $ac_hdr" >&5
-#line 10612 "configure"
+#line 10598 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10649,15 +10635,15 @@
do
-echo "configure:10653: checking for $ac_hdr" >&5
+echo "configure:10639: checking for $ac_hdr" >&5
-#line 10656 "configure"
+#line 10642 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10700,7 +10686,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10704: checking for location of FFMPEG library" >&5
+echo "configure:10690: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10727,13 +10713,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10731: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10717: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $LIBS"
-#line 10737 "configure"
+#line 10723 "configure"
@@ -10744,7 +10730,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10763,13 +10749,13 @@
-echo "configure:10767: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10753: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10773 "configure"
+#line 10759 "configure"
@@ -10780,7 +10766,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10825,13 +10811,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10829: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10815: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $LIBS"
-#line 10835 "configure"
+#line 10821 "configure"
@@ -10842,7 +10828,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10861,13 +10847,13 @@
-echo "configure:10865: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10851: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat -lavutil $MATHLIB $LIBS"
-#line 10871 "configure"
+#line 10857 "configure"
@@ -10878,7 +10864,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10938,7 +10924,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10942: checking whether to use OpenGL" >&5
+echo "configure:10928: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10972,7 +10958,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10976: checking for location of OpenGL includes" >&5
+echo "configure:10962: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10998,15 +10984,15 @@
do
-echo "configure:11002: checking for $ac_hdr" >&5
+echo "configure:10988: checking for $ac_hdr" >&5
-#line 11005 "configure"
+#line 10991 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11040,7 +11026,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11044: checking for location of OpenGL library" >&5
+echo "configure:11030: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11069,13 +11055,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11073: checking for glBegin in -lGL" >&5
+echo "configure:11059: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11079 "configure"
+#line 11065 "configure"
@@ -11086,7 +11072,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11105,13 +11091,13 @@
-echo "configure:11109: checking for glBegin in -lGL" >&5
+echo "configure:11095: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11115 "configure"
+#line 11101 "configure"
@@ -11122,7 +11108,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11141,13 +11127,13 @@
-echo "configure:11145: checking for glBegin in -lGL" >&5
+echo "configure:11131: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11151 "configure"
+#line 11137 "configure"
@@ -11158,7 +11144,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11177,13 +11163,13 @@
-echo "configure:11181: checking for glBegin in -lGL" >&5
+echo "configure:11167: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11187 "configure"
+#line 11173 "configure"
@@ -11194,7 +11180,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11184: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11256,13 +11242,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11260: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11246: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11266 "configure"
+#line 11252 "configure"
@@ -11273,7 +11259,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11292,13 +11278,13 @@
-echo "configure:11296: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11282: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11302 "configure"
+#line 11288 "configure"
@@ -11309,7 +11295,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11353,10 +11339,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11357: checking for glXCreatePbuffer" >&5
+echo "configure:11343: checking for glXCreatePbuffer" >&5
-#line 11360 "configure"
+#line 11346 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11379,7 +11365,7 @@
; return 0; }
EOF
-if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11401,10 +11387,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11405: checking for glXCreateGLXPixmap" >&5
+echo "configure:11391: checking for glXCreateGLXPixmap" >&5
-#line 11408 "configure"
+#line 11394 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11427,7 +11413,7 @@
; return 0; }
EOF
-if { (eval echo configure:11431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11466,7 +11452,7 @@
-echo "configure:11470: checking for location of OpenGL includes" >&5
+echo "configure:11456: checking for location of OpenGL includes" >&5
@@ -11492,15 +11478,15 @@
do
-echo "configure:11496: checking for $ac_hdr" >&5
+echo "configure:11482: checking for $ac_hdr" >&5
-#line 11499 "configure"
+#line 11485 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11535,10 +11521,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11539: checking for glBegin" >&5
+echo "configure:11525: checking for glBegin" >&5
-#line 11542 "configure"
+#line 11528 "configure"
which can conflict with char glBegin(); below. */
@@ -11561,7 +11547,7 @@
; return 0; }
EOF
-if { (eval echo configure:11565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11576,10 +11562,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11580: checking for gluBeginCurve" >&5
+echo "configure:11566: checking for gluBeginCurve" >&5
-#line 11583 "configure"
+#line 11569 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11602,7 +11588,7 @@
; return 0; }
EOF
-if { (eval echo configure:11606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11648,7 +11634,7 @@
-echo "configure:11652: checking for location of OpenGL includes" >&5
+echo "configure:11638: checking for location of OpenGL includes" >&5
@@ -11674,15 +11660,15 @@
do
-echo "configure:11678: checking for $ac_hdr" >&5
+echo "configure:11664: checking for $ac_hdr" >&5
-#line 11681 "configure"
+#line 11667 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11716,7 +11702,7 @@
-echo "configure:11720: checking for location of OpenGL library" >&5
+echo "configure:11706: checking for location of OpenGL library" >&5
@@ -11739,33 +11725,33 @@
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11743: checking for OpenGL library" >&5
+echo "configure:11729: checking for OpenGL library" >&5
LIBS="-lopengl32"
-#line 11746 "configure"
+#line 11732 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
OPENGLLIB=-lopengl32
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11759: checking for GLU library" >&5
+echo "configure:11745: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB"
-#line 11762 "configure"
+#line 11748 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11816,7 +11802,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11820: checking whether to use ODBC" >&5
+echo "configure:11806: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11835,7 +11821,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11839: checking for location of ODBC includes" >&5
+echo "configure:11825: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11861,15 +11847,15 @@
do
-echo "configure:11865: checking for $ac_hdr" >&5
+echo "configure:11851: checking for $ac_hdr" >&5
-#line 11868 "configure"
+#line 11854 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11903,7 +11889,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11907: checking for location of ODBC library" >&5
+echo "configure:11893: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11928,13 +11914,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11932: checking for SQLConnect in -lodbc" >&5
+echo "configure:11918: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11938 "configure"
+#line 11924 "configure"
@@ -11945,7 +11931,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11970,13 +11956,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11974: checking for SQLConnect in -liodbc" >&5
+echo "configure:11960: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11980 "configure"
+#line 11966 "configure"
@@ -11987,7 +11973,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12036,7 +12022,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12040: checking whether to use FFTW" >&5
+echo "configure:12026: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12055,7 +12041,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12059: checking for location of FFTW includes" >&5
+echo "configure:12045: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12081,15 +12067,15 @@
do
-echo "configure:12085: checking for $ac_hdr" >&5
+echo "configure:12071: checking for $ac_hdr" >&5
-#line 12088 "configure"
+#line 12074 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12079: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12117,15 +12103,15 @@
do
-echo "configure:12121: checking for $ac_hdr" >&5
+echo "configure:12107: checking for $ac_hdr" >&5
-#line 12124 "configure"
+#line 12110 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12129: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12153,15 +12139,15 @@
do
-echo "configure:12157: checking for $ac_hdr" >&5
+echo "configure:12143: checking for $ac_hdr" >&5
-#line 12160 "configure"
+#line 12146 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12207,7 +12193,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12211: checking for location of FFTW library" >&5
+echo "configure:12197: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12232,13 +12218,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12236: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12222: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12242 "configure"
+#line 12228 "configure"
@@ -12249,7 +12235,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12274,13 +12260,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12278: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12264: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12284 "configure"
+#line 12270 "configure"
#include "confdefs.h"
@@ -12291,7 +12277,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12316,13 +12302,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12320: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12306: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12326 "configure"
+#line 12312 "configure"
@@ -12333,7 +12319,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12390,7 +12376,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12394: checking whether to use BLAS" >&5
+echo "configure:12380: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12411,7 +12397,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12415: checking for location of BLAS includes" >&5
+echo "configure:12401: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12431,7 +12417,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12435: checking for location of BLAS library" >&5
+echo "configure:12421: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12457,15 +12443,15 @@
do
-echo "configure:12461: checking for $ac_hdr" >&5
+echo "configure:12447: checking for $ac_hdr" >&5
-#line 12464 "configure"
+#line 12450 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12500,13 +12486,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12504: checking for dnrm2_ in -lblas" >&5
+echo "configure:12490: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12510 "configure"
+#line 12496 "configure"
@@ -12517,7 +12503,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12536,13 +12522,13 @@
-echo "configure:12540: checking for dnrm2_ in -lblas" >&5
+echo "configure:12526: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12546 "configure"
+#line 12532 "configure"
@@ -12553,7 +12539,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12597,13 +12583,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12601: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12587: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12607 "configure"
+#line 12593 "configure"
@@ -12614,7 +12600,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12629,13 +12615,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12633: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12619: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12639 "configure"
+#line 12625 "configure"
@@ -12646,7 +12632,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12661,13 +12647,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12665: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12651: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12671 "configure"
+#line 12657 "configure"
@@ -12678,7 +12664,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12723,16 +12709,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12727: checking for sgemm in $vlib_flags" >&5
+echo "configure:12713: checking for sgemm in $vlib_flags" >&5
-#line 12729 "configure"
+#line 12715 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12750,13 +12736,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12754: checking for sgemm_ in -lblas" >&5
+echo "configure:12740: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12760 "configure"
+#line 12746 "configure"
@@ -12767,7 +12753,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12782,13 +12768,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12786: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12772: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12792 "configure"
+#line 12778 "configure"
@@ -12799,7 +12785,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12814,13 +12800,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12818: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12804: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12824 "configure"
+#line 12810 "configure"
@@ -12831,7 +12817,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12865,13 +12851,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12869: checking for acosp in -lsunmath" >&5
+echo "configure:12855: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsunmath $LIBS"
-#line 12875 "configure"
+#line 12861 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12882,7 +12868,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12897,13 +12883,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12901: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12887: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12907 "configure"
+#line 12893 "configure"
@@ -12914,7 +12900,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12944,13 +12930,13 @@
# Generic BLAS library
-echo "configure:12948: checking for sgemm_ in -lblas" >&5
+echo "configure:12934: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12954 "configure"
+#line 12940 "configure"
@@ -12961,7 +12947,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13000,7 +12986,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13004: checking whether to use LAPACK" >&5
+echo "configure:12990: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13025,7 +13011,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13029: checking for location of LAPACK includes" >&5
+echo "configure:13015: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13045,7 +13031,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13049: checking for location of LAPACK library" >&5
+echo "configure:13035: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13071,15 +13057,15 @@
do
-echo "configure:13075: checking for $ac_hdr" >&5
+echo "configure:13061: checking for $ac_hdr" >&5
-#line 13078 "configure"
+#line 13064 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13111,10 +13097,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13115: checking for dsegv_" >&5
+echo "configure:13101: checking for dsegv_" >&5
-#line 13118 "configure"
+#line 13104 "configure"
which can conflict with char dsegv_(); below. */
@@ -13137,7 +13123,7 @@
; return 0; }
EOF
-if { (eval echo configure:13141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13164,13 +13150,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13168: checking for desgv_ in -llapack" >&5
+echo "configure:13154: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13174 "configure"
+#line 13160 "configure"
@@ -13181,7 +13167,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13213,13 +13199,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13217: checking for dgesv_ in -llapack" >&5
+echo "configure:13203: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13223 "configure"
+#line 13209 "configure"
@@ -13230,7 +13216,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13249,13 +13235,13 @@
-echo "configure:13253: checking for dgesv_ in -llapack" >&5
+echo "configure:13239: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13259 "configure"
+#line 13245 "configure"
@@ -13266,7 +13252,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13322,7 +13308,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13326: checking whether to use Motif" >&5
+echo "configure:13312: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13341,7 +13327,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13345: checking for location of Motif includes" >&5
+echo "configure:13331: checking for location of Motif includes" >&5
case "$with_motif_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13367,15 +13353,15 @@
do
-echo "configure:13371: checking for $ac_hdr" >&5
+echo "configure:13357: checking for $ac_hdr" >&5
-#line 13374 "configure"
+#line 13360 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13365: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13409,7 +13395,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13413: checking for location of Motif library" >&5
+echo "configure:13399: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13434,13 +13420,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13438: checking for XmStringCreate in -lXm" >&5
+echo "configure:13424: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13444 "configure"
+#line 13430 "configure"
@@ -13451,7 +13437,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13492,7 +13478,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13496: checking whether to use Cairo" >&5
+echo "configure:13482: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13518,15 +13504,15 @@
do
-echo "configure:13522: checking for $ac_hdr" >&5
+echo "configure:13508: checking for $ac_hdr" >&5
-#line 13525 "configure"
+#line 13511 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13530: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13516: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13563,10 +13549,10 @@
LDFLAGS="$LDFLAGS $CAIROLIB"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13567: checking for cairo_create" >&5
+echo "configure:13553: checking for cairo_create" >&5
-#line 13570 "configure"
+#line 13556 "configure"
which can conflict with char cairo_create(); below. */
@@ -13589,7 +13575,7 @@
; return 0; }
EOF
-if { (eval echo configure:13593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13624,7 +13610,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13628: checking whether to use GLw" >&5
+echo "configure:13614: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13643,7 +13629,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13647: checking for location of GLw includes" >&5
+echo "configure:13633: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13669,15 +13655,15 @@
do
-echo "configure:13673: checking for $ac_hdr" >&5
+echo "configure:13659: checking for $ac_hdr" >&5
-#line 13676 "configure"
+#line 13662 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13705,15 +13691,15 @@
do
-echo "configure:13709: checking for $ac_hdr" >&5
+echo "configure:13695: checking for $ac_hdr" >&5
-#line 13712 "configure"
+#line 13698 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13753,7 +13739,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13757: checking for location of GLw library" >&5
+echo "configure:13743: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13778,13 +13764,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13782: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13768: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13788 "configure"
+#line 13774 "configure"
@@ -13795,7 +13781,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13820,13 +13806,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13824: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13810: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13830 "configure"
+#line 13816 "configure"
@@ -13837,7 +13823,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13862,13 +13848,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13866: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13852: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13872 "configure"
+#line 13858 "configure"
@@ -13879,7 +13865,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13904,13 +13890,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13908: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13894: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13914 "configure"
+#line 13900 "configure"
@@ -13921,7 +13907,7 @@
; return 0; }
EOF
-if { (eval echo configure:13925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13946,13 +13932,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13950: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13936: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13956 "configure"
+#line 13942 "configure"
@@ -13963,7 +13949,7 @@
; return 0; }
EOF
-if { (eval echo configure:13967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13988,13 +13974,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13992: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13978: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13998 "configure"
+#line 13984 "configure"
@@ -14005,7 +13991,7 @@
; return 0; }
EOF
-if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14032,13 +14018,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14036: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14022: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14042 "configure"
+#line 14028 "configure"
@@ -14049,7 +14035,7 @@
; return 0; }
EOF
-if { (eval echo configure:14053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14068,13 +14054,13 @@
-echo "configure:14072: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14058: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14078 "configure"
+#line 14064 "configure"
@@ -14085,7 +14071,7 @@
; return 0; }
EOF
-if { (eval echo configure:14089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14112,13 +14098,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14116: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14102: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14122 "configure"
+#line 14108 "configure"
@@ -14129,7 +14115,7 @@
; return 0; }
EOF
-if { (eval echo configure:14133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14148,13 +14134,13 @@
-echo "configure:14152: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14138: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14158 "configure"
+#line 14144 "configure"
@@ -14165,7 +14151,7 @@
; return 0; }
EOF
-if { (eval echo configure:14169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14278,7 +14264,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14282: checking whether to use FreeType" >&5
+echo "configure:14268: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14297,7 +14283,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14301: checking for location of FreeType includes" >&5
+echo "configure:14287: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14323,15 +14309,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14327: checking for $ac_hdr" >&5
+echo "configure:14313: checking for $ac_hdr" >&5
-#line 14330 "configure"
+#line 14316 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14365,7 +14351,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14369: checking for location of FreeType library" >&5
+echo "configure:14355: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14390,13 +14376,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14394: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14380: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14400 "configure"
+#line 14386 "configure"
@@ -14407,7 +14393,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14448,7 +14434,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14452: checking whether to use NLS" >&5
+echo "configure:14438: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14468,10 +14454,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14472: checking for gettext" >&5
+echo "configure:14458: checking for gettext" >&5
-#line 14475 "configure"
+#line 14461 "configure"
which can conflict with char gettext(); below. */
@@ -14494,7 +14480,7 @@
; return 0; }
EOF
-if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14512,13 +14498,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14516: checking for gettext in -lintl" >&5
+echo "configure:14502: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14522 "configure"
+#line 14508 "configure"
@@ -14529,7 +14515,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14564,7 +14550,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14568: checking whether to use C++" >&5
+echo "configure:14554: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14580,7 +14566,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14584: checking for $ac_word" >&5
+echo "configure:14570: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14609,7 +14595,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14613: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14599: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14620,12 +14606,12 @@
cat > conftest.$ac_ext << EOF
-#line 14624 "configure"
+#line 14610 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14651,19 +14637,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14655: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14641: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14660: checking whether we are using GNU C++" >&5
+echo "configure:14646: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14681,7 +14667,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14685: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14671: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14722,7 +14708,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14726: checking whether to use openDWG" >&5
+echo "configure:14712: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14742,7 +14728,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14746: checking for location of openDGW includes" >&5
+echo "configure:14732: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14768,15 +14754,15 @@
do
-echo "configure:14772: checking for $ac_hdr" >&5
+echo "configure:14758: checking for $ac_hdr" >&5
-#line 14775 "configure"
+#line 14761 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14810,7 +14796,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14814: checking for location of openDWG library" >&5
+echo "configure:14800: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14857,7 +14843,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14861: checking for special C compiler options needed for large files" >&5
+echo "configure:14847: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14865,7 +14851,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14869 "configure"
+#line 14855 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14881,7 +14867,7 @@
; return 0; }
EOF
-if { (eval echo configure:14885: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14871: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14890,7 +14876,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14894 "configure"
+#line 14880 "configure"
@@ -14906,7 +14892,7 @@
; return 0; }
EOF
-if { (eval echo configure:14910: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14896: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14926,11 +14912,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14930: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14916: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14934 "configure"
+#line 14920 "configure"
@@ -14946,14 +14932,14 @@
; return 0; }
EOF
-if { (eval echo configure:14950: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14936: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14957 "configure"
+#line 14943 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14971,7 +14957,7 @@
; return 0; }
EOF
-if { (eval echo configure:14975: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14990,11 +14976,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14994: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14980: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14998 "configure"
+#line 14984 "configure"
@@ -15010,14 +14996,14 @@
; return 0; }
EOF
-if { (eval echo configure:15014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15021 "configure"
+#line 15007 "configure"
#define _LARGE_FILES 1
@@ -15035,7 +15021,7 @@
; return 0; }
EOF
-if { (eval echo configure:15039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15025: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15054,25 +15040,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15058: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15044: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15062 "configure"
+#line 15048 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15069: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15055: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15076 "configure"
+#line 15062 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15081,7 +15067,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15085: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15071: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15102,10 +15088,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15106: checking if system supports Large Files at all" >&5
+echo "configure:15092: checking if system supports Large Files at all" >&5
-#line 15109 "configure"
+#line 15095 "configure"
#include <stdio.h>
@@ -15137,7 +15123,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15141: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15166,7 +15152,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15170: checking whether to use Python" >&5
+echo "configure:15156: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15186,7 +15172,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15190: checking for $ac_word" >&5
+echo "configure:15176: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15231,15 +15217,15 @@
do
-echo "configure:15235: checking for $ac_hdr" >&5
+echo "configure:15221: checking for $ac_hdr" >&5
-#line 15238 "configure"
+#line 15224 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15279,7 +15265,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15283: checking for $ac_word" >&5
+echo "configure:15269: checking for $ac_word" >&5
case "$SWIG" in
@@ -15325,7 +15311,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15329: checking whether to use wxWidgets" >&5
+echo "configure:15315: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15345,7 +15331,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15349: checking for $ac_word" >&5
+echo "configure:15335: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15393,7 +15379,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15397: checking wxWidgets version" >&5
+echo "configure:15383: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15416,15 +15402,15 @@
do
-echo "configure:15420: checking for $ac_hdr" >&5
+echo "configure:15406: checking for $ac_hdr" >&5
-#line 15423 "configure"
+#line 15409 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15460,15 +15446,15 @@
do
-echo "configure:15464: checking for $ac_hdr" >&5
+echo "configure:15450: checking for $ac_hdr" >&5
-#line 15467 "configure"
+#line 15453 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-05-11 12:48:50 UTC (rev 31317)
+++ grass/trunk/configure.in 2008-05-11 19:16:33 UTC (rev 31318)
@@ -32,7 +32,7 @@
AC_CONFIG_HEADER(include/config.h)
AC_CANONICAL_HOST
AC_PROG_CC
-AC_EXEEXT
+LOC_EXEEXT
AC_SUBST(MINGW32)
# Check for full floating-point support, including Infinity and NaN
