[GRASS-SVN] r31411 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun May 18 05:53:19 EDT 2008
Author: martinl
Date: 2008-05-18 05:53:19 -0400 (Sun, 18 May 2008)
New Revision: 31411
grass/trunk/gui/wxpython/gui_modules/globalvar.py
grass/trunk/gui/wxpython/gui_modules/histogram.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: histogram component fixed (sync'ed with devbr6, r31410)
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py 2008-05-18 09:51:42 UTC (rev 31410)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py 2008-05-18 09:53:19 UTC (rev 31411)
@@ -81,6 +81,7 @@
DIALOG_TEXTCTRL_SIZE = (400, -1)
MAP_WINDOW_SIZE = (680, 520)
+HIST_WINDOW_SIZE = (500, 350)
"""File name extension binaries/scripts"""
if subprocess.mswindows:
Modified: grass/trunk/gui/wxpython/gui_modules/histogram.py
--- grass/trunk/gui/wxpython/gui_modules/histogram.py 2008-05-18 09:51:42 UTC (rev 31410)
+++ grass/trunk/gui/wxpython/gui_modules/histogram.py 2008-05-18 09:53:19 UTC (rev 31411)
@@ -35,6 +35,7 @@
import render
import menuform
import disp_print
+import utils
from gui_modules.preferences import SetDefaultFont as SetDefaultFont
from debug import Debug as Debug
from icon import Icons as Icons
@@ -92,8 +93,11 @@
self.pdc = wx.PseudoDC()
self._Buffer = '' # will store an off screen empty bitmap for saving to file
- self.Map.SetRegion() # make sure that extents are updated at init
+ # make sure that extents are updated at init
+ self.Map.region = self.Map.GetRegion()
+ self.Map.SetRegion()
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0,0,0,0]):
@@ -294,7 +298,7 @@
self.iconsize = (16, 16)
# Init variables
- self.params = {} # previously set histogram parameters
+ self.params = {} # previously set histogram parameters
self.propwin = '' # ID of properties dialog
self.font = ""
@@ -371,24 +375,23 @@
self.Map.geom = self.width, self.height
def OnOptions(self, event):
- global gmpath
- completed = ''
+ """Change histogram settings"""
- menuform.GUI().ParseCommand(['d.histogram'], gmpath,
- completed=(self.GetOptData, "hist", self.params),
- parentframe=None)
+ cmd = ['d.histogram']
+ if self.mapname != '':
+ cmd.append('map=%s' % self.mapname)
+ menuform.GUI().ParseCommand(cmd,
+ completed=(self.GetOptData, None, self.params),
+ parentframe=self)
def GetOptData(self, dcmd, layer, params, propwin):
Callback method for histogram command generated by
dialog created in menuform.py
- # Reset comand and rendering options in render.Map. Always render decoration.
- # Showing/hiding handled by PseudoDC
- self.SetHistLayer(dcmd)
+ if dcmd:
+ self.SetHistLayer(dcmd)
self.params = params
self.propwin = propwin
@@ -398,11 +401,8 @@
Set histogram layer
+ self.mapname = utils.GetLayerNameFromCmd(cmd)
- for item in cmd:
- if 'map=' in item:
- self.mapname = item.split('=')[1]
self.layer = self.Map.ChangeLayer(layer=self.layer, type="command", name='histogram',
command=cmd,
l_active=True, l_hidden=False, l_opacity=1.0)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-05-18 09:51:42 UTC (rev 31410)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-05-18 09:53:19 UTC (rev 31411)
@@ -3267,7 +3267,7 @@
Init histogram display canvas and tools
self.histogram = histogram.HistFrame(self,
- id=wx.ID_ANY, pos=wx.DefaultPosition, size=(400,300),
+ id=wx.ID_ANY, size=globalvar.HIST_WINDOW_SIZE,
style=wx.DEFAULT_FRAME_STYLE)
#show new display
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-05-18 09:51:42 UTC (rev 31410)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-05-18 09:53:19 UTC (rev 31411)
@@ -370,7 +370,7 @@
if not self.histogramFrame:
self.histogramFrame = histogram.HistFrame(self,
id=wx.ID_ANY,
- pos=wx.DefaultPosition, size=(400, 300),
+ pos=wx.DefaultPosition, size=globalvar.HIST_WINDOW_SIZE,
# show new display
self.histogramFrame.Show()
