[GRASS-SVN] r31412 - in grass-addons/gipe: i.eb.g0 i.eb.netrad
i.evapo.potrad
svn_grass at osgeo.org
Sun May 18 08:46:59 EDT 2008
Author: ychemin
Date: 2008-05-18 08:46:59 -0400 (Sun, 18 May 2008)
New Revision: 31412
grass-addons/gipe/i.eb.g0/main.c
grass-addons/gipe/i.eb.netrad/main.c
grass-addons/gipe/i.evapo.potrad/solar_day.c
code standardization
Modified: grass-addons/gipe/i.eb.g0/main.c
--- grass-addons/gipe/i.eb.g0/main.c 2008-05-18 09:53:19 UTC (rev 31411)
+++ grass-addons/gipe/i.eb.g0/main.c 2008-05-18 12:46:59 UTC (rev 31412)
@@ -34,9 +34,9 @@
struct GModule *module;
struct Option *input1, *input2, *input3, *input4, *input5, *output1;
- struct Flag *flag1;
+ struct Flag *flag1, *flag2;
struct History history; //metadata
+ struct Colors colors; //metadata
/* FMEO Declarations*****************/
char *name; // input raster name
@@ -50,7 +50,7 @@
int i=0,j=0;
void *inrast_albedo, *inrast_ndvi, *inrast_tempk, *inrast_rnet, *inrast_time;
- unsigned char *outrast;
+ DCELL *outrast;
RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
RASTER_MAP_TYPE data_type_albedo;
RASTER_MAP_TYPE data_type_ndvi;
@@ -99,6 +99,7 @@
flag1 = G_define_flag();
flag1->key = 'r';
flag1->description = _("HAPEX-Sahel empirical correction (Roerink, 1995)");
if (G_parser(argc, argv))
exit (EXIT_FAILURE);
@@ -184,6 +185,7 @@
DCELL d_rnet;
DCELL d_time;
G_percent(row,nrows,2);
+// printf("row = %i/%i\n",row,nrows);
/* read soil input maps */
if(G_get_raster_row(infd_albedo,inrast_albedo,row,data_type_albedo)<0)
G_fatal_error(_("Could not read from <%s>"),albedo);
@@ -253,21 +255,17 @@
d_time = ((DCELL *) inrast_time)[col];
break;
- if(G_is_d_null_value(&d_albedo)){
- ((DCELL *) outrast)[col] = -999.99;
- }else if(G_is_d_null_value(&d_ndvi)){
- }else if(G_is_d_null_value(&d_tempk)){
- }else if(G_is_d_null_value(&d_rnet)){
- }else if(G_is_d_null_value(&d_time)){
+ if(G_is_d_null_value(&d_albedo)||
+ G_is_d_null_value(&d_ndvi)||
+ G_is_d_null_value(&d_tempk)||
+ G_is_d_null_value(&d_rnet)||
+ G_is_d_null_value(&d_time)){
+ G_set_d_null_value(&outrast[col],1);
}else {
/* calculate soil heat flux */
d = g_0(d_albedo,d_ndvi,d_tempk,d_rnet,d_time,roerink);
- ((DCELL *) outrast)[col] = d;
+ outrast[col] = d;
if (G_put_raster_row (outfd, outrast, data_type_output) < 0)
@@ -288,6 +286,9 @@
G_free (outrast);
G_close_cell (outfd);
+ /* Colors in grey shade */
+ G_init_colors(&colors);
+ G_add_color_rule(0.0,0,0,0,200.0,255,255,255,&colors);
G_short_history(result, "raster", &history);
G_command_history(&history);
G_write_history(result,&history);
Modified: grass-addons/gipe/i.eb.netrad/main.c
--- grass-addons/gipe/i.eb.netrad/main.c 2008-05-18 09:53:19 UTC (rev 31411)
+++ grass-addons/gipe/i.eb.netrad/main.c 2008-05-18 12:46:59 UTC (rev 31412)
@@ -29,14 +29,13 @@
int nrows, ncols;
int row,col;
- int verbose=1;
struct Option *input1, *input2, *input3, *input4, *input5;
struct Option *input6, *input7, *input8, *input9, *output1;
struct Flag *flag1;
+ struct Colors colors; //Color rules
@@ -46,7 +45,8 @@
int infd_emissivity, infd_tsw, infd_doy, infd_sunzangle;
int outfd;
- char *albedo,*ndvi,*tempk,*time,*dtair,*emissivity,*tsw,*doy,*sunzangle;
+ char *albedo,*ndvi,*tempk,*time,*dtair,*emissivity;
+ char *tsw,*doy,*sunzangle;
int i=0,j=0;
@@ -54,7 +54,8 @@
void *inrast_time, *inrast_dtair, *inrast_emissivity, *inrast_tsw;
void *inrast_doy, *inrast_sunzangle;
+ DCELL *outrast;
@@ -74,90 +75,56 @@
module->description = _("net radiation approximation (Bastiaanssen, 1995)");
/* Define the different options */
- input1 = G_define_option() ;
+ input1 = G_define_standard_option(G_OPT_R_INPUT) ;
input1->key = _("albedo");
- input1->type = TYPE_STRING;
- input1->required = YES;
- input1->gisprompt =_("old,cell,raster") ;
input1->description=_("Name of the Albedo map [0.0;1.0]");
input1->answer =_("albedo");
- input2 = G_define_option() ;
+ input2 = G_define_standard_option(G_OPT_R_INPUT) ;
input2->key =_("ndvi");
- input2->type = TYPE_STRING;
- input2->required = YES;
- input2->gisprompt =_("old,cell,raster");
input2->description=_("Name of the ndvi map [-1.0;+1.0]");
input2->answer =_("ndvi");
- input3 = G_define_option() ;
+ input3 = G_define_standard_option(G_OPT_R_INPUT) ;
input3->key =_("tempk");
- input3->type = TYPE_STRING;
- input3->required = YES;
- input3->gisprompt =_("old,cell,raster");
input3->description=_("Name of the Surface temperature map [degree Kelvin]");
input3->answer =_("tempk");
- input4 = G_define_option() ;
+ input4 = G_define_standard_option(G_OPT_R_INPUT) ;
input4->key =_("time");
- input4->type = TYPE_STRING;
- input4->required = YES;
- input4->gisprompt =_("old,cell,raster");
input4->description=_("Name of the map of local UTC time of satellite overpass [hh.hhh]");
input4->answer =_("time");
- input5 = G_define_option() ;
+ input5 = G_define_standard_option(G_OPT_R_INPUT) ;
input5->key =_("dtair");
- input5->type = TYPE_STRING;
- input5->required = YES;
- input5->gisprompt =_("old,cell,raster");
input5->description=_("Name of the difference of temperature from surface skin to about 2 m height [K]");
input5->answer =_("dtair");
- input6 = G_define_option() ;
+ input6 = G_define_standard_option(G_OPT_R_INPUT) ;
input6->key =_("emissivity");
- input6->type = TYPE_STRING;
- input6->required = YES;
- input6->gisprompt =_("old,cell,raster");
input6->description=_("Name of the emissivity map [-]");
input6->answer =_("emissivity");
- input7 = G_define_option() ;
+ input7 = G_define_standard_option(G_OPT_R_INPUT) ;
input7->key =_("tsw");
- input7->type = TYPE_STRING;
- input7->required = YES;
- input7->gisprompt =_("old,cell,raster");
input7->description=_("Name of the single-way atmospheric transmissivitymap [-]");
input7->answer =_("tsw");
- input8 = G_define_option() ;
+ input8 = G_define_standard_option(G_OPT_R_INPUT) ;
input8->key =_("doy");
- input8->type = TYPE_STRING;
- input8->required = YES;
- input8->gisprompt =_("old,cell,raster");
input8->description=_("Name of the Day Of Year (DOY) map [-]");
input8->answer =_("doy");
- input9 = G_define_option() ;
+ input9 = G_define_standard_option(G_OPT_R_INPUT) ;
input9->key =_("sunzangle");
- input9->type = TYPE_STRING;
- input9->required = YES;
- input9->gisprompt =_("old,cell,raster");
input9->description=_("Name of the sun zenith angle map [degrees]");
input9->answer =_("sunzangle");
- output1 = G_define_option() ;
+ output1 = G_define_standard_option(G_OPT_R_INPUT) ;
output1->key =_("rnet");
- output1->type = TYPE_STRING;
- output1->required = YES;
- output1->gisprompt =_("new,cell,raster");
output1->description=_("Name of the output rnet layer");
output1->answer =_("rnet");
- flag1 = G_define_flag();
- flag1->key = 'q';
- flag1->description = _("Quiet");
@@ -173,7 +140,6 @@
sunzangle = input9->answer;
result = output1->answer;
- verbose = (!flag1->answer);
mapset = G_find_cell2(albedo, "");
if (mapset == NULL) {
@@ -294,8 +260,7 @@
DCELL d_tsw;
DCELL d_doy;
DCELL d_sunzangle;
- if(verbose)
- G_percent(row,nrows,2);
+ G_percent(row,nrows,2);
/* read input maps */
@@ -318,6 +283,7 @@
/*process the data */
for (col=0; col < ncols; col++)
+ //printf("row:%d\tcol:%d\n",row,col);
switch(data_type_albedo){
case CELL_TYPE:
d_albedo = (double) ((CELL *) inrast_albedo)[col];
@@ -326,7 +292,7 @@
d_albedo = (double) ((FCELL *) inrast_albedo)[col];
break;
case DCELL_TYPE:
- d_albedo = ((DCELL *) inrast_albedo)[col];
+ d_albedo = (double) ((DCELL *) inrast_albedo)[col];
break;
switch(data_type_ndvi){
@@ -348,7 +314,7 @@
d_tempk = (double) ((FCELL *) inrast_tempk)[col];
break;
case DCELL_TYPE:
- d_tempk = ((DCELL *) inrast_tempk)[col];
+ d_tempk = (double) ((DCELL *) inrast_tempk)[col];
break;
switch(data_type_dtair){
@@ -359,7 +325,7 @@
d_dtair = (double) ((FCELL *) inrast_dtair)[col];
break;
case DCELL_TYPE:
- d_dtair = ((DCELL *) inrast_dtair)[col];
+ d_dtair = (double) ((DCELL *) inrast_dtair)[col];
break;
switch(data_type_time){
@@ -370,7 +336,7 @@
d_time = (double) ((FCELL *) inrast_time)[col];
break;
case DCELL_TYPE:
- d_time = ((DCELL *) inrast_time)[col];
+ d_time = (double) ((DCELL *) inrast_time)[col];
break;
switch(data_type_emissivity){
@@ -381,7 +347,7 @@
d_emissivity = (double) ((FCELL *) inrast_emissivity)[col];
break;
case DCELL_TYPE:
- d_emissivity = ((DCELL *) inrast_emissivity)[col];
+ d_emissivity = (double) ((DCELL *) inrast_emissivity)[col];
break;
switch(data_type_tsw){
@@ -392,7 +358,7 @@
d_tsw = (double) ((FCELL *) inrast_tsw)[col];
break;
case DCELL_TYPE:
- d_tsw = ((DCELL *) inrast_tsw)[col];
+ d_tsw = (double) ((DCELL *) inrast_tsw)[col];
break;
switch(data_type_doy){
@@ -403,7 +369,7 @@
d_doy = (double) ((FCELL *) inrast_doy)[col];
break;
case DCELL_TYPE:
- d_doy = ((DCELL *) inrast_doy)[col];
+ d_doy = (double) ((DCELL *) inrast_doy)[col];
break;
switch(data_type_sunzangle){
@@ -414,38 +380,26 @@
d_sunzangle = (double) ((FCELL *) inrast_sunzangle)[col];
break;
case DCELL_TYPE:
- d_sunzangle = ((DCELL *) inrast_sunzangle)[col];
+ d_sunzangle = (double) ((DCELL *) inrast_sunzangle)[col];
break;
- }else if(G_is_d_null_value(&d_dtair)){
- }else if(G_is_d_null_value(&d_emissivity)){
- }else if(G_is_d_null_value(&d_tsw)){
- }else if(G_is_d_null_value(&d_doy)){
- }else if(G_is_d_null_value(&d_sunzangle)){
+ G_is_d_null_value(&d_dtair)||
+ G_is_d_null_value(&d_time)||
+ G_is_d_null_value(&d_emissivity)||
+ G_is_d_null_value(&d_tsw)||
+ G_is_d_null_value(&d_doy)||
+ G_is_d_null_value(&d_sunzangle)){
}else {
/* calculate the net radiation */
d = r_net(d_albedo,d_ndvi,d_tempk,d_dtair,d_emissivity,d_tsw,d_doy,d_time,d_sunzangle);
- // printf(" || d=%5.3f",d);
+ outrast[col] = d;
// printf(" -> %5.3f\n",d);
- // if(row==50){
- // exit(EXIT_SUCCESS);
G_fatal_error(_("Cannot write to output raster file"));
@@ -472,7 +426,11 @@
G_free (outrast);
+ G_add_color_rule(0,0,0,0,900,255,255,255,&colors);
+ /* Metadata */
Modified: grass-addons/gipe/i.evapo.potrad/solar_day.c
--- grass-addons/gipe/i.evapo.potrad/solar_day.c 2008-05-18 09:53:19 UTC (rev 31411)
+++ grass-addons/gipe/i.evapo.potrad/solar_day.c 2008-05-18 12:46:59 UTC (rev 31412)
@@ -10,11 +10,14 @@
double ws, cosun, latrad, delta, deltarad, ds, result;
+ //Sun-Earth Distance (ds; A.U.)
ds = 1.0 + 0.01672 * sin(2*PI*(doy-93.5)/365.0);
+ //Solar declination (delta; radians)
deltarad = 0.4093*sin((2*PI*doy/365)-1.39);
+ //Convert latitude in radians
latrad = lat * PI / 180.0;
ws = acos(-tan(latrad)*tan(deltarad));
cosun = ws*sin(deltarad)*sin(latrad)+cos(deltarad)*cos(latrad)*sin(ws);
