[GRASS-SVN] r31567 - grass/branches/develbranch_6/doc
svn_grass at osgeo.org
Thu May 29 10:46:20 EDT 2008
Author: martinl
Date: 2008-05-29 10:46:20 -0400 (Thu, 29 May 2008)
New Revision: 31567
grass/branches/develbranch_6/doc/debugging.txt
NVIZ debug tip added
Modified: grass/branches/develbranch_6/doc/debugging.txt
--- grass/branches/develbranch_6/doc/debugging.txt 2008-05-29 08:27:21 UTC (rev 31566)
+++ grass/branches/develbranch_6/doc/debugging.txt 2008-05-29 14:46:20 UTC (rev 31567)
@@ -50,7 +50,13 @@
at the start of nviz2.2_script, change the DEBUG setting to:
set DEBUG 1
+To debug NVIZ using gdb:
+$ gdb $GISBASE/etc/nviz2.2/nviz
+> attach <pid>
+> break Create_OS_Ctx
+> cont
To make gcc less tolerant in accepting errors and code flaws, compile
