[GRASS-SVN] r31568 - grass/trunk/doc
Thu May 29 10:47:33 EDT 2008
Author: martinl
Date: 2008-05-29 10:47:33 -0400 (Thu, 29 May 2008)
New Revision: 31568
   grass/trunk/doc/debugging.txt
NVIZ debug tip added (merge devbr6, r31567)
Modified: grass/trunk/doc/debugging.txt
--- grass/trunk/doc/debugging.txt	2008-05-29 14:46:20 UTC (rev 31567)
+++ grass/trunk/doc/debugging.txt	2008-05-29 14:47:33 UTC (rev 31568)
@@ -50,7 +50,13 @@
    at the start of nviz2.2_script, change the DEBUG setting to:
    set DEBUG 1
+To debug NVIZ using gdb:
+$ gdb $GISBASE/etc/nviz2.2/nviz
+> attach <pid>
+> break Create_OS_Ctx
+> cont
 To make gcc less tolerant in accepting errors and code flaws, compile
