[GRASS-SVN] r34188 - grass/trunk/scripts/v.db.join
svn_grass at osgeo.org
Fri Nov 7 17:12:12 EST 2008
Author: glynn
Date: 2008-11-07 17:12:12 -0500 (Fri, 07 Nov 2008)
New Revision: 34188
grass/trunk/scripts/v.db.join/v.db.join.py
Add gisprompts
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2008-11-07 21:57:52 UTC (rev 34187)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-11-07 22:12:12 UTC (rev 34188)
@@ -34,6 +34,7 @@
#% description: Layer where to join
#% answer: 1
#% required : no
+#% gisprompt: old_layer,layer,layer
#%end
#%option
@@ -41,6 +42,7 @@
#% type: string
#% description: Join column in map table
#% required : yes
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#%end
#%option
@@ -48,6 +50,7 @@
#% type: string
#% description: Other table name
#% required : yes
+#% gisprompt: old_dbtable,dbtable,dbtable
#%end
#%option
@@ -55,6 +58,7 @@
#% type: string
#% description: Join column in other table
#% required : yes
#%end
import sys
