[GRASS-SVN] r34187 - grass/trunk/locale/po
svn_grass at osgeo.org
Fri Nov 7 16:57:53 EST 2008
Author: neteler
Date: 2008-11-07 16:57:52 -0500 (Fri, 07 Nov 2008)
New Revision: 34187
grass/trunk/locale/po/grassmods_de.po
Robert Nuske <rnuske gwdg.de>: cont'ed
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2008-11-07 21:54:18 UTC (rev 34186)
+++ grass/trunk/locale/po/grassmods_de.po 2008-11-07 21:57:52 UTC (rev 34187)
@@ -11,7 +11,7 @@
"Project-Id-Version: grassmods_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2008-10-11 22:08+0200\n"
-"PO-Revision-Date: 2008-10-27 09:44+0100\n"
+"PO-Revision-Date: 2008-11-03 22:31+0100\n"
"Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -42,12 +42,11 @@
#: ../db/base/execute.c:76 ../db/base/execute.c:81
#, fuzzy, c-format
msgid "Error while executing: '%s'"
-msgstr "Fehler beim Ausführen von: '%s'"
+msgstr "Fehler beim Ausführen von: <%s>."
#: ../db/base/execute.c:106 ../db/base/copy.c:34 ../db/base/select.c:230
-#, fuzzy
msgid "database, attribute table, SQL"
-msgstr "Datenbank, Attributtabelle"
+msgstr "Datenbank, Attributtabelle, SQL"
#: ../db/base/execute.c:107
msgid "Executes any SQL statement."
@@ -75,9 +74,8 @@
msgstr "Erzeugt eine leere Datenbank."
#: ../db/base/copy.c:35
-#, fuzzy
msgid "Copy a table."
-msgstr "Kopiere Tabellen..."
+msgstr "Kopiere eine Tabelle."
#: ../db/base/copy.c:37
#, fuzzy
@@ -208,7 +206,7 @@
#: ../db/base/select.c:206 ../vector/v.db.select/main.c:75
msgid "Null value indicator"
-msgstr "Nullwert-Indikator"
+msgstr "NULL-Wert-Indikator"
#: ../db/base/select.c:210
msgid "Name of file with sql statement"
@@ -410,7 +408,7 @@
#: ../db/drivers/mysql/describe.c:120
#, fuzzy, c-format
msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr "MySQL-Treiber: Spalte '%s', Typ %d ist nicht definiert."
+msgstr "MySQL-Treiber: Spalte <%s>, Typ %d wird nicht unterstützt."
#: ../db/drivers/mysql/describe.c:126
#, fuzzy, c-format
@@ -477,12 +475,12 @@
#, fuzzy, c-format
msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
msgstr ""
-"PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry' wird nicht konvertiert."
+"PG-Treiber: PostGIS Spalte <%s>, vom Typ 'geometry' wird nicht konvertiert."
#: ../db/drivers/postgres/describe.c:109
#, fuzzy, c-format
msgid "pg driver: column '%s', type %d is not supported"
-msgstr "PG-Treiber: Spalte '%s', Typ %d wird nicht unterstützt."
+msgstr "PG-Treiber: Spalte <%s>, Typ %d wird nicht unterstützt."
#: ../db/drivers/postgres/describe.c:116
#, fuzzy, c-format
@@ -518,7 +516,7 @@
#: ../db/drivers/ogr/describe.c:93
#, fuzzy, c-format
msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr "OGR-Treiber: Spalte '%s', OGR Typ %d wird nicht unterstützt."
+msgstr "OGR-Treiber: Spalte <%s>, OGR Typ %d wird nicht unterstützt."
#: ../db/drivers/ogr/describe.c:153
#, fuzzy, c-format
@@ -656,9 +654,9 @@
msgstr "Kategorie-Dateien für <%s> nicht vorhanden. "
#: ../display/d.histogram/main.c:178 ../display/d.legend/main.c:484
-#, fuzzy, c-format
+#, c-format
msgid "Range information for <%s> not available"
-msgstr "Bereich-Information für Karte [%s] nicht vorhanden."
+msgstr "Bereich-Information für <%s> nicht vorhanden."
#: ../display/d.text/main.c:139
msgid ""
@@ -741,9 +739,8 @@
msgstr "Schrift-Größe ist Höhe in Pixel."
#: ../display/d.text/main.c:250
-#, fuzzy
msgid "Ignored (compatibility with d.text.freetype)"
-msgstr "Kommando-Modus (kompatibel mit d.text)."
+msgstr "Ignoriert (kompatibel mit d.text.freetype)."
#: ../display/d.text/main.c:260
msgid "Please choose only one placement method"
@@ -776,7 +773,7 @@
#: ../display/d.text/main.c:541
#, fuzzy, c-format
msgid "[%s]: No such color. Use '%s'"
-msgstr "[%s]: Diese Farbe gibt es nicht, verwende '%s'."
+msgstr "<%s>: Diese Farbe gibt es nicht, verwende <%s>."
#: ../display/d.erase/main.c:32
msgid "Erase the contents of the active display frame with user defined color"
@@ -885,8 +882,9 @@
msgstr "Kann die Rasterkarte <%s> nicht öffnen."
#: ../display/d.profile/main.c:258
+#, fuzzy
msgid "At least two points are required"
-msgstr ""
+msgstr "Nicht genügend Punkte, %d werden benötigt."
#: ../display/d.measure/main.c:49
msgid ""
@@ -1170,9 +1168,9 @@
msgstr "Kann Eingabe nicht von <%s> lesen."
#: ../display/d.font/main.c:109
-#, fuzzy, c-format
+#, c-format
msgid "Font path %s is not a file"
-msgstr "%s ist keine gültige Regel."
+msgstr "Font-Pfad %s ist keine Datei."
#: ../display/d.font/main.c:126
#, c-format
@@ -1214,7 +1212,7 @@
#: ../display/d.rast.num/main.c:144
#, c-format
msgid "rows: %d"
-msgstr "Reihen: %d"
+msgstr "Zeilen: %d"
#: ../display/d.rast.num/main.c:145
#, c-format
@@ -1408,15 +1406,15 @@
#: ../display/d.title/main.c:78
msgid "Do a fancier title"
-msgstr ""
+msgstr "Mache einen aufwändigen Titel"
#: ../display/d.title/main.c:83
msgid "Do a simple title"
-msgstr ""
+msgstr "Mache einen einfachen Titel"
#: ../display/d.title/main.c:101
msgid "Title can be fancy or simple, not both"
-msgstr ""
+msgstr "Titel kann einfach oder aufwändig sein, aber nicht beides."
#: ../display/d.title/main.c:104
msgid "No map name given"
@@ -1464,14 +1462,13 @@
msgstr "Linien-Farbe"
#: ../display/d.geodesic/main.c:69
-#, fuzzy
msgid "Text color or \"none\""
-msgstr "Text-Farbe"
+msgstr "Text-Farbe oder \"none\"."
#: ../display/d.geodesic/main.c:77 ../display/d.rhumbline/main.c:76
-#, fuzzy, c-format
+#, c-format
msgid "Location is not %s"
-msgstr "Location: %s\n"
+msgstr "Location ist nicht %s"
#: ../display/d.geodesic/main.c:80 ../display/d.rhumbline/main.c:80
#: ../display/d.path/main.c:139
@@ -1482,16 +1479,16 @@
#: ../display/d.geodesic/main.c:89 ../display/d.geodesic/main.c:92
#: ../display/d.rhumbline/main.c:83 ../display/d.rhumbline/main.c:86
#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#, fuzzy, c-format
+#, c-format
msgid "%s - illegal longitude"
-msgstr "%s - unzulässiger x-Wert."
+msgstr "%s - ungültiger Longitude."
#: ../display/d.labels/color.c:66 ../display/d.graph/do_graph.c:104
#: ../display/d.graph/do_graph.c:354 ../display/d.graph/do_graph.c:369
#: ../display/d.graph/main.c:106 ../display/d.rast/display.c:23
#, fuzzy, c-format
msgid "[%s]: No such color"
-msgstr "[%s]: Diese Farbe gibt es nicht."
+msgstr "<%s>: Diese Farbe gibt es nicht."
#: ../display/d.labels/do_labels.c:143
#, c-format
@@ -1671,15 +1668,15 @@
"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet.\n"
#: ../display/d.legend/main.c:322
-#, fuzzy, c-format
+#, c-format
msgid "Range information for <%s> not available (run r.support)"
msgstr ""
-"Bereich-Information für Karte [%s] nicht vorhanden. (Benutzen Sie r.support)."
+"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
+"aus)."
#: ../display/d.legend/main.c:327
-#, fuzzy
msgid "Input map contains no data"
-msgstr "Das Array enthält keine Daten."
+msgstr "Eingabekarte enthält keine Daten."
#: ../display/d.legend/main.c:340 ../display/d.legend/main.c:498
msgid "Color range exceeds lower limit of actual data"
@@ -1706,7 +1703,7 @@
"aktuellen Fensters."
#: ../display/d.legend/main.c:509
-#, fuzzy, c-format
+#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
msgstr "use=%s out of range [%.3f, %.3f]. (extend with range= ?)"
@@ -1719,12 +1716,12 @@
#: ../display/d.graph/do_graph.c:266 ../display/d.graph/do_graph.c:333
#, fuzzy, c-format
msgid "Problem parsing command [%s]"
-msgstr "Probleme beim Interpretieren des Kommandos [%s]."
+msgstr "Probleme bei der Interpretation des Kommandos <%s>."
#: ../display/d.graph/do_graph.c:64 ../display/d.graph/do_graph.c:80
#, fuzzy, c-format
msgid "Problem parsing coordinates [%s]"
-msgstr "Probleme beim Auslesen der Koordinaten [%s]."
+msgstr "Problem bei der Interpretation der Koordinaten <%s>."
#: ../display/d.graph/do_graph.c:97
msgid "Unable to read color"
@@ -1866,7 +1863,6 @@
msgstr "Darstellung, Vektor"
#: ../display/d.vect/main.c:123
-#, fuzzy
msgid "Displays vector data in the active frame on the graphics monitor."
msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
@@ -1909,11 +1905,8 @@
#: ../display/d.vect/main.c:163 ../display/d.vect/main.c:173
#: ../display/d.vect/main.c:261 ../display/d.vect/main.c:271
-#, fuzzy
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-"Hintergrundfarbe, entweder eine GRASS Standardfarbe, ein R:G:B Tripel oder "
-"\"none\" für nichts."
+msgstr "Entweder eine Standard GRASS-Farbe, ein R:G:B-Tripel oder \"none\"."
#: ../display/d.vect/main.c:169
msgid "Area fill color"
@@ -1924,9 +1917,8 @@
msgstr "Name der Farbdefinitionsspalte (mit dem Schalter -a zu benutzen)."
#: ../display/d.vect/main.c:186
-#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr "Name der Farbdefinitionsspalte (mit dem Schalter -a zu benutzen)."
+msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
#: ../display/d.vect/main.c:195 ../display/d.vect/main.c:200
#: ../display/d.vect/main.c:208
@@ -1979,9 +1971,8 @@
msgstr "Label Farbe"
#: ../display/d.vect/main.c:251
-#, fuzzy
msgid "Either a standard color name or R:G:B triplet"
-msgstr "Textfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
+msgstr "Entweder ein Standardfarbname oder ein R:G:B Tripel."
#: ../display/d.vect/main.c:258
msgid "Label background color"
@@ -2035,9 +2026,8 @@
"(oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
#: ../display/d.vect/main.c:342
-#, fuzzy
msgid "Use values from 'cats' option as feature id"
-msgstr "Benutze Werte der 'cats' Option als Linien-ID."
+msgstr "Verwende Werte der Option 'cats' Option als Fature-ID."
#: ../display/d.vect/main.c:346
msgid "Colorize polygons according to z height"
@@ -2055,7 +2045,7 @@
#: ../display/d.thematic.area/main.c:285
#, fuzzy, c-format
msgid "Unknown color: [%s]"
-msgstr "Unbekannte Farbe: [%s]."
+msgstr "Unbekannte Farbe: <%s>."
#: ../display/d.vect/main.c:441 ../vector/v.surf.rst/main.c:394
#: ../vector/v.extract/main.c:261
@@ -2129,10 +2119,9 @@
msgstr "Kein Attribut für cat %d: %s gefunden."
#: ../display/d.vect.chart/main.c:65
-#, fuzzy
msgid ""
"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr "Stellt Diagramme von GRASS-Vektordaten im aktiven Grafik-Fenster dar."
+msgstr "Stellt Diagramme von Vektordaten im aktiven Grafik-Fenster dar."
#: ../display/d.vect.chart/main.c:82
msgid "Chart type"
@@ -2209,7 +2198,7 @@
#: ../display/d.rast.arrow/main.c:135
msgid "Color for drawing X's (Null values)"
-msgstr "Farbe zum Zeichnen der X (Null-Werte)."
+msgstr "Farbe zum Zeichnen der X (NULL-Werte)."
#: ../display/d.rast.arrow/main.c:143
msgid "Color for showing unknown information"
@@ -2271,11 +2260,11 @@
#: ../display/d.thematic.area/main.c:88
msgid "Data to be classified: column name or expression"
-msgstr ""
+msgstr "Zu klassifizierende Daten: Spaltenname oder Ausdruck."
#: ../display/d.thematic.area/main.c:95
msgid "Class breaks, without minimum and maximum"
-msgstr ""
+msgstr "Klassengrenzen, ohne Minimum und Maximum."
#: ../display/d.thematic.area/main.c:103 ../vector/v.class/main.c:67
#, fuzzy
@@ -2295,7 +2284,7 @@
#: ../display/d.thematic.area/main.c:122
msgid "Colors (one per class)."
-msgstr ""
+msgstr "Farben (eine pro Klasse)."
#: ../display/d.thematic.area/main.c:137 ../display/d.thematic.area/main.c:145
msgid "Boundaries"
@@ -2346,9 +2335,10 @@
msgstr ""
#: ../display/d.thematic.area/main.c:333
-#, fuzzy
msgid "You must either give classbreaks or a classification algorithm"
-msgstr "%s: Fehler im Klassifikationsalgorithmus."
+msgstr ""
+"Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus "
+"angeben."
#: ../display/d.thematic.area/main.c:346
#, c-format
@@ -2363,11 +2353,13 @@
msgstr "Fehler beim Interpretieren der Farbe %s."
#: ../display/d.thematic.area/main.c:425
-#, fuzzy, c-format
+#, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
-msgstr "Initiale Anzahl der Klassen: %s"
+msgstr ""
+"\n"
+"Gesamtzahl der Datensätze: %.0f\n"
#: ../display/d.thematic.area/main.c:427
#, c-format
@@ -2422,7 +2414,7 @@
#: ../display/d.rast/main.c:85
msgid "Background color (for null)"
-msgstr "Hintergrundfarbe (für NULL)"
+msgstr "Hintergrundfarbe (für NULL)."
#: ../display/d.rast/main.c:89
msgid "Make null cells opaque"
@@ -2444,11 +2436,10 @@
"Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
#: ../display/d.extract/main.c:52
-#, fuzzy
msgid "Selects and extracts vectors with mouse into new vector map."
msgstr ""
-"Interaktives Auswählen und extrahieren von Vektoren mit der Maus. Als "
-"Resultat entsteht eine neue Karte."
+"Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine "
+"neue Karte."
#: ../display/d.extract/main.c:65 ../display/d.path/main.c:98
msgid "Original line color"
@@ -2501,7 +2492,7 @@
#: ../display/d.rgb/main.c:59
msgid "Overlay (non-null values only)"
-msgstr "Überlagerung (nur nicht-Null Werte)."
+msgstr "Überlagerung (nur nicht-NULL Werte)."
#: ../display/d.rgb/main.c:64 ../raster/r.out.ppm3/main.c:63
#, c-format
@@ -2510,7 +2501,7 @@
#: ../display/d.rgb/main.c:115
msgid "Error reading row of data"
-msgstr "Fehler beim Lesen eine Datenreihe."
+msgstr "Fehler beim Lesen eine Datenzeile."
#: ../display/d.where/main.c:46
#, fuzzy
@@ -2524,7 +2515,7 @@
#: ../display/d.where/main.c:56
#, fuzzy
msgid "Display coordinates to convert"
-msgstr "Name des Grafik-Fensters, das gestartet werden soll."
+msgstr "Keine Koordinaten angegeben."
#: ../display/d.where/main.c:61
#, fuzzy
@@ -2752,11 +2743,8 @@
msgstr "%d Raster%s, %d Vektor%s\n"
#: ../display/d.zoom/main.c:231
-#, fuzzy
msgid "No previous zoom available"
-msgstr ""
-"Das ist das erste Mal, dass 'd.zoom' benutzt wird; keine vorherigen "
-"Zoomstufen vorhanden."
+msgstr "Keine vorherige Zoomeinstellung vorhanden."
#: ../display/d.zoom/main.c:235
msgid "Returning to previous zoom"
@@ -2912,9 +2900,8 @@
#: ../display/d.grid/main.c:118 ../display/d.grid/main.c:123
#: ../display/d.grid/main.c:128
-#, fuzzy
msgid "Disable"
-msgstr "Fehlende Tabelle."
+msgstr "ausschalten"
#: ../display/d.grid/main.c:122
msgid "Disable border drawing"
@@ -2967,9 +2954,8 @@
msgstr ""
#: ../display/d.nviz/main.c:69
-#, fuzzy
msgid "Creates fly-through script to run in NVIZ."
-msgstr "Erzeuge ein lauffähiges NVIZ-Skript eines Gelände-Durchflugs."
+msgstr "Erzeuge ein Skript für Gelände-Durchflugs für nviz."
#: ../display/d.nviz/main.c:74
msgid "Name of output script"
@@ -3061,9 +3047,8 @@
msgstr "Darstellung, Setup"
#: ../display/d.colortable/main.c:65
-#, fuzzy
msgid "Displays the color table associated with a raster map layer."
-msgstr "Erstellt/modifiziert die Farbtabelle einer Rasterkarte."
+msgstr "Stellt die Farbtabelle einer Rasterkarte dar."
#: ../display/d.colortable/main.c:134
#, fuzzy, c-format
@@ -3086,20 +3071,21 @@
msgstr "Kosten auf Basis des Netzwerkes = %f\n"
#: ../display/d.path/select.c:127
-#, fuzzy, c-format
+#, c-format
msgid ""
" Distance to the network = %f, distance from the network = %f\n"
"\n"
-msgstr "Abstand zum Netzwerk = %f, Abstand vom Netzwerk = %f\n"
+msgstr ""
+" Abstand zum Netzwerk = %f, Abstand vom Netzwerk = %f\n"
+"\n"
#: ../display/d.path/main.c:48
msgid "display, networking"
msgstr "Darstellung, Netzwerk"
#: ../display/d.path/main.c:50
-#, fuzzy
msgid "Finds shortest path for selected starting and ending node."
-msgstr "Finden."
+msgstr "Finde den kürzesten Weg für die gewählten Start- und Endpunkte."
#: ../display/d.path/main.c:57 ../vector/v.net.salesman/main.c:109
#: ../vector/v.net.iso/main.c:84 ../vector/v.net.path/main.c:49
@@ -3370,7 +3356,7 @@
#: ../general/g.gisenv/main.c:75
#, fuzzy
msgid "-s and -n are mutually exclusive"
-msgstr "weight= und -c schließen sich gegenseitig aus."
+msgstr "-r und -e schliessen sich gegenseitig aus."
#: ../general/g.access/main.c:39
msgid "Controls access to the current mapset for other users on the system."
@@ -3390,9 +3376,8 @@
"Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
#: ../general/g.access/main.c:67
-#, fuzzy
msgid "Unable to determine mapset permissions"
-msgstr "Kann die Zugriffs-Erlaubnis des Mapsets nicht herausfinden."
+msgstr "Kann die Zugriffsrechte des Mapsets nicht ermitteln."
#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:39
#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:99
@@ -3479,7 +3464,7 @@
#: ../general/manage/cmd/remove.c:38 ../general/g.mremove/check_reclass.c:14
#, fuzzy, c-format
msgid "[%s@%s] is a base map for [%s]. Remove forced."
-msgstr "[%s@%s] ist die Ausgangskarte für [%s]. Löschen wurde erzwungen."
+msgstr "[%s@%s] ist die Ausgangskarte für <%s>. Löschen wurde erzwungen."
#: ../general/manage/cmd/remove.c:41 ../general/g.mremove/check_reclass.c:18
#, c-format
@@ -3593,16 +3578,15 @@
#: ../general/g.proj/input.c:98
#, fuzzy, c-format
msgid "Unable to open file [%s] for reading"
-msgstr "Kann Zelldatei [%s] nicht zum Lesen öffnen."
+msgstr "Kann die Datei <%s> nicht zum Lesen öffnen."
#: ../general/g.proj/input.c:143
msgid "Can't parse PROJ.4-style parameter string"
msgstr "Kann den PROJ.4 Parameterstring nicht verstehen."
#: ../general/g.proj/input.c:181
-#, fuzzy
msgid "Unable to translate EPSG code"
-msgstr "Kann kein Face erzeugen."
+msgstr "Kann den EPSG-Code nicht übersetzen."
#: ../general/g.proj/input.c:218
msgid "Trying to open with OGR..."
@@ -3617,9 +3601,9 @@
msgstr "Versuche mit GDAL zu öffnen..."
#: ../general/g.proj/input.c:254
-#, fuzzy, c-format
+#, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr "Kann die georeferenzierte Datei %s nicht mit GDAL oder OGR lesen."
+msgstr "Konnte die georeferenzierte Datei %s nicht mit GDAL oder OGR lesen."
#: ../general/g.proj/input.c:259
#, c-format
@@ -3653,7 +3637,7 @@
#: ../general/g.proj/output.c:165
msgid "Unspecified error while creating new location"
-msgstr ""
+msgstr "Unbekannter Fehler beim Erzeugen einer neuen Location."
#: ../general/g.proj/output.c:176
#, c-format
@@ -3770,7 +3754,7 @@
#, fuzzy, c-format
msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
msgstr ""
-"Nur eine dieser Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
+"Nur eine der Optionen <%s>, <%s>, <%s> oder <%s> kann angegeben werden."
#: ../general/g.proj/main.c:220
msgid "Projection files missing"
@@ -3780,7 +3764,7 @@
#, fuzzy, c-format
msgid "Only one of -%c, -%c, -%c, -%c or -%c flags may be specified"
msgstr ""
#: ../general/g.proj/main.c:259
msgid "No output! Please specify an output option."
@@ -3789,30 +3773,27 @@
#: ../general/g.transform/main.c:93
#, c-format
msgid "Not enough points, %d are required"
-msgstr ""
#: ../general/g.transform/main.c:192
msgid "Poorly placed control points"
-msgstr ""
+msgstr "Schlecht platzierte Kontrollpunkte."
#: ../general/g.transform/main.c:194
msgid "Insufficient memory"
-msgstr ""
+msgstr "Ungenügend Speicher."
#: ../general/g.transform/main.c:196
-#, fuzzy
msgid "Parameter error"
-msgstr "Parameter"
+msgstr "Parameterfehler"
#: ../general/g.transform/main.c:198
-#, fuzzy
msgid "No active control points"
-msgstr "Keine Startpunkte."
+msgstr "Keine aktiven Kontrollpunkte."
#: ../general/g.transform/main.c:249
-#, fuzzy
msgid "general, transformation, GCP"
-msgstr "Vektor, Interpolation"
+msgstr "Allgemein, Transformation, GCP"
#: ../general/g.transform/main.c:251
#, fuzzy
@@ -3862,10 +3843,9 @@
"Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
#: ../general/g.mapsets/main.c:85
-#, fuzzy
msgid "Name(s) of existing mapset(s) to remove from search list"
msgstr ""
-"Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
+"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
#: ../general/g.mapsets/main.c:89
msgid "List all available mapsets"
@@ -3885,9 +3865,9 @@
msgstr "Mapset <%s> nicht gefunden."
#: ../general/g.mapsets/main.c:148
-#, fuzzy, c-format
+#, c-format
msgid "Mapset <%s> added to search path"
-msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
+msgstr "Mapset <%s> zum Suchpfad hinzugefügt."
#: ../general/g.mapsets/main.c:172
#, c-format
@@ -3907,14 +3887,12 @@
msgstr "Name des Elements."
#: ../general/g.findfile/main.c:53
-#, fuzzy
msgid "Name of a mapset"
-msgstr "Name des Zielmapsets."
+msgstr "Name eines Mapsets"
#: ../general/g.findfile/main.c:60
-#, fuzzy
msgid "Name of an existing map"
-msgstr "Name einer existierenden Rasterkarte."
+msgstr "Name einer existierenden Karte."
#: ../general/g.findfile/main.c:74
#, c-format
@@ -4082,7 +4060,7 @@
#: ../general/g.region/main.c:241
msgid "Number of rows in the new region"
-msgstr "Anzahl der Reihen in der neuen Region."
+msgstr "Anzahl der Zeilen in der neuen Region."
#: ../general/g.region/main.c:242 ../general/g.region/main.c:251
#: ../general/g.region/main.c:261 ../general/g.region/main.c:271
@@ -4118,7 +4096,7 @@
#: ../general/g.region/main.c:307
msgid "Shrink region until it meets non-NULL data from this raster map"
msgstr ""
-"Schrumpfe die Region so lange, bis sie auf Nicht-NULL Zellen dieser "
+"Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
"Rasterkarte stösst."
#: ../general/g.region/main.c:318
@@ -4218,19 +4196,17 @@
msgstr "Fehler in pj_do_proj (Projektion des Eingabekoordinatenpaars)."
#: ../general/g.region/printwindow.c:406
-#, fuzzy
msgid "You are already in Lat/Long. Use the -p flag instead."
msgstr ""
-"Sie sind bereits in lat/long. Verwenden Sie den Schalter -p statt dessen."
+"Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
#: ../general/g.region/printwindow.c:408
-#, fuzzy
msgid ""
"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
"the -p flag instead."
msgstr ""
-"Sie befinden sich in einer XY-Location (keine Projektion möglich, verwenden "
-"Sie statt dessen den Schalter -p)."
+"Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
+"ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
#: ../general/g.region/printwindow.c:502
msgid ""
@@ -4605,9 +4581,8 @@
"Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
#: ../general/g.mapset/main.c:154
-#, fuzzy
msgid "Unable to read GIS_LOCK environment variable"
-msgstr "Kann die EW-Auflösung (ew_res) nicht lesen."
+msgstr "Kann die Umgebungsvariable GIS_LOCK nicht lesen."
#: ../general/g.mapset/main.c:168
#, c-format
@@ -4639,71 +4614,70 @@
msgstr ""
#: ../general/g.mremove/do_remove.c:20
-#, fuzzy, c-format
+#, c-format
msgid "Removing %s <%s>"
-msgstr "Lese <%s> in <%s>"
+msgstr "Entferne %s <%s>."
#: ../general/g.mremove/do_remove.c:41 ../general/g.mremove/do_remove.c:83
-#, fuzzy
msgid "couldn't be removed"
-msgstr "Icon, das entfernt werden soll."
+msgstr "konnte nicht entfernt werden."
#: ../general/g.mremove/do_remove.c:61
-#, fuzzy, c-format
+#, c-format
msgid "%s: couldn't be removed"
-msgstr "%s Datei(en), die entfernt werden sollen."
+msgstr "%s: konnte nicht entfernt werden."
#: ../general/g.mremove/do_remove.c:66 ../general/g.mremove/do_remove.c:88
#, c-format
msgid "%s: missing"
-msgstr ""
+msgstr "%s: fehlt."
#: ../general/g.mremove/do_remove.c:70 ../general/g.mremove/do_remove.c:92
-#, fuzzy, c-format
+#, c-format
msgid "%s: removed"
-msgstr "%d Vertices gelöscht"
+msgstr "%s: gelöscht."
#: ../general/g.mremove/do_remove.c:99
-#, fuzzy, c-format
+#, c-format
msgid "<%s> nothing removed"
-msgstr "<%s> nicht gefunden werden."
+msgstr "<%s> nichts gelöscht."
#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:119
msgid "Use basic regular expressions instead of wildcards"
-msgstr ""
+msgstr "Verwende einfache reguläre Ausdrücke an Stelle von wildcards."
#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:124
msgid "Use extended regular expressions instead of wildcards"
-msgstr ""
+msgstr "Verwende erweiterte reguläre Ausdrücke an Stelle von wildcards."
#: ../general/g.mremove/main.c:76
#: ../locale/scriptstrings/db.droptable_to_translate.c:3
#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
msgid "Force removal (required for actual deletion of files)"
-msgstr ""
+msgstr "Erzwinge das Löschen (benötigt um tatsächlich Dateien zu löschen)."
#: ../general/g.mremove/main.c:80
-#, fuzzy
msgid "Remove base maps"
-msgstr "Entfernen"
+msgstr "Entferne Basiskarten"
#: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:148
-#, fuzzy
msgid "-r and -e are mutually exclusive"
#: ../general/g.mremove/main.c:107
msgid "The following files would be deleted:"
-msgstr ""
+msgstr "Die folgenden Karten würden gelöscht:"
#: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:156
-#, fuzzy, c-format
+#, c-format
msgid "Unable to compile regular expression %s"
-msgstr "Kann die Ergebnis-Datei <%s> nicht öffnen."
+msgstr "Kann den regulären Ausdruck nicht kompilieren %s"
#: ../general/g.mremove/main.c:158
msgid "You must use the force flag to actually remove them. Exiting."
msgstr ""
+"Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
+"mich."
#: ../general/g.mremove/read_list.c:144 ../general/g.mlist/read_list.c:144
#, c-format
@@ -4712,6 +4686,9 @@
"Line: %d\n"
"%s"
msgstr ""
+"Formatfehler: <%s>\n"
+"Zeile: %d\n"
+"%s"
#: ../general/g.mlist/main.c:97
msgid "Map name search pattern (default: all)"
@@ -4720,21 +4697,20 @@
#: ../general/g.mlist/main.c:106
msgid "One-character output separator, newline, comma, space, or tab"
msgstr ""
+"Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
+"Tabulator."
#: ../general/g.mlist/main.c:128
-#, fuzzy
msgid "Print data types"
-msgstr "Gebe nur Rasterkartentyp aus."
+msgstr "Gebe Datentypen aus."
#: ../general/g.mlist/main.c:132
-#, fuzzy
msgid "Print mapset names"
msgstr "Gebe den Namen des Mapsets aus."
#: ../general/g.mlist/main.c:136
-#, fuzzy
msgid "Pretty printing in human readable format"
-msgstr "Unterdrücke Headerinformationen."
+msgstr "Schöne Ausgabe in menschenlesbaren Format."
#: ../imagery/i.ifft/orig_wind.c:27
msgid "The real and imaginary original windows did not match."
@@ -4803,7 +4779,7 @@
#: ../imagery/i.ifft/main.c:120
#, c-format
msgid "Power 2 values : [%d] rows [%d] columns."
-msgstr "Hoch zwei Werte: [%d] Reihen [%d] Spalten."
+msgstr "'hoch zwei'-Werte: [%d] Zeilen [%d] Spalten."
#: ../imagery/i.ifft/main.c:130
msgid "Reading the raster maps..."
@@ -5057,7 +5033,7 @@
#: ../imagery/i.smap/bouman/model.c:48
#, c-format
msgid "Nonpositive eigenvalues for class [%d] subclass [%d]."
-msgstr "Nichtpositive Eigenwerte für Klasse [%d] Unterklasse [%d]."
+msgstr "Nichtpositive Eigenwerte für Klasse <%d> Unterklasse <%d>."
#: ../imagery/i.smap/bouman/interp.c:38
msgid "pyramid constructed."
@@ -5097,7 +5073,7 @@
#: ../imagery/i.smap/bouman/segment.c:93
#, c-format
msgid "Processing rows %d-%d (of %d), cols=%d-%d (of %d)"
-msgstr "Prozessiere Reihen %d-%d (von %d), Spalten=%d-%d (von %d)"
+msgstr "Verarbeite Zeilen %d-%d (von %d), Spalten=%d-%d (von %d)"
#: ../imagery/i.smap/bouman/multialloc.c:115
msgid "get_img: out of memory."
@@ -5115,18 +5091,18 @@
#: ../imagery/i.smap/shapiro/read_sig.c:13 ../imagery/i.gensig/openfiles.c:16
#, fuzzy, c-format
msgid "Unable to read REF file for subgroup [%s] in group [%s]."
-msgstr "Kann die REF-Datei für Untergruppe [%s] in Gruppe [%s] nicht lesen."
+msgstr "Kann die REF-Datei für Untergruppe <%s> in Gruppe <%s> nicht lesen."
#: ../imagery/i.smap/shapiro/openfiles.c:19
#: ../imagery/i.smap/shapiro/read_sig.c:17 ../imagery/i.gensig/openfiles.c:20
#, fuzzy, c-format
msgid "Subgroup [%s] in group [%s] contains no files."
-msgstr "Untergruppe [%s] in Gruppe [%s] enthält keine Dateien."
+msgstr "Untergruppe <%s> in Gruppe <%s> enthält keine Dateien."
#: ../imagery/i.smap/shapiro/write_img.c:13
#, fuzzy, c-format
msgid "Writing [%s] ..."
-msgstr "Schreibe [%s] ..."
+msgstr "Schreibe <%s> ..."
#: ../imagery/i.smap/shapiro/closefiles.c:14
#: ../raster/r.basins.fill/main.c:157 ../raster/r.cross/main.c:166
@@ -5154,24 +5130,24 @@
msgstr "Arbeite schweigsam."
#: ../imagery/i.smap/shapiro/parse.c:57
-#, c-format
+#, fuzzy, c-format
msgid "Group [%s] not found."
-msgstr "Gruppe [%s] nicht gefunden."
+msgstr "Gruppe <%s> nicht gefunden."
#: ../imagery/i.smap/shapiro/parse.c:60
-#, c-format
+#, fuzzy, c-format
msgid "Subgroup [%s] not found."
-msgstr "Untergruppe [%s] nicht gefunden."
+msgstr "Untergruppe <%s> nicht gefunden."
#: ../imagery/i.smap/shapiro/read_sig.c:23
#, fuzzy, c-format
msgid "Signature file [%s] is missing or not readable."
-msgstr "Signaturdatei [%s] fehlt oder kann nicht gelesen werden."
+msgstr "Signaturdatei <%s> fehlt oder kann nicht gelesen werden."
#: ../imagery/i.smap/shapiro/read_sig.c:27
#, fuzzy, c-format
msgid "Signature file [%s] is invalid."
-msgstr "Signatur-Datei [%s] ist ungültig."
+msgstr "Signatur-Datei <%s> ist ungültig."
#: ../imagery/i.vpoints/main.c:51
msgid ""
@@ -5188,13 +5164,13 @@
#: ../imagery/i.vpoints/main.c:82 ../imagery/i.points/main.c:87
#, fuzzy, c-format
msgid "[%s] Only local groups may be used"
-msgstr "[%s] Nur lokale Gruppen können benutzt werden."
+msgstr "<%s> Nur lokale Gruppen können benutzt werden."
#: ../imagery/i.vpoints/main.c:91 ../imagery/i.vpoints/main.c:95
#: ../imagery/i.points/main.c:96 ../imagery/i.points/main.c:100
#, fuzzy, c-format
msgid "Group [%s] contains no maps, run i.group"
-msgstr "Gruppe [%s] enthält keine Dateien. Bitte i.group benutzen."
+msgstr "Gruppe <%s> enthält keine Dateien. Bitte i.group benutzen."
#: ../imagery/i.vpoints/main.c:209 ../imagery/i.points/main.c:205
#, c-format
@@ -5417,12 +5393,12 @@
#, fuzzy, c-format
msgid "** The following raster maps in subgroup [%s] do not exist:"
msgstr ""
-"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+"** Die folgenden Rasterkarten in der Untergruppe <%s> existieren nicht:"
#: ../imagery/i.class/main.c:260
#, fuzzy, c-format
msgid "Subgroup [%s] does not have any files"
-msgstr "Untergruppe [%s] hat keine Dateien."
+msgstr "Untergruppe <%s> hat keine Dateien."
#: ../imagery/i.class/main.c:261 ../imagery/i.class/main.c:265
msgid "The subgroup must have at least 2 files to run"
@@ -5431,7 +5407,7 @@
#: ../imagery/i.class/main.c:264 ../imagery/i.cluster/open_files.c:42
#, fuzzy, c-format
msgid "Subgroup [%s] only has 1 file"
-msgstr "Untergruppe [%s] hat nur eine Datei."
+msgstr "Untergruppe <%s> hat nur eine Datei."
#: ../imagery/i.class/main.c:270
#, fuzzy
@@ -5462,12 +5438,12 @@
#: ../imagery/i.class/main.c:292
#, fuzzy, c-format
msgid "Unable to read signature file [%s]"
-msgstr "Kann die Signaturdatei [%s] nicht lesen."
+msgstr "Kann die Signaturdatei <%s> nicht lesen."
#: ../imagery/i.class/main.c:295
#, fuzzy, c-format
msgid "** Unable to read signature file [%s] **"
-msgstr "** Kann die Signatur-Datei [%s] nicht lesen. **"
+msgstr "** Kann die Signatur-Datei <%s> nicht lesen. **"
#: ../imagery/i.class/main.c:302
#, c-format
@@ -5544,9 +5520,9 @@
msgstr "Gruppe <%s> existiert nicht."
#: ../imagery/i.rectify/main.c:118
-#, fuzzy, c-format
+#, c-format
msgid "Group <%s> contains no raster maps; run i.group"
+msgstr "Gruppe <%s> enthält keine Dateien; führen Sie i.group aus."
#: ../imagery/i.rectify/main.c:177
#, c-format
@@ -5631,7 +5607,7 @@
#: ../imagery/i.gensig/check.c:33
#, c-format
msgid "Signature [%d] not positive definite."
-msgstr "Signatur [%d] nicht."
+msgstr "Signatur [%d] not positive definite."
#: ../imagery/i.gensig/main.c:41
msgid "Generates statistics for i.maxlik from raster map layer."
@@ -5641,13 +5617,13 @@
#, fuzzy, c-format
msgid "Unable to create signature file [%s] for subgroup [%s] in group [%s]."
msgstr ""
-"Kann die Siganturdatei [%s] für die Untergruppe [%s] in Gruppe [%s] nicht "
+"Kann die Siganturdatei <%s> für die Untergruppe <%s> in Gruppe <%s> nicht "
"erzeugen."
#: ../imagery/i.gensig/write_sig.c:19
#, fuzzy, c-format
msgid "Writing signature file [%s] ..."
-msgstr "Schreibe Signaturdatei [%s]..."
+msgstr "Schreibe Signaturdatei <%s>..."
#: ../imagery/i.points/main.c:55
msgid "Mark ground control points on image to be rectified."
@@ -5684,24 +5660,21 @@
msgstr "Anzahl der Interpolationspunkte."
#: ../imagery/i.zc/main.c:112
-#, fuzzy
msgid "Threshold less than or equal to zero not allowed"
-msgstr "Bereich weniger oder gleich null ist nicht erlaubt."
+msgstr "Schwellwert kleiner oder gleich Null ist nicht erlaubt."
#: ../imagery/i.zc/main.c:118
-#, fuzzy
msgid "Width less than or equal to zero not allowed"
+msgstr "Weite weniger oder gleich Null ist nicht erlaubt."
#: ../imagery/i.zc/main.c:122
-#, fuzzy
msgid "Fewer than 1 orientation classes not allowed"
+msgstr "Weniger als 1 Orientierungsklasse ist nicht erlaubt."
#: ../imagery/i.zc/main.c:136
-#, fuzzy, c-format
+#, c-format
msgid "Power 2 values : %d rows %d columns"
+msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
#: ../imagery/i.zc/main.c:146
msgid "Initializing data..."
@@ -5833,7 +5806,7 @@
#: ../imagery/i.fft/main.c:130
msgid "Range less than or equal to zero not allowed."
+msgstr "Bereich weniger oder gleich Null ist nicht erlaubt."
#: ../imagery/i.fft/main.c:152
msgid "Initializing data...\n"
@@ -5979,14 +5952,14 @@
#: ../imagery/i.cluster/open_files.c:32
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr "Rasterkarte [%s] existiert in der Gruppe."
+msgstr "Rasterkarte <%s> existiert nicht in der Untergruppe <%s>."
#: ../imagery/i.cluster/open_files.c:40
#, fuzzy, c-format
msgid "Subgroup [%s] doesn't have any files"
+msgstr "Untergruppe <%s> beinhaltet keine Dateien."
#: ../imagery/i.cluster/open_files.c:43
#, c-format
@@ -6006,7 +5979,7 @@
#: ../imagery/i.cluster/open_files.c:67
#, fuzzy, c-format
msgid "Can't read signature file <%s>"
#: ../imagery/i.cluster/open_files.c:71
#, fuzzy, c-format
@@ -6047,7 +6020,7 @@
#: ../imagery/i.cluster/main.c:121
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr "Sample-Intervall (für Reihen und Spalten) Standard: ~10,000 Pixel"
+msgstr "Sample-Intervall (für Zeilen und Spalten); Standard: ~10,000 Pixel."
#: ../imagery/i.cluster/main.c:127
msgid "Maximum number of iterations"
@@ -6190,7 +6163,7 @@
#: ../imagery/i.cluster/main.c:270
#, c-format
msgid " Rows: %12d Cols: %12d Cells: %d\n"
-msgstr " Reihen: %12d Spalten: %12d Zellen: %d\n"
+msgstr " Zeilen: %12d Spalten: %12d Zellen: %d\n"
#: ../imagery/i.cluster/main.c:272
#, c-format
@@ -6268,7 +6241,7 @@
msgid ""
"Not enough non-zero sample data points. Check your current region (and mask)"
msgstr ""
-"Nicht genug nicht-null Beispielpunkte. Bitte überprüfen Sie die aktuelle "
+"Nicht genug nicht-NULL Beispielpunkte. Bitte überprüfen Sie die aktuelle "
"Region (und Maske)."
#: ../imagery/i.cluster/main.c:332
@@ -6400,12 +6373,12 @@
#: ../imagery/i.maxlik/open.c:16
#, fuzzy, c-format
msgid "group=[%s] - not found."
-msgstr "Gruppe=[%s] - nicht gefunden."
+msgstr "Gruppe=<%s> - nicht gefunden."
#: ../imagery/i.maxlik/open.c:19
#, fuzzy, c-format
msgid "subgroup=[%s] (of group [%s]) - not found."
-msgstr "Untergruppe=[%s] (der Grupppe [%s]) kann nicht gefunden werden."
+msgstr "Untergruppe=<%s> (der Grupppe <%s>) kann nicht gefunden werden."
#: ../imagery/i.maxlik/open.c:26
#, fuzzy, c-format
@@ -6413,7 +6386,7 @@
"Subgroup [%s] of group [%s] doesn't have any files.\n"
"The subgroup must have at least 2 files."
msgstr ""
-"Untergruppe [%s] der Gruppe [%s] beinhaltet keine Dateien.\n"
+"Untergruppe <%s> der Gruppe <%s> beinhaltet keine Dateien.\n"
"Die Untergruppe muss aber mindestens 2 Dateien haben."
#: ../imagery/i.maxlik/open.c:29
@@ -6422,23 +6395,23 @@
"Subgroup [%s] of group [%s] only has 1 file.\n"
msgstr ""
-"Untergruppe [%s] der Gruppe [%s] hat nur eine Datei. \n"
+"Untergruppe <%s> der Gruppe <%s> hat nur eine Datei. \n"
#: ../imagery/i.maxlik/open.c:52
#, fuzzy, c-format
msgid "Can't read signature file [%s]."
#: ../imagery/i.maxlik/open.c:55
#, fuzzy, c-format
msgid "[%s] has more than 255 signatures."
-msgstr "[%s] hat mehr als 255 Signaturen."
+msgstr "<%s> hat mehr als 255 Signaturen."
#: ../imagery/i.maxlik/open.c:70
#, fuzzy, c-format
msgid "Unable to create reject layer [%s]."
-msgstr "Kann die Reject-Karte [%s] nicht erzeugen."
+msgstr "Kann die Reject-Karte <%s> nicht erzeugen."
#: ../imagery/i.maxlik/main.c:53
msgid "Classifies the cell spectral reflectances in imagery data."
@@ -6565,7 +6538,7 @@
#: ../imagery/i.target/main.c:115
#, fuzzy, c-format
msgid "Group <%s> targeted for location [%s], mapset [%s]"
-msgstr "Gruppe [%s] mit Ziellocation [%s], Zielmapset [%s]\n"
+msgstr "Gruppe <%s> ziel auf Location <%s>, Mapset <%s>."
#: ../imagery/i.target/main.c:92
#, c-format
@@ -6630,7 +6603,7 @@
#: ../imagery/i.albedo/main.c:166
#, fuzzy
msgid "At least two raster maps are required"
-msgstr "Stile, die vom Mapserver angefragt werden sollen."
+msgstr "Zumindest einer von <%s> oder <%s> ist notwendig."
#: ../imagery/i.albedo/main.c:194
#, fuzzy, c-format
@@ -6654,12 +6627,12 @@
#: ../imagery/i.modis.qc/main.c:79
#, fuzzy
msgid "Name of QC type to extract"
-msgstr "Name der zur erzeugenden Raster-Ebene."
+msgstr "Name der zu editierenden Vektorkarte"
#: ../imagery/i.modis.qc/main.c:80
#, fuzzy
msgid "Name of QC"
#: ../imagery/i.modis.qc/main.c:82
msgid "modland_qa_bits"
@@ -6682,7 +6655,7 @@
#: ../imagery/i.modis.qc/main.c:99
#, fuzzy
msgid "Name of the output QC type classification layer"
-msgstr "Name der Eingabe-Rasterkarte mit den Reibungskosten."
+msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
#: ../imagery/i.modis.qc/main.c:100
msgid "qc"
@@ -6731,12 +6704,14 @@
msgstr "Name der Ausgabe-Rasterkarte."
#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
+#, fuzzy
msgid "Configuration editor for r.li.'index'"
-msgstr "Editor für Konfigurationsdateien für r.li.'index'."
+msgstr "Konfigurationsdatei"
#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
+#, fuzzy
msgid "raster, landscape structure analysis"
-msgstr "Raster, Landschaftsstruktur Analyse"
+msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
#: ../locale/scriptstrings/d.polar_to_translate.c:1
msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -6744,20 +6719,23 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:2
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#, fuzzy
msgid "display, diagram"
-msgstr "Darstellung, Diagramm"
+msgstr "Darstellung, Kartographie"
#: ../locale/scriptstrings/d.polar_to_translate.c:3
+#, fuzzy
msgid "Name of raster angle map"
-msgstr "Name der Winkel-Rasterkarte."
+msgstr "Name der Rasterkarte"
#: ../locale/scriptstrings/d.polar_to_translate.c:4
msgid "Pixel value to be interpreted as undefined (different from NULL)"
msgstr ""
#: ../locale/scriptstrings/d.polar_to_translate.c:5
+#, fuzzy
msgid "Name of optional EPS output file"
-msgstr "Name der optinalen EPS-Ausgabedatei."
+msgstr "Name der Ausgabedatei"
#: ../locale/scriptstrings/d.polar_to_translate.c:6
msgid "Plot using Xgraph"
@@ -6772,8 +6750,9 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:5
#: ../locale/scriptstrings/d.correlate_to_translate.c:6
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#, fuzzy
msgid "raster input map"
-msgstr "Eingabe-Rasterkarte"
+msgstr "Raster, Import"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
msgid "Interactively edit cell values in a raster map."
@@ -6788,66 +6767,78 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+#, fuzzy
msgid "Name of aspect raster map"
-msgstr "Name der Expositions-Rasterkarte."
+msgstr "Name der Basis-Rasterkarte."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
msgid "Width of display canvas"
msgstr "Breite des Fensters."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+#, fuzzy
msgid "Height of display canvas"
-msgstr "Höhe des Fensters."
+msgstr "Darzustellender Text"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+#, fuzzy
msgid "Minimum size of each cell"
-msgstr "Minimale Zellengröße."
+msgstr "Minimales Iso-Flächen-Level."
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+#, fuzzy
msgid "Maximum number of rows to load"
-msgstr "Maximale Anzahl von Reihen die geladen werde sollen."
+msgstr "Maximale Anzahl der Spalten: %d"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+#, fuzzy
msgid "Maximum number of columns to load"
-msgstr "Maximale Anzahl von Spalten die geladen werde sollen."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his"
msgstr ""
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
+#, fuzzy
msgid "Name of shaded relief or aspect map"
-msgstr "Name der Schummerungs- oder Expositionskarte."
+msgstr "Name der zweiten Rasterkarte."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
+#, fuzzy
msgid "Name of raster to drape over relief map"
-msgstr "Name der Rasterkarte, die auf dem Relief drapiert werden soll."
+msgstr "Name der Rasterkarte(n) mit Höhenwerten"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+#, fuzzy
msgid "Percent to brighten"
-msgstr "Aufhellen um Prozent"
+msgstr "Prozent Konvergenz."
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
#, fuzzy
msgid "Drops an attribute table."
-msgstr "Löscht eine Attributtabelle."
+msgstr "Datenbank, Attributtabelle"
#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+#, fuzzy
msgid "Table to drop"
-msgstr "zu löschende Tabelle"
+msgstr "Kann nicht weitermachen."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
+#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr "Entfernt eine Spalte von der selektierten Attributtabelle."
+msgstr "Keine Attributtabelle erzeugen."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
+#, fuzzy
msgid "Table from which to drop attribute column"
-msgstr "Attributtabelle, aus der eine Spalte gelöscht werden soll."
+msgstr "Skalierfaktor für die Werte der Attributspalte."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
+#, fuzzy
msgid "Name of the column"
-msgstr "Name der Spalte."
+msgstr "Anzahl der Spalten"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
msgid "Imports attribute tables in various formats."
@@ -6864,8 +6855,9 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#, fuzzy
msgid "Name for output table"
-msgstr "Name für Ausgabetabelle."
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
msgid "Name for auto-generated unique key column"
@@ -6876,44 +6868,50 @@
msgstr "Exportiert Attributtabellen in verschiedene Formate."
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#, fuzzy
msgid "GRASS table name"
-msgstr "GRASS Tabellenname"
+msgstr "Eingabetabelle"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
msgid "Table file to be exported or DB connection string"
msgstr "Tabellendatei, die exportiert werden soll oder DB-Verbindung"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+#, fuzzy
msgid "Table format"
-msgstr "Tabellenformat."
+msgstr "Format"
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
#: ../locale/scriptstrings/db.test_to_translate.c:3
+#, fuzzy
msgid "Test name"
-msgstr "Test Name"
+msgstr "Schriftname"
#: ../locale/scriptstrings/g.manual_to_translate.c:1
msgid "Display the HTML man pages of GRASS"
msgstr ""
#: ../locale/scriptstrings/g.manual_to_translate.c:2
+#, fuzzy
msgid "general, manual, help"
-msgstr "Allgemein, Handbuch, Hilfe"
+msgstr "Allgemein, Kartenverwaltung"
#: ../locale/scriptstrings/g.manual_to_translate.c:3
+#, fuzzy
msgid "Display index"
-msgstr "Zeige den Index."
+msgstr "Darstellung"
#: ../locale/scriptstrings/g.manual_to_translate.c:4
msgid "Display as MAN text page instead of HTML page in browser"
msgstr ""
#: ../locale/scriptstrings/g.manual_to_translate.c:5
+#, fuzzy
msgid "Manual entry to be displayed"
-msgstr "Handbuch Eintrag, der aufgerufen werden soll."
+msgstr "Rasterkarte, die angezeigt werden soll."
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
msgid ""
@@ -6921,8 +6919,9 @@
msgstr ""
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
+#, fuzzy
msgid "raster, imagery, fusion"
-msgstr "Raster, Bildverarbeitung, Fusion"
+msgstr "Raster, Import, Konvertierung"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
msgid "sensor: LANDSAT"
@@ -6962,8 +6961,9 @@
msgstr ""
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#, fuzzy
msgid "raster, imagery, mosaicking"
-msgstr "Raster, Bildverarbeitung, Mosaickierung"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
msgid "1st map for mosaic (top of image stack)."
@@ -6982,13 +6982,15 @@
msgstr ""
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+#, fuzzy
msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr "Importiert eine SPOT VGT NDVI Datei in a Rasterkarte."
+msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#, fuzzy
msgid "raster, imagery, import"
-msgstr "Raster, Bildverarbeitung, Import"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
msgid "also import quality map (SM status map layer) and filter NDVI map"
@@ -7003,8 +7005,9 @@
msgstr ""
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
+#, fuzzy
msgid "raster, imagery, colors"
-msgstr "Raster, Bildverarbeitung, Farben"
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
msgid "LANDSAT red channel"
@@ -7039,8 +7042,9 @@
msgstr ""
#: ../locale/scriptstrings/i.oif_to_translate.c:2
+#, fuzzy
msgid "raster, imagery, statistics"
-msgstr "Raster, Bildverarbeitung, Statistik"
+msgstr "Raster, Statistik"
#: ../locale/scriptstrings/i.oif_to_translate.c:3
msgid "LANDSAT TM band 1."
@@ -7071,15 +7075,14 @@
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:2
+#, fuzzy
msgid "miscellaneous, projection"
-msgstr "Verschiedenes, Projektion"
+msgstr "Verschiedenes"
#: ../locale/scriptstrings/m.proj_to_translate.c:3
#, fuzzy
msgid "Input coordinate file (omit to read from stdin)"
-msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
+msgstr "Pfad zur Datei mit Regeln (\"-\" um Regeln von stdin zu lesen)."
#: ../locale/scriptstrings/m.proj_to_translate.c:4
msgid "Output coordinate file (omit to send to stdout)"
@@ -7089,16 +7092,19 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:5
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#, fuzzy
msgid "Field separator"
-msgstr "Trennzeichen"
+msgstr "Ausgabe Feld-Trennzeichen"
#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#, fuzzy
msgid "Input projection parameters (PROJ.4 style)"
-msgstr "Eingabe Projektions-Parameter (im PROJ.4-Stil)."
+msgstr "* Eingabe-Projektion der GCP-Tabelle: %s"
#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#, fuzzy
msgid "Output projection parameters (PROJ.4 style)"
+msgstr "* Ausgabe-Projektion der GCP-Tabelle: %s"
#: ../locale/scriptstrings/m.proj_to_translate.c:8
msgid "Use LL WGS84 as input and current location as output projection"
@@ -7123,8 +7129,9 @@
msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+#, fuzzy
msgid "raster, imagery"
-msgstr "Raster, Bildverarbeitung"
+msgstr "Raster, Kartenalgebra"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
msgid "use transformation rules for LANDSAT-4"
@@ -7163,8 +7170,9 @@
msgstr "Eingabe-Rasterkarte (LANDSAT Kanal 7)."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+#, fuzzy
msgid "raster output TC maps prefix"
-msgstr "Präfix für TC-Ausgabe-Rasterkarten."
+msgstr "Überschreibe Ausgabedatei."
#: ../locale/scriptstrings/r.blend_to_translate.c:1
msgid "Blends color components of two raster maps by a given ratio."
@@ -7220,12 +7228,14 @@
msgstr "Raster"
#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#, fuzzy
msgid "Name of first raster map for blending"
-msgstr "Name der ersten Rasterkarte zum Mischen."
+msgstr "Name der ersten Rasterkarte."
#: ../locale/scriptstrings/r.blend_to_translate.c:4
+#, fuzzy
msgid "Name of second raster map for blending"
-msgstr "Name der zweiten Rasterkarte zum Mischen."
#: ../locale/scriptstrings/r.blend_to_translate.c:5
msgid "Base name for red, green and blue output maps containing the blend"
@@ -7242,12 +7252,14 @@
msgstr ""
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#, fuzzy
msgid "raster, elevation, interpolation"
-msgstr "Raster, Höhenwerte, Interpolation"
+msgstr "Vektor, Interpolation"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#, fuzzy
msgid "Raster map in which to fill nulls"
-msgstr "Rasterkarte, in der die Null-Werte gefüllt werden."
+msgstr "Rasterkarte, bei der die NULL-Datei editiert werden soll."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
msgid ""
@@ -7257,12 +7269,14 @@
"umgebenden Werte gefüllt wurden."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#, fuzzy
msgid "Spline tension parameter"
-msgstr "Spannungs-Parameter (tension)."
+msgstr "Spannung (Tension) Parameter."
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+#, fuzzy
msgid "Spline smoothing parameter"
-msgstr "Glättungs-Parameter (smooth)."
+msgstr "Glättungs-(smooth) Parameter"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -7299,8 +7313,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
+#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr "Ausgabe-Rasterkarte (Standard: Eingabe Kachel)."
+msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -7332,8 +7347,9 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
+#, fuzzy
msgid "Request"
-msgstr "Request"
+msgstr "Benötigt"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
msgid "Skip to downloading (to resume downloads faster)"
@@ -7359,7 +7375,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
#: ../raster/r.in.gdal/main.c:140
msgid "Keep band numbers instead of using band color names"
-msgstr "Verwende die Nummern der Kanäle anstatt der Farbenbezeichnungen."
+msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
@@ -7382,8 +7398,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
+#, fuzzy
msgid "Mapserver to request data from"
-msgstr "Mapserver, von dem Daten angefragt werden sollen."
+msgstr "Kann Daten der Tabelle nicht selektieren."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
msgid "Layers to request from map server"
@@ -7415,7 +7432,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
#, fuzzy
msgid "Maximum rows to request at a time"
+msgstr "Maximale Distanz vom Punkt zum Netzwerk."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
msgid "Additional options for r.tileset"
@@ -7438,8 +7455,9 @@
msgstr ""
#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
+#, fuzzy
msgid "Reprojection method to use"
-msgstr "Zu verwendende Methode zur Umprojektion."
+msgstr "Zu benutzende Interpolationsmethode."
#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
msgid "Filename to save capabilities XML file to"
@@ -7452,20 +7470,23 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+#, fuzzy
msgid "Verbosity level"
-msgstr "Gesprächigkeitsstufe"
+msgstr "Wasserniveau"
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Create a MASK for limiting raster operation"
msgstr ""
#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#, fuzzy
msgid "raster, mask"
-msgstr "Raster, Maske"
+msgstr "Raster, Metadaten"
#: ../locale/scriptstrings/r.mask_to_translate.c:3
+#, fuzzy
msgid "Raster map to use as MASK"
-msgstr "Rasterkarte, die als Maske verwendet werden soll."
+msgstr "Rasterkarte, die umgeschlüsselt werden soll."
#: ../locale/scriptstrings/r.mask_to_translate.c:4
msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
@@ -7513,12 +7534,14 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:2
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
+#, fuzzy
msgid "raster, elevation"
-msgstr "Raster, Höhenwerte"
+msgstr "Profildatei"
#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#, fuzzy
msgid "Name of raster plane to be created"
+msgstr "Name der Rasterkarte, die angezeigt werden soll."
#: ../locale/scriptstrings/r.plane_to_translate.c:4
msgid "Dip of plane. Value must be between -90 and 90 degrees"
@@ -7529,20 +7552,24 @@
msgstr ""
#: ../locale/scriptstrings/r.plane_to_translate.c:6
+#, fuzzy
msgid "Easting coordinate of a point on the plane"
-msgstr "Rechtswert eines Punktes der Ebene."
+msgstr "Ost Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
#: ../locale/scriptstrings/r.plane_to_translate.c:7
+#, fuzzy
msgid "Northing coordinate of a point on the plane"
-msgstr "Hochwert eines Punktes der Ebene."
+msgstr "Nord Koordinate (ausgewählter Punkt, Standard: Kartenmittelpunkt)."
#: ../locale/scriptstrings/r.plane_to_translate.c:8
+#, fuzzy
msgid "Elevation coordinate of a point on the plane"
-msgstr "Höhenwert eines Punktes der Ebene."
+msgstr "Bitte nur ein Koordinatenpaar pro Zeile."
#: ../locale/scriptstrings/r.plane_to_translate.c:9
+#, fuzzy
msgid "Type of the raster map to be created"
-msgstr "Typ der zu erzeugenden Rasterkarte."
+msgstr "Name der Rasterkarte, die reskaliert werden soll."
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
msgid ""
@@ -7551,8 +7578,9 @@
msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#, fuzzy
msgid "raster, statistics, aggregation"
-msgstr "Raster, Statistik, Aggregation"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
msgid "lesser val option that sets the <= area size limit [hectares]"
@@ -7563,8 +7591,9 @@
msgstr ""
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
+#, fuzzy
msgid "reclass raster output map"
-msgstr "Reklassifizierte Ausgabe-Rasterkarte"
+msgstr "Kann Ausgabekarte nicht erzeugen."
#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
msgid "Calculates linear regression from two raster maps: y = a + b*x"
@@ -7596,8 +7625,11 @@
msgstr ""
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
+#, fuzzy
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "Erstellt geschummerte Reliefkarte auf Basis einer Höhenkarte (DEM)."
+msgstr ""
+"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis einer "
+"Karte mit Höhenwerten."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
#: ../raster/r.topidx/main.c:46
@@ -7605,26 +7637,31 @@
msgstr "Eingabekarte, die Höheninformationen enthält."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
+#, fuzzy
msgid "Output shaded relief map name"
-msgstr "Name der geschummerten Ausgabe-Rasterkarte."
+msgstr "Ausgabe-Treibername"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
+#, fuzzy
msgid "Altitude of the sun in degrees above the horizon"
-msgstr "Höhe der Sonne in Grad über dem Horizont."
+msgstr "A: Höhe der Sonne über dem Horizont (in Grad)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
+#, fuzzy
msgid "Azimuth of the sun in degrees to the east of north"
-msgstr "Azimuth der Sonne östlich von der Nordrichtung (in Grad)."
+msgstr "A: Winkel der Sonne, gemessen von Norden (in Grad)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
+#, fuzzy
msgid "Factor for exaggerating relief"
-msgstr "Faktor für die Überhöhung des Reliefs."
+msgstr "Format für die Hangneigung."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
+#, fuzzy
msgid "Scale factor for converting horizontal units to elevation units"
msgstr ""
-"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten in "
-"Höheneinheiten."
+"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
+"wurde)."
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
msgid ""
@@ -7638,12 +7675,14 @@
msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#, fuzzy
msgid "raster, tiling"
-msgstr "Raster, Kachelung"
+msgstr "Raster, Projektion"
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#, fuzzy
msgid "Produces shell script output"
-msgstr "Erzeugt Shell-Skript Ausgabe."
+msgstr "Gebe im Shell-Skript-Style aus."
#: ../locale/scriptstrings/r.tileset_to_translate.c:4
#, fuzzy
@@ -7665,29 +7704,34 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+#, fuzzy
msgid "Conversion factor from units to meters in source projection"
-msgstr "Konvertierungsfaktor für Einheiten nach Meter in Quell-Projektion."
+msgstr "Geben Sie den Umrechnungsfaktor von %s zu Meter ein: "
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+#, fuzzy
msgid "Destination projection, defaults to this location's projection"
-msgstr "Ziel-Projektion (Standard: Projektion dieser Location)."
+msgstr "Übersteuere die Projektion (verwende Projektion der Location)."
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
-msgstr "Maximale Anzahl der Spalten einer Kachel in der Quell-Projektion."
+msgstr "Anzahl der Spalten in der neuen Region."
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+#, fuzzy
msgid "Maximum number of rows for a tile in the source projection"
-msgstr "Maximale Anzahl der Zeilen einer Kachel in der Quell-Projektion."
+msgstr "Minimale Anzahl der im Hauptspeicher zu haltenden Zeile ist 1."
#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+#, fuzzy
msgid "Number of cells tiles should overlap in each direction"
-msgstr ""
-"Anzahl der Zellen, die die Kacheln in alle Richtungen überlappen sollten."
+msgstr "Anzahl der Level, welche für jeden Komponent benutzt werden sollen."
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+#, fuzzy
msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr "Baut die Topologie aller Vektorkarten im aktuellen Mapset neu auf."
+msgstr "Nicht in der Lage Vektorkarte in anderem Mapset zu ändern."
#: ../locale/scriptstrings/v.build.all_to_translate.c:2
#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:72
@@ -7703,31 +7747,35 @@
msgstr "Vektor"
#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr ""
-"Füge fehlende Zentroide zu geschlossenen Flächengrenzen (boundaries) hinzu."
+msgstr "%d Linien zu Grenzen verwandelt"
#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#, fuzzy
msgid "vector, centroid, area"
-msgstr "Vektor, Zentroid, Fläche"
+msgstr "Vektor, Import"
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
#: ../locale/scriptstrings/v.report_to_translate.c:5
+#, fuzzy
msgid "Name of input vector map"
-msgstr "Name der Eingabe-Vektorkarte."
+msgstr "von"
#: ../locale/scriptstrings/v.centroids_to_translate.c:4
#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
+#, fuzzy
msgid "Name for output vector map"
msgstr "Name der Ausgabe-Vektorkarte."
#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#, fuzzy
msgid "Action to be taken"
-msgstr "Aktion, die ausgeführt werden soll."
+msgstr "Erzwinge das Löschen"
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
#: ../locale/scriptstrings/v.report_to_translate.c:6
@@ -7764,8 +7812,9 @@
#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
+#, fuzzy
msgid "run non-interactively"
-msgstr ""
+msgstr "Gebe Regeln interaktive ein"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
msgid ""
@@ -7789,8 +7838,10 @@
msgstr "Vektor, Datenbank, Attributtabelle"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
+#, fuzzy
msgid "Vector map for which to edit attribute table"
-msgstr "Vektorkarte, dessen Attributtabelle editiert werden soll. "
+msgstr ""
+"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
#, fuzzy
@@ -7813,16 +7864,20 @@
"Vektorkarte."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#, fuzzy
msgid "Vector map for which to add new attribute table"
-msgstr "Vektorkarte, die eine neue Attributtabelle erhalten soll. "
+msgstr ""
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
-msgstr "Name der neuen Attributtabelle (Standard: Name der Vektorkarte)."
+msgstr "Kann Elemente nicht von der Vektorkarte <%s> kopieren."
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+#, fuzzy
msgid "Layer where to add new attribute table"
-msgstr "Layer, in dem die neue Attributtabelle hinzugefügt wird."
+msgstr "Vektor, Raster, Attributtabelle"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
msgid ""
@@ -7831,29 +7886,33 @@
msgstr ""
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+#, fuzzy
msgid "Allows to join a table to a vector map table."
-msgstr ""
-"Ermöglicht es eine Tabelle mit der Tabelle einer Vektorkarte zu 'joinen'. "
#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#, fuzzy
msgid "Vector map to which to join other table"
-msgstr "Vektorkarte, an die die andere Tabelle 'gejoined' werden soll."
+msgstr "Rasterkarte, von der die Farbtabelle kopiert werden soll."
#: ../locale/scriptstrings/v.db.join_to_translate.c:4
msgid "Layer where to join"
msgstr "Layer, in dem 'gejoined' werden soll."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+#, fuzzy
msgid "Join column in map table"
-msgstr "'Join'-Spalte der Vektorkarte."
+msgstr "Vermisse Spalte <%s> in der Tabelle <%s>."
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+#, fuzzy
msgid "Other table name"
-msgstr "Name der anderen Tabelle."
+msgstr "Ausgabe-Tabellenname"
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#, fuzzy
msgid "Join column in other table"
-msgstr "'Join'-Spalte der anderen Tabelle."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
msgid ""
@@ -7861,8 +7920,10 @@
msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
+#, fuzzy
msgid "Vector map for which to drop attribute column"
-msgstr "Vektorkarte, dessen Attributtabelle gelöscht werden soll. "
+msgstr ""
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
#, fuzzy
@@ -7870,34 +7931,41 @@
msgstr "Layer, in dem der Spaltenname geändert werden soll."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+#, fuzzy
msgid "Removes existing attribute table of a vector map."
-msgstr "Entfernt eine existierende Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#, fuzzy
msgid "Force removal (required for actual deletion of table)"
-msgstr ""
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#, fuzzy
msgid "Vector map from which to remove attribute table"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"Name der existierenden Attributtabelle (Standard: Name der Vektorkarte)."
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+#, fuzzy
msgid "Layer from which to drop linked attribute table"
-msgstr "Layer, dessen verknüpfte Attributtabelle gelöscht werden soll. "
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
+#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr "Ändert den Namen einer Spalte einer Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
+#, fuzzy
msgid "Vector map for which to rename attribute column"
-msgstr "Vektorkarte, in der der Spaltenname geändertwerden soll."
+msgstr ""
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
msgid "Layer where to rename column"
@@ -7928,16 +7996,17 @@
msgstr "Altes Schema"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#, fuzzy
msgid "New schema"
-msgstr "Neues Schema"
+msgstr "Datenbank-Schema"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+#, fuzzy
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
msgstr ""
-"Berechnet Kennzahlen univariater Statistik einer Spalte der Attributtabelle "
-"einer GRASS Vektorkarte."
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../vector/lidar/v.outlier/main.c:67 ../vector/v.univar/main.c:64
@@ -7952,22 +8021,23 @@
msgstr "Mehr statistische Kennzahlen (Quartile und 90% Perzentil)."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#, fuzzy
msgid "Name of data table"
-msgstr "Name der Tabelle."
+msgstr "Name der Datenbank-Datei."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#, fuzzy
msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Spalte, für die statistische Kennzahlen berechnet werden sollen (muß "
-"numerisch sein)."
+msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
msgid "Database/directory for table"
msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#, fuzzy
msgid "Database driver"
-msgstr "Datenbanktreiber"
+msgstr "Listet alle verfügbaren Datenbanktreiber auf."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
msgid "WHERE conditions of SQL statement without 'where' keyword"
@@ -7979,8 +8049,9 @@
msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#, fuzzy
msgid "Vector map to edit the attribute table for"
#: ../locale/scriptstrings/v.db.update_to_translate.c:4
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
@@ -7988,8 +8059,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+#, fuzzy
msgid "Column to update"
-msgstr "Spalten, die aktualisiert werden."
+msgstr "Spaltentyp nicht unterstützt."
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid ""
@@ -7998,8 +8070,9 @@
msgstr ""
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#, fuzzy
msgid "Column to query"
-msgstr "Spalte, die abgefragt werden soll."
+msgstr "Spaltentypen stimmen nicht überein."
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
msgid ""
@@ -8008,28 +8081,33 @@
msgstr ""
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+#, fuzzy
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
msgstr ""
-"Dissolve: Entfernt Grenzen zwischen benachbarten Flächen mit gleicher "
-"Kategorienummer oder Attributwert. "
+"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
+"Attributes."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+#, fuzzy
msgid "vector, area, dissolve"
-msgstr "Vektor, Fläche, Dissolve"
+msgstr "Raster, Volumen, Konvertierung"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+#, fuzzy
msgid "Layer number. If -1, all layers are extracted"
-msgstr "Layernummer: Wenn -1, dann werden alle Layer extrahiert."
+msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer dargestellt."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr "Name der Spalte, die für das 'dissolve' verwendet werden soll."
+msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+#, fuzzy
msgid "Import E00 file into a vector map."
-msgstr "Importiert E00-Datei in eine Vektorkarte."
+msgstr "von"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
@@ -8042,8 +8120,9 @@
msgstr "E00 Datei"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
+#, fuzzy
msgid "Input type point, line or area"
-msgstr "Eingabe Typ: Punkt, Linie oder Fläche."
+msgstr "Wähle Typ aus: Linie oder Fläche"
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
msgid ""
@@ -8053,8 +8132,9 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
+#, fuzzy
msgid "vector, import, GPS"
-msgstr "Vektor, Import, GPS"
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
msgid "Download Waypoints from GPS"
@@ -8088,8 +8168,9 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr "Name der neuen Vektorkarte (leer lassen für Ausgabe auf stdout)."
+msgstr "Name der Vektorausgabekarte mit den angepassten Punkten im Fluss."
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
msgid "Port Garmin receiver is connected to"
@@ -8102,8 +8183,9 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
+#, fuzzy
msgid "vector, import, gazetteer"
-msgstr "Vektor, Import, Gazetteer"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
msgid "Uncompressed geonames file from (with .txt extension)"
@@ -8126,12 +8208,14 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
+#, fuzzy
msgid "Import waypoints"
-msgstr "Importiere Wegpunkte."
+msgstr "Importiere Punkte..."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
+#, fuzzy
msgid "Import routes"
-msgstr "Importiere Routen."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
msgid "Import track"
@@ -8142,8 +8226,9 @@
msgstr ""
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
+#, fuzzy
msgid "Device or file used to import data"
-msgstr "Gerät oder Datei von dem Daten importiert werden sollen."
+msgstr "Zu importierende Rasterdatei."
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
msgid "Format of GPS input data (use gpsbabel supported formats)"
@@ -8159,16 +8244,21 @@
msgstr ""
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#, fuzzy
msgid "Input map is in Matlab format"
-msgstr "Eingabekarte ist im Matlab Format."
+msgstr "Eingabekarte enthält keine Daten."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#, fuzzy
msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr "Erzeuge eine 3D Vektorkarte (Punkte) aus 3-Spalten-Matlab-Daten."
+msgstr ""
+"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
+"Koordinaten beinhaltet."
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
-msgstr "Name der Eingabedatei im Mapgen/Matlab Format."
+msgstr "Name der Eingabe-Vektorkarte."
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
msgid "import GetFeature from WFS"
@@ -8179,23 +8269,25 @@
msgstr ""
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#, fuzzy
msgid "Vector output map"
-msgstr "Ausgabe-Vektorkarte."
+msgstr "Keine Ausgabekarte angegeben."
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
+#, fuzzy
msgid ""
"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Konvertiert alle alten GRASS sites (Version < 5.7) im aktuellen Mapset in "
-"Vektorkarten."
+msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
+#, fuzzy
msgid "sites, vector, import"
-msgstr "Sites, Vektor, Import"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
+#, fuzzy
msgid "Run non-interactively"
-msgstr ""
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
msgid ""
@@ -8206,8 +8298,9 @@
"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#, fuzzy
msgid "vector, raster, statistics"
-msgstr "Vektor, Raster, Statistik"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
msgid "Continue if upload column(s) already exist"
@@ -8220,18 +8313,19 @@
msgstr "Berechnet mehr statistische Kennzahlen."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+#, fuzzy
msgid "Name of vector polygon map"
-msgstr "Name der Polygon-Vektorkarte"
+msgstr "Name der Vektorkarte"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+#, fuzzy
msgid "Name of raster map to calculate statistics from"
-msgstr ""
-"Name der Rasterkarte, für die statistische Kennzahlen berechnet werden "
-"sollen."
+msgstr "Name der Rasterkarte(n), die in die Gruppe eingefügt werden sollen."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+#, fuzzy
msgid "Column prefix for new attribute columns"
-msgstr "Präfix für Spaltennamen neuer Attribute."
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
#: ../raster/r.univar/r.univar_main.c:38
@@ -8240,59 +8334,69 @@
msgstr ""
#: ../locale/scriptstrings/v.report_to_translate.c:1
+#, fuzzy
msgid "Reports geometry statistics for vectors."
-msgstr "Berichtet statistische Kennzahlen der Geometrien einer Vektorkarte."
+msgstr "Gibt statistische Werte für eine Rasterkarte aus."
#: ../locale/scriptstrings/v.report_to_translate.c:2
+#, fuzzy
msgid "vector, report, statistics"
-msgstr "Vektor, Report, Statistik"
+msgstr "Vektor, Statistik"
#: ../locale/scriptstrings/v.report_to_translate.c:3
+#, fuzzy
msgid "Reverse sort the result"
-msgstr "Sortiere die Ergebnisse in umgekehrter Reihenfolge."
+msgstr "Kehre die Auswahl um"
#: ../locale/scriptstrings/v.report_to_translate.c:4
msgid "Sort the result"
msgstr "Sortiere die Ergebnisse."
#: ../locale/scriptstrings/v.report_to_translate.c:7
+#, fuzzy
msgid "Value to calculate"
-msgstr "Wert, der berechnet werden soll."
+msgstr "Wert zum Laden in die Attributtabelle."
#: ../locale/scriptstrings/v.report_to_translate.c:8
+#, fuzzy
msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr "mi(les),f(eet),me(ter),k(ilometer),a(cres),h(ektar),p(rozent)"
+msgstr "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-"Schreibt Werte einer Vektorkarte an den Stellen von Vektor-Punkten in die "
+"Überninmmt die Rasterwerte an einem angegebenen Vektor-Punkt in die "
"Attributtabelle."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#, fuzzy
msgid "Points vector map to modify"
-msgstr "Vektorkarte (Punkte), die verändert wird."
+msgstr "Mindestens 2 Layer müssen angegeben werden."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#, fuzzy
msgid "Layer in the vector to be modified"
-msgstr "Layer der Vektorkarte, der geändert wird."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
msgid "Column to be updated with the query result"
msgstr ""
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#, fuzzy
msgid "Vector map to be queried"
-msgstr "Vektorkarte, die abgefragt werden soll."
+msgstr "Rasterkarte, die abgefragt werden soll."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
#, fuzzy
msgid "Layer of the query vector containing data"
-msgstr "Layer der abzufragenden Vektorkarte, der die Daten enthält."
+msgstr "Eingabekarte enthält Linien."
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#, fuzzy
msgid "Column to be queried"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
#, fuzzy
@@ -8943,8 +9047,8 @@
"transform the map to North-up."
msgstr ""
"Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie "
-"können das Programm 'gdalwarp' verwenden, um die Karte so zu transformieren, "
-"dass Norden nach oben zeigt."
+"können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden "
+"nach oben zeigt."
#: ../raster/r.external/main.c:300
#, fuzzy
@@ -9007,9 +9111,9 @@
msgstr "Erstelle Support-Dateien für <%s>..."
#: ../raster/r.external/main.c:480 ../raster/r.in.gdal/main.c:922
-#, fuzzy, c-format
+#, c-format
msgid "<%s> created"
-msgstr "Datei <%s> erstellt."
+msgstr "<%s> erzeugt."
#: ../raster/r.external/main.c:507
#, fuzzy
@@ -9059,7 +9163,7 @@
#: ../raster/r.external/main.c:546 ../raster/r.in.gdal/main.c:130
#: ../vector/v.in.ogr/main.c:229
msgid "Extend location extents based on new dataset"
-msgstr "Vergrößere die Location basierend auf dem zu importierenden Datensatz."
+msgstr "Vergrößere die Location basierend auf dem neuen Datensatz."
#: ../raster/r.external/main.c:550
msgid "Require exact range"
@@ -9068,7 +9172,7 @@
#: ../raster/r.external/main.c:554 ../raster/r.in.gdal/main.c:134
#: ../vector/v.in.ogr/main.c:200
msgid "List supported formats and exit"
-msgstr "Zeige unterstützte Formate an und beende das Modul."
+msgstr "Zeige unterstützte Formate an und beendet sich."
#: ../raster/r.external/main.c:584
#, fuzzy
@@ -9181,7 +9285,7 @@
#: ../raster/r.out.ppm3/main.c:94
#, c-format
msgid "rows = %d, cols = %d"
-msgstr "Reihen = %d, Spalten = %d"
+msgstr "Zeilen = %d, Spalten = %d"
#: ../raster/r.out.png/main.c:155 ../raster/r.out.vrml/main.c:116
#, fuzzy, c-format
@@ -9414,7 +9518,7 @@
#: ../raster/r.los/main.c:179 ../raster/r.los/main.c:184
#, fuzzy, c-format
msgid "[%s]: Cannot read map header"
-msgstr "[%s]: Kann den Kartenheader nicht lesen."
+msgstr "<%s>: Kann den Kartenheader nicht lesen."
#: ../raster/r.los/main.c:213
msgid "Pattern map should be a binary 0/1 CELL map"
@@ -9542,7 +9646,7 @@
#: ../raster/r.in.ascii/gethead.c:189
msgid "ignoring null filed in header, null string is set on command line"
msgstr ""
-"Ignoriere Null-Feld im Header, da der Null-Wert auf der Kommandozeile "
+"Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile "
"gesetzt wurde."
#: ../raster/r.in.ascii/gethead.c:218
@@ -9585,7 +9689,7 @@
#: ../raster/r.in.ascii/main.c:100
msgid "String representing NULL value data cell"
-msgstr "Zeichenkette, die NULL-Werte darstellen."
+msgstr "Zeichenkette, die NULL-Werte darstellt."
#: ../raster/r.in.ascii/main.c:104
msgid "Integer values are imported"
@@ -9629,7 +9733,7 @@
#: ../raster/r.in.ascii/main.c:193 ../raster/r.in.arc/main.c:135
#, c-format
msgid "OOPS: rows changed from %d to %d"
-msgstr "OOPS: Reihen haben sich von %d auf %d verändert."
+msgstr "UPS: Die Zeilen haben sich von %d auf %d geändert."
#: ../raster/r.in.ascii/main.c:196 ../raster/r.in.arc/main.c:138
#, c-format
@@ -9639,7 +9743,7 @@
#: ../raster/r.in.ascii/main.c:210 ../raster/r.in.arc/main.c:161
#, c-format
msgid "Data conversion failed at row %d, col %d"
-msgstr "Datenkonvertierung in Reihe %d, Spalte %d fehlgeschlagen."
+msgstr "Datenkonvertierung in Zeile %d, Spalte %d fehlgeschlagen."
#: ../raster/r.in.ascii/main.c:283
msgid "Unable to write to file"
@@ -9667,7 +9771,8 @@
#: ../raster/r.out.ascii/main.c:99
msgid "String to represent null cell (GRASS grid only)"
-msgstr "Zeichenwert, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)"
+msgstr ""
+"Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
#: ../raster/r.out.ascii/main.c:103 ../raster/r.out.arc/main.c:87
#: ../raster3d/r3.out.ascii/main.c:103
@@ -9762,12 +9867,12 @@
#, fuzzy, c-format
msgid "Invalid width value '%s' - using default."
msgstr ""
-"Ungültiger Wert '%s' für die Breite - verwende die Standardeinstellung."
+"Ungültiger Wert <%s> für die Breite - verwende die Standardeinstellung."
#: ../raster/r.carve/main.c:145
#, fuzzy, c-format
msgid "Invalid depth value '%s' - using default."
-msgstr "Ungültiger Wert '%s' für die Tiefe - verwende die Standardeinstellung."
+msgstr "Ungültiger Wert <%s> für die Tiefe - verwende die Standardeinstellung."
#: ../raster/r.carve/main.c:214
msgid "lat/lon projection not supported at this time."
@@ -9867,7 +9972,6 @@
msgstr "Erzeugt Texturbilder von einer Rasterkarte."
#: ../raster/r.texture/main.c:84
-#, fuzzy
msgid "Prefix for output raster map(s)"
msgstr "Präfix für Ausgabe-Rasterkarte(n)."
@@ -10020,7 +10124,7 @@
#: ../raster/r.what/main.c:335
#, fuzzy, c-format
msgid "Error reading <%s>"
-msgstr "Fehler beim Lesen der Karte '%s'."
+msgstr "Fehler beim Lesen der Datenspanne für <%s>."
#: ../raster/r.sum/main.c:46
msgid "Sums up the raster cell values."
@@ -10124,11 +10228,11 @@
#: ../raster/r.sun/main.c:235
msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr "Einaberasterkarte des Grund-Albedokoeffizients [-]."
+msgstr "Name der Eingabe-Rasterkarte mit Grund-Albedokoeffizienten [-]."
#: ../raster/r.sun/main.c:245
msgid "A single value of the ground albedo coefficient [-]"
-msgstr "Ein einfacher Wert des Grund-Albedokoeffizients [-]."
+msgstr "Ein einzelner Wert für den Grund-Albedokoeffizienten [-]."
#: ../raster/r.sun/main.c:253
msgid "Name of the latitudes input raster map [decimal degrees]"
@@ -10277,7 +10381,7 @@
#: ../raster/r.sun/main.c:739
#, c-format
msgid "rows changed from %d to %d"
-msgstr "Reihen haben sich von %d auf %d geändert."
+msgstr "Zeilen änderten sich von %d auf %d."
#: ../raster/r.sun/main.c:742
#, c-format
@@ -10324,11 +10428,11 @@
#: ../raster/r.null/main.c:46
msgid "Creates explicitly the NULL-value bitmap file."
-msgstr "Erzeugt eine NULL-Wert Bitmap-Datei."
+msgstr "Erzeugt ausdrücklich eine NULL-Wert Bitmap-Datei."
#: ../raster/r.null/main.c:54
msgid "Raster map for which to edit null file"
-msgstr "Rasterkarte, bei der die Null-Datei editiert werden soll."
#: ../raster/r.null/main.c:62 ../raster3d/base/r3.null.main.c:63
msgid "List of cell values to be set to NULL"
@@ -10349,13 +10453,13 @@
#: ../raster/r.null/main.c:82
msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
msgstr ""
-"Nur ausführen, wenn für die Karte noch keine Null-Wert Bitmap Datei "
+"Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
"existiert."
#: ../raster/r.null/main.c:87
msgid "Create NULL-value bitmap file validating all data cells"
msgstr ""
-"Erzeuge eine Null-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
+"Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
"erklärt."
#: ../raster/r.null/main.c:91
@@ -10392,9 +10496,9 @@
msgstr "%s: Kann die temporäre Datei nicht öffnen."
#: ../raster/r.lake/main.c:79
-#, fuzzy, c-format
+#, c-format
msgid "Failed writing output raster map row %d"
-msgstr "Schreiben der Zeile der Rasterkarte fehlgeschlagen."
+msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
#: ../raster/r.lake/main.c:151
msgid "Fills lake from seed at given level."
@@ -10458,9 +10562,8 @@
msgstr "Saatpunkt außerhalb der aktuellen Region."
#: ../raster/r.lake/main.c:255
-#, fuzzy
msgid "G_malloc: out of memory"
-msgstr "get_img: Speicher voll."
+msgstr "G_malloc: Kein Speicher mehr da."
#: ../raster/r.lake/main.c:281
msgid ""
@@ -10490,9 +10593,9 @@
"Metern angegeben wurde."
#: ../raster/r.lake/main.c:385
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read color file of raster map <%s>"
-msgstr "Kann die Farbdatei für die Rasterkarte <%s@%s> nicht lesen."
+msgstr "Kann die Farbdatei für die Rasterkarte <%s> nicht lesen."
#: ../raster/r.out.gdal/main.c:48
#, c-format
@@ -10736,7 +10839,7 @@
#: ../raster/r.in.bin/main.c:212
msgid "Number of rows"
-msgstr "Anzahl der Reihen"
+msgstr "Anzahl der Zeilen"
#: ../raster/r.in.bin/main.c:219
msgid "Number of columns"
@@ -10770,24 +10873,24 @@
msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
#: ../raster/r.in.bin/main.c:297 ../raster/r.in.bin/main.c:337
-#, fuzzy, c-format
+#, c-format
msgid "Illegal south coordinate <%s>"
-msgstr "Ungültige Nord-Koordinate <%s>."
+msgstr "Ungültige Süd-Koordinate <%s>."
#: ../raster/r.in.bin/main.c:301 ../raster/r.in.bin/main.c:341
-#, fuzzy, c-format
+#, c-format
msgid "Illegal west coordinate <%s>"
-msgstr "Ungültige Ost-Koordinate <%s>."
+msgstr "Ungültige West-Koordinate <%s>."
#: ../raster/r.in.bin/main.c:303 ../raster/r.in.bin/main.c:313
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of rows <%s>"
-msgstr "Ungültiger Untergruppenname <%s>."
+msgstr "Ungültiger Zeilenanzahl <%s>."
#: ../raster/r.in.bin/main.c:305 ../raster/r.in.bin/main.c:316
-#, fuzzy, c-format
+#, c-format
msgid "Illegal number of columns <%s>"
-msgstr "Maximale Anzahl der Spalten: %d"
+msgstr "Ungültiger Spaltenanzahl <%s>."
#: ../raster/r.in.bin/main.c:321
#, c-format
@@ -10797,7 +10900,7 @@
#: ../raster/r.in.bin/main.c:346
#, c-format
msgid "Using rows=%d cols=%d\n"
-msgstr "Verwende Reihen=%d Spalten=%d\n"
+msgstr "Verwende Zeilen=%d Spalten=%d\n"
#: ../raster/r.in.bin/main.c:451 ../raster/r.in.bin/main.c:461
#: ../raster/r.in.bin/main.c:473
@@ -10826,7 +10929,7 @@
#: ../raster/r.in.bin/main.c:518
#, c-format
msgid "Conversion failed at row %d"
-msgstr "Konvertierung in Reihe %d fehlgeschlagen."
+msgstr "Konvertierung in Zeile %d fehlgeschlagen."
#: ../raster/r.out.gridatb/main.c:50
msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
@@ -11108,14 +11211,14 @@
msgstr "Kann Rasterkarten nicht schreiben."
#: ../raster/simwe/simlib/input.c:49
-#, c-format
+#, fuzzy, c-format
msgid "File [%s] not found"
-msgstr "Datei [%s] nicht gefunden."
+msgstr "Datei <%s> nicht gefunden."
#: ../raster/simwe/simlib/input.c:52
-#, c-format
+#, fuzzy, c-format
msgid "Unable to open file [%s]"
-msgstr "Kann die Datei [%s] nicht öffnen."
+msgstr "Kann die Datei <%s> nicht öffnen."
#: ../raster/simwe/simlib/input.c:55
msgid "Failed to guess file format"
@@ -11338,7 +11441,7 @@
#: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:403
#, c-format
msgid "rows=%d"
-msgstr "Reihen = %d"
+msgstr "Zeilen = %d"
#: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:404
#, c-format
@@ -11368,7 +11471,7 @@
#: ../raster/r.out.mat/main.c:377
#, fuzzy, c-format
msgid "%ld bytes written to '%s'"
-msgstr "%ld Bytes nach '%s' geschrieben."
+msgstr "%ld Bytes nach <%s> geschrieben."
#: ../raster/r.to.rast3elev/main.c:98
msgid "The number of input and elevation maps is not equal"
@@ -11405,14 +11508,12 @@
msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte."
#: ../raster/r.to.rast3elev/main.c:234
-#, fuzzy
msgid "Could not get raster row from input map"
-msgstr "Kann die Rasterzeile nicht holen\n"
+msgstr "Konnte die Rasterzeile der Eingabekarte nicht holen."
#: ../raster/r.to.rast3elev/main.c:236
-#, fuzzy
msgid "Could not get raster row from elev map"
+msgstr "Konnte die Rasterzeile der Karte mit Höhenwerten nicht holen."
#: ../raster/r.to.rast3elev/main.c:284 ../raster/r.to.rast3elev/main.c:318
msgid "Error writing G3D double data"
@@ -11476,9 +11577,8 @@
msgstr "%s: verarbeite %s Anweisung"
#: ../raster/r.statistics/main.c:61 ../raster/r.statistics2/main.c:102
-#, fuzzy
msgid "Calculates category or object oriented statistics."
-msgstr "Kategorie- oder objektorientierte Statistik."
+msgstr "Berechnet kategorie- oder objektorientierte Statistik."
#: ../raster/r.statistics/main.c:79 ../raster/r.statistics2/main.c:112
msgid "Method of object-based statistic"
@@ -11595,22 +11695,22 @@
msgstr "Entkomprimiert die Karte"
#: ../raster/r.compress/main.c:102
-#, c-format
+#, fuzzy, c-format
msgid "[%s] not found"
-msgstr "[%s] nicht gefunden."
+msgstr "<%s> nicht gefunden werden."
#: ../raster/r.compress/main.c:108
#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
msgstr ""
-"[%s] ist eine reklassifizierte Karte von <%s> im Mapset <%s> - kann %s nicht "
+"<%s> ist eine reklassifizierte Karte von <%s> im Mapset <%s> - kann %s nicht "
"dekomprimieren."
#: ../raster/r.compress/main.c:110
#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
msgstr ""
"komprimieren."
#: ../raster/r.compress/main.c:153
@@ -11636,12 +11736,12 @@
#: ../raster/r.compress/main.c:181
#, fuzzy, c-format
msgid "[%s] already uncompressed"
-msgstr "[%s] ist bereits dekomprimiert."
+msgstr "<%s> ist bereits dekomprimiert."
#: ../raster/r.compress/main.c:185
#, fuzzy, c-format
msgid "[%s] already compressed"
-msgstr "[%s] ist bereits komprimiert."
+msgstr "<%s> ist bereits komprimiert."
#: ../raster/r.compress/main.c:189
#, fuzzy, c-format
@@ -11650,7 +11750,7 @@
"%sCOMPRESS [%s]"
msgstr ""
"\n"
-"%sKOMPRIMIERE [%s]"
+"%sKOMPRIMIERE <%s>"
#: ../raster/r.patch/main.c:55
msgid ""
@@ -11671,7 +11771,7 @@
#: ../raster/r.patch/main.c:72
msgid "Use zero (0) for transparency instead of NULL"
-msgstr "Benutzte Null (0) für Transparenz anstelle von NULL (NO-DATA)."
+msgstr "Verwende Null (0) für Transparenz anstelle von NULL."
#: ../raster/r.patch/main.c:89
msgid "The minimum number of input raster maps is two"
@@ -11745,12 +11845,12 @@
#: ../raster/r.digit/get_label.c:31
#, c-format
msgid "Enter the category number for this %s: "
-msgstr "Editiere die Kategorie-Nummer für Karte [%s]?"
+msgstr "Editiere die Kategorie-Nummer für Karte <%s>?"
#: ../raster/r.digit/get_label.c:46
#, fuzzy, c-format
msgid "Enter a label for category %ld [%s] "
-msgstr "Geben Sie ein Label für die Kategorie %ld [%s] ein."
+msgstr "Geben Sie ein Label für die Kategorie %ld <%s> ein."
#: ../raster/r.digit/get_label.c:68
msgid "Look ok? "
@@ -11902,7 +12002,8 @@
#: ../raster/r.thin/main.c:57
msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
-"Dünnt Zellen, die nicht null (0) sind und linienhafte Strukturen zeigen, aus."
+"Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer "
+"Rasterkarte abbilden."
#: ../raster/r.thin/main.c:69
msgid "Maximal number of iterations"
@@ -11911,7 +12012,7 @@
#: ../raster/r.thin/io.c:100
#, c-format
msgid "File %s -- %d rows X %d columns"
-msgstr "Datei %s -- %d Reihen X %d Spalten."
+msgstr "Datei %s -- %d Zeilen X %d Spalten."
#: ../raster/r.thin/io.c:110
#, c-format
@@ -11927,17 +12028,17 @@
#: ../raster/r.thin/io.c:126
#, fuzzy, c-format
msgid "%s: Error reading from raster map <%s>"
-msgstr "Fehler beim Lesen der Rasterkarte [%s]."
+msgstr "Fehler beim Lesen der Rasterkarte <%s>."
#: ../raster/r.thin/io.c:168
#, c-format
msgid "Output file %d rows X %d columns"
-msgstr "Ausgabe-Datei %d Reihen X %d Spalten."
+msgstr "Ausgabe-Datei %d Zeilen X %d Spalten."
#: ../raster/r.thin/io.c:169
#, c-format
msgid "Window %d rows X %d columns"
-msgstr "Fenster %d Reihen X %d Spalten."
+msgstr "Fenster %d Zeilen X %d Spalten."
#: ../raster/r.thin/thin_lines.c:67
#, c-format
@@ -12296,9 +12397,9 @@
msgstr "Berechnet Shannons Diversitäts-Index einer Rasterkarte."
#: ../raster/r.flow/mem.c:39
-#, fuzzy, c-format
+#, c-format
msgid "Unable to write segment file for %s"
-msgstr "Kann die temporäre Datei nicht schreiben."
+msgstr "Kann die Segementdatei für <%s>nicht schreiben."
#: ../raster/r.flow/main.c:315
msgid "Calculating maps ..."
@@ -12314,16 +12415,15 @@
#: ../raster/r.flow/main.c:431
msgid "Input elevation raster map"
-msgstr "Eingabe-Rasterkarte, die Höheninformationen enthält."
+msgstr "Eingabe-Rasterkarte, mit Höheninformationen"
#: ../raster/r.flow/main.c:438
msgid "Input aspect raster map"
-msgstr "Eingabe-Expositionskarte."
+msgstr "Eingabe-Rasterkarte mit Expositionen."
#: ../raster/r.flow/main.c:445
-#, fuzzy
msgid "Input barrier raster map"
-msgstr "Eingabe-Rasterkarte."
+msgstr "Eingabe-Rasterkarte mit den Barrieren"
#: ../raster/r.flow/main.c:451
msgid "Number of cells between flowlines"
@@ -12376,30 +12476,28 @@
"'r.watershed' für die Berechnung der Fussakkumulation."
#: ../raster/r.flow/precomp.c:47
-#, fuzzy
msgid "Precomputing: e/w distances"
-msgstr "Karten für die Berechnung von Inter-class-Entfernungen"
+msgstr "Vorberechnung: o/w Distanzen."
#: ../raster/r.flow/precomp.c:49
msgid "Precomputing: quantization tolerances"
-msgstr ""
+msgstr "Vorberechnung: Diskretisierungstoleranz."
#: ../raster/r.flow/precomp.c:52
msgid "Precomputing: inverted elevations"
-msgstr ""
+msgstr "Vorberechnung: invertierte Höhenwerte."
#: ../raster/r.flow/precomp.c:56
msgid "Precomputing: interpolated border elevations"
-msgstr ""
+msgstr "Vorberechnung: interpolierte Grenzhöhen."
#: ../raster/r.flow/precomp.c:62
msgid "Precomputing: re-oriented aspects"
-msgstr ""
+msgstr "Vorberechnung: neuorientierte Expositionen."
#: ../raster/r.flow/precomp.c:66
-#, fuzzy
msgid "Precomputing: aspects"
+msgstr "Vorberechnung: Expositionen."
#: ../raster/r.flow/precomp.c:110
#, c-format
@@ -12408,11 +12506,16 @@
"atan2(%f deg, %f deg) =%f < %f tolerance\n"
"please resample input map"
msgstr ""
+"Auflösung ist zu unausgewogen:\n"
+"atan2(%f Grad, %f Grad) =%f < %f Toleranz.\n"
+"Bitte resamplen Sie die Eingabekarte."
#: ../raster/r.flow/precomp.c:115
#, c-format
msgid "Resolution too unbalanced (%f x %f); please resample input map"
msgstr ""
+"Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die "
+"Eingabekarte."
#: ../raster/r.flow/io.c:66
#, c-format
@@ -12440,9 +12543,8 @@
"aktuellen Region"
#: ../raster/r.flow/io.c:112
-#, fuzzy
msgid "Reading input files: barrier"
-msgstr "Kann input dig Datei nicht öffnen."
+msgstr "Lese Eingabe-Dateien: Barrieren"
#: ../raster/r.flow/io.c:140
#, c-format
@@ -12500,16 +12602,14 @@
msgstr "in"
#: ../raster/r.topidx/main.c:43
-#, fuzzy
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr ""
-"Erstellt Topographischen Index (ln(a/tan(beta))) auf Basis einer Höhenkarte "
-"(DEM)."
#: ../raster/r.topidx/main.c:50
-#, fuzzy
msgid "Output topographic index map"
-msgstr "Ausgabekarte des Topographischen Index ln(a/tanB)."
+msgstr "Ausgabekarte mit topographischem Index"
#: ../raster/r.topidx/main.c:57
#, c-format
@@ -12523,9 +12623,8 @@
msgstr "Lese Höheninformationen... "
#: ../raster/r.topidx/file_io.c:83
-#, fuzzy
msgid "Writing topographic index map..."
+msgstr "Schreibe Karte mit topographischem Index."
#: ../raster/r.out.pov/main.c:122
msgid "Converts a raster map layer into a height-field file for POVRAY."
@@ -12555,9 +12654,8 @@
"Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
#: ../raster/r.out.pov/main.c:210
-#, fuzzy
msgid "Negative elevation values in input"
-msgstr "Rasterkarte mit Höheninformationen."
+msgstr "Negative Höhenwerte in der Eingabe."
#: ../raster/r.covar/main.c:52
msgid ""
@@ -12578,7 +12676,7 @@
#: ../raster/r.covar/main.c:111
msgid "No non-null values"
-msgstr "Keine Nicht-Nullwerte."
+msgstr "Keine nicht-NULL-Werte."
#: ../raster/r.out.arc/main.c:60
msgid "Converts a raster map layer into an ESRI ARCGRID file."
@@ -12598,7 +12696,7 @@
#: ../raster/r.out.arc/main.c:93
msgid "List one entry per line instead of full row"
-msgstr "Gebe einen Eintrag pro Linie anstatt eine volle Reihe aus."
+msgstr "Gebe einen Eintrag pro Linie anstatt eine volle Zeile aus."
#: ../raster/r.report/stats.c:65
#, c-format
@@ -12618,18 +12716,14 @@
msgstr "Rasterkarte(n), für die ein Report erstellt werden soll."
#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:82
-#, fuzzy
msgid "Units"
-msgstr "Sites"
+msgstr "Einheiten"
#: ../raster/r.report/parse.c:46
-#, fuzzy
msgid ""
"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
"cover"
-msgstr ""
-"mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
-"(ercent_cover)"
+msgstr "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
#: ../raster/r.report/parse.c:56
msgid "Character representing no data cell value"
@@ -12705,12 +12799,12 @@
#: ../raster/r.report/parse.c:223
#, c-format
msgid "Only %d unit%s allowed"
-msgstr "Nur %d Einheiten%s erlaubt."
+msgstr "Nur %d Einheit%s erlaubt."
#: ../raster/r.report/parse.c:256
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read fp range for raster map <%s>"
-msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
+msgstr "Kann den fp Bereich für die Rasterkarte <%s> nicht lesen."
#: ../raster/r.report/parse.c:264 ../raster/r.mapcalc/map3.c:186
#: ../raster/r.mapcalc/map.c:92 ../raster/r.category/main.c:155
@@ -12731,7 +12825,7 @@
#: ../raster/r.in.gdal/main.c:100
msgid "Band to select (default is all bands)"
-msgstr "Ausgewählte Kanäle (Standard: alle Kanäle)."
+msgstr "auszuwählende Kanäle (Standard: alle Kanäle)."
#: ../raster/r.in.gdal/main.c:107
msgid "Name of location to read projection from for GCPs transformation"
@@ -12780,7 +12874,7 @@
#: ../raster/r.in.gdal/main.c:294
#, c-format
msgid "Location <%s> created"
-msgstr "Location <%s> erstellt!"
+msgstr "Location <%s> erstellt."
#: ../raster/r.in.gdal/main.c:393
msgid ""
@@ -12791,7 +12885,7 @@
"\n"
"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
"Projektion zu übersteuern und die Projektionsinformation der Location für "
-"diesen Import zu verwenden.\n"
+"diesen Datensatz zu verwenden.\n"
#: ../raster/r.in.gdal/main.c:512
#, c-format
@@ -12851,14 +12945,14 @@
msgstr "nicht gefunden"
#: ../raster/r.in.gdal/main.c:898
-#, fuzzy, c-format
+#, c-format
msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr "Erstelle Farbtabelle für <%s in %s> ..."
+msgstr "Erstelle Graustufen Farbtabelle für <%s> (8bit, full range)."
#: ../raster/r.in.gdal/main.c:911
-#, fuzzy, c-format
+#, c-format
msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr "Erstelle Graustufen Farbtabelle für <%s> (16bit, image range)."
#: ../raster/r.rescale/main.c:45
msgid "Rescales the range of category values in a raster map layer."
@@ -12938,9 +13032,8 @@
msgstr "Die Zahl der Punkte, die verteilt werden sollen."
#: ../raster/r.random/main.c:81
-#, fuzzy
msgid "Generate points also for NULL category"
-msgstr "Erzeuge auch Vektorpunkte für die Vektorkategorie 0 (zero)."
+msgstr "Erzeuge Punkte auch für die NULL-Kategorie."
#: ../raster/r.random/main.c:86
msgid "Report information about input raster and exit"
@@ -12951,9 +13044,9 @@
msgstr "Erzeuge Vektorpunkte als 3D-Punkte."
#: ../raster/r.random/main.c:125
-#, fuzzy, c-format
+#, c-format
msgid "Note: one (or both) of %s and %s must be specified"
-msgstr "Mindestens 2 Layer müssen angegeben werden."
+msgstr "Anmerkung: Eins (oder beide) von %s und %s muss angegeben werden."
#: ../raster/r.random/main.c:133
#, c-format
@@ -12971,9 +13064,9 @@
msgstr "Es sind keine [%ld] Zellen in der aktuellen Region."
#: ../raster/r.random/main.c:156
-#, fuzzy, c-format
+#, c-format
msgid "There aren't [%ld] non-NULL cells in the current region"
-msgstr "Es sind keine [%ld] Nichtnull-Zellen in der aktuellen Region."
+msgstr "Es sind keine [%ld] nicht-NULL Zellen in der aktuellen Region."
#: ../raster/r.random/main.c:161
msgid "There are no valid locations in the current region"
@@ -13279,9 +13372,9 @@
msgstr "Sie wissen bereits die Sonnenposition.\n"
#: ../raster/r.sunmask/main.c:465
-#, fuzzy, c-format
+#, c-format
msgid "Can't open range file for %s"
-msgstr "Kann Range-Datei für Karte %s nicht öffnen."
+msgstr "Kann Range-Datei für %s nicht öffnen."
#: ../raster/r.sunmask/main.c:481
msgid "Calculating shadows from DEM..."
@@ -13435,8 +13528,7 @@
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
-"Berechnet univariate Statistikparameter einer Rasterkarte (nur Nicht-Null-"
-"Zellen)."
#: ../raster/r.univar/r.univar_main.c:119
#, fuzzy, c-format
@@ -13453,13 +13545,12 @@
msgstr "Raster3D, Statistik"
#: ../raster/r.univar/r3.univar_main.c:79
-#, fuzzy
msgid ""
"Calculates univariate statistics from the non-null 3d cells of a raster3d "
"map."
msgstr ""
-"Zellen)."
+"Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-"
+"Rasterkarte."
#: ../raster/r.univar/r3.univar_main.c:102 ../raster3d/r3.stats/main.c:611
#, c-format
@@ -13493,19 +13584,16 @@
"(accuracy assessment) der Klassifikationsergebnisse."
#: ../raster/r.kappa/main.c:60
-#, fuzzy
msgid "Name of raster map containing classification result"
-msgstr "Name der Eingabe-Rasterkarte mit den Reibungskosten."
+msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
#: ../raster/r.kappa/main.c:65
-#, fuzzy
msgid "Name of raster map containing reference classes"
-msgstr "Name der Rasterkarte, die Brennstoff-MODELLE beinhalten."
+msgstr "Name der Rasterkarte mit Referenzklassen"
#: ../raster/r.kappa/main.c:70
-#, fuzzy
msgid "Name for output file containing error matrix and kappa"
-msgstr "Name der Ausgabedatei mit der Fehlermatrix und dem Kappa"
+msgstr "Name der Ausgabedatei mit der Fehlermatrix und Kappawert."
#: ../raster/r.kappa/main.c:76
msgid "Title for error matrix and kappa"
@@ -13516,22 +13604,20 @@
msgstr ""
#: ../raster/r.kappa/main.c:82
-#, fuzzy
msgid "132 columns (default: 80)"
-msgstr "Breite Ausgabe mit 132 Spalten (Standard: 80)"
+msgstr "132 Zeichen (Standard: 80)"
#: ../raster/r.kappa/main.c:86
-#, fuzzy
msgid "No header in the report"
msgstr "Keinen Header im Report."
#: ../raster/r.kappa/prt_label.c:16
-#, fuzzy, c-format
+#, c-format
msgid "Can't open file <%s> to write label"
-msgstr "Kann die Datei <%s> nicht zum Schreiben des Headers öffnen."
+msgstr "Kann die Datei <%s> nicht zum Schreiben der Beschriftungen öffnen."
#: ../raster/r.kappa/prt_mat.c:39
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
msgstr ""
"Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) "
@@ -13587,11 +13673,11 @@
#: ../raster/r.resamp.rst/main.c:200
msgid "Output profile curvature map (or fxx)"
-msgstr "Name der Ausgabekarte mit der Vertikal-Wölbung (fxx)."
+msgstr "Gebe vertikale Wölbung (oder fxx) aus."
#: ../raster/r.resamp.rst/main.c:208
msgid "Output tangential curvature map (or fyy)"
-msgstr "Name der Ausgabekarte mit der Horizontal-Wölbung (fyy)."
+msgstr "Gebe horizontale Wölbung (oder fyy) aus."
#: ../raster/r.resamp.rst/main.c:216
msgid "Output mean curvature map (or fxy)"
@@ -13607,7 +13693,7 @@
#: ../raster/r.resamp.rst/main.c:240
msgid "Rows/columns overlap for segmentation"
-msgstr "Reihen/Spalte Überlappung für Segmentierung."
+msgstr "Zeilen/Spalte Überlappung für Segmentierung."
#: ../raster/r.resamp.rst/main.c:248
msgid "Multiplier for z-values"
@@ -13635,9 +13721,9 @@
msgstr "Benutze dnorm unabhängige Spannung."
#: ../raster/r.resamp.rst/main.c:280 ../vector/v.surf.rst/main.c:166
-#, fuzzy
msgid "Output partial derivatives instead of topographic parameters"
-msgstr "von"
+msgstr ""
+"Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
#: ../raster/r.resamp.rst/main.c:315
#, fuzzy
@@ -13677,12 +13763,12 @@
#: ../raster/r.support/histo.c:21 ../raster/r.resample/main.c:100
#, fuzzy, c-format
msgid "Unable to read header for <%s>"
-msgstr "Kann den Header für die Karte [%s] nicht schreiben."
+msgstr "Kann den Header für <%s> nicht schreiben."
#: ../raster/r.resamp.rst/main.c:379
#, fuzzy, c-format
msgid "Map <%s> is the wrong resolution"
-msgstr "Karte [%s] hat die falsche Auflösung."
+msgstr "<%s>: Karte hat die falsche Auflösung."
#: ../raster/r.resamp.rst/main.c:387
msgid "Smoothing values can not be negative or NULL"
@@ -13706,7 +13792,7 @@
#: ../raster/r.resamp.rst/main.c:440
#, fuzzy, c-format
msgid "Error reading row %d (error = %d)"
-msgstr "Kann die Reihe %d (error = %d) nicht holen."
+msgstr "Kann die Zeile %d (Fehler = %d) nicht bekommen."
#: ../raster/r.resamp.rst/main.c:450
msgid "Maximum value of a raster map is NULL."
@@ -13796,7 +13882,7 @@
#: ../raster/r.stats/main.c:165
msgid "Print x and y (column and row)"
-msgstr "Gebe x und y aus (Spalten und Reihen)."
+msgstr "Gebe x und y aus (Spalte und Zeile)."
#: ../raster/r.stats/main.c:170
msgid "Print raw indexes of fp ranges (fp maps only)"
@@ -13807,14 +13893,14 @@
msgstr "Unterdrücke die Ausgabe von NULL-Werten, wenn alle Werte NULL sind."
#: ../raster/r.stats/main.c:196
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open file <%s> for writing"
msgstr "Kann Datei <%s> nicht zum Schreiben öffnen."
#: ../raster/r.stats/main.c:202
#, fuzzy, c-format
msgid "'%s' must be greater than zero; using %s=255"
-msgstr "nsteps muss größer als 0 sein, benutze daher nsteps=255."
+msgstr "<%s> muss größer sein als Null; verwende %s=255."
#: ../raster/r.stats/main.c:249 ../raster/r.series/main.c:158
msgid "Raster map not found"
@@ -13826,17 +13912,17 @@
"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
"will be ignored."
msgstr ""
-"%s: -i zeigt, dass %s als Integerkarte gelesen werden soll! Das -C flag und/"
-"oder die nsteps Option werden ignoriert."
+"Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
+"Option<%s> werden ignoriert."
#: ../raster/r.stats/main.c:285
-#, fuzzy, c-format
+#, c-format
msgid ""
"Cats for raster map <%s> are either missing or have no explicit labels. "
"Using %s=%d."
msgstr ""
-"%s: Kategorien für %s fehlen oder haben keine expliziten Label. Benutze "
-"nsteps=%d."
+"Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
+"Beschriftungen. Verwende %s=%d."
#: ../raster/r.stats/main.c:291
#, fuzzy, c-format
@@ -13844,13 +13930,13 @@
"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
"option"
msgstr ""
-"%s: Das -C flag wurde angegeben. Benutze daher die fp-Kategoriespannen von %"
-"s und ignoriere die Option nsteps."
+"Der Schalter '-%c' wurde angegeben. Verwende die fp-Kategoriespanne der "
+"Rasterkarte <%s> und ignoriere die Option <%s>."
#: ../raster/r.stats/main.c:297
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read fp range of raster map <%s>"
+msgstr "Kann den fp Bereich der Rasterkarte <%s> nicht lesen."
#: ../raster/r.stats/main.c:317 ../raster/r.recode/read_rules.c:34
#, c-format
@@ -13882,16 +13968,16 @@
msgstr "Raster, Import, LIDAR"
#: ../raster/r.in.xyz/main.c:161
-#, fuzzy
msgid ""
"Create a raster map from an assemblage of many coordinates using univariate "
"statistics."
-msgstr "Erstellen."
+msgstr ""
+"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
+"univariater Statistik."
#: ../raster/r.in.xyz/main.c:165
msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-"ASCII-Datei die Eingabedaten enthält (oder \"-\" um von stdin zu lesen)"
+msgstr "ASCII-Datei mit Eingabedaten (oder \"-\" um von stdin zu lesen)"
#: ../raster/r.in.xyz/main.c:173
msgid "Statistic to use for raster values"
@@ -13920,49 +14006,49 @@
#: ../raster/r.in.xyz/main.c:204
msgid "Column number of y coordinates in input file"
-msgstr "Spaltenummer der X-Koordinate in der Eingabedatei."
+msgstr "Spaltenummer der Y-Koordinate in der Eingabedatei."
#: ../raster/r.in.xyz/main.c:212
msgid "Column number of data values in input file"
msgstr "Spaltenummer der Daten in der Eingabedatei."
#: ../raster/r.in.xyz/main.c:220
-#, fuzzy
msgid "Filter range for z data (min,max)"
-msgstr "Integerspanne: min,max"
+msgstr "Filterbereich für z-Daten (min,max)."
#: ../raster/r.in.xyz/main.c:227
msgid "Scale to apply to z data"
-msgstr ""
+msgstr "Skalierungsfaktor für die z-Daten."
#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:209
#: ../raster/r.walk/main.c:274
msgid "Percent of map to keep in memory"
-msgstr "Prozent der Karte, welche im Speicher bleiben soll."
+msgstr "Prozentteil der Karte, der im Speicher gehalten werden soll."
#: ../raster/r.in.xyz/main.c:242
-#, fuzzy
msgid "pth percentile of the values"
-msgstr "Ausgabekarte, die den Blau-Kanal repräsentiert."
+msgstr "Perzentil der Werte"
#: ../raster/r.in.xyz/main.c:251
msgid ""
"Discard <trim> percent of the smallest and <trim> percent of the largest "
"observations"
msgstr ""
+"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
+"Beobachtungen."
#: ../raster/r.in.xyz/main.c:256
msgid "Scan data file for extent then exit"
msgstr ""
+"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
#: ../raster/r.in.xyz/main.c:261
-#, fuzzy
msgid "In scan mode, print using shell script style"
-msgstr "Gebe die Statistik im Shell-Skript-Style aus."
+msgstr "Im Lesemodus Ausgabe im Shell-Skript-Stil."
#: ../raster/r.in.xyz/main.c:265
msgid "Ignore broken lines"
-msgstr ""
+msgstr "Ignoriere kaputte Zeilen."
#: ../raster/r.in.xyz/main.c:291
msgid "Please specify a reasonable column number."
@@ -13970,24 +14056,26 @@
#: ../raster/r.in.xyz/main.c:386
msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
+msgstr "Kann das Perzentil nicht berechnen ohne die Angabe von pth!"
#: ../raster/r.in.xyz/main.c:398
msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
+msgstr "Kann keinen getrimmten Mittelwert (trimmean) ohne Angabe von trim!"
#: ../raster/r.in.xyz/main.c:474
msgid ""
"If input is not from a file it is only possible to perform a single pass."
msgstr ""
+"Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
+"ausgeführt werden."
#: ../raster/r.in.xyz/main.c:480
msgid "zrange will not be taken into account during scan"
-msgstr ""
+msgstr "zrange wird im Lesemodus nicht berücksichtigt."
#: ../raster/r.in.xyz/main.c:518 ../raster/r.in.xyz/main.c:1085
msgid "Scanning data ..."
-msgstr "Scanne Daten..."
+msgstr "Lese Daten ..."
#: ../raster/r.in.xyz/main.c:525 ../raster/r.in.poly/poly2rast.c:41
#, c-format
@@ -14001,40 +14089,43 @@
"Not enough data columns. Incorrect delimiter or column number? Found the "
"following character(s) in row %lu:\n"
"[%s]"
-msgstr "in"
+msgstr ""
+"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe "
+"die folgenden Zeichen in Zeile %lu gefunden:\n"
+"<%s>"
#: ../raster/r.in.xyz/main.c:600 ../raster/r.in.xyz/main.c:1104
msgid "Line ignored as requested"
msgstr "Zeile, wie gefordert, ignoriert."
#: ../raster/r.in.xyz/main.c:619 ../raster/r.in.xyz/main.c:1138
-#, fuzzy, c-format
+#, c-format
msgid "Bad y-coordinate line %lu column %d. <%s>"
-msgstr "Böse Y-Koordinate in Zeile %d Spalte %d. <%s>"
+msgstr "Schlechte Y-Koordinate in Zeile %lu Spalte %d. <%s>"
#: ../raster/r.in.xyz/main.c:626 ../raster/r.in.xyz/main.c:1123
-#, fuzzy, c-format
+#, c-format
msgid "Bad x-coordinate line %lu column %d. <%s>"
-msgstr "Böse X-Koordinate in Zeile %d Spalte %d. <%s>"
+msgstr "Schlechte X-Koordinate in Zeile %lu Spalte %d. <%s>"
#: ../raster/r.in.xyz/main.c:633 ../raster/r.in.xyz/main.c:1153
-#, fuzzy, c-format
+#, c-format
msgid "Bad z-coordinate line %lu column %d. <%s>"
-msgstr "Böse Z-Koordinate in Zeile %d Spalte %d. <%s>"
+msgstr "Schlechte Z-Koordinate in Zeile %lu Spalte %d. <%s>"
#: ../raster/r.in.xyz/main.c:715
msgid "Writing to map ..."
-msgstr "Übetrage in die Karte ..."
+msgstr "Schreibe in die Karte ..."
#: ../raster/r.in.xyz/main.c:1011
#, c-format
msgid "Writing map, row %d"
-msgstr "Schreibe Karte, derzeit Reihe %d."
+msgstr "Schreibe Karte, Zeile %d."
#: ../raster/r.in.xyz/main.c:1058
-#, fuzzy, c-format
+#, c-format
msgid "%lu points found in region."
-msgstr "%d Punkte in der Region."
+msgstr "%lu Punkte in der Region gefunden."
#: ../raster/r.in.xyz/main.c:1173
#, c-format
@@ -14042,9 +14133,8 @@
msgstr "Bereich: min max\n"
#: ../raster/r.slope.aspect/main.c:151
-#, fuzzy
msgid "raster, terrain analysis"
-msgstr "Raster, Statistik"
+msgstr "Raster, Geländeanalyse"
#: ../raster/r.slope.aspect/main.c:153
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:155
@@ -14058,14 +14148,12 @@
"werden vom Osten gegen den Uhrzeigersinn berechnet."
#: ../raster/r.slope.aspect/main.c:165
-#, fuzzy
msgid "Name for output slope raster map"
-msgstr "Name der Ausgabe-Rasterkarte."
+msgstr "Name der Ausgabe-Neigungs-Rasterkarte."
#: ../raster/r.slope.aspect/main.c:173
-#, fuzzy
msgid "Name for output aspect raster map"
+msgstr "Name der Ausgabe-Expositions-Rasterkarte."
#: ../raster/r.slope.aspect/main.c:181
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:188
@@ -14078,43 +14166,38 @@
msgstr "Typ für die Ausgabe von Hangneigung und -ausrichtung."
#: ../raster/r.slope.aspect/main.c:201
-#, fuzzy
msgid "Name for output profile curvature raster map"
-msgstr "Ausgabekarte mit der Vertikal-Wölbung."
+msgstr "Name der Ausgabe-Rasterkarte mit vertikaler Wölbung."
#: ../raster/r.slope.aspect/main.c:211
-#, fuzzy
msgid "Name for output tangential curvature raster map"
-msgstr "Ausgabekarte mit Horizontal-Wölbung."
+msgstr "Name der Ausgabe-Rasterkarte mit horizontaler Wölbung."
#: ../raster/r.slope.aspect/main.c:221
-#, fuzzy
msgid ""
"Name for output first order partial derivative dx (E-W slope) raster map"
msgstr ""
-"Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West "
+"Hangneigung)."
#: ../raster/r.slope.aspect/main.c:231
-#, fuzzy
msgid ""
"Name for output first order partial derivative dy (N-S slope) raster map"
msgstr ""
-"Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd "
+"Hangneigung)."
#: ../raster/r.slope.aspect/main.c:241
-#, fuzzy
msgid "Name for output second order partial derivative dxx raster map"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
+msgstr "Name der Ausgabe-Rasterkarte der zweiten partiellen Ableitung dxx."
#: ../raster/r.slope.aspect/main.c:251
-#, fuzzy
msgid "Name for output second order partial derivative dyy raster map"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dyy."
+msgstr "Name der Ausgabe-Rasterkarte der zweiten partiellen Ableitung dyy."
#: ../raster/r.slope.aspect/main.c:261
-#, fuzzy
msgid "Name for output second order partial derivative dxy raster map"
-msgstr "Ausgabekarte der zweiten partiellen Ableitung dxy."
+msgstr "Name der Ausgabe-Rasterkarte der zweiten partiellen Ableitung dxy."
#: ../raster/r.slope.aspect/main.c:267
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
@@ -14136,14 +14219,14 @@
"anpassen."
#: ../raster/r.slope.aspect/main.c:337
-#, fuzzy, c-format
+#, c-format
msgid "%s=%s - must be a positive number"
-msgstr "%s = %s -- muss größer als 0 (zero) sein."
+msgstr "%s=%s - muss eine positive Zahl sein."
#: ../raster/r.slope.aspect/main.c:343
-#, fuzzy, c-format
+#, c-format
msgid "%s=%s - must be a non-negative number"
+msgstr "%s=%s - muss eine nicht negative Zahl sein."
#: ../raster/r.slope.aspect/main.c:358
#, c-format
@@ -14153,31 +14236,30 @@
msgstr ""
#: ../raster/r.slope.aspect/main.c:388
-#, fuzzy, c-format
+#, c-format
msgid "Wrong raster type: %s"
-msgstr "Falscher Typ: %s"
+msgstr "Falscher Raster-Typ: %s"
#: ../raster/r.slope.aspect/main.c:418
#, c-format
msgid "Converting units to meters, factor=%.6f"
-msgstr ""
+msgstr "Konvertiere Einheit zu Meter, Faktor=%.6f"
#: ../raster/r.slope.aspect/main.c:1000
-#, fuzzy, c-format
+#, c-format
msgid "Elevation products for mapset <%s> in <%s>"
-msgstr "Kann Rasterkarte [%s] in [%s] nicht öffnen."
+msgstr "Höhen-Ergebnisse für Mapset <%s> in <%s>."
#: ../raster/r.slope.aspect/main.c:1019
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1042
-#, fuzzy, c-format
+#, c-format
msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr ""
-"minimale berechnete Exposition%.4f maximale berechnete Exposition %.4f."
+msgstr "Min berechnete Exposition%.4f, max berechnete Exposition %.4f."
#: ../raster/r.slope.aspect/main.c:1081
-#, fuzzy, c-format
+#, c-format
msgid "Aspect raster map <%s> complete"
-msgstr "Basis-Rasterkarte <%s> nicht gefunden."
+msgstr "Expositions-Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1123
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1146
@@ -14187,44 +14269,44 @@
"minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
#: ../raster/r.slope.aspect/main.c:1174
-#, fuzzy, c-format
+#, c-format
msgid "Slope raster map <%s> complete"
-msgstr "slopein Rasterkarte <%s> nicht gefunden."
+msgstr "Neigungs-Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1245
-#, fuzzy, c-format
+#, c-format
msgid "Profile curve raster map <%s> complete"
+msgstr "Rasterkarte mit vertikaler Wölbung <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1271
-#, fuzzy, c-format
+#, c-format
msgid "Tangential curve raster map <%s> complete"
-msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+msgstr "Rasterkarte mit horizontaler Wölbung <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1295
-#, fuzzy, c-format
+#, c-format
msgid "E-W slope raster map <%s> complete"
+msgstr "O-W Neigungs-Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1319
-#, fuzzy, c-format
+#, c-format
msgid "N-S slope raster map <%s> complete"
+msgstr "N-S Neigungs-Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1343
-#, fuzzy, c-format
+#, c-format
msgid "Dxx raster map <%s> complete"
-msgstr "3D-Rasterkarte <%s> nicht gefunden."
+msgstr "Dxx Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1367
-#, fuzzy, c-format
+#, c-format
msgid "Dyy raster map <%s> complete"
+msgstr "Dyy Rasterkarte <%s> komplett."
#: ../raster/r.slope.aspect/main.c:1391
-#, fuzzy, c-format
+#, c-format
msgid "Dxy raster map <%s> complete"
+msgstr "Dxy Rasterkarte <%s> komplett."
#: ../raster/r.surf.gauss/main.c:40
msgid ""
@@ -14238,9 +14320,8 @@
"verwendet."
#: ../raster/r.surf.gauss/main.c:46
-#, fuzzy
msgid "Name of the output random surface"
+msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche."
#: ../raster/r.surf.gauss/main.c:50
msgid "Distribution mean"
@@ -14255,19 +14336,16 @@
msgstr "Raster, Farbtabellen"
#: ../raster/r.colors/main.c:166
-#, fuzzy
msgid "Creates/modifies the color table associated with a raster map layer."
-msgstr "Erstellt/modifiziert die Farbtabelle einer Rasterkarte."
+msgstr "Erzeugt/verändert die Farbtabelle einer Rasterkarte."
#: ../raster/r.colors/main.c:178
msgid "Raster map name from which to copy color table"
#: ../raster/r.colors/main.c:183
-#, fuzzy
msgid "Path to rules file (\"-\" to read rules from stdin)"
-msgstr ""
-"Eingabe-Koordinatendatei (leer lassen, wenn von stdin gelesen werden soll)."
+msgstr "Pfad zur Datei mit Regeln (\"-\" um Regeln von stdin zu lesen)."
#: ../raster/r.colors/main.c:194
msgid "Type of color table"
@@ -14279,7 +14357,7 @@
#: ../raster/r.colors/main.c:205
msgid "Only write new color table if one doesn't already exist"
-msgstr ""
+msgstr "Schreibe neue Farbtabelle nur, wenn noch keine existiert."
#: ../raster/r.colors/main.c:209
msgid "List available rules then exit"
@@ -14291,7 +14369,7 @@
#: ../raster/r.colors/main.c:218
msgid "Logarithmic scaling"
-msgstr ""
+msgstr "Logarithmische Skalierung"
#: ../raster/r.colors/main.c:223
#, fuzzy
@@ -14300,7 +14378,7 @@
#: ../raster/r.colors/main.c:243
msgid "No map specified"
-msgstr "Keine Karte(n) angegeben."
+msgstr "Keine Karte angegeben."
#: ../raster/r.colors/main.c:246
#, fuzzy
@@ -14314,6 +14392,8 @@
#: ../raster/r.colors/main.c:249
msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
msgstr ""
+"Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig "
+"aus."
#: ../raster/r.colors/main.c:263
#, c-format
@@ -14359,9 +14439,9 @@
"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
#: ../raster/r.colors/rules.c:51
-#, fuzzy, c-format
+#, c-format
msgid "fp: Data range is %s to %s\n"
-msgstr "fp: Datenspanne reicht von %.25f bis %.25f\n"
+msgstr "fp: Datenspanne von %s bis %s\n"
#: ../raster/r.colors/rules.c:66
#, c-format
@@ -14409,9 +14489,9 @@
msgstr "Schlechte Regel (%s); Regel nicht hinzugefügt."
#: ../raster/r.colors/rules.c:136
-#, c-format
+#, fuzzy, c-format
msgid "bad rule (%s): [%s]"
-msgstr ""
+msgstr "Schlechte Regel (%s): <%s>."
#: ../raster/r.out.ppm/main.c:54
#, fuzzy
@@ -14447,17 +14527,17 @@
#: ../raster/r.fill.dir/resolve.c:135
#, c-format
msgid "Downward pass %d"
-msgstr ""
+msgstr "abwärts Durchgang %d"
#: ../raster/r.fill.dir/resolve.c:172
#, c-format
msgid "Upward pass %d"
-msgstr ""
+msgstr "aufwärts Durchgang %d"
#: ../raster/r.fill.dir/wtrshed.c:94
#, c-format
msgid "wtrshed pass %d"
-msgstr ""
+msgstr "Einzugsgebiet Durchgang %d"
#: ../raster/r.fill.dir/main.c:86
#, fuzzy
@@ -14485,7 +14565,6 @@
msgstr "Ausgabeformat der Expositionsrichtung (agnps, answers oder grass)."
#: ../raster/r.fill.dir/main.c:127
-#, fuzzy
msgid "Find unresolved areas only"
msgstr "Finde nur unaufgelöste Flächen."
@@ -14553,12 +14632,12 @@
#: ../raster/r.what/main.c:142
msgid "Output color values as RRR:GGG:BBB"
-msgstr ""
+msgstr "Gebe Farbwerte als RRR:GGG:BBB aus."
#: ../raster/r.what/main.c:190
#, fuzzy, c-format
msgid "can only do up to %d raster maps"
-msgstr "Location der Eingabe-Rasterkarte"
+msgstr "%s: Kann nur bis zu %d Rasterkarten abfragen, sorry\n"
#: ../raster/r.what/main.c:207
#, fuzzy, c-format
@@ -14571,23 +14650,23 @@
"%s: saving [%s] raster map layer.\n"
"Percent complete:"
msgstr ""
-"%s: Speichere [%s] Rasterkarte.\n"
+"%s: Speichere <%s> Rasterkarte.\n"
"Prozent fertig: "
#: ../raster/r.random.surface/init.c:114
#, c-format
msgid "Seed [%d] larger than maximum [%d]"
-msgstr ""
+msgstr "Startwert [%d] größer als das Maximum [%d]."
#: ../raster/r.random.surface/init.c:117 ../raster/r.random.surface/init.c:126
#, c-format
msgid " seed is set to %d"
-msgstr ""
+msgstr "Startwert wurde auf %d gesetzt."
#: ../raster/r.random.surface/init.c:122
#, c-format
msgid "Seed [%d] smaller than minimum [%d]"
-msgstr ""
+msgstr "Startwert [%d] kleiner als das Minimum [%d]."
#: ../raster/r.random.surface/main.c:62
msgid "Generates random surface(s) with spatial dependence."
@@ -14596,12 +14675,12 @@
#: ../raster/r.random.surface/main.c:126
#, fuzzy, c-format
msgid "Starting map [%s]"
-msgstr "Ausgangskarte [%s]."
+msgstr "Ausgangskarte <%s>."
#: ../raster/r.random.surface/main.c:136
#, c-format
msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-msgstr ""
+msgstr "Beginne Filter Nr. %d, Distanz: %.*lf, Exponent: %.*lf, flach: %.*lf"
#: ../raster/r.random.surface/main.c:141
msgid "Percent done:"
@@ -14618,7 +14697,7 @@
#: ../raster/r.cost/btree.c:183
msgid "Illegal delete request"
-msgstr ""
+msgstr "Ungültige Löschanfrage."
#: ../raster/r.cost/btree.c:370
msgid "Nothing to show"
@@ -14626,31 +14705,31 @@
#: ../raster/r.cost/btree.c:401
msgid "Bad Start Cell"
-msgstr ""
+msgstr "Schlechte Start-Zelle."
#: ../raster/r.cost/btree.c:415
#, c-format
msgid "%s %f-%f lower cost higher or equal"
-msgstr ""
+msgstr "%s %f-%f niedrigere Kosten höher oder gleich"
#: ../raster/r.cost/btree.c:421
#, c-format
msgid "%s lower above pointer wrong"
-msgstr ""
+msgstr "%s lower above pointer wrong"
#: ../raster/r.cost/btree.c:428
#, c-format
msgid "%s %f-%f higher cost lower"
-msgstr ""
+msgstr "%s %f-%f higher cost lower"
#: ../raster/r.cost/btree.c:434
-#, fuzzy, c-format
+#, c-format
msgid "%s higher above pointer wrong"
-msgstr "Kamerahöhe über der Oberfläche."
+msgstr "%s higher above pointer wrong"
#: ../raster/r.cost/main.c:134
msgid "raster, cost surface, cumulative costs"
-msgstr ""
+msgstr "Raster, Kostenfläche, kumulative Kosten"
#: ../raster/r.cost/main.c:136
msgid ""
@@ -14694,8 +14773,8 @@
#: ../raster/r.cost/main.c:200 ../raster/r.walk/main.c:266
msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
-"Kosten, welche Zellen mit NULL-Werten zugewiesen werden soll. Standardmäßig "
-"werden NULL-Zellen ignoriert."
+"Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen "
+"ignoriert."
#: ../raster/r.cost/main.c:214 ../raster/r.walk/main.c:316
msgid "Use the 'Knight's move'; slower, but more accurate"
@@ -14705,7 +14784,7 @@
#: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:320
msgid "Keep null values in output map"
-msgstr "Behalte NULL-Werte in Ausgabe-Karte bei."
+msgstr "Behalte NULL-Werte in Ausgabekarte bei."
#: ../raster/r.cost/main.c:222 ../raster/r.walk/main.c:324
msgid "Start with values in raster map"
@@ -14713,7 +14792,6 @@
#: ../raster/r.cost/main.c:234 ../raster/r.water.outlet/main.c:101
#: ../raster/r.walk/main.c:339
-#, fuzzy
msgid "Unable to read current window parameters"
msgstr "Kann die aktuellen Fensterparameter nicht lesen."
@@ -14740,16 +14818,16 @@
#: ../raster/r.cost/main.c:287 ../raster/r.walk/main.c:410
msgid "Null cells excluded from cost evaluation."
-msgstr "Nullwerte werden von der Kostenevaluation ausgeschlossen."
+msgstr "NULL-Zellen werden von der Kostenevaluation ausgeschlossen."
#: ../raster/r.cost/main.c:291 ../raster/r.walk/main.c:414
msgid "Input null cell will be retained into output map"
-msgstr "Eingabe-Nullwerte den in der Ausgabe-Karte beibehalten."
+msgstr "Eingabe-NULL-Werte werden in der Ausgabe-Karte beibehalten."
#: ../raster/r.cost/main.c:301 ../raster/r.walk/main.c:503
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
msgstr ""
-"Warnung: Weise negative Costen Nullzellen zu. Nullzellen werden "
+"Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden "
"ausgeschlossen."
#: ../raster/r.cost/main.c:339
@@ -14768,7 +14846,7 @@
#: ../raster/r.walk/main.c:582 ../raster/r.walk/main.c:619
#, c-format
msgid " %d rows, %d cols"
-msgstr "%d Reihen, %d Spalten."
+msgstr "%d Zeilen, %d Spalten."
#: ../raster/r.cost/main.c:362 ../raster/r.walk/main.c:637
msgid "Creating some temporary files..."
@@ -14784,21 +14862,19 @@
msgstr "Initialisiere die Ausgabe ."
#: ../raster/r.cost/main.c:456 ../raster/r.walk/main.c:803
-#, fuzzy
msgid "Unable to allocate memory for segment fbuff == NULL"
-msgstr "Kann den Speicher für das Segment fbuff == NULL nicht belegen."
+msgstr "Kann den Speicher für das Segment fbuff == NULL nicht allokieren."
#: ../raster/r.cost/main.c:583
#, fuzzy, c-format
msgid "can't open raster map [%s] needed for input coordinates"
msgstr ""
-"Kann die Rasterkarte [%s], die für die Eingabekoordinaten benötigt wird, "
+"Kann die Rasterkarte <%s>, die für die Eingabekoordinaten benötigt wird, "
"nicht öffnen."
#: ../raster/r.cost/main.c:643 ../raster/r.walk/main.c:887
-#, fuzzy
msgid "Specified starting location outside database window"
-msgstr "Angegebener Startpunkt ist außerhalb des Datenbankfensters."
+msgstr "Angegebene Start-Location ist außerhalb des Datenbankfensters."
#: ../raster/r.cost/main.c:659 ../raster/r.walk/main.c:904
msgid "Finding cost path"
@@ -14819,7 +14895,7 @@
#: ../raster/r.cost/main.c:903 ../raster/r.walk/main.c:1373
msgid "Will copy input map null values into output map"
-msgstr "Nullwerte der Eingabekarte werden in die Ausgabekarte übernommen."
+msgstr "NULL-Werte der Eingabekarte werden in die Ausgabekarte übernommen."
#: ../raster/r.cost/main.c:911 ../raster/r.walk/main.c:1380
msgid ""
@@ -14894,19 +14970,16 @@
"angegeben wurde)."
#: ../raster/r.out.vtk/parameters.c:76
-#, fuzzy
msgid ""
"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
msgstr ""
-"Drei (R,G,B) Rasterkarten, welche zum Erzeugen der RGB-Werte verwendet "
-"werden sollen [Rote Karte,Grüne Karte,Blaue Karte]."
+"Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,"
+"blaue Karte]."
#: ../raster/r.out.vtk/parameters.c:86
-#, fuzzy
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-"Drei (x,y,z) Rasterkarten, welche zum Erzeugen der Vektorwerte verwendet "
-"werden sollen. [xmap,ymap,zmap]"
+"Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
#: ../raster/r.out.vtk/parameters.c:93 ../raster3d/r3.out.vtk/parameters.c:99
#: ../vector/v.out.vtk/main.c:76
@@ -14970,7 +15043,7 @@
#: ../raster/r.out.vtk/writeascii.c:479
#, c-format
msgid "Unable to read row %i\n"
-msgstr "Kann Reihe %i nicht lesen.\n"
+msgstr "Kann Zeile %i nicht lesen.\n"
#: ../raster/r.out.vtk/writeascii.c:227
msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
@@ -15030,7 +15103,7 @@
#: ../raster/r.support/histo.c:34
#, fuzzy, c-format
msgid "Unable to read row %d"
#: ../raster/r.support/main.c:55
msgid "raster, metadata"
@@ -15089,7 +15162,7 @@
#, fuzzy
msgid "Update statistics (histogram, range)"
msgstr ""
-"Wollen Sie die Statistik (Histogramm, Spannweite) für die Karte [%s] "
+"Wollen Sie die Statistik (Histogramm, Spannweite) für die Karte <%s> "
"aktualisieren?"
#: ../raster/r.support/main.c:133
@@ -15103,9 +15176,9 @@
msgstr "Kann Signaturdatei nicht öffnen."
#: ../raster/r.support/main.c:147 ../raster/r.category/main.c:136
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found in current mapset"
-msgstr "Vektorkarte <%s> nicht gefunden."
+msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
#: ../raster/r.support/main.c:186 ../raster/r.support/main.c:204
msgid "Not enough room in history file"
@@ -15114,27 +15187,27 @@
#: ../raster/r.support/main.c:291
#, fuzzy, c-format
msgid "cats table for [%s] set to %s"
-msgstr "Farbtabelle für [%s] ist auf %s gesetzt."
+msgstr "Farbtabelle für <%s> ist auf %s gesetzt."
#: ../raster/r.support/main.c:315 ../raster/r.support/main.c:345
#, fuzzy, c-format
msgid "[%s] is a reclass of another map. Exiting."
-msgstr "[%s] ist eine reklassifizierte Karte einer anderen Karte. Beende mich."
+msgstr "<%s> ist eine reklassifizierte Karte einer anderen Karte. Beende mich."
#: ../raster/r.support/main.c:326
#, fuzzy, c-format
msgid "Writing new null file for [%s]... "
-msgstr "Schreibe neue null-Datei für Karte [%s]..."
+msgstr "Schreibe neue NULL-Datei für Karte <%s>... "
#: ../raster/r.support/main.c:331
#, c-format
msgid "Error writing null row [%d]."
-msgstr "Fehler beim Schreiben der null-Reihe [%d]."
+msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
#: ../raster/r.support/main.c:349
#, fuzzy, c-format
msgid "Removing null file for [%s]...\n"
-msgstr "Entferne null-Datei für [%s]...\n"
+msgstr "Entferne NULL-Datei für <%s>...\n"
#: ../raster/r.support/check.c:25
#, fuzzy, c-format
@@ -15143,7 +15216,7 @@
" Updating statistics for [%s]"
msgstr ""
"\n"
-" Aktualisiere die Statistik für Karte [%s]."
+" Aktualisiere die Statistik für Karte <%s>."
#: ../raster/r.support/check.c:68
#, fuzzy, c-format
@@ -15151,7 +15224,7 @@
" Updating the number of categories for [%s]\n"
"\n"
msgstr ""
-" Aktualisiere die Anzahl der kategorien für Karte [%s].\n"
+" Aktualisiere die Anzahl der Kategorien für <%s>.\n"
"\n"
#: ../raster/r.out.bin/main.c:63
@@ -15164,7 +15237,7 @@
#: ../raster/r.out.bin/main.c:86
msgid "Value to write out for null"
-msgstr "Wert für NULL."
+msgstr "Wert der für NULL ausgegeben werden soll."
#: ../raster/r.out.bin/main.c:95
msgid "Export array with GMT compatible header"
@@ -15426,7 +15499,7 @@
#: ../vector/v.in.ogr/main.c:867 ../vector/v.random/main.c:284
#, c-format
msgid "Cannot insert new row: %s"
-msgstr "Kann neu Reihe '%s' nicht einfügen."
+msgstr "Kann neue Zeile %s nicht einfügen."
#: ../raster/r.to.vect/main.c:72
msgid "Converts a raster map into a vector map layer."
@@ -15631,13 +15704,15 @@
#, fuzzy, c-format
msgid "Range info for [%s] not available (run r.support)"
msgstr ""
-"Bereich-Information für Karte [%s] nicht vorhanden. (Benutzen Sie r.support)."
+"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
+"aus)."
#: ../raster/r.out.vrml/main.c:105
#, fuzzy, c-format
msgid "Range info for <%s> not available (run r.support)"
msgstr ""
+"aus)."
#: ../raster/r.out.vrml/main.c:140
#, c-format
@@ -15767,7 +15842,7 @@
#: ../raster/r.in.mat/main.c:473
#, fuzzy, c-format
msgid "Writing raster map, row %d"
+msgstr "Schreibe Karte, derzeit Zeile %d."
#: ../raster/r.watershed/ram/init_vars.c:84
#, c-format
@@ -16525,12 +16600,11 @@
#: ../raster/r.in.poly/main.c:49 ../vector/v.to.rast/main.c:86
msgid "Number of rows to hold in memory"
-msgstr "Anzahl der Reihen, die im Hauptspeicher gehalten werden sollen."
+msgstr "Anzahl der Zeilen, die im Hauptspeicher gehalten werden sollen."
#: ../raster/r.in.poly/main.c:58
-#, fuzzy
msgid "Minimum number of rows to hold in memory is 1"
+msgstr "Minimale Anzahl der im Hauptspeicher zu haltenden Zeile ist 1."
#: ../raster/r.quant/main.c:48
#, fuzzy
@@ -16546,8 +16620,7 @@
#: ../raster/r.quant/main.c:61
#, fuzzy
msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr ""
#: ../raster/r.quant/main.c:67
msgid "Base map to take quant rules from"
@@ -16572,7 +16645,7 @@
#: ../raster/r.quant/main.c:108
#, fuzzy
msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
-msgstr "weight= und -c schließen sich gegenseitig aus."
+msgstr "-r und -e schliessen sich gegenseitig aus."
#: ../raster/r.quant/main.c:116
#, fuzzy
@@ -16618,9 +16691,8 @@
msgstr ""
#: ../raster/r.quant/main.c:174
-#, fuzzy
msgid "No rules specified. Quant table(s) not changed."
-msgstr "Keine Regeln angegeben. [%s] nicht erzeugt."
+msgstr "Keine Regeln angegeben. Quant-Tabelle nicht geändert."
#: ../raster/r.quant/main.c:182
#, fuzzy, c-format
@@ -16786,7 +16858,7 @@
#: ../raster/r.cross/main.c:81
msgid "Non-zero data only"
-msgstr "Nur Nicht-Null-Daten"
+msgstr "Nur nicht-Null Daten"
#: ../raster/r.cross/main.c:94
#, c-format
@@ -16939,7 +17011,7 @@
#: ../raster/r.out.tiff/main.c:392
msgid "Got null region struct"
-msgstr "Habe Null Region struct erhalten."
+msgstr "Habe NULL-Region struct erhalten."
#: ../raster/r.out.tiff/main.c:395
msgid "Unable to open TIFF world file for writing"
@@ -16947,7 +17019,7 @@
#: ../raster/r.out.mpeg/main.c:86
msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Konvertiert Rasterkarten-Reihen zu einem MPEG-Film."
+msgstr "Konvertiert Folgen von Rasterkarten zu einem MPEG-Film."
#: ../raster/r.out.mpeg/main.c:97 ../visualization/xganim/main.c:102
#, c-format
@@ -16990,7 +17062,7 @@
#: ../raster/r.out.mpeg/main.c:297
#, fuzzy, c-format
msgid "Error reading row <%d>"
-msgstr "Fehler beim Lesen eine Datenreihe."
+msgstr "Fehler beim Lesen eine Datenzeile."
#: ../raster/r.out.mpeg/main.c:339 ../raster/r.out.mpeg/main.c:369
msgid "mpeg_encode ERROR"
@@ -17325,7 +17397,7 @@
#: ../raster/r.mapcalc/main.c:148
#, fuzzy
msgid "parse error"
-msgstr "Parameter"
+msgstr "Parameterfehler"
#: ../raster/r.mapcalc/main.c:157
msgid "Floating point error(s) occured in the calculation"
@@ -17413,72 +17485,63 @@
#: ../raster/r.mfilter/getfilt.c:27
#, fuzzy, c-format
msgid "Cannot open filter file '%s'"
-msgstr "Kann die Datei <%s> nicht öffnen."
+msgstr "Kann die Filter-Datei <%s> nicht öffnen."
#: ../raster/r.mfilter/getfilt.c:47
-#, fuzzy
msgid "Illegal filter matrix size specified"
+msgstr "Ungültige Größe für die Filtermatrix angegeben."
#: ../raster/r.mfilter/getfilt.c:50
-#, fuzzy
msgid "Even filter matrix size specified"
+msgstr "Die Filtermatrix hat eine gerade Größe."
#: ../raster/r.mfilter/getfilt.c:72
-#, fuzzy
msgid "Illegal filter matrix"
-msgstr "Ungültiger Dateiname: %s"
+msgstr "Ungültige Filtermatrix."
#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
#: ../raster/r.mfilter/getfilt.c:124
-#, fuzzy
msgid "Filter file format error"
-msgstr "Quelldatei"
+msgstr "Filter-Datei Formatfehler."
#: ../raster/r.mfilter/getfilt.c:83
msgid "Duplicate filter divisor specified"
-msgstr ""
+msgstr "Doppelter Filter-Divisior angegebn."
#: ../raster/r.mfilter/getfilt.c:101
msgid "Illegal divisor matrix"
-msgstr ""
+msgstr "Ungültige Divisormatrix."
#: ../raster/r.mfilter/getfilt.c:110
msgid "Duplicate filter type specified"
-msgstr ""
+msgstr "Doppelter Filtertyp angegebn."
#: ../raster/r.mfilter/getfilt.c:117
-#, fuzzy
msgid "Illegal filter type specified"
+msgstr "Ungültiger Filtertyp angegeben."
#: ../raster/r.mfilter/getfilt.c:127
msgid "Duplicate filter start specified"
-msgstr ""
+msgstr "Doppelter Filter-Start angegeben."
#: ../raster/r.mfilter/getfilt.c:135
#, c-format
msgid "Filter start %s ignored, using UL"
-msgstr ""
+msgstr "Filter-Start %s ignoriert, verwende UL."
#: ../raster/r.mfilter/getfilt.c:157
-#, fuzzy
msgid "Illegal filter file format"
-msgstr "Das Erraten des Sites-Formates ist schief gegangen."
+msgstr "Ungültiges Filterdateiformat."
#: ../raster/r.mfilter/main.c:55
-#, fuzzy
msgid "raster, map algebra"
-msgstr "Raster, Bildverarbeitung"
+msgstr "Raster, Kartenalgebra"
#: ../raster/r.mfilter/main.c:56
-#, fuzzy
msgid "Raster map matrix filter."
-msgstr "Rasterdatei mit Matrix-Filter"
+msgstr "Rasterkarte mit Matrix-Filter"
#: ../raster/r.mfilter/main.c:67
-#, fuzzy
msgid "Name of filter file"
msgstr "Name der Filterdatei"
@@ -17491,34 +17554,30 @@
msgstr "Titel der Ausgabe-Rasterkarte."
#: ../raster/r.mfilter/main.c:93
-#, fuzzy
msgid "Apply filter only to null data values"
-msgstr "Filter nur auf 0-Werte anwenden."
+msgstr "Filter nur auf NULL-Werte anwenden."
#: ../raster/r.mfilter/main.c:119
-#, fuzzy
msgid "Raster map too small for the size of the filter"
-msgstr "%s: Rasterkarte ist zu klein für die Größe des Filters."
+msgstr "Die Rasterkarte ist zu klein für die Größe des Filters."
#: ../raster/r.mfilter/getrow.c:12
-#, fuzzy, c-format
+#, c-format
msgid "Cannot read raster row %d"
-msgstr "Kann Rasterreihe %d nicht lesen."
+msgstr "Kann die Zeile %d des Rasters nicht lesen."
#: ../raster/r.mfilter/getrow.c:23
-#, fuzzy
msgid "Error reading temporary file"
-msgstr "Fehler beim Lesen der Datei dbmscap\n"
+msgstr "Fehler beim Lesen der temporären Datei."
#: ../raster/r.mfilter/perform.c:42 ../raster/r.mfilter/perform.c:53
-#, fuzzy
msgid "Unable to create temporary file"
+msgstr "Kann die temporäre Datei nicht erzeugen."
#: ../raster/r.mfilter/perform.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Writing raster map <%s>"
-msgstr "Schreibe Rasterkarte ..."
+msgstr "Schreibe Rasterkarte <%s>."
#: ../raster/r.composite/main.c:71
#, fuzzy
@@ -17561,7 +17620,7 @@
#: ../raster/r.composite/main.c:203
#, fuzzy, c-format
msgid "Error reading raster map <%s>"
#: ../raster/r.composite/main.c:291
#, fuzzy
@@ -17972,12 +18031,12 @@
#: ../raster/r.resample/main.c:121
#, fuzzy, c-format
msgid "Error reading row %d"
#: ../raster/r.resample/main.c:123
#, fuzzy, c-format
msgid "Error writing row %d"
#: ../raster/r.resample/main.c:144
msgid "Creating new cats file..."
@@ -18014,7 +18073,7 @@
#: ../raster/r.buffer/main.c:82
msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr "Ignoriere 0-Werte anstatt NULL-Werte."
+msgstr "Ignoriere 0-Werte anstatt der NULL-Zellen."
#: ../raster/r.buffer/main.c:119
msgid "Parse distances error"
@@ -18047,7 +18106,7 @@
#: ../raster/r.support.stats/check.c:42
#, fuzzy, c-format
msgid "Updating statistics for [%s]..."
-msgstr "Aktualisiere die Statistik für [%s]..."
+msgstr "Aktualisiere die Statistik für <%s>..."
#: ../raster/r.support.stats/check.c:55
msgid "Updating histogram range..."
@@ -18056,7 +18115,7 @@
#: ../raster/r.support.stats/check.c:87
#, fuzzy, c-format
msgid "Updating the number of categories for [%s]..."
-msgstr "Aktualisiere die Anzahl der Kategorien für [%s]..."
+msgstr "Aktualisiere die Anzahl der Kategorien für <%s>..."
#: ../raster/r.in.arc/gethead.c:88
msgid "Illegal line in header"
@@ -18198,7 +18257,7 @@
#: ../raster/r.proj/main.c:364 ../raster/r.proj/main.c:375
#, c-format
msgid "Rows: %d (%d)"
-msgstr "Reihen: %d (%d)"
+msgstr "Zeilen: %d (%d)"
#: ../raster/r.proj/main.c:365 ../raster/r.proj/main.c:376
#, c-format
@@ -18345,7 +18404,7 @@
#: ../raster/r.statistics2/main.c:185
#, fuzzy, c-format
msgid "Unable to read range of base map <%s>"
#: ../raster/r.statistics2/main.c:249
msgid "First pass"
@@ -18379,7 +18438,7 @@
#: ../raster/r.grow.distance/main.c:150 ../raster/r.grow/main.c:194
#, fuzzy, c-format
msgid "Unknown metric: [%s]."
-msgstr "Unbekannte Einheit: [%s]."
+msgstr "Unbekannte Einheit: <%s>."
#: ../raster/r.grow.distance/main.c:163
#, fuzzy, c-format
@@ -18398,7 +18457,9 @@
#: ../raster/r.grow/main.c:156
msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr "Wert für Eingabezellen, die nicht-NULL sind. (-1 => NULL)"
+msgstr ""
+"Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben "
+"werden."
#: ../raster/r.grow/main.c:162
msgid "Value to write for \"grown\" cells"
@@ -18458,7 +18519,7 @@
#: ../raster/r.category/main.c:159
#, fuzzy, c-format
msgid "Category table for <%s> set from <%s>"
#: ../raster/r.category/main.c:197 ../raster/r.category/main.c:243
#, c-format
@@ -18498,13 +18559,12 @@
#: ../raster/r.colors.out/main.c:64
#, fuzzy
msgid "Exports the color table associated with a raster map layer."
+msgstr "Stellt die Farbtabelle einer Rasterkarte dar."
#: ../raster/r.colors.out/main.c:73
#, fuzzy
msgid "Path to rules file (\"-\" to write rules to stdin)"
-msgstr ""
#: ../raster/r.colors.out/main.c:77
#, fuzzy
@@ -18523,8 +18583,8 @@
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
msgstr ""
-"Der Wert, der NULL-Werte repräsentiert. Bitte 'none' eingeben, wenn keine "
-"NULL-Werte vorhanden sind."
+"Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn Sie "
+"keinen sezen wollen)."
#: ../raster3d/r3.in.ascii/main.c:174
#, c-format
@@ -18607,7 +18667,7 @@
#: ../raster3d/r3.stats/main.c:664
msgid "Sort non-null values"
-msgstr "Sortiere Nicht-Nullwerte."
+msgstr "Sortiere Nicht-NULL-Werte."
#: ../raster3d/r3.cross.rast/main.c:55
msgid "Could not close G3D map"
@@ -18640,7 +18700,7 @@
#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
msgid "Could not write raster row"
-msgstr "Kann die Rasterreihe nicht schreiben."
+msgstr "Kann die Zeile des Rasters nicht schreiben."
#: ../raster3d/r3.cross.rast/main.c:270 ../raster3d/r3.in.v5d/main.c:193
#: ../raster3d/r3.mkdspf/main.c:78 ../raster3d/r3.out.v5d/main.c:289
@@ -18752,23 +18812,23 @@
#: ../raster3d/r3.mkdspf/main.c:155
#, fuzzy, c-format
msgid "Not able to find grid3 file for [%s]"
-msgstr "Kann grid3-Datei [%s] nicht finden."
+msgstr "Kann Grid3-Datei für <%s> nicht finden."
#: ../raster3d/r3.mkdspf/main.c:167 ../raster3d/base/r3.info.main.c:128
#, fuzzy, c-format
msgid "Error opening grid3 file [%s]"
-msgstr "Fehler beim Öffnen der Grid3 Datei [%s]."
+msgstr "Fehler beim Öffnen der Grid3-Datei <%s>."
#: ../raster3d/r3.mkdspf/main.c:170 ../raster3d/base/r3.info.main.c:287
#: ../raster3d/base/r3.info.main.c:349
#, fuzzy, c-format
msgid "Error reading range for [%s]"
-msgstr "Fehler beim Lesen der Spanne für [%s]."
+msgstr "Fehler beim Lesen der Datenspanne für <%s>."
#: ../raster3d/r3.mkdspf/main.c:199
#, fuzzy, c-format
msgid "Error opening display file [%s]"
-msgstr "Fehler beim Öffnen der Displaydatei [%s]."
+msgstr "Fehler beim Öffnen der Displaydatei <%s>."
#: ../raster3d/r3.mkdspf/main.c:220
#, c-format
@@ -18791,7 +18851,7 @@
#: ../raster3d/r3.out.v5d/main.c:152
#, c-format
msgid "Viz5D allows %d rows, you have %d rows"
-msgstr "Vis5D erlaubt %d Reihen, sie haben %d Reihen."
+msgstr "Vis5D gestattet %d Zeilen, Sie haben %d Zeilen."
#: ../raster3d/r3.out.v5d/main.c:262
#, c-format
@@ -18911,7 +18971,7 @@
#: ../raster3d/base/r3.null.main.c:204
msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Erstelle explizit ein 3D NULL-Wert Bitmap-Bild."
+msgstr "Erstelle explizit ein 3D NULL-Wert Bitmap Datei."
#: ../raster3d/base/r3.info.main.c:80
msgid "Outputs basic information about a user-specified 3D raster map layer."
@@ -19195,11 +19255,11 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:131
msgid "Could not get top raster row \n"
-msgstr "Kann die obere Rasterreihe nicht bekommen.\n"
+msgstr "Kann die oberste Zeile des Rasters nicht bekommen.\n"
#: ../raster3d/r3.out.vtk/writeVTKData.c:135
msgid "Could not get bottom raster row \n"
-msgstr "Kann die untere Rasterreihe nicht bekommen.\n"
+msgstr "Kann die untereste Zeile des Rasters nicht bekommen.\n"
#: ../raster3d/r3.out.vtk/writeVTKData.c:256
msgid "write_vtk_unstructured_grid_cells: Writing the cells"
@@ -19211,7 +19271,7 @@
"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
"ascii file"
msgstr ""
-"writeVTKData: >Schreibe Zelldata %s mit %i Reihen, %i Spalten und einer "
+"write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer "
"Tiefe von %i in eine VTK-ASCII-Datei."
#: ../raster3d/r3.out.vtk/writeVTKData.c:392
@@ -19302,11 +19362,11 @@
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:207
msgid "Output profile curvature filename"
-msgstr "Ausgabekarte mit Vertikal-Wölbung."
+msgstr "Dateiname für Ausgabekarte mit vertikaler Wölbung."
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:216
msgid "Output tangential curvature filename"
+msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:226
msgid "Output first order partial derivative dx (E-W slope) filename"
@@ -19346,52 +19406,52 @@
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1023
#, fuzzy, c-format
msgid "Elevation products for mapset [%s] in [%s]"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1104
#, fuzzy, c-format
msgid "ASPECT [%s] COMPLETE"
-msgstr "Exposition [%s] komplett."
+msgstr "EXPOSITION <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1197
-#, c-format
+#, fuzzy, c-format
msgid "SLOPE [%s] COMPLETE"
-msgstr "Hangneigung (SLOPE) [%s] komplett."
+msgstr "E-W NEIGUNG <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1268
#, fuzzy, c-format
msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "Vertikal-Wölbung (profile-curvature) [%s] komplett."
+msgstr "VERTIKALE WÖLBUNG <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
#, fuzzy, c-format
msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "Horizontal-Wölbung (tangential curvature) [%s] komplett."
+msgstr "HORIZONTALE WÖLBUNG <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1318
#, fuzzy, c-format
msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "Ost-West-Hangneigung [%s] komplett."
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1342
#, fuzzy, c-format
msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "Nord-Süd-Hangneigung [%s] komplett."
+msgstr "N-S NEIGUNG <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1366
#, fuzzy, c-format
msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] komplett."
+msgstr "DXX <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1390
#, fuzzy, c-format
msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] komplett."
+msgstr "DYY <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1414
#, fuzzy, c-format
msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] komplett."
+msgstr "DXY <%s> KOMPLETT"
#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:16
#, c-format
@@ -19651,7 +19711,7 @@
#: ../vector/v.perturb/main.c:146
msgid "Standard deviation of normal distribution must be >= zero"
-msgstr "Standardabweichung der Normalverteilung muss >= Null (Zero) sein."
+msgstr "Standardabweichung der Normalverteilung muss >= Null sein."
#: ../vector/v.perturb/main.c:228
msgid "Cannot get db link info"
@@ -19712,7 +19772,7 @@
#: ../vector/v.edit/a2b.c:270
#, fuzzy, c-format
msgid "Unknown keyword '%s' in vector head"
-msgstr "Unbekanntes Wort [%s] im Vektor-Kopf."
+msgstr "Unbekanntes Schlüsselwort <%s im Vektor-Header."
#: ../vector/v.edit/main.c:54
msgid "vector, editing, geometry"
@@ -20046,9 +20106,9 @@
#: ../vector/v.in.dxf/write_vect.c:58 ../vector/v.in.ascii/points.c:401
#: ../vector/v.in.sites/main.c:240 ../vector/v.mkgrid/main.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Unable to insert new record: %s"
+msgstr "Kann den neuen Datensatz '%s' nicht einfügen."
#: ../vector/v.in.dxf/write_vect.c:79
msgid "No DXF layers found!"
@@ -20247,9 +20307,8 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:161
#: ../vector/lidar/v.outlier/main.c:130
#: ../vector/lidar/v.surf.bspline/main.c:187
-#, fuzzy
msgid "Unable to read name of driver"
+msgstr "Kann den Namen des Treibers nicht lesen."
#: ../vector/lidar/v.lidar.edgedetection/main.c:191
#: ../vector/lidar/v.lidar.correction/main.c:177
@@ -20465,7 +20524,7 @@
#: ../vector/lidar/v.lidar.growing/main.c:224
#, c-format
msgid "Rows = %d"
-msgstr "Reihen = %d"
+msgstr "Zeilen = %d"
#: ../vector/lidar/v.lidar.growing/main.c:225
#, c-format
@@ -20876,9 +20935,9 @@
msgstr ""
#: ../vector/v.distance/main.c:808 ../vector/v.overlay/main.c:444
-#, c-format
+#, fuzzy, c-format
msgid "Unable to create table: '%s'"
-msgstr "Kann Tabelle nicht erzeugen: '%s'"
+msgstr "Kann Tabelle nicht erzeugen: %s"
#: ../vector/v.distance/main.c:845
msgid "DATETIME type not yet supported, no attributes will be uploaded"
@@ -20999,7 +21058,7 @@
#: ../vector/v.reclass/main.c:255
#, fuzzy, c-format
msgid "Cannot insert data: [%s]"
-msgstr "Kann Daten nicht einfügen: [%s]"
+msgstr "Kann Daten nicht einfügen: <%s>"
#: ../vector/v.reclass/main.c:281
msgid "Column type must be integer or string"
@@ -21062,9 +21121,9 @@
msgstr "Kann die Vektorkarte %s nicht öffnen."
#: ../vector/v.in.ascii/head.c:56
-#, fuzzy, c-format
+#, c-format
msgid "Unknown keyword <%s> in vector head"
#: ../vector/v.in.ascii/a2b.c:51
#, fuzzy, c-format
@@ -21088,7 +21147,7 @@
#: ../vector/v.in.ascii/a2b.c:153
#, fuzzy, c-format
msgid "Error reading categories: [%s]"
-msgstr "Fehler beim Lesen der Kategorien <%s>."
+msgstr "Fehler beim Lesen der Kategorien: '%s'."
#: ../vector/v.in.ascii/points.c:83
#, fuzzy
@@ -21196,13 +21255,11 @@
"(erste Spalte is 1)."
#: ../vector/v.in.ascii/main.c:136
-#, fuzzy
msgid ""
"If 0, unique category is assigned to each row and written to new column 'cat'"
msgstr ""
-"Nummer der Spalte, die als Kategoriespalte im Punkt-Modus benutzt werden "
-"soll (erste Spalte ist 1). Sofern 0 wird eine eindeutige Kategorie für jede "
-"Reihe erstellt und in die neue Spalte 'cat' geschrieben."
+"Wenn 0, dann wird in die neue Spalte 'cat' eine eindeutige Kategorie in jede "
+"Zeile geschrieben."
#: ../vector/v.in.ascii/main.c:140
msgid "Create 3D vector map"
@@ -22840,7 +22897,7 @@
"The number of features for those areas is stored as category in layer %d"
msgstr ""
"%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem "
-"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Reihe in "
+"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in "
"der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
"als Kategoriewert im Layer %d abgelegt."
@@ -23071,16 +23128,16 @@
#: ../vector/v.patch/main.c:415
msgid "Cannot fetch row"
-msgstr "Kann die Reihe nicht holen."
+msgstr "Kann die Zeile nicht holen."
#: ../vector/v.patch/main.c:466
msgid "Unknown column type"
msgstr "Unbekannter Spalten-Typ."
#: ../vector/v.patch/main.c:474
-#, c-format
+#, fuzzy, c-format
msgid "Cannot insert new record: '%s'"
+msgstr "Kann neuen Eintrag nicht einfügen: %s"
#: ../vector/v.digit/centre.c:176
msgid "Region restored to original extent."
@@ -23170,9 +23227,9 @@
msgstr "%s: Keine Datenpunkte gefunden."
#: ../vector/v.surf.idw/main.c:249
-#, fuzzy, c-format
+#, c-format
msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
-msgstr "Interpoliere Rasterkarte <%s> ... %d Reihen... "
+msgstr "Interpoliere Rasterkarte <%s> (%d Zeilen, %d Spalten)... "
#: ../vector/v.vol.rst/user1.c:107
#, fuzzy
@@ -23601,9 +23658,8 @@
msgstr "Konvertiert eine GRASS-Binärkarte vom Vektor- in das Rasterformat."
#: ../vector/v.mkgrid/main.c:74
-#, fuzzy
msgid "Number of rows and columns in grid"
+msgstr "Anzahl der Zeilen und Spalten des Gitternetzes."
#: ../vector/v.mkgrid/main.c:83
msgid "Where to place the grid"
@@ -24042,7 +24098,7 @@
#: ../vector/v.overlay/line_area.c:220 ../vector/v.overlay/area_area.c:245
#, fuzzy, c-format
msgid "Unable to insert new record: '%s'"
#: ../vector/v.overlay/area_area.c:50 ../vector/v.buffer/main.c:621
#, fuzzy
@@ -24243,7 +24299,7 @@
#: ../vector/v.label.sa/labels.c:90
#, fuzzy, c-format
msgid "Font '%s' is not a FreeType font\n"
-msgstr "%s ist keine gültige Regel."
+msgstr "Font-Pfad %s ist keine Datei."
#: ../vector/v.label.sa/labels.c:94
msgid "Font file format is not supported by FreeType"
@@ -24603,9 +24659,8 @@
msgstr ""
#: ../vector/v.kcv/main.c:86
-#, fuzzy
msgid "Number of partitions"
-msgstr "Anzahl der Reihen"
+msgstr "Anzahl der Partitionen."
#: ../vector/v.kcv/main.c:96
msgid "Name for new column to which partition number is written"
@@ -24855,9 +24910,9 @@
msgstr "Layer %d"
#: ../vector/v.what/what.c:168
-#, fuzzy, c-format
+#, c-format
msgid "Id: %d\n"
-msgstr "Insel[%d]: %d\n"
+msgstr "Id: %d\n"
#: ../vector/v.what/what.c:194
#, fuzzy, c-format
@@ -25147,9 +25202,8 @@
msgstr ""
#: ../vector/v.to.db/query.c:151
-#, fuzzy
msgid "Unable to fetch record"
+msgstr "Kann den Datensatz nicht holen."
#: ../vector/v.to.db/parse.c:37
msgid ""
@@ -25165,9 +25219,8 @@
msgstr "Name des Elements."
#: ../vector/v.to.db/parse.c:45
-#, fuzzy
msgid "Query layer (used by 'query' option)"
-msgstr "Abfrage-Layer. Wird nur von der 'Query'-Option benutzt."
+msgstr "Abfrage-Layer. Wird nur von der 'Query'-Option verwendet."
#: ../vector/v.to.db/parse.c:54
msgid "Value to upload"
@@ -25565,15 +25618,15 @@
#: ../vector/v.surf.rst/main.c:205
msgid "Output profile curvature raster map"
+msgstr "Ausgabekarte mit vertikaler Wölbung."
#: ../vector/v.surf.rst/main.c:211
msgid "Output tangential curvature raster map"
+msgstr "Ausgabekarte mit horizontaler Wölbung."
#: ../vector/v.surf.rst/main.c:217
msgid "Output mean curvature raster map"
-msgstr "Ausgabekarte mit der mittleren Wölbung."
+msgstr "Ausgabekarte mit mittlerer Wölbung."
#: ../vector/v.surf.rst/main.c:245
#, fuzzy
@@ -26731,9 +26784,9 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:822
-#, fuzzy, c-format
+#, c-format
msgid "Unable to insert reference records: %s"
+msgstr "Kann Referenzdatensatz nicht einfügen: %s"
#: ../vector/v.lrs/v.lrs.create/main.c:863
#, fuzzy
@@ -26910,7 +26963,7 @@
#: ../vector/v.proj/main.c:170
#, fuzzy, c-format
msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr "Vektordatei [%s] in der Location [%s] im Mapset [%s] nicht vorhanden."
+msgstr "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden."
#: ../vector/v.proj/main.c:194
#, c-format
@@ -27064,7 +27117,7 @@
#: ../visualization/xganim/Clr_table.c:318
#, c-format
msgid "Unknown visual class [%d]."
-msgstr "Unbekannte sichtbare Klase [%d]."
+msgstr "Unbekannte sichtbare Klasse [%d]."
#: ../visualization/ximgview/color.c:239
#: ../visualization/xganim/Clr_table.c:243
@@ -27123,7 +27176,7 @@
#: ../visualization/xganim/main.c:379
#, fuzzy, c-format
msgid "Reading file [%s]..."
-msgstr "Lese Datei [%s]..."
+msgstr "Lese Datei <%s>..."
#: ../visualization/xganim/main.c:401
msgid "Unable to determine raster cell type"
@@ -27220,11 +27273,11 @@
#: ../visualization/nviz2/cmd/main.c:46
msgid "visualization, raster, vector, raster3d"
-msgstr ""
+msgstr "Visualisierung, Raster, Vektor, 3D Raster"
#: ../visualization/nviz2/cmd/main.c:47
msgid "Experimental NVIZ CLI prototype."
-msgstr ""
+msgstr "Experimenteller Prototyp der NVIZ Kommandozeilenversion."
#: ../visualization/nviz2/cmd/main.c:133
#, c-format
@@ -27237,18 +27290,17 @@
msgstr ""
#: ../visualization/nviz2/cmd/main.c:168
-#, fuzzy
msgid "Unsupported output format"
-msgstr "Zeige unterstützte Dateiformate."
+msgstr "Nicht unterstütztes Dateiformat."
#: ../visualization/nviz2/cmd/main.c:170
-#, fuzzy, c-format
+#, c-format
msgid "File <%s> created."
msgstr "Datei <%s> erstellt."
#: ../visualization/nviz2/cmd/args.c:49
msgid "Use draw mode for all loaded surfaces"
-msgstr ""
+msgstr "Verwende Zeichen-Modus für alle geladenen Oberflächen."
#: ../visualization/nviz2/cmd/args.c:74
#, fuzzy
@@ -27263,7 +27315,7 @@
#: ../visualization/nviz2/cmd/args.c:83
msgid "Graphics file format"
-msgstr "Dateiformat"
+msgstr "Grafikdateiformat"
#: ../visualization/nviz2/cmd/args.c:93
#, fuzzy
@@ -27271,9 +27323,8 @@
msgstr "von"
#: ../visualization/nviz2/cmd/args.c:110
-#, fuzzy
msgid "Name of raster map(s) for elevation"
-msgstr "Name der Rasterkarte(n) mit Höheninformationen."
+msgstr "Name der Rasterkarte(n) mit Höhenwerten"
#: ../visualization/nviz2/cmd/args.c:111 ../visualization/nviz2/cmd/args.c:120
#: ../visualization/nviz2/cmd/args.c:127 ../visualization/nviz2/cmd/args.c:133
@@ -27281,47 +27332,40 @@
#: ../visualization/nviz2/cmd/args.c:161 ../visualization/nviz2/cmd/args.c:169
#: ../visualization/nviz2/cmd/args.c:179 ../visualization/nviz2/cmd/args.c:187
#: ../visualization/nviz2/cmd/args.c:197
-#, fuzzy
msgid "Surface"
-msgstr "Summe der Varianzen"
+msgstr "Oberfläche"
#: ../visualization/nviz2/cmd/args.c:119
-#, fuzzy
msgid "Elevation value(s)"
-msgstr "Höhenausrichtung"
+msgstr "Höhenwert(e)"
#: ../visualization/nviz2/cmd/args.c:126
-#, fuzzy
msgid "Name of raster map(s) for color"
-msgstr "Name der Rasterkarte(n) für dir Farbgebung."
+msgstr "Name der Rasterkarte(n) mit Farbwerten"
#: ../visualization/nviz2/cmd/args.c:132
-#, fuzzy
msgid "Color value(s)"
-msgstr "ID Werte"
+msgstr "Farbwert(e)"
#: ../visualization/nviz2/cmd/args.c:141
-#, fuzzy
msgid "Name of raster map(s) for mask"
+msgstr "Name der Rasterkarte(n) mit der Maske"
#: ../visualization/nviz2/cmd/args.c:150
-#, fuzzy
msgid "Name of raster map(s) for transparency"
+msgstr "Name der Rasterkarte(n) mit Transparenzwerten"
#: ../visualization/nviz2/cmd/args.c:160
msgid "Transparency value(s)"
-msgstr ""
+msgstr "Transparenz Wert(e)"
#: ../visualization/nviz2/cmd/args.c:168
-#, fuzzy
msgid "Name of raster map(s) for shininess"
+msgstr "Name der Rasterkarte(n) mit Glanzwerten"
#: ../visualization/nviz2/cmd/args.c:178
msgid "Shininess value(s)"
-msgstr ""
+msgstr "Glanz Wert(e)"
#: ../visualization/nviz2/cmd/args.c:186
#, fuzzy
@@ -27334,9 +27378,8 @@
msgstr "Eigenwert:"
#: ../visualization/nviz2/cmd/args.c:210
-#, fuzzy
msgid "Draw mode"
-msgstr "Verschiebe-Modus"
+msgstr "Zeichen-Modus"
#: ../visualization/nviz2/cmd/args.c:213 ../visualization/nviz2/cmd/args.c:224
#: ../visualization/nviz2/cmd/args.c:235 ../visualization/nviz2/cmd/args.c:247
@@ -27344,26 +27387,23 @@
#: ../visualization/nviz2/cmd/args.c:280 ../visualization/nviz2/cmd/args.c:290
#: ../visualization/nviz2/cmd/args.c:510 ../visualization/nviz2/cmd/args.c:522
msgid "Draw"
-msgstr "Zeiche"
+msgstr "Zeichnen"
#: ../visualization/nviz2/cmd/args.c:222
-#, fuzzy
msgid "Fine resolution"
-msgstr "Verwende Auflösung [%g]"
+msgstr "Feine Auflösung"
#: ../visualization/nviz2/cmd/args.c:233
-#, fuzzy
msgid "Coarse resolution"
-msgstr "Korrelation"
+msgstr "Grobe Auflösung"
#: ../visualization/nviz2/cmd/args.c:244
-#, fuzzy
msgid "Draw style"
-msgstr "Datentyp"
+msgstr "Zeichenstil"
#: ../visualization/nviz2/cmd/args.c:256 ../visualization/nviz2/cmd/args.c:277
msgid "Shading"
-msgstr ""
+msgstr "Shading"
#: ../visualization/nviz2/cmd/args.c:265
#, fuzzy
@@ -27372,9 +27412,8 @@
#: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
#: ../visualization/nviz2/cmd/args.c:426
-#, fuzzy
msgid "Position"
-msgstr "Quell-Projektion."
+msgstr "Position"
#: ../visualization/nviz2/cmd/args.c:301
#, fuzzy
@@ -27425,28 +27464,25 @@
msgstr "Symbolgröße"
#: ../visualization/nviz2/cmd/args.c:392
-#, fuzzy
msgid "Icon width"
-msgstr "Linienbreite"
+msgstr "Symbolbreite"
#: ../visualization/nviz2/cmd/args.c:401
-#, fuzzy
msgid "Icon color"
-msgstr "nv Farbe\n"
+msgstr "Symbolfarbe"
#: ../visualization/nviz2/cmd/args.c:413
msgid "Icon marker"
-msgstr ""
+msgstr "Symbolmarker"
#: ../visualization/nviz2/cmd/args.c:443
-#, fuzzy
msgid "Viewpoint position (x,y model coordinates)"
-msgstr "Position auf dem Bildschirm in geographischen Koordinaten. "
+msgstr "Position des Blickpunktes (x,y Modelkoordinaten)."
#: ../visualization/nviz2/cmd/args.c:444 ../visualization/nviz2/cmd/args.c:455
#: ../visualization/nviz2/cmd/args.c:465 ../visualization/nviz2/cmd/args.c:477
msgid "Viewpoint"
-msgstr ""
+msgstr "Blickpunkt"
#: ../visualization/nviz2/cmd/args.c:454
#, fuzzy
@@ -27464,27 +27500,24 @@
#: ../visualization/nviz2/cmd/args.c:497 ../visualization/nviz2/cmd/args.c:532
#: ../visualization/nviz2/cmd/args.c:544 ../visualization/nviz2/cmd/args.c:554
-#, fuzzy
msgid "Volume"
-msgstr "Spalten"
+msgstr "Volumen"
#: ../visualization/nviz2/cmd/args.c:507
msgid "Volume draw mode"
-msgstr ""
+msgstr "Volumen-Zeichnen-Modus"
#: ../visualization/nviz2/cmd/args.c:519
msgid "Volume shading"
-msgstr ""
+msgstr "Volumen shading"
#: ../visualization/nviz2/cmd/args.c:531
-#, fuzzy
msgid "Volume position"
+msgstr "Volumen Position"
#: ../visualization/nviz2/cmd/args.c:542
-#, fuzzy
msgid "Volume resolution"
-msgstr "Auflösung"
+msgstr "Volumen Auflösung"
#: ../visualization/nviz2/cmd/args.c:553
#, fuzzy
@@ -27494,7 +27527,7 @@
#: ../visualization/nviz2/cmd/args.c:599
#, c-format
msgid "At least one <%s> or <%s> required"
-msgstr ""
+msgstr "Zumindest einer von <%s> oder <%s> ist notwendig."
#: ../visualization/nviz2/cmd/args.c:613 ../visualization/nviz2/cmd/args.c:643
#: ../visualization/nviz2/cmd/args.c:655 ../visualization/nviz2/cmd/args.c:661
@@ -27587,57 +27620,72 @@
msgid "Height in pixels of new display monitor"
msgstr "Höhe des neuen Grafik-Fensters in Pixel."
+#, fuzzy
msgid "Moves displayed maps to another monitor"
-msgstr "Verschiebt dargestellte Karten in ein anderes Grafik-Fensters."
+msgstr "Verwaltet Fenster im Grafik-Fenster des Benutzers."
+#, fuzzy
msgid "Target monitor"
-msgstr "Ziel Grafik-Fenster."
+msgstr "Lösche Monitore... "
msgid "Source monitor"
msgstr "Quell Grafik-Fenster."
+#, fuzzy
msgid "display, export, GPS"
-msgstr "Darstellung, Export, GPS"
+msgstr "Darstellung, Vektor"
msgid "Make JPEG instead of PNG image"
msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
+#, fuzzy
msgid "display, export"
-msgstr "Darstellung, Export"
+#, fuzzy
msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr "Speichert den Inhalt des aktiven Grafik-Fensters in eine Datei."
+msgstr ""
+"Löscht den Inhalte des aktiven Grafik-Fensters mit einer benutzerdefinierten "
+"Farbe."
msgid "Compression for PNG files"
msgstr "Komprimierung für PNG-Dateien."
+#, fuzzy
msgid "Paper size for PostScript output"
-msgstr "Papierformat für PostScript Ausgabe."
+msgstr "PostScript Ausgabedatei"
+#, fuzzy
msgid "PostScript"
-msgstr "PostScript"
+#, fuzzy
msgid "Set transparent background"
-msgstr "Wähle transparenten Hintergrund."
+msgstr "Bestimmt die Farbe des Menü Hintergrunds."
+#, fuzzy
msgid "Displays a raster map and its legend on a graphics window"
-msgstr ""
-"Stellt eine Rasterkarte und die zugehörige Legende im Grafik-Fenster dar."
+msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
+#, fuzzy
msgid "omit entries with missing label"
-msgstr "Lasse Einträge mit fehlender Beschriftung weg."
+msgstr "Überspringe Kategorien ohne Label."
+#, fuzzy
msgid "Number of lines to appear in the legend"
-msgstr "Anzahl der Zeilen in der Legende."
+msgstr "Wie oft soll der Filter wiederholt werden?"
+#, fuzzy
msgid "Redraws the current display frame in the GRASS monitor"
-msgstr "Zeichnet Inhalt des aktive Grafik-Fenster neu."
+msgstr "Gebe die Namen aller im GRASS Fenster dargestellten Karten aus."
+#, fuzzy
msgid "Redraw all frames"
-msgstr "Zeichne alle Fenster erneut."
+msgstr "Speichere alle Rahmen ab."
+#, fuzzy
msgid "Resizes active display monitor"
-msgstr "Verändert die Größe des aktive Grafik-Fenster."
+msgstr "Zeige Informationen über das aktive Grafik-Fenster."
msgid "New width for window"
msgstr "Neue Fensterbreite."
@@ -27645,95 +27693,114 @@
msgid "New height for window"
msgstr "Neue Fensterhöhe."
+#, fuzzy
msgid "Slide show of GRASS raster/vector maps."
-msgstr "Diashow der GRASS Raster- und Vektorkarten."
+msgstr "von"
+#, fuzzy
msgid "display, slideshow"
-msgstr "Darstellung, Diashow"
+msgstr "Darstellung, Setup"
+#, fuzzy
msgid "Show vector maps rather than raster maps"
-msgstr "Zeige lieber Vektorkarten als Rasterkarten."
+msgstr "Setze Region angepasst an diese Rasterkarte."
+#, fuzzy
msgid "Number of seconds to pause between slides"
-msgstr "Wartezeit zwischen zwei Bildern in Sekunden."
+msgstr "Anzahl der Zellen zwischen Fließlinien."
+#, fuzzy
msgid "Enter raster map to display in 1st frame"
-msgstr ""
-"Geben Sie die Rasterkarte an, die im 1. Rahmen dargestellt werden soll."
+msgstr "Name der Rasterkarte, die angezeigt werden soll."
msgid "Enter command to execute in 1st frame"
msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
+#, fuzzy
msgid "Enter raster map to display in 2nd frame"
-msgstr ""
-"Geben Sie die Rasterkarte an, die im 2. Rahmen dargestellt werden soll."
msgid "Enter command to execute in 2nd frame"
msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
+#, fuzzy
msgid "How to split display"
-msgstr "Wie soll das Fenster geteilt werden"
+msgstr "Darzustellender Text"
+#, fuzzy
msgid "display, legend"
-msgstr "Darstellung, Legende"
+msgstr "Drehe Legende."
+#, fuzzy
msgid "Vector map to display thematically"
-msgstr "Vektorkarte, die thematisch dargestellt werden soll."
+msgstr "Vektorkartentyp."
msgid "Theme_prefs"
msgstr "Theme_prefs"
+#, fuzzy
msgid "Vector map type"
+#, fuzzy
msgid "Attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Attribut-Spalte, die für die thematische Darstellung verwendet werden soll "
-"(muss numerisch sein)."
+msgstr "Attribut-Spalte, die für die Pufferdistanz benutzt werden soll."
+#, fuzzy
msgid "Type of thematic display"
-msgstr "Art der thematische Darstellung."
+#, fuzzy
msgid "Layer to use for thematic display"
-msgstr "Layer, der für die thematische Darstellung verwendet werden soll."
+msgstr "Text für das vertikale Datum der Karte."
+#, fuzzy
msgid "Points"
-msgstr "Punkte"
+msgstr "Drucke"
+#, fuzzy
msgid "Vector point icon for point data"
-msgstr "Vektorpunkt-Icon für Punktdaten."
+msgstr "Vektordatei die Beispielpunkte enthält."
+#, fuzzy
msgid "Number of classes for interval theme (integer)"
-msgstr "Anzahl der Klassen für Einteilung in Intervalle (ganzahlig)."
+msgstr "Anzahl der Kopien."
+#, fuzzy
msgid "Misc"
-msgstr "Sonstiges"
+msgstr "Metrisch"
+#, fuzzy
msgid "Mapset(s) to list (default: current mapset search path)"
-msgstr ""
-"Mapset, dessen Dateien ausgegeben werden sollen (Standard: aktueller Mapset-"
-"Suchpfad)."
+msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
+#, fuzzy
msgid "Output separator (default: newline)"
-msgstr "Trennzeichen für die Ausgabe (Standard: Zeilenumbruch)"
+msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
+#, fuzzy
msgid "Raster to remove"
-msgstr "Rasterkarte, die entfernt werden soll."
+msgstr "Keine Rasterkarte gelöscht."
+#, fuzzy
msgid "3d raster to remove"
-msgstr "3D Raster, das entfernt werden soll."
+#, fuzzy
msgid "Vector to remove"
-msgstr "Vektorkarte, die entfernt werden soll."
+#, fuzzy
msgid "Region to remove"
-msgstr "Region, die entfernt werden soll."
+msgstr "Erzwinge das Löschen"
+#, fuzzy
msgid "Label to remove"
-msgstr "Beschriftung, die entfernt werden soll."
+msgstr "Kann nicht weitermachen."
+#, fuzzy
msgid "3dview to remove"
-msgstr "3DAnsicht, die entfernt werden sollen."
+msgstr "%d Vertices gelöscht"
msgid "Group to remove"
msgstr "Gruppe, die entfernt werden soll."
@@ -27741,18 +27808,21 @@
msgid "imagery, raster, multispectral"
msgstr "Bildverarbeitung, Raster, Multispektral"
+#, fuzzy
msgid "raster input maps"
-msgstr "Eingabe-Rasterkarten"
+msgstr "Raster, Import"
+#, fuzzy
msgid "write output to PNG image"
-msgstr "Schreibe die Ausgabe in eine PNG-Bilddatei."
+msgstr "Überschreibe Ausgabedatei."
+#, fuzzy
msgid "label with coordinates instead of numbering"
-msgstr "Beschrifte mit Koordinaten anstatt Nummerierung."
+msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
+#, fuzzy
msgid "Keep band numbers instead of using band color names."
-msgstr ""
-"Behalte die Kanalnummern bei, anstatt die Namen der Kanalfarben zu verwenden."
+msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
msgid "A"
msgstr "A"
@@ -27778,56 +27848,72 @@
msgid "Show help"
msgstr "Zeige die Hilfe an."
+#, fuzzy
msgid "Do not overwrite existing map"
-msgstr "Überschreibe existierende Karten nicht."
+msgstr "Name einer existierenden Karte."
+#, fuzzy
msgid "Exports GRASS raster into GDAL supported formats."
-msgstr "Exportiert GRASS Rasterkarten in GDAL-unterstütze Formate."
+msgstr "Exportiert GRASS-Rasterkarten in GDAL-unterstütze Formate."
+#, fuzzy
msgid "Region sensitive output"
-msgstr "Beachte die aktuelle Region."
+msgstr "Lese r.stats Ausgabe."
+#, fuzzy
msgid ""
"Creation option to the output format driver. Multiple options may be listed"
msgstr ""
-"Optionen für den Ausgabeformat Treiber. Es können mehrere Optionen angegeben "
-"werden."
+"Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
+"Optionen angegeben werden."
+#, fuzzy
msgid "Output field seperator"
-msgstr "Feld-Trennzeichen für die Ausgabe"
+msgstr "Ausgabe Feld-Trennzeichen"
+#, fuzzy
msgid "calculates univariate statistics from a GRASS raster map"
-msgstr "Berechnet Kennzahlen der univariaten Statistik einer Rasterkarte."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
msgid "extended statistics (quartiles and percentile)"
msgstr "Mehr statistische Kennzahlen (Quartile und Perzentile)."
+#, fuzzy
msgid "Percentile to calculate (requires -e flag)"
-msgstr "Perzentile, die berechnet werden sollen (benötigt den Schalter -e)."
+msgstr "Kann die Eingabekarte nicht schließen."
+#, fuzzy
msgid "A (grid3D file)"
-msgstr "A (G3D Datei)"
+msgstr "Eingabe-grid3D-Datei"
+#, fuzzy
msgid "B (grid3D file)"
-msgstr "B (G3D Datei)"
+#, fuzzy
msgid "C (grid3D file)"
-msgstr "C (G3D Datei)"
+#, fuzzy
msgid "D (grid3D file)"
-msgstr "D (G3D Datei)"
+#, fuzzy
msgid "E (grid3D file)"
-msgstr "E (G3D Datei)"
+#, fuzzy
msgid "F (grid3D file)"
-msgstr "F (G3D Datei)"
+#, fuzzy
msgid "Name for output grid3D volume"
-msgstr "Name für Ausgabe-G3D-Volumen."
+msgstr "Name der Ausgabedatei"
+#, fuzzy
msgid "raster, imagery, dehaze"
-msgstr "Raster, Bildverarbeitung, dehaze"
msgid "LANDSAT TM1 channel"
msgstr "LANDSAT TM1 Kanal"
@@ -27849,10 +27935,11 @@
#, fuzzy
msgid "raster output dehazed maps prefix"
-msgstr "Präfix für TC-Ausgabe-Rasterkarten."
+msgstr "Prefix der Ausgabe-Rasterkarte."
+#, fuzzy
msgid "%s: [%s] not found"
-msgstr "%s: [%s] nicht gefunden."
+msgstr "%s: <%s> nicht gefunden."
msgid " 'c': cells"
msgstr " 'c': Zellen"
@@ -27862,11 +27949,11 @@
#, fuzzy
msgid " 'x': percent of '%s' category (column)"
-msgstr " 'x': Prozent der '%s' Kategorie (Spalte)"
+msgstr " 'x': Prozent der <%s> Kategorie (Spalte)"
#, fuzzy
msgid " 'y': percent of '%s' category (row)"
-msgstr " 'y': Prozent der '%s' Kategorie (Zeile)"
+msgstr " 'y': Prozent der <%s> Kategorie (Zeile)"
msgid " 'a': acres"
msgstr " 'a': Acres"
@@ -27895,7 +27982,7 @@
#, fuzzy
msgid "'%s' being saved\n"
-msgstr "'%s' wird gespeichert\n"
+msgstr "<%s> wird gespeichert\n"
msgid ""
"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
@@ -27966,49 +28053,61 @@
msgid "Unable to find clump map"
msgstr "Kann die Rasterkarte mit Klumpen nicht finden."
+#, fuzzy
msgid "Memory allocation error"
-msgstr "Speicherbelegungsfehler."
+msgstr "Metrische Belegung."
+#, fuzzy
msgid "Saving new map"
-msgstr "Speichere neue Karte ..."
+msgstr "Lese Karte"
#, fuzzy
msgid "Terrain raster map (DEM)"
msgstr "Terrain Rasterkarte (DEM)."
+#, fuzzy
msgid "Output raster map with lake"
-msgstr "Ausgabe-Rasterkarte mit See."
+msgstr "Titel der Ausgabe-Rasterkarte."
+#, fuzzy
msgid "Cannot write lake raster map <%s>!"
-msgstr "Kann Rasterkarte mit See <%s> nicht schreiben!"
+msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+#, fuzzy
msgid "Terrain raster map <%s> not found!"
-msgstr "Terrain Rasterkarte <%s> konnte nicht gefunden werden."
+msgstr "aspin Rasterkarte <%s> nicht gefunden."
+#, fuzzy
msgid "Cannot open terrain raster map <%s@%s>!"
-msgstr "Kann die Terrain Rasterkarte <%s@%s> nicht öffnen!"
+msgstr "Kann die Rasterkarte <%s> nicht öffnen!"
+#, fuzzy
msgid "Seed map <%s> not found!"
-msgstr "Saatkarte <%s> konnte nicht gefunden werden."
+msgstr "%s Karte <%s> nicht gefunden."
+#, fuzzy
msgid "Cannot open seed map <%s@%s>!"
-msgstr "Kann die Saatkarte <%s@%s> nicht öffnen!"
+#, fuzzy
msgid "Failure to allocate memory for row pointers"
-msgstr "Fehlschlag beim Zuweisen von Speicherplatz für Zeilen-'Pointer'."
+msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
+#, fuzzy
msgid "Loading maps: "
-msgstr "Lade Karten: "
+#, fuzzy
msgid "Error reading terrain raster map. Probably broken file."
-msgstr ""
-"Fehler beim Lesen der Terrain-Rasterkarte. Wahrscheinlich eine kaputte Datei."
+#, fuzzy
msgid "Error reading seed raster map. Probably broken file."
-msgstr "Kann die Rasterkarte [%s] nicht lesen."
+#, fuzzy
msgid "Cannot write lake raster map <%s@%s>!"
-msgstr "Kann die See-Rasterkarte <%s@%s> nicht schreiben!"
msgid ""
"Starting lake filling at level of %8.4f in %d passes. \n"
@@ -28017,11 +28116,13 @@
"Beginne mit dem Füllen des Sees bei Niveau von %8.4f mit %d Durchgängen. \n"
"Prozent erledigt:"
+#, fuzzy
msgid "Pass: %d\n"
-msgstr "Durchlauf: %d\n"
+msgstr "Maske: %s\n"
+#, fuzzy
msgid "Error writing color file for <%s@%s>!"
-msgstr "Fehler beim Schreiben der Farbdatei für <%s@%s>!"
+msgstr "Fehler beim Schreiben der Farb-Datei für <%s>."
msgid "All done."
msgstr "Alles erledigt."
@@ -28032,11 +28133,13 @@
msgid "%s: cover raster map not found"
msgstr "%s: Bedeckungs-Rasterkarte nicht gefunden."
+#, fuzzy
msgid "Calculates <simple> index on a raster map"
-msgstr "Berechnet <einfache> Indices einer Rasterkarte."
+msgstr "Berechnet den Form-Index einer Rasterkarte."
+#, fuzzy
msgid "raster, landscape structure analysis, job launcher"
-msgstr "Raster, Landschaftsstruktur Analyse, job launcher"
+msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
msgid "Quietly"
msgstr "ruhig"
@@ -28044,13 +28147,12 @@
msgid "Bilinear interpolation utility for raster map layers."
msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#, fuzzy
msgid ""
"Specific input value to be assigned to the north and/or south poles for "
"longitude-latitude grids"
msgstr ""
-"Spezieller Eingabewert, welcher zum Nord- und/oder Südpol bei Lat-Long-"
-"Rastern zugewiesen werden soll."
+"Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und "
+"Breitengrad-Gittern zugewiesen wird."
msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
msgstr ""
@@ -28059,13 +28161,12 @@
msgid "Illegal output file name <%s>"
msgstr "Ungültiger Ausgabe-Dateiname<%s>."
-#, fuzzy
msgid ""
"The '-q' flag is superseded and will be removed in future. Please use '--"
"quiet' instead"
msgstr ""
-"Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-"ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+"Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft "
+"entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
msgid "Not enough memory for zero_array_cell"
msgstr "Nicht genügend Speicher für zero_array_cell."
@@ -28075,24 +28176,29 @@
"Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
"schreiben."
+#, fuzzy
msgid "Raster input maps(s)"
-msgstr "Eingabe-Rasterkarte(n)"
+msgstr "Eingabe-Rasterkarte für rot."
+#, fuzzy
msgid "Output file name"
-msgstr "Ausgabedateiname"
+msgstr "Ausgabe-Tabellenname"
+#, fuzzy
msgid "%s: can't read fp range for [%s]"
-msgstr "%s: Kann die fp-Spanne der Karte [%s] nicht lesen."
+msgstr "Kann die fp Spanne für <%s> nicht lesen."
+#, fuzzy
msgid ""
"Raster map [%s] already exists.\n"
"Please try another."
msgstr ""
-"Rasterkarte [%s] existiert bereits.\n"
-"Bitte versuchen Sie eine andere."
+"Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen "
+"Namen."
+#, fuzzy
msgid "Path to rules file"
-msgstr "Pfad zur Regel-Datei."
+msgstr "Pfad zur Font-Datei."
msgid "RGB raster map <%s> not found"
msgstr "RGB Rasterkarte <%s> nicht gefunden."
@@ -28114,11 +28220,11 @@
#, fuzzy
msgid "Edit header for [%s]\n"
-msgstr "Editiere Header für Karte [%s].\n"
+msgstr "Schreibe Header für <%s>.\n"
#, fuzzy
msgid "[%s] cannot be found!"
-msgstr "[%s] konnte nicht gefunden werden!"
+msgstr "<%s> konnte nicht gefunden werden!"
msgid "For what layer shall the header file be edited? "
msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
@@ -28126,21 +28232,22 @@
#, fuzzy
msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
msgstr ""
-"[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht "
-"editieren! Wende support für Karte [%s] an."
+"<%s> ist eine reklassifizierte Karte von <%s> - kann den Header nicht "
+"editieren! Führen Sie support für <%s> aus."
#, fuzzy
msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
msgstr ""
-"[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht "
+"<%s> ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht "
"editieren!"
+#, fuzzy
msgid "Cannot open raster map [%s]!"
-msgstr "Kann Rasterkarte [%s] nicht öffnen!"
#, fuzzy
msgid "Raster file [%s] is empty."
-msgstr "Rasterkarte [%s] ist leer."
+msgstr "Rasterdatei <%s> ist leer."
msgid "cellhd compression: %d\n"
msgstr "cellhd Kompression: %d\n"
@@ -28153,7 +28260,7 @@
#, fuzzy
msgid "[%s] appears to be compressed. Is it? "
-msgstr "[%s] scheint komprimiert zu sein. Ist sie es?"
+msgstr "<%s> scheint komprimiert zu sein. Ist sie es?"
msgid "Please indicate the type of compression:\n"
msgstr "Bitte geben Sie den Typ der Komprimierung an:\n"
@@ -28166,7 +28273,7 @@
#, fuzzy
msgid "The header for [%s] says the file is not compressed. "
-msgstr "Der Header der Datei [%s] sagt, dass die Datei nicht komprimiert ist."
+msgstr "Der Header der Datei <%s> sagt, dass die Datei nicht komprimiert ist."
msgid "The file appears to be compressed.\n"
msgstr "Die Datei erscheint, als sei sie komprimiert.\n"
@@ -28178,7 +28285,7 @@
#, fuzzy
msgid "The header for [%s] says the file is compressed. "
-msgstr "Der Header der Datei [%s] sagt, dass die Datei komprimiert ist."
+msgstr "Der Header der Datei <%s> sagt, dass die Datei komprimiert ist."
msgid "The file does NOT appear to be compressed.\n"
msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
@@ -28187,16 +28294,16 @@
"Header indicates %d row%s in the raster map, but the actual file format "
"indicates %d row%s"
msgstr ""
-"Header gibt an, dass %d Reihe%s in der Rasterkarte enthalten sind, aber die "
-"aktuelle Datei hat %d Reihe%s."
+"Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die "
+"aktuelle Datei hat %d Zeile%s."
#, fuzzy
msgid "Unable to write header for [%s]."
-msgstr "Kann den Header für die Karte [%s] nicht schreiben."
+msgstr "Kann den Header für <%s> nicht schreiben."
#, fuzzy
msgid "Header for raster map [%s] updated."
-msgstr "Header der Rasterkarte [%s] wurde aktualisiert."
+msgstr "Header der Rasterkarte <%s> aktualisiert."
msgid ""
"\n"
@@ -28207,7 +28314,7 @@
#, fuzzy
msgid "Please enter the following information for [%s]:"
-msgstr "Bitte geben Sie die folgenden Informationen für [%s]:"
+msgstr "Bitte geben Sie die folgenden Informationen für <%s> ein:"
msgid " Number of rows"
msgstr " Anzahl der Zeilen"
@@ -28237,15 +28344,15 @@
#, fuzzy
msgid "Raster file [%s] not found. Exiting."
-msgstr "Rasterkarte [%s] nicht gefunden. Beenden mich. "
+msgstr "Rasterkarte <%s> nicht gefunden. Beende mich. "
#, fuzzy
msgid "History file for [%s] updated."
-msgstr "Die Historiedatei für die Karte [%s] wurde aktualisiert."
+msgstr "Die Historiedatei für <%s> wurde aktualisiert."
#, fuzzy
msgid "History file for [%s] not updated."
-msgstr "Die Historiedatei für die Karte [%s] wurde nicht aktualisiert."
+msgstr "Die Historiedatei für <%s> wurde nicht aktualisiert."
msgid ""
"\n"
@@ -28256,7 +28363,7 @@
#, fuzzy
msgid "Edit header for [%s]? "
-msgstr "Editiere Header der Karte [%s]?"
+msgstr "Header für <%s> schreiben?"
#, fuzzy
msgid ""
@@ -28264,22 +28371,22 @@
"NOTE: [%s] is a reclass of [%s in %s]"
msgstr ""
"\n"
-"BEACHTE: [%s] ist eine reklassifizierte Karte von [%s in %s]."
+"BEACHTE: <%s> ist eine reklassifizierte Karte von [%s in %s]."
msgid "Canceling from edit header."
-msgstr "Breche das Editieren der Headerdatei ab."
+msgstr "Breche das Schreiben der Headerdatei ab."
#, fuzzy
msgid "Edit the category file for [%s]? "
-msgstr "Editiere die Kategorie-Datei für Karte [%s]?"
+msgstr "Kategorie-Datei für <%s> schreiben?"
#, fuzzy
msgid "Create/Update the color table for [%s]? "
-msgstr "Erzeuge/Aktualisiere die Farbtabelle für die Karte [%s]?"
+msgstr "Erzeuge/Aktualisiere die Farbtabelle für <%s>?"
#, fuzzy
msgid "Edit the history file for [%s]? "
-msgstr "Wollen Sie die History-Datei für Karte [%s] editieren?"
+msgstr "Wollen Sie die History-Datei für <%s> editieren?"
#, fuzzy
msgid ""
@@ -28289,9 +28396,9 @@
" it are treated by GRASS application programs as no data."
msgstr ""
"\n"
-"Die null-Datei für Karte [%s] kann anzeigen, dass einige Zellen NODATA "
-"enthalten. Falls die null-Datei für Karte [%s] nicht existiert, werden zero "
-"(0)-Zellen von den GRASS-Modulen als NODATA behandelt. "
+"Die NULL-Datei für <%s> könnte anzeigen, dass einige Zellen\n"
+" NULL-Werte enthalten. Falls die NULL-Datei für <%s> nicht existiert, \n"
+"werden Zellen mit 0 von GRASS-Modulen als NULL behandelt. "
#, fuzzy
msgid ""
@@ -28300,8 +28407,8 @@
"are considered valid data? "
msgstr ""
"\n"
-"Wollen Sie eine null-Datei für Karte [%s] erzeugen/zurücksetzen, so dass "
-"Zellen mit null-Werten als gültige Daten angesehen werden?"
+"Wollen Sie eine NULL-Datei für <%s> erzeugen/zurücksetzen, so dass Zellen "
+"mit NULL-Werten als gültige Daten angesehen werden?"
#, fuzzy
msgid ""
@@ -28310,8 +28417,8 @@
"(all zero cells will then be considered no data)? "
msgstr ""
"\n"
-"Wollen Sie die Null-Datei für Karte [%s] löschen?\n"
-"(alle 0 (zero)-Zellen werden dann NODATA sein.)"
+"Wollen Sie die NULL-Datei für <%s> löschen\n"
+"(alle 0 (zero)-Zellen werden dann zu NULL-Werten)? "
msgid "Which vector map needs updated categories?"
msgstr "Für welche Vektordatei sollen die Kategorien aktualisiert werden?"
@@ -28362,8 +28469,9 @@
msgid "G_put_raster_row failed (file system full?)"
msgstr "G_put_raster_row failed (Dateisystem voll?)"
+#, fuzzy
msgid "Run verbosly"
-msgstr "Ausführliche Ausgabe."
+msgstr "Detaillierte Ausgabe"
msgid "Run VERBOSELY"
@@ -28374,18 +28482,21 @@
msgid "Vector map <%s> not found in the current mapset"
msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
+#, fuzzy
msgid "Cannot execute: %s"
-msgstr "Kann '%s' nicht ausführen."
+msgstr "Kann folgende Attribute nicht auswählen: %s"
+#, fuzzy
msgid "Cannot link table: %s"
-msgstr "Kann Tabelle '%s' nicht verbinden (link)."
+msgstr "Kann die Tabelle '%s' nicht verändern."
+#, fuzzy
msgid "DXF input file"
-msgstr "DXF-Quelldatei"
+msgstr "DXF Ausgabedatei."
#, fuzzy
msgid "Cannot open dxf file <%s>"
#, fuzzy
msgid "Use output= option to change vector map name"
@@ -28393,10 +28504,11 @@
#, fuzzy
msgid "Cannot open new vector map <%s>"
-msgstr "%s: Kann neue Vektordatei nicht öffnen."
+msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
+#, fuzzy
msgid "Conversion of <%s> to vector map:"
-msgstr "Konvertiert <%s> in eine Vektorkarte:"
+msgstr "Kann die Vektordatei %s nicht erzeugen."
msgid "Vector map <%s> is not in user mapset and cannot be updated"
msgstr ""
@@ -28432,20 +28544,25 @@
msgid "Insufficent memory for allocation of data structure"
msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
+#, fuzzy
msgid "Specified group does not exist"
-msgstr "Angegebene Gruppe existiert nicht."
+msgstr "Angegebene Gruppe existiert nicht im aktuellen Mapset."
+#, fuzzy
msgid "imagery group"
msgstr "Bildgruppe"
+#, fuzzy
msgid "imagery subgroup"
-msgstr "Bild Untergruppe"
+msgstr "Bildgruppe"
+#, fuzzy
msgid "output raster map"
-msgstr "Ausgabe-Rasterkarte."
+msgstr "Ausgabe-Farbton-Rasterkarte (hue)."
+#, fuzzy
msgid "Name of input raster map(s)"
-msgstr "Name der Eingabe-Rasterkarte(n)."
+msgstr "Name der Eingabe-Rasterkarte."
msgid "Output file extension (inputfile(s) + extension)"
msgstr ""
@@ -28461,7 +28578,7 @@
msgstr "Vollname=%s\n"
msgid "usage: %s file [prompt %%x %%y]\n"
-msgstr "Benutzung: %s Datei [%%x %%y]\n"
+msgstr "Verwendung: %s Datei [Prompt %%x %%y]\n"
#, fuzzy
msgid "Illegal file name for real part: %s"
@@ -28471,15 +28588,15 @@
msgid "Illegal file name for imaginary part: %s"
msgstr "%s: %s - ungültiger Dateiname für den Bildteil\n"
+#, fuzzy
msgid "** Can't read signature file <%s> **"
-msgstr "** Kann die Signaturdatei <%s> nicht lesen. **"
+msgstr "Kann die Signaturdatei <%s> nicht lesen."
+#, fuzzy
msgid ""
"\n"
"<%s> -- illegal result signature file name"
-msgstr ""
-"\n"
-"<%s> -- Ungültiger Signaturdateiname"
+msgstr "Ungültiger Signaturdateiname <%s>."
msgid "Illegal group name <%s>"
msgstr "Ungültiger Gruppen-Name <%s>."
@@ -28546,14 +28663,14 @@
"Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
msgid "Optional display raster"
-msgstr "Rasterdarstellung optional"
+msgstr "optionale Ansichts-Rasterkarte"
msgid "Output profile data to file(s) with prefix 'name'"
msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
#, fuzzy
msgid "Display raster [%s] not found. Using profile raster."
-msgstr "Darstellung."
+msgstr "Ansichts-Rasterkarte <%s> nicht gefunden. Verwende Profilraster."
msgid ""
"\n"
@@ -28628,11 +28745,8 @@
msgid "Font name or pathname of TTF file"
msgstr "Ausgabename der neuen TIFF-Datei."
-#, fuzzy
msgid "Setting release of FreeType"
-msgstr ""
-"\n"
-" Einstellungen des FreeType-Releases\n"
+msgstr "Einstellunge des FreeType-Releases"
msgid "Display number of colors"
msgstr "Stelle die Anzahl der Farben dar."
@@ -28640,11 +28754,9 @@
msgid "Use mouse to size & place legend"
msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
-#, fuzzy
msgid "Creates a list of commands for recreating screen graphics."
msgstr ""
-"Erstelle eine Liste von Kommandos die zum Erstellen der aktuellen Grafik "
-"nötig sind."
+"Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
msgid "Name of frame(s) to save"
msgstr "Name der Rahmen zum speichern."
@@ -28840,16 +28952,15 @@
msgid "No such monitor as <%s>"
msgstr "Es gibt das Grafik-Fenster <%s> nicht."
-#, fuzzy
msgid "Monitor <%s> released"
-msgstr "Kein Grafik-Fenster ausgewählt."
+msgstr "Grafik-Fenster <%s> freigegeben."
msgid "Error - Locking mechanism failed"
msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
#, fuzzy
msgid "Error choosing frame [%s]\n"
+msgstr "Fehler beim wählen des Fensters <%s>.\n"
msgid ""
"\n"
@@ -28859,31 +28970,25 @@
"Maustasten:\n"
msgid "Left: Select frame\n"
-msgstr "Links: Fenster (frame) auswählen.\n"
+msgstr "Links: Fenster selektieren\n"
-#, fuzzy
msgid "Right: Accept frame\n"
-msgstr "Rechts: Menü beenden\n"
+msgstr "Rechts: Akzeptiere Fenster\n"
-#, fuzzy
msgid "Manages display frames on the user's graphics monitor."
-msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
-#, fuzzy
msgid "Create a new frame"
-msgstr "Speichere alle Rahmen ab."
+msgstr "Erzeuge ein neues Fenster."
-#, fuzzy
msgid "Select a frame"
-msgstr "Selektiere Daten aus der Datenbank."
+msgstr "Wählen Sie ein Fenster."
-#, fuzzy
msgid "Print name of current frame"
-msgstr "Speichere aktuellen Rahmen."
+msgstr "Gebe Namen des aktuellen Fensters aus."
-#, fuzzy
msgid "Print names of all frames"
-msgstr "Gebe Flächensummen aus."
+msgstr "Gebe Namen aller Fenster aus."
msgid "List map names displayed in GRASS monitor"
@@ -28914,36 +29019,29 @@
"Rechts: Beenden\n"
"\n"
-#, fuzzy
msgid "Monitor: interactive command in redraw"
-msgstr "Grafik-Fenster: Interaktives Kommando zum erneuten Zeichnen\n"
+msgstr "Grafik-Fenster: Interaktives Kommando zum erneuten Zeichnen."
-#, fuzzy
msgid "found %d visuals of type TrueColor"
-msgstr "Habe %d Ansichten vom Typ TrueColor gefunden\n"
+msgstr "Habe %d Ansichten vom Typ TrueColor gefunden."
msgid "searching for highest bit depth"
msgstr "Suche die höchste Bit-Tiefe"
-#, fuzzy
msgid "selected %d bit depth"
-msgstr "Ausgewählte Bit-Tiefe: %d\n"
+msgstr "wählte %d Bit-Tiefe"
-#, fuzzy
msgid "using default visual which is %s"
-msgstr "Benutze Standard-Ansicht mit '%s'.\n"
+msgstr "Verwende Standard-Ansicht %s"
-#, fuzzy
msgid "Monitor: waitpid: expected %d but got %d"
-msgstr "Grafik-Fenster: Waitpid: erwarte %d, habe aber %d bekommen.\n"
+msgstr "Grafik-Fenster: waitpid: erwartete %d, habe aber %d bekommen."
-#, fuzzy
msgid "Monitor: XGetWMName failed"
-msgstr "Grafik-Fenster: XGetWMName fehlgeschlagen.\n"
+msgstr "Grafik-Fenster: XGetWMName fehlgeschlagen."
-#, fuzzy
msgid "Monitor: XGetWMName: bad result"
-msgstr "Grafik-Fenster: XGetWMName: Falsches Ergebnis.\n"
+msgstr "Grafik-Fenster: XGetWMName: Schlechtes Ergebnis."
msgid ""
"\n"
@@ -28963,8 +29061,9 @@
msgid "<%s> is an illegal region name"
msgstr "<%s> ist ein ungültiger Regions-Name."
+#, fuzzy
msgid "No LatLong information for XY-Projection"
-msgstr "Keine LatLong-Information für XY-Projektion."
+msgstr "Geo-Gitter Option ist für XY-Projektionen nicht verfügbar."
msgid "Erasing monitors..."
@@ -29048,7 +29147,7 @@
"\a\n"
"** The following raster maps in subgroup [%s] do not exist:"
msgstr ""
-"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+"** Die folgenden Rasterkarten in der Untergruppe <%s> existieren nicht:"
#, fuzzy
msgid " %s"
@@ -29068,7 +29167,7 @@
#, fuzzy
msgid "Skipping [%s]..."
-msgstr "Schreibe [%s] ..."
+msgstr "Schreibe <%s> ..."
#, fuzzy
msgid "Writing group REF"
@@ -29076,7 +29175,7 @@
#, fuzzy
msgid "Writing subgroup REF"
+msgstr "Schreibe %s"
msgid "Found file <%s@%s> in group."
msgstr "Habe Datei <%s@%s> in der Gruppe gefunden."
@@ -29122,7 +29221,7 @@
#, fuzzy
msgid "%s: can't read range for [%s]"
+msgstr "Kann Range-Datei für %s nicht öffnen."
#, fuzzy
msgid "Raster file [%s] not found"
@@ -29199,7 +29298,7 @@
#, fuzzy
msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
#, fuzzy
msgid ""
@@ -29286,7 +29385,7 @@
#, fuzzy
msgid "%s: <%s> cellfile not found"
-msgstr "%s <%s> nicht gefunden."
#, fuzzy
msgid "Cell file [%s] not found\n"
@@ -29346,11 +29445,11 @@
#, fuzzy
msgid "%s file [%s] not found!"
-msgstr "Datei [%s] nicht gefunden."
+msgstr "3dview-Datei <%s> nicht gefunden."
#, fuzzy
msgid "%s: %s - map not found"
#, fuzzy
msgid "%s: unable to open %s"
@@ -29370,20 +29469,19 @@
#, fuzzy
msgid "[%s] map not found."
-msgstr "[%s] nicht gefunden."
#, fuzzy
msgid "[%s] map not found"
#, fuzzy
msgid "elevation file [%s] not found"
+msgstr "Label-Datei <%s> nicht gefunden."
#, fuzzy
msgid "min computed aspect %.4f max computed aspect %.4f"
-msgstr ""
-"minimale berechnete Exposition%.4f maximale berechnete Exposition %.4f."
+msgstr "Min berechnete Exposition%.4f, max berechnete Exposition %.4f."
#, fuzzy
msgid "min computed slope %.4f max computed slope %.4f"
@@ -29467,7 +29565,7 @@
#, fuzzy
msgid "Training map [%s] not found."
-msgstr "Gruppe [%s] nicht gefunden."
#, fuzzy
msgid "%s map not found"
@@ -29507,7 +29605,7 @@
#, fuzzy
msgid "%s: %s - not found"
#, fuzzy
msgid "%s: %s - illegal units"
@@ -29515,7 +29613,7 @@
#, fuzzy
msgid "%s: %s - can't open"
#, fuzzy
msgid "Reading input map (%s) ... "
@@ -29554,7 +29652,7 @@
#, fuzzy
msgid "Output separator character (default: tab)"
+msgstr "Suchmuster für Kartennamen (Standard: alle)."
#, fuzzy
msgid "Cannot read category file of raster map <%s> in <%s>"
@@ -29562,7 +29660,7 @@
#, fuzzy
msgid "Cannot find file %s"
+msgstr "Kann die Datei %s nicht finden."
#, fuzzy
msgid "Cannot get header for %s"
@@ -29582,7 +29680,7 @@
#, fuzzy
msgid "Number of raster rows to hold in memory"
-msgstr "Anzahl der Reihen, die im Hauptspeicher gehalten werden sollen."
+msgstr "Anzahl der Zeilen, die im Hauptspeicher gehalten werden sollen."
#, fuzzy
msgid "Print raster map title only"
@@ -29594,7 +29692,7 @@
#, fuzzy
msgid "Cannot open raster map [%s]"
+msgstr "Kann die Rasterkarte <%s> nicht öffnen."
#, fuzzy
msgid "Cannot get raster band."
@@ -29606,7 +29704,7 @@
#, fuzzy
msgid "Cannot read GRASS raster."
#, fuzzy
msgid "Cannot write GDAL raster."
@@ -29638,7 +29736,7 @@
#, fuzzy
msgid "Cannot open TIFF file <%s>"
+msgstr "Kann die Regel-Datei <%s> nicht öffnen."
#, fuzzy
msgid "Reading raster map"
@@ -29662,7 +29760,7 @@
#, fuzzy
msgid "memory allocation failure"
#, fuzzy
msgid "Can't find data map."
@@ -29746,7 +29844,7 @@
#, fuzzy
msgid "can't open raster map [%s]"
#, fuzzy
msgid "Cannot rewrite line %d"
@@ -29815,7 +29913,7 @@
#, fuzzy
msgid "Could not find vector map <%s> in current mapset"
-msgstr "Baut die Topologie aller Vektorkarten im aktuellen Mapset neu auf."
+msgstr "Vektorkarte <%s> im aktuellen Mapset nicht gefunden."
#, fuzzy
msgid "Could not find input map <%s>."
@@ -29859,7 +29957,7 @@
#, fuzzy
msgid "Can't read raster"
#, fuzzy
msgid "driver name"
@@ -29895,7 +29993,7 @@
#, fuzzy
msgid "null value indicator"
-msgstr "Nullwert-Indikator"
+msgstr "NULL-Wert-Indikator"
#, fuzzy
msgid "do not include column names in output"
@@ -29911,7 +30009,7 @@
#, fuzzy
msgid "Cannot find mapset for %s"
-msgstr "Kann neu Reihe '%s' nicht einfügen."
+msgstr "Kann neue Zeile %s nicht einfügen."
#, fuzzy
msgid "Cannot open File %s"
@@ -29919,7 +30017,7 @@
#, fuzzy
msgid "Not able to open file for [%s]"
-msgstr "Kann die Datei [%s] nicht öffnen."
#, fuzzy
msgid "Label file [%s] not available"
@@ -29927,15 +30025,15 @@
#, fuzzy
msgid "Can't open label file [%s]"
-msgstr "Kann Range-Datei für Karte %s nicht öffnen."
#, fuzzy
msgid "unable to open [%s] in [%s]"
+msgstr "Kann die Karte <%s> nicht öffnen."
#, fuzzy
msgid "warning: unable to open [%s] in [%s]"
+msgstr "Kann die Datei mit Gewichten <%s> nicht öffnen."
#, fuzzy
msgid "Unable to open raster map [%s] in [%s]"
@@ -29959,7 +30057,7 @@
#, fuzzy
msgid "Input file [%s] not found."
#, fuzzy
msgid "Unable to open output file <%s>."
@@ -29987,11 +30085,11 @@
#, fuzzy
msgid "Cannot open file for <%s>"
#, fuzzy
msgid "Name of the random surface to be produced"
-msgstr "Name der Ausgabe-Rasterkarte."
+msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche."
#, fuzzy
msgid "%s: Unable to find raster map <%s>"
@@ -30015,7 +30113,7 @@
#, fuzzy
msgid "Table name"
-msgstr "Test Name"
+msgstr "Eingabetabelle"
#, fuzzy
msgid ""
@@ -30056,7 +30154,7 @@
#, fuzzy
msgid "SVG file <%s> cannot be opened"
#, fuzzy
msgid "Querying input '%s' ... "
@@ -30076,7 +30174,7 @@
#, fuzzy
msgid "cannot insert row: %s"
#, fuzzy
msgid "Cannot find line of cat %d"
@@ -30143,7 +30241,7 @@
#, fuzzy
msgid "Not able to open cellfile for [%s]"
#, fuzzy
msgid "Not able to find cellfile [%s]"
@@ -30203,15 +30301,14 @@
#, fuzzy
msgid "Exports GRASS raster data into various formats (requires GDAL)."
-msgstr "Exportiert Attributtabellen in verschiedene Formate."
#, fuzzy
msgid "Couldn't find raster map %s"
-#, fuzzy
msgid "%s: <%s> not found"
#, fuzzy
msgid "%s: <%s> illegal name"
@@ -30293,7 +30390,7 @@
#, fuzzy
msgid "Raster input map"
-msgstr "Eingabe-Rasterkarte"
#, fuzzy
msgid "Mapset of input map"
@@ -30357,7 +30454,7 @@
#, fuzzy
msgid "Couldn't find raster map [%s]"
#, fuzzy
msgid "%s in %s -can't open raster map"
@@ -30422,11 +30519,11 @@
#, fuzzy
msgid "Database's name couldn't be read"
-msgstr "%s Datei(en), die entfernt werden sollen."
+msgstr "%s: konnte nicht entfernt werden."
#, fuzzy
msgid "Driver's name couldn't be read"
#, fuzzy
msgid "Cannot open vector points map <%s>"
@@ -30443,7 +30540,7 @@
#, fuzzy
msgid "Could not find input map <%s> in current mapset."
+msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
#, fuzzy
msgid "Vector file [%s] not available in search list"
@@ -30459,7 +30556,7 @@
#, fuzzy
msgid "Cannot open driver <%s>"
-msgstr "Kann die Datei <%s> nicht öffnen."
#, fuzzy
msgid "Could not find input vector map %s"
@@ -30548,11 +30645,11 @@
#, fuzzy
msgid "%s: cellfile [%s] not found."
+msgstr "Cell-Datei nicht gefunden."
#, fuzzy
msgid "Unable to open cellfile [%s]."
+msgstr "Kann die Datei <%s> nicht öffnen."
#, fuzzy
msgid "Error reading wildcard."
@@ -30605,7 +30702,7 @@
#, fuzzy
msgid "name for new vector map (omit for display to stdout)"
-msgstr "Name der neuen Vektorkarte (leer lassen für Ausgabe auf stdout)."
+msgstr "Name der Vektorausgabekarte mit den angepassten Punkten im Fluss."
#, fuzzy
msgid "Input vector map"
@@ -30859,7 +30956,7 @@
#, fuzzy
msgid " %d rows, %d cols."
-msgstr "%d Reihen, %d Spalten."
+msgstr "%d Zeilen, %d Spalten."
#, fuzzy
msgid ""
@@ -30895,7 +30992,7 @@
#, fuzzy
msgid "%s - unable to create category file"
-msgstr "Kann die temporäre Datei nicht schreiben."
#, fuzzy
msgid "verbose mode"
@@ -30903,7 +31000,8 @@
#, fuzzy
msgid "Vector map with points for which to modify the attribute table"
-msgstr "Vektorkarte, dessen Attributtabelle editiert werden soll. "
+msgstr ""
+"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
#, fuzzy
msgid "Layer of the vector for which to modify the attribute table"
@@ -31000,7 +31098,7 @@
#, fuzzy
msgid "Unknown keyword [%s] in vector head."
#, fuzzy
msgid "Region Growing"
@@ -31020,7 +31118,7 @@
#, fuzzy
msgid "Error in opening output file <%s>"
#, fuzzy
msgid "Unable to find input cell map <%s>"
@@ -31028,7 +31126,7 @@
#, fuzzy
msgid "Error in opening input file <%s>"
#, fuzzy
msgid "Unable to open cell man <%s> for input.\n"
@@ -31048,7 +31146,7 @@
#, fuzzy
msgid "Cannot find map %s"
+msgstr "Kann %s nicht öffnen."
#, fuzzy
msgid "Cannot open map %s"
@@ -31171,12 +31269,11 @@
#, fuzzy
msgid "Assign cats to boundaries too"
-msgstr ""
-"Füge fehlende Zentroide zu geschlossenen Flächengrenzen (boundaries) hinzu."
+msgstr "%d Linien zu Grenzen verwandelt"
#, fuzzy
msgid "Lines could not be merged"
#, fuzzy
msgid "Could not find input vector '%s'"
@@ -31184,7 +31281,7 @@
#, fuzzy
msgid "Failed opening output vector map '%s'"
-msgstr "Name der Ausgabe-Vektorkarte."
+msgstr "Schreiben der Zeile <%d> der Rasterkarte fehlgeschlagen."
#, fuzzy
msgid "Do not create attribute table."
@@ -31322,7 +31419,7 @@
#, fuzzy
msgid "vector map to be created"
-msgstr "Vektorkarte, die abgefragt werden soll."
+msgstr "Vektordaten werden nicht erzeugt."
msgid "%s: Error reading from raster map <%s> in mapset <%s>"
msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
@@ -31330,9 +31427,8 @@
msgid "Color table for <%s> updated"
msgstr "Farbtabelle für <%s> aktualisiert."
-#, fuzzy
msgid "Error reading raster map <%s>."
-msgstr "Fehler beim Lesen der Rasterkarte [%s]."
+msgstr "Fehler beim Lesen der Rasterkarte <%s>."
msgid " Number of bytes per cell"
msgstr " Anzahl der Bytes pro Zelle"
@@ -31341,17 +31437,15 @@
msgid "Option <%s>: <%s> exists."
msgstr "Option <%s>: <%s> existiert."
-#, fuzzy
msgid "Unable to create table: <%s>"
-msgstr "Kann die Ausgabe <%s> nicht erzeugen."
+msgstr "Kann die Tabelle <%s> nicht erzeugen."
#, fuzzy
msgid "Cannot insert new record: <%s>"
-#, fuzzy
msgid "Unable to insert new record: <%s>"
+msgstr "Kann neuen Datensatz <%s> nicht einfügen."
#, fuzzy
msgid "No attribute table found"
@@ -31371,9 +31465,8 @@
msgid "No monitor selected"
-#, fuzzy
msgid "Invalid rendering method <%s>"
-msgstr "Ungültige Methode: %s."
+msgstr "Ungültige Render-Methode <%s>."
msgid "Unable to create face"
msgstr "Kann kein Face erzeugen."
@@ -31387,42 +31480,63 @@
"frame on the user's graphics monitor."
msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr ""
-#~ "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden "
-#~ "Buchstaben:"
+msgid "Please choose a unit by entering one of the following letter codes:"
+msgstr ""
+"Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
-#~ msgid ""
-#~ "Right: Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Rechts: Beende Profil und stop\n"
-#~ "\n"
+msgid ""
+"Right: Finish profile and exit\n"
+"\n"
+msgstr ""
+"Rechts: Beende Profil und stop\n"
+"\n"
+msgid "Cannot open raster map <%s>!"
#, fuzzy
-#~ msgid "Cannot open raster map <%s>!"
-#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+msgid "Group <%s> not found."
+msgstr "Gruppe <%s> nicht gefunden."
#, fuzzy
-#~ msgid "Group <%s> not found."
-#~ msgstr "Gruppe <%s> nicht gefunden."
+msgid "Subgroup <%s> not found."
+msgstr "Untergruppe <%s> nicht gefunden."
+msgid "Monitor <%s> terminated"
+msgstr "Grafik-Fenster <%s> beendet."
+msgid "format"
+msgstr "Format"
#, fuzzy
-#~ msgid "Subgroup <%s> not found."
-#~ msgstr "Untergruppe <%s> nicht gefunden."
+msgid "Name of PNG file"
+msgstr "Name der Farb-Datei."
#, fuzzy
-#~ msgid "Monitor <%s> terminated"
-#~ msgstr "Kein Grafik-Fenster ausgewählt."
+msgid "Files"
+msgstr "Sites"
-#~ msgid "format"
-#~ msgstr "Format"
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr "Expertenmodus (Geben Sie ein Satz von r3.mapcalc Befehlen an)."
-#~ msgid "Name of PNG file"
-#~ msgstr "Name der PNG-Datei."
+#~ msgid ""
+#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
+#~ "\" options"
+#~ msgstr ""
+#~ "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules"
+#~ "\" und \"raster\"."
-#~ msgid "Files"
-#~ msgstr "Dateien"
+#~ msgid "Error - Monitor <%s> was not running"
+#~ msgstr "Fehler - Grafik-Fenster <%s> wurde nicht ausgeführt."
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Expertenmodus (Geben Sie ein Satz von r3.mapcalc Befehlen an)."
+#~ msgid "Error - Monitor <%s> in use by another user"
+#~ msgstr ""
+#~ "Fehler - Grafik-Fenster <%s> wird von einem anderen Benutzer verwendet."
+#~ msgid "Middle: Keep original frame\n"
+#~ msgstr "Middle: Behalte original Fenster\n"
+#~ msgid "Enable interactive prompting (for command-line use only)"
+#~ msgstr ""
+#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
+#~ "Befehlszeile)."
