[GRASS-SVN] r34254 - grass/branches/develbranch_6/scripts/v.dissolve
svn_grass at osgeo.org
Tue Nov 11 20:39:48 EST 2008
Author: hamish
Date: 2008-11-11 20:39:48 -0500 (Tue, 11 Nov 2008)
New Revision: 34254
grass/branches/develbranch_6/scripts/v.dissolve/description.html
fix see also module
Modified: grass/branches/develbranch_6/scripts/v.dissolve/description.html
--- grass/branches/develbranch_6/scripts/v.dissolve/description.html 2008-11-12 01:16:09 UTC (rev 34253)
+++ grass/branches/develbranch_6/scripts/v.dissolve/description.html 2008-11-12 01:39:48 UTC (rev 34254)
@@ -5,7 +5,7 @@
this category value. Alternatively an integer or string column can be defined
which is used to find adjacent polygons with identical attribute for common
boundary dissolving. In this case the categories are not retained, only the
-values of the new key column. See the <em>v.extract</em> help page for details.
+values of the new key column. See the <em>v.reclass</em> help page for details.
<h2>NOTES</h2>
