[GRASS-SVN] r34255 - grass/trunk/scripts/v.dissolve
Tue Nov 11 20:41:06 EST 2008
Author: hamish
Date: 2008-11-11 20:41:06 -0500 (Tue, 11 Nov 2008)
New Revision: 34255
   grass/trunk/scripts/v.dissolve/v.dissolve.html
fix see also module (merge from devbr6)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.html
--- grass/trunk/scripts/v.dissolve/v.dissolve.html	2008-11-12 01:39:48 UTC (rev 34254)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.html	2008-11-12 01:41:06 UTC (rev 34255)
@@ -5,7 +5,7 @@
 this category value. Alternatively an integer or string column can be defined
 which is used to find adjacent polygons with identical attribute for common
 boundary dissolving. In this case the categories are not retained, only the
-values of the new key column. See the <em>v.extract</em> help page for details.
+values of the new key column. See the <em>v.reclass</em> help page for details.
 <h2>NOTES</h2>
