[GRASS-SVN] r34294 - grass/trunk/raster/r.terraflow
Fri Nov 14 12:09:58 EST 2008
Author: neteler
Date: 2008-11-14 12:09:58 -0500 (Fri, 14 Nov 2008)
New Revision: 34294
   grass/trunk/raster/r.terraflow/main.cc
fix order
Modified: grass/trunk/raster/r.terraflow/main.cc
--- grass/trunk/raster/r.terraflow/main.cc	2008-11-14 17:09:21 UTC (rev 34293)
+++ grass/trunk/raster/r.terraflow/main.cc	2008-11-14 17:09:58 UTC (rev 34294)
@@ -459,12 +459,13 @@
   assert(region);
   parse_args(argc, argv);
-  check_args();
   /* get the current region and dimensions */
   if (G_get_set_window(region) == -1) {
     G_fatal_error("r.terraflow: error getting current region");
+  check_args();
   int nr = G_window_rows();
   int nc = G_window_cols();
   if ((nr > dimension_type_max) || (nc > dimension_type_max)) {
