[GRASS-SVN] r34295 - grass/branches/develbranch_6/vector/v.patch
Fri Nov 14 15:40:25 EST 2008
Author: neteler
Date: 2008-11-14 15:40:25 -0500 (Fri, 14 Nov 2008)
New Revision: 34295
   grass/branches/develbranch_6/vector/v.patch/description.html
fix HTML
Modified: grass/branches/develbranch_6/vector/v.patch/description.html
--- grass/branches/develbranch_6/vector/v.patch/description.html	2008-11-14 17:09:58 UTC (rev 34294)
+++ grass/branches/develbranch_6/vector/v.patch/description.html	2008-11-14 20:40:25 UTC (rev 34295)
@@ -14,9 +14,14 @@
 editing can be done automatically using
 <em><a HREF="v.clean.html">v.clean</a></em> (tool=snap,break,rmdupl).
-When using the <em>-a</em< flag, the user has to make sure that the features in the different maps added to the output map do not have overlapping category numbers, unless identical category numbers reflect identical attributes, otherwise the attributes of the added maps are lost. To avoid this, the user can use <em>v.category option=sum</em> to change category values of some of the maps before patching.
+When using the <em>-a</em> flag, the user has to make sure that the
+features in the different maps added to the output map do not have
+overlapping category numbers, unless identical category numbers
+reflect identical attributes, otherwise the attributes of the added
+maps are lost. To avoid this, the user can use <em>v.category
+option=sum</em> to change category values of some of the maps before
+patching.
 <h2>EXAMPLES</h2>
 Patch together two maps with mixed feature types:
