[GRASS-SVN] r34378 -
grass/branches/develbranch_6/scripts/i.fusion.brovey
svn_grass at osgeo.org
Tue Nov 18 15:37:43 EST 2008
Author: martinl
Date: 2008-11-18 15:37:43 -0500 (Tue, 18 Nov 2008)
New Revision: 34378
grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey
i.fusion.brovey: message standardization + verbose mode
Modified: grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey
--- grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey 2008-11-18 20:21:31 UTC (rev 34377)
+++ grass/branches/develbranch_6/scripts/i.fusion.brovey/i.fusion.brovey 2008-11-18 20:37:43 UTC (rev 34378)
@@ -28,53 +28,56 @@
#%Module
#% description: Brovey transform to merge multispectral and high-res panchromatic channels
-#% keywords: raster, imagery, fusion
+#% keywords: imagery, fusion, Brovey
#%End
#%Flag
#% key: l
-#% description: sensor: LANDSAT
+#% description: LANDSAT sensor
+#% guisection: Sensor
#%END
#%Flag
#% key: q
-#% description: sensor: QuickBird
+#% description: QuickBird sensor
#%END
#%Flag
#% key: s
-#% description: sensor: SPOT
+#% description: SPOT sensor
#%END
#%option
#% key: ms1
#% type: string
#% gisprompt: old,cell,raster
-#% description: raster input map (green: tm2 | qbird_green | spot1)
+#% description: Name of input raster map (green: tm2 | qbird_green | spot1)
#% required : yes
#%end
#%option
#% key: ms2
#% type: string
-#% description: raster input map (NIR: tm4 | qbird_nir | spot2)
+#% description: Name of input raster map (NIR: tm4 | qbird_nir | spot2)
#% required : yes
#%end
#%option
#% key: ms3
#% type: string
-#% description: raster input map (MIR; tm5 | qbird_red | spot3)
+#% description: Name of input raster map (MIR; tm5 | qbird_red | spot3)
#% required : yes
#%end
#%option
#% key: pan
#% type: string
-#% description: raster input map (etmpan | qbird_pan | spotpan)
+#% description: Name of input raster map (etmpan | qbird_pan | spotpan)
#% required : yes
#%end
#%option
#% key: outputprefix
#% type: string
#% gisprompt: new,cell,raster
-#% description: raster output map prefix (e.g. 'brov')
+#% description: Name for output raster map prefix (e.g. 'brov')
#% required : yes
#%end
@@ -143,12 +146,12 @@
# clone current region
g.region save="i.fusion.brovey.$TMP"
-g.message message="Using resolution from PAN: $PANRES"
+g.message -v message="Using resolution from PAN: $PANRES"
WIND_OVERRIDE="i.fusion.brovey.$TMP"
export WIND_OVERRIDE
g.region res="$PANRES" -a
-g.message "Performing Brovey transformation..."
+g.message -v "Performing Brovey transformation..."
# The formula was originally developed for LANDSAT-TM5 and SPOT,
# but it also works well with LANDSAT-TM7
@@ -163,7 +166,7 @@
# r.mapcalc "brov.blue= 1. * spot.ms.1 / (spot.ms.1 + spot.ms.2 + spot.ms.3) * spot.p"
# note: for RGB composite then revert brov.red and brov.green!
-g.message message="Calculating $GIS_OPT_OUTPUTPREFIX.red: ...(step 1/4)"
+g.message message="Calculating <$GIS_OPT_OUTPUTPREFIX.red>... (step 1/4)"
r.mapcalc "\"$GIS_OPT_OUTPUTPREFIX.red\" = 1. * \"$GIS_OPT_MS3\" / (\"$GIS_OPT_MS1\" + \"$GIS_OPT_MS2\" + \"$GIS_OPT_MS3\") * \"$GIS_OPT_PAN\""
if [ $? -ne 0 ] ; then
g.message -e "An error occurred while running r.mapcalc"
@@ -171,7 +174,7 @@
exit 1
fi
-g.message message="Calculating $GIS_OPT_OUTPUTPREFIX.green: ...(step 2/4)"
+g.message message="Calculating <$GIS_OPT_OUTPUTPREFIX.green>... (step 2/4)"
r.mapcalc "\"$GIS_OPT_OUTPUTPREFIX.green\" = 1. * \"$GIS_OPT_MS2\" / (\"$GIS_OPT_MS1\" + \"$GIS_OPT_MS2\" + \"$GIS_OPT_MS3\") * \"$GIS_OPT_PAN\""
@@ -179,7 +182,7 @@
exit 1
fi
-g.message message="Calculating $GIS_OPT_OUTPUTPREFIX.blue: ...(step 3/4)"
+g.message message="Calculating <$GIS_OPT_OUTPUTPREFIX.blue>... (step 3/4)"
r.mapcalc "\"$GIS_OPT_OUTPUTPREFIX.blue\" = 1. * \"$GIS_OPT_MS1\" / (\"$GIS_OPT_MS1\" + \"$GIS_OPT_MS2\" + \"$GIS_OPT_MS3\") * \"$GIS_OPT_PAN\""
@@ -201,7 +204,7 @@
if [ $GIS_FLAG_S -eq 1 ] ; then
#apect table is nice for SPOT:
- g.message message="Assigning color tables for SPOT ...(step 4/4)"
+ g.message message="Assigning color tables for SPOT... (step 4/4)"
r.colors "$GIS_OPT_OUTPUTPREFIX.blue" col=aspect
r.colors "$GIS_OPT_OUTPUTPREFIX.green" col=aspect
r.colors "$GIS_OPT_OUTPUTPREFIX.red" col=aspect
@@ -211,13 +214,13 @@
g.rename "$GIS_OPT_OUTPUTPREFIX.$TMP","$GIS_OPT_OUTPUTPREFIX.red" --quiet
else
#aspect table is nice for LANDSAT and QuickBird:
- g.message message="Assigning color tables for LANDSAT or QuickBird ...(step 4/4)"
+ g.message message="Assigning color tables for LANDSAT or QuickBird... (step 4/4)"
fi
-g.message "Restoring region settings."
+g.message -v "Restoring region settings."
cleanup
g.message "Following pan-sharpened output maps have been generated:"
@@ -225,10 +228,10 @@
echo "$GIS_OPT_OUTPUTPREFIX.green"
echo "$GIS_OPT_OUTPUTPREFIX.blue"
-g.message "To visualize output, run:"
-g.message message="g.region -p rast=$GIS_OPT_OUTPUTPREFIX.red ; d.erase"
-g.message message="d.rgb r=$GIS_OPT_OUTPUTPREFIX.red g=$GIS_OPT_OUTPUTPREFIX.green b=$GIS_OPT_OUTPUTPREFIX.blue"
-g.message "If desired, combine channels with 'r.composite' to a single map."
+g.message -v "To visualize output, run:"
+g.message -v message="g.region -p rast=$GIS_OPT_OUTPUTPREFIX.red ; d.erase"
+g.message -v message="d.rgb r=$GIS_OPT_OUTPUTPREFIX.red g=$GIS_OPT_OUTPUTPREFIX.green b=$GIS_OPT_OUTPUTPREFIX.blue"
+g.message -v "If desired, combine channels with 'r.composite' to a single map."
# write cmd history:
r.support "$GIS_OPT_OUTPUTPREFIX.red" history="${CMDLINE}"
